hey all, well ive managed to clear a few faults liking ths vcds just getting used to it now lol ive managed to fit a alarm horn as was missing for some reason got it to work on test and ive managed to get it to chirp on unlock but not lock yet but getting there but I have a fault code coming up regarding ecu I think.. will post a scan
thanks Anton
Monday,10,December,2018,13:05:35:13126
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4436.4
VIN: WUAZZZ8P5D1901189 License Plate:
Chassis Type: 8P-AU35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 55 56
61 62 72 77
VIN: WUAZZZ8P5D1901189 Mileage: 64030km-39786miles
Address 01: Engine (CEP) Labels:. 07K-907-404-CEP.clb
Part No SW: 8P0 907 404 HW: 8J0 907 404 M
Component: 2.5l R5/4V TFSI 0050
Revision: F7H07--- Serial number: AUX7Z0L7FNH01N
Coding: 0103000C240F0060
Shop #: WSC 00046 000 00000
VCID: 70B9D32066A027E76EB-8024
001537 - Internal Control Module
P0601 - 004 - Memory Check Sum Error
Mileage: 64038 km
Date: 2018.10.30
Time: 01:06:18
Temperature: 2.0°C
Temperature: 1.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Temperature: -40.0°C
Voltage: 0.000 V
Readiness: 0110 0101
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BH 300 012 HW: 0BH 927 711 C
Component: DSG DQ500-7A H07 1811
Revision: 00H07V01
ROD: EV_TCMDQ500021.rod
VCID: 6099A360BAC09767FEB-8034
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 A HW: 8J0 614 517 G
Component: ESP MK60E1 0030
Revision: 00H60001
Coding: 0610199
Shop #: WSC 01236 785 00200
VCID: 2A0D014880FC1D37E0F-807E
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0180
Revision: 000799 Serial number: 8P0820043BN
VCID: 79AFEE0435DA66AFD95-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 AB HW: 8P0 907 063 AB
Component: BCM PQ35 H 112 0715
Revision: AB112715
Coding: 46000ABFA017F6C0207049E00100085C42762BAA306DD928E4000E840041
Shop #: WSC 01236 758 00200
VCID: 74B1DF301EB81BC78A3-8020
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Component: Innenraumuebe H04 0020
Component: LIN BACKUP HO H03 1301
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861221903278
Coding: 000103
VCID: 48C95BC032B0CF2716B-801C
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003JU007MTL2
Coding: 30314238303830303033554A305238503053
ROD: EV_Airba10AURB4.rod
VCID: 52FD79A8C46C75F778F-8006
Serial number: 3572DRB40000ED21117P
Serial number: 3582DRB40000ED492A2+
Serial number: 35128RB400006C8F8AB2
Serial number: 35228RB400006C90DAD$
Serial number: 35547RB400006C44AB3U
Serial number: 35647RB400006C44AB2U
9442587 - Igniter for battery interrupt
B1015 1B [137] - Resistance Too High
Mileage: 64038 km
Date: 2018.10.30
Time: 00:45:30
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0014112
VCID: 46D555F834A4D957E47-8012
Component: E0221 H06 0030
Part No SW: 8P0 920 983 M HW: 8P0 920 983 M
Component: KOMBIINSTR. VDO H03 0380
Revision: D0H03005 Serial number: 2247L005000216
Coding: 0001428
Shop #: WSC 65536 645 577705
VCID: 44D14FF00298EB47FA3-8010
Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
Component: J533 Gateway H43 1632
Revision: H43 Serial number: 280812F2002472
Coding: 353103
VCID: 40D943E01A80F767DEB-8014
Part No SW: 2K0 907 554 D HW: 2K0 907 554 D
Component: Haldex 4Motion 5010
Coding: 0000005
Shop #: WSC 41624 000 1048576
VCID: 2F3B105CBB1E781F371-807A
Revision: D0H03005 Serial number: AUX7Z0L7FNH01N
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H07 0220
Revision: 0000013S Serial number: AUZBZ7MD216184
Coding: 0209725
Shop #: WSC 00443 210 87197
VCID: 34311F3052385BC74A3-8060
00862 - Antenna for GPS Navigation (R50/R52)
Reset counter: 175
Mileage: 64038 km
Date: 2018.10.30
Time: 00:26:29
Mileage: 64030 km
Count: 3010
Clock: 00:26
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
Component: Tuer-SG H04 0101
Coding: 0004788
VCID: 48C95BC03EB0CF2716B-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 243 3305
Revision: 00H22000
VCID: 372B283C434EB0DF6F1-8062
Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
Coding: 0004788
VCID: 49CF5EC425BA362F095-801C
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 120809-0002-000
Coding: 1163A51010002400
ROD: EV_HeadlRegulBasic.rod
VCID: 42DD49E8140CE577C8F-8016
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209725
Reset counter: 175
Mileage: 64038 km
Date: 2018.10.30
Time: 00:26:29
Mileage: 64030 km
Count: 3010
Clock: 00:26
Part No SW: 7N0 907 534 HW: 7N0 907 530 J
Component: Batt.regelung H43 1632
Coding: F326015A
VCID: 71BFD62461AA2EEF615-8024
Subsystem 1 - Part No SW: 8K0 915 181 K HW: 8K0 915 181 K
Component: J367-BDM H07 0150
Serial number: 00000000009370230874
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 01236 785 1012552
VCID: 42DD49E8188CE577C8F-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000144
VCID: 43D34CEC0796EC7FC39-8016
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005571476
Coding: 0011422
VCID: 35372234594242CF7DD-8060
End----(Elapsed Time: 01:36, VBatt start/end: 12.5V/11.9V. VIg
