Hi all,
I've recently acquired a '58 Caddy Maxi Life and have been slowly working through its issues. The latest one to happen, is a totally unresponsive starter only a couple of hours after I had stopped the car. I went back to it a few hours later again and it started without hesitation.
I have previously noticed a hesitation when starting warm, this may be unrelated.
Fault codes for terminal 30 and cam sensor have been persistent, as was the ignition switch. The ignition switch has since been replaced and the fault code has disappeared (newer scan)
The cambelt has just been replaced and this sensor fault may well stay clear if the belt was stretched, but not sure about that one.
Other than starting or not, as the case may be, there appears to be no other issue, even the wipers work as they should, although the fault code for terminal 30 appears to indicate a fault with them.
Ignore the radio faults - That's resolved also.
Scan below.
Scan below.
Thursday,02,May,2019,16:59:59:38737VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64)
VIN: WV2ZZZ2KZ9X030324 License Plate:
Mileage: 182160km-113188mi Repair Order: Pre mods
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
VIN: WV2ZZZ2KZ9X030324 Mileage: 182160km-113188miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 PD HW: 03G 906 021 CG
Component: R4 1,9L EDC 000SG 2387
Revision: --H08--- Serial number: VWX7Z0H53NR1C7
Coding: 0000071
Shop #: WSC 35110 377 00162
VCID: 70E5EC60633442CA2D-8024
012295 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
Fault Status: 00110000
Fault Frequency: 82
Mileage: 181814 km
Time: 11:00:31
RPM: 1428 /min
Speed: 47.0 km/h
Voltage: 14.44 V
Bin. Bits: 00000000
Idle Stabilization: -3.9°KW
(no units): 48.0
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0020801
VCID: 76E9DA7801506CFAF7-8022
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Revision: 00H54000 Serial number: 01000008687319
Coding: 01884F030004100057000000000000000008FF075C000120000000000000
Shop #: WSC 35110 377 08192
VCID: 336F236C52A239D210-8066
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 200608 021 0501
Coding: 00038805
Shop #: WSC 35110
Fault Status: 00101010
Reset counter: 59
Mileage: 181816 km
Voltage: 5.00 V
00926 - Terminal 30
Reset counter: 19
Mileage: 181807 km
Voltage: 5.00 V
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AJ HW: 6Q0 909 605 AJ
Component: 1C AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037UR00GASZ
Coding: 0012611
VCID: 7F073F5C2E6A2DB2A4-802A
Part No SW: 1K0 953 549 BT HW: 1K0 953 549 BT
Component: J0527 752 0101
VCID: 050BADB44CB67762EE-8050
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 17: Instruments Labels: None
Part No SW: 1T0 920 954 C HW: 1T0 920 954 C
Component: KOMBIINSTRUMENT VDD 1222
Revision: V0002000 Serial number: VWX7Z0H53NR1C7
Coding: 0016401
Shop #: WSC 80093 222 69422
VCID: 356B1D745CD627E23E-8060
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 040708F2001496
Coding: 89801F060002027401
Component: IMMO VDD 1222
Part No SW: 1T0 959 701 H HW: 1T0 959 701 H
Component: Tuer-SG 006 1206
Coding: 0000532
VCID: 3C7D08507FFCF6AAC1-8068
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 818B04087F2D8405485AC61010C0
VCID: 0005BCA05394524ADD-8054
Subsystem 5 - Part No: 2K0 951 172
Component: Innenraumueberw.009 4807
Coding: 00000000
Subsystem 6 - Part No: 1K0 951 605 C
Subsystem 7 - Part No: 1K0 907 719 C
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Component: Tuer-SG 005 0929
Coding: 0000532
VCID: 3973114470CEC382DA-806C
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 013 0036
Revision: 00000000 Serial number: VWZ1Z2I6675681
Coding: 0100040004
VCID: 65CB8D346CF697624E-8030
00856 - Radio Antenna
Reset counter: 19
Mileage: 182165 km
Time: 00:00:09
Reset counter: 19
Mileage: 182165 km
Time: 00:00:09
Reset counter: 19
Mileage: 182165 km
Time: 16:59:03
End-------------------------(Elapsed Time: 01:25)-------------------------
