Hi Guys n Gals
A few weeks ago I was driving along and got the 3 brake lights on my instrument cluster (abs, handbrake & esp) after doing an auto scan it came up with
so I decided to change the ABS module for one ending in BJ, at first the new module wouldn't except my original code, so found out via a friend I had to knock off the basic settings after doing the coding and do a security login between each basic setting (40168) and its seems to have held the code, but in doing this I have activated function brake test and I cant seem to clear it/ complete it..... I followed the ESP function test but I cant seem to get a change in the warning lights as it suggests (no matter how hard I press the pedal) there's obviously something I'm doing wrong could anyone please point me in the right direction please?
here is yesterday's auto scan
Any help would be greatly appreciated
Monday,01,October,2018,16:32:41:28228
VCDS Version: 18.1.0.2
VIN: WV1ZZZ2KZCX031974 License Plate: RYLOMAK1/10/18
Mileage: 42760km-26569mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 2E 37 3D 42 44 46 52 56 6C 77
VIN: WV1ZZZ2KZCX031974 Mileage: 42760km-26569miles
2E-Media Player 3 -- Status: Cannot be reached 1100
3D-Special Function -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 1010
6C-Back-up Cam. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 NF HW: 03L 907 309 R
Component: R4 2,0L EDC H25 0660
Revision: 42H25--- Serial number: 00000000000000
Coding: 00190010042500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01103L906018NF 003001
ROD: EV_ECM20TDI01103L906018NF_VN35.rod
VCID: 7BF5D657F28B249DE0-802E
4714 - Steering Column Control Module
U0212 00 [047] - No Communications
Mileage: 41555 km
Date: 2018.09.06
Time: 20:39:12
Coolant temperature: 80 °C
Intake air temperature: 30 °C
Voltage terminal 30: 12.400 V
Limitation: accelerator pedal: 126.6 Nm
Cruise Control System (CCS): status-Bits 0-7: 200
selected gear-Bits 0-7: 0
4891 - EGR Valve (N18)
P0403 00 [040] - Malfunction
Fault Frequency: 10
Mileage: 41555 km
Date: 2018.09.06
Time: 20:40:45
Engine speed: 811.50 /min
Normed load value: 35.3 %
Vehicle speed: 1 km/h
Intake air temperature: 29 °C
Voltage terminal 30: 14.140 V
Unlearning counter according OBD: 28
Air mass: actual value (mg/stroke): 488.7 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 15.00 %
EGR Solen.val.: actual value: 94.95 %
EGR valve: offset closed: 1.25 %
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 7
Actuator for high pressure EGR: status-Bits 0-7: 4
High press EGR actuator: actual unconditioned volt val: 1114.2 mV
Readiness: 0 1 0 0 0
Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 433C400D092503FBC21402EB901DC082300000
Shop #: WSC 35110 377 08192
VCID: 79F9CC5FF0B7168DF2-802C
Fault Status: 00101110
Reset counter: 199
Mileage: 42555 km
Date: 2018.10.01
Time: 02:35:37
Count: 7
Count: 4608
Count: 104
Count: 50433
Count: 65280
01130 - ABS Operation
Reset counter: 199
Mileage: 42539 km
Date: 2018.10.01
Time: 02:12:27
Count: 32768
Count: 4608
Count: 100
Count: 50944
Count: 1
Part No SW: 5K0 937 087 AC HW: 5K0 937 087 AC
Component: BCM PQ35 H+ 122 0174
Revision: BF122001
Coding: 411A0A3AC025186A08480080950010E803F0740872210560E48400000048
Shop #: WSC 19861 123 12345
VCID: 76E3C763C1A979F59F-8022
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 19071 26 0512
Coding: 009795
Component: RLS 201211 05 54 0403
Coding: 0750ED
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 198
Mileage: 42451 km
Date: 2018.09.30
Time: 23:41:43
Voltage: 11.75 V
Reset counter: 198
Mileage: 42451 km
Date: 2018.09.30
Time: 23:33:34
Voltage: 11.55 V
Reset counter: 198
Mileage: 42451 km
Date: 2018.09.30
Time: 23:33:34
Voltage: 11.55 V
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL006USR3
Coding: 000000000000000000000000000000003055
VCID: 3561006F942F32ED56-8060
B1000 1B [136] - Resistance Too High
Mileage: 42451 km
Date: 2018.09.30
Time: 23:44:50
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90849LGP0004F
Coding: 1080040000
Shop #: WSC 00004 123 12345
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 70EFF17BABCD57C545-8024
Part No SW: 1T0 920 985 G HW: 1T0 920 985 G
Component: KOMBI H03 0705
Coding: 781800
Shop #: WSC 01342 020 12345
VCID: 3D71184FAC1FEAAD9E-8068
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 220711F1000133
Coding: 357401
VCID: 3561006F9C2F32ED56-8060
Fault Status: 00110100
Reset counter: 225
Mileage: 41580 km
Date: 2018.09.08
Time: 12:34:48
00469 - Infotainment Databus in Single Wire Operation
Fault Frequency: 83
Reset counter: 199
Mileage: 41767 km
Date: 2018.09.09
Time: 22:23:26
Reset counter: 181
Mileage: 41531 km
Date: 2018.09.05
Time: 17:02:29
03272 - Control Module for Audio Interface
Reset counter: 181
Mileage: 41531 km
Date: 2018.09.05
Time: 17:02:29
Component: IMMO H03 0705
VCID: 6ADBE3138D11AD150B-803E
Address 2E: Media Player 3
Address 37: Navigation
Address 3D: Special Function Labels: None
Part No SW: 1F9 909 919 A HW: 1F9 909 919 A
Component: MultifunctionDevice 0067
Revision: 00H03000 Serial number: 00000000000134
Coding: 198073
VCID: 36630763412939F55F-8062
Subsystem 1 - Part No: Unknown
Component: Slave HW Part
02071 - Local Databus
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000626
VCID: 489F799B3BDDBF053D-801C
00096 - Drivers Door Central Locking (Safe) Motor (V161)
01030 - Central Locking Key Switch; Driver Side; Lock
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
VCID: 34673D6B57552BE561-8060
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000626
VCID: 479D7AA736C3B07D34-8012
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 56: Radio
Address 6C: Back-up Cam.
Address 77: Telephone
End-------------------------(Elapsed Time: 03:00)--------------------------
Saturday,04,May,2019,16:31:43:28228
VCDS Version: 18.9.1.0
VIN: WV1ZZZ2KZCX031974 License Plate: RY10 MAK
Mileage: 43930km-27296mi Repair Order:
Scan: 01 03 09 15 16 17 19 25 2E 37 3D 42 44 46 52 56 77
VIN: WV1ZZZ2KZCX031974 Mileage: 43930km-27296miles
VCID: 7BF5D657F28B249288-802E
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Revision: 00H31001
VCID: 7BF5D657FA8B249288-802E
Reset counter: 229
Mileage: 43932 km
Date: 2019.05.04
Time: 16:27:15
Count: 3
Count: 29184
Count: 320
Count: 50432
Count: 1
00003 - Control Module
Fault Status: 01100101
Reset counter: 229
Mileage: 43932 km
Date: 2019.05.04
Time: 16:27:15
Count: 3
Count: 29184
Count: 143
Count: 50432
Count: 1
Revision: BF122001
Coding: 411A0A3A8025186A08800082900009EC03950000526D0160E48400040040
VCID: 76E3C763C1A979FAF7-8022
Coding: 009795
Reset counter: 229
Mileage: 43932 km
Date: 2019.05.04
Time: 16:27:19
Voltage: 13.90 V
VCID: 3561006F942F32E23E-8060
Coding: 1080040000
VCID: 70EFF17BABCD57CA2D-8024
Coding: 781800
VCID: 3D71184FAC1FEAA2F6-8068
Coding: 357401
VCID: 3561006F9C2F32E23E-8060
Reset counter: 229
Mileage: 43932 km
Date: 2019.05.04
Time: 16:27:20
VCID: 6ADBE3138D11AD1A63-803E
Coding: 198073
VCID: 36630763412939FA37-8062
Subsystem 1 - Part No: 6C0 959 442 C
Component: E221__MFL-DC1
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2113
Coding: 0004726
Shop #: WSC 12345 935 45725
VCID: 326B3B73AD4125DA1B-8066
Revision: 00H20000
VCID: 34673D6B57552BEA09-8060
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Component: Tuer-SG 009 2121
Coding: 0004720
VCID: 489F799B3BDDBF0A55-801C
Address 56: Radio
End-------------------------(Elapsed Time: 02:14)--------------------------
