Passat B8 Led low to Led high retrofit problrm
aXu
C?ID=372430
Hello everyone
Need some help with GTE Passat. Factory installed headlights were LED Lows and now I have retrofitted those to OEM high ones. Adapters and aLWR module from Kufatec. Also coded with Kufatec-dongle.
Problem is that the main beams and static cornering lights are not working at all. Dipped beams, dlr's and turn signals are ok. AFS fault is showing in MIB
Any idea?
:banghead:
 Wednesday,20,November,2019,11:11:51:55961
Dealer/Shop Name: T.R
Workshop Code: 103 05311 000001
VIN: WVWZZZ3CZGE160285   License Plate:
Mileage: 63079km-39195mi   Repair Order: forum
Chassis Type: 3C-VW48 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 23 2B 42 44 51 52 55
          5F 69 6C 75 8C A9 BB BC C6
VIN: WVWZZZ3CZGE160285   Mileage: 63079km-39195miles
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-CUKC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AH    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H22 3379
   Revision: X3H22---
   Coding: 011D001A647405083000
   Shop #: WSC 40850 222 12345
   ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
   ROD: EV_ECM14TFS_006_VW48.rod
   VCID: 6695B68ED8EA64A753B-8032
Readiness: 1110 0001
   Part No SW: 0DD 300 045 T    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1601
   Revision: 00031033    Serial number: TFK01511280148
   Shop #: WSC 40850 222 00000
   ASAM Dataset: EV_TCMDQ400021 001001
   ROD: EV_TCMDQ400021_VW37.rod
   VCID: 382928F6C2DE2257317-806C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 3Q0 907 379 S    HW: 3Q0 907 379 G
   Component: ESC           H42 0823
   Revision: 00000000    Serial number: 63425000000230
   Coding: 0FEC408F3826336C0779060841C849F0021CCCE0608292F118A1F078C202
   Shop #: WSC 45182 002 1048576
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 002001
   ROD: EV_Brake1UDSContiMK100OMG_002.rod
   VCID: 4ACD623EAC32A0C7573-801E
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0392284624
   Coding: 000F0F0F03
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   VCID: 392F2DF2F9D43B5FCE9-806C
   Part No SW: 5GE 907 044 E    HW: 5GE 907 044 E
   Component: Climatronic   H04 1301
   Revision: 00001K07
   Coding: 1202100420010101001550000010180A
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   ROD: EV_ACClimaBHBVW37X_005_VW37.rod
   VCID: 3E253EEEE0FA1C67FBB-806A
   Subsystem 3 - Part No SW: 3Q0 963 231 A    HW: 3Q0 963 231 A
   Component: J848 HV-PTC  200 0202
   Serial number: -00100.2T.1B20340259
H02
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580601161522
   Coding: 00031C46C3D102F72F8C5094B13C07381C80000000000000000000000000
   Shop #: WSC 17873 123 50804
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03538F1ACB98B18FD45-8056
   Component: WWS    151208  042 0607
   Serial number:         160109213215
   Component: RLHS  037 0059
   Serial number: S3Y16M01D13H20M57S48
   Coding: 90A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
   Serial number: 27 10 2015  10001293
   Serial number: 000000000ZY153210SL3
   Serial number: 00000000000064437426
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391601204423
   Coding: 0071151911
   Shop #: WSC 05311 115 00093
   VCID: 44D14C068E1676B7ADF-8010
   Component: ACC BOSCH MQB H04 0192
   Coding: 5200678A11FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311CC6DEB6C6371DF-8060
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR01SDR7
   Coding: 88CCC000002000005C5400CF004800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 50F970564A6E9A17197-8004
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 3G1857705G0156Q01110
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 3G1857706G0183Q00202
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 601 16
   Serial number: 35700000000F0924281D
   Subsystem 4 - Part No SW: -----------    HW: 480 000 601 16
   Serial number: 35800000000739242819
   Subsystem 5 - Part No SW: -----------    HW: 480 401 012 15
   Serial number: 35100029B1E3EAA41316
   Subsystem 6 - Part No SW: -----------    HW: 480 401 012 15
   Serial number: 3520002AF1E3EAA2E22N
   Subsystem 7 - Part No SW: -----------    HW: 480 402 909 16
   Serial number: 3550002A1229A29501E.
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160114500578
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D2739E2EDFC077FE21-8068
   Part No SW: 3G0 920 794 D    HW: 3G0 920 794 D
   Component: KOMBI         401 4191
   Coding: 07AD0B182FC000080C886F111600002000000000
   VCID: 2D0709A23D9C97FF521-8078
   Part No SW: 5Q0 963 272 F    HW: 5Q0 963 272 F
   Component: STH-MQB       007 0072
   Coding: 13C1
   Shop #: WSC 15486 002 1048576
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001301585
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3245
   Revision: --------    Serial number: 12011610800494
   Coding: 020300172EF21000FF00527E5C1F00000001070100010000000300000000
   Shop #: WSC 05311 103 00001
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 48C95836B23E52D7417-801C
   Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Serial number: 29150002460490115504
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 5543008303
   Analog clock:
   Subsystem 3 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
   Component: EBKV          H14 0182
   Serial number:   085430011074
   Coding: 05720100431900020002060500
   Shop #: WSC 17300 205 00000
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
   ROD: EV_BrakeBoostBoschMQBOMG_003_VW37.rod
   VCID: 4FFB732A575085EF00D-801A
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861141215125525
   Serial number: 15000180983012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD5D2E124B31F369-8024
   Serial number: 101115BK904191
   Coding: 003F0E208000028000001000
   VCID: 43D34F1A8B18718F945-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000569007
   Coding: 01000010005101
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 3G0 907 080 E    HW: 3G0 907 080 D
   Component: LE Gen 3.3H10 0072
   Revision: 00H10000
   Coding: C0020000000000000000
   Shop #: WSC 09502 002 1048576
   ASAM Dataset: EV_DMCM08530113G0907080E 001017
   ROD: EV_DMCM08530113G0907080E.rod
   VCID: 270BFB8A1F60BDAFA8D-8072
   Serial number: 071115BK611649
   Coding: 003F00208000028000001000
   VCID: 42DD4A1E940278879F3-8016
   Component: AFS-ECU       H01 0120
   Coding: 039A00000F200200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDB43EAE7F0156FF0D-806A
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: LeiMo rechts  H02 0003
   Coding: E02400
5545009 - LED Headlamp Power Output Stage; Left
          B149C 31 [137] - No Signal
                    Reset counter: 58
                    Mileage: 63079 km
                    Date: 2019.11.20
                    Time: 11:04:37
5544753 - LED Headlamp Power Output Stage; Right
          B149B 31 [137] - No Signal
                    Reset counter: 58
                    Mileage: 63079 km
                    Date: 2019.11.20
                    Time: 11:04:37
   Part No SW: 5NA 035 022 D    HW: 5NA 035 022
   Component: MU-H-LND-EU   H55 1367
   Serial number: A846J0JS022231
   Coding: 028482010000000051110001008808101F0109F441A002009C
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9120
   Serial number: VWZ6ZHT1600142
   Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Component: Gracenote2  --- 1017
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0392243933
   Coding: 0100000202000000
   VCID: 3B2337FAF3E8094FDC5-806E
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020163002217000041
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
   VCID: 77ABEBCA8F40ED2FF8D-8022
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0715
   Coding: 0284720110169A0300F800000000
   ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 3Q0 915 227 P    HW: 3Q0 915 227 K
   Component: K8C           H05 0520
   Serial number: 20111515010233
   ASAM Dataset: EV_BECM09620213Q0915227P 002009
   ROD: EV_BECM09620213Q0915227P.rod
   Battery Junction Box:
   Subsystem 1 - Part No SW: 3Q0 915 227 J    HW: 3Q0 915 227 J
   Component: A2 HVSMBJBECU  H08 0410
   Serial number: 00000007111514010009
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC1  H04 0442
   Serial number: 15914ZKK311A01040871
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC2  H04 0442
   Serial number: 15914ZKK311A01040670
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC3  H04 0442
   Serial number: 15914ZKK311A01041076
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC4  H04 0442
   Serial number: 15914ZKK311A01040384
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC5  H04 0442
   Serial number: 15914ZKK311A01040248
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC6  H04 0442
   Serial number: 15914ZKK311A01040322
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC7  H04 0442
   Serial number: 15915ZKK311A01040183
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC8  H04 0442
   Serial number: 15917ZKK311A01040047
   Part No SW: 3G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 151116200427
   VCID: 698FBDB2C9F44BDF7E9-803C
   Serial number: 091215BL901256
   Coding: 000E00200100028000001000
   Shop #: WSC 13623 002 1048576
   VCID: 45D75102852C4FBFBA1-8010
   Serial number: 091215BL901253
Address C6: Batt. Chrg. (J1050)       Labels:* None
   Part No SW: 5QE 915 682 M    HW: 5QE 915 682 M
   Component: OBC KOSTAL    H31 4006
   Revision: --------    Serial number: 0607160G40004D
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
   ROD: EV_OBCSinglPhaseKLOMQB11P.rod
   VCID: 57EB8B4A6F80CD2FD8D-8002
End----------(Elapsed Time: 02:24, VBatt start/end: 13.2V/13.2V)-----------
siLc
Tallinn, Estonia
C?ID=330192
https://www.kufatec.com/en/volkswag...d-with-cornering-light-for-vw-passat-b8-42225 <- this adapter?
High LED headlights have CAN between the lights and module 55, which is missing a couple of submodules. Are you sure you connected the CAN twisted pairs to the correct LWR module pins?
Module 55 should also show submodules as follows:
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
aXu
C?ID=372430
Thank's for your reply.
Yes, that's same adapter I have. And yes I am sure about CAN-connections. If I disconnect for example CAN-high wire connected to LWR pin 4, I will lost all submodules. I have tried this also.
If I disable "multifunction LED" bit on HEX55, I will get all four submodules visible with no faults. For some reason SW and HW information is not recognized.
   Coding: 039A00000F030200
   Subsystem 1 - Part No SW: ID-L fehlt     HW: -----------  Labels: ID-55-01.CLB
   Component: LED LeiMo li.  ... ....
   Coding: FFFF00
   Subsystem 2 - Part No SW: ID-R fehlt     HW: -----------  Labels: ID-55-02.CLB
   Component: LED LeiMo re.  ... ....
   Coding: FFFF00
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Coding: E02400
aXu
C?ID=372430
Anyone? I’m in stuck with this.
downtime
C?ID=280813
I have an autoscan from a friends GTE Passat with factory fit high leds. This is what it says about 55 module :
   Coding: 039A00004F210200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3FB4CDB6A63574BEB3-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Coding: E02400
   Coding: E02400
Coding at least seems different than on your car.
I would check the wiring as well. Kufatec's adapters are very popular in having incorrectly connected pins.
hadez16
C?ID=289891
   Coding: FFFF00
   Coding: FFFF00
   Coding: E02400
   Coding: E02400
I read about that issue before.
The submodules are either wrong, or have no parameters.
I assume the LED modules are brand new??
aXu
C?ID=372430
Non functional modules are brand new and labelled: 7PP 941 572 AB. Thats correct one according to ETKA... BUT there is two variants with same part number, 7PP941572AB Z01 (to 11/2016) and another one ending Z08 (from 11/2016)
At the same time AFS module 55 was changed to multifunction module 4B. My car is fitted with module 55 so I should have variant Z01.
So my new LED-modules might have wrong shareware inside and need to be flashed somehow to older Z01-version?
hadez16
C?ID=289891
Parameterization of these modules is only possible via ODIS when the car had High LED from stock.
I recommend to buy some used modules instead of trying to get the brand new ones working.
There is no solution for this afaik.
aXu
C?ID=372430
I did found couple of used modules with really reasonable price. Orginally fitted to Passat MY2015, so should work to my car.
hadez16
C?ID=289891
Feedback is very welcome! :)
aXu
C?ID=372430
Modules replaced with used ones and everything works now :thumbs:
Thanks!
   Coding: 039A00000F210200
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
hadez16
C?ID=289891
Very nice ;)
ejne
Slovakia
C?ID=136992
do you have all parameters what should be changed and for which ?
