Audi e-tron - Disable rear wiper and turning on audible sound (when locking the car).
UWSCSI
Norway
C?ID=134408
Hi... I have a 2019 Audi e-tron EU-edition.
1. This car has no audible sound when locking it/turning on the alarm. I know that EU-regulations does not approve to have this audible alarm on, but is it possible to turn it on using VAGCOM?
2. The rear wiper turns on when it is raining and the gear is in "R". I would like to disable this function, but when I look for it using VAGCOM, I can not figure out how to disable it...
Any help would be appreciated.
Best regards from Norway.
Saturday,06,June,2020,16:21:45:42591
VIN: WAUZZZGE1KB005103   License Plate:
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 09 13 15 16 17 19 2B 36 42 44 46 47 51 52 5F 69 6C 6D
          74 75 81 8C A5 BB BC C5 C6 CA CD CE D6 D7 DE 8104 8111 8112
VIN: WAUZZZGE1KB005103   Mileage: 14362km-8924miles
51-Electric Drive -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
BC-Door Rear Pass -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
CE-Drive Motor 2 -- Status: Malfunction 0010
DE-Charger 1 for mobile dev -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
8111-Rearview Mirror Right -- Status: Malfunction 0010
8112-Rearview Mirror Left -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558     HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0002
   Coding: 2A0A0012007E040034080000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558 001006
   ROD: EV_VCU00XXX0204KE907558.rod
   VCID: 065590CD38AD48CB697-8052
   Part No SW: 4KE 909 059 R    HW: 4KE 909 059 G
   Component: ESC           H09 0075
   Revision: 00000000    Serial number: 63368000000549
   Coding: 008800BA3D940B9ED3510871187AD2E025BEA10000BCD0CB10184B07A47D85
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_BRSContiMKC1AU516 009376
   ROD: EV_BRSContiMKC1AU516_009.rod
   VCID: 56F5808DA88D384B597-8002
   Part No SW: 4N0 907 063 EG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0671
   Coding: 07000943C13900DD070057889CBF8C68131B33100806009789010A00792216810A4509BB42B6260B00000303004918180802800044010000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 015009
   ROD: EV_BCM1BOSCHAU651_015.rod
   VCID: 77ABED094F472143621-8022
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001810100403638
   Coding: 7DC727
   Serial number: 22314881X81A955555A0
   Coding: 02005E
   Light switch:
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S05.01.1900690622
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE105101823811407
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 L    HW: 4K0 947 135 L
   Component: Dachmodul  H42 0413
   Serial number: C00153219
   Coding: 0D0104
   Front windshield washer pump:
   Subsystem 6 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001900902032
   Coding: 020000
65828 - Databus
          [Comfort system central control module: no signal/communication]
                    Reset counter: 56
                    Mileage: 14278 km
                    Date: 2020.06.05
                    Time: 18:06:25
                    average_Voltage_terminals: 12.50 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 16.00 °C
                    interior_temperature: 20.00 °C
                    Vehicle speed: Initializing
                    Terminal control-Terminal 75 status: OFF
                    Terminal control-Terminal 15 status signal: OFF
                    Terminal control-Terminal 15 via CAN: OFF
   Part No SW: 4KE 907 561 B    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Coding: 7E61FF4B58082C0001038020000000BA4A1246494481009E01
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 42DD4CDD5405B4EB05F-8016
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Fault Frequency: 51
                    Reset counter: 58
                    Mileage: 12908 km
                    Date: 2020.05.06
                    Time: 07:37:06
                    Control Module temperature: 12 °C
                    Voltage terminal 15: 14.7 V
                    Velocity_vehicle_reference: 4.79 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.68 m/s²
                    Steering_angle-Data: -10.900 °
                    Yaw_rate-Data: -0.336 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.085 °
                    Misalignment angle: horiz: fast algorithm: 0.411 °
                    Congestion pilot: status: OFF
                    Outside air temperature: 8.50 °C
                    Sensor blindness: radar: no blindness detected
2102 - Databus
          [FAULT_ESP_CONTROL_FAIL]
                    Fault Frequency: 51
                    Reset counter: 58
                    Mileage: 12908 km
                    Date: 2020.05.06
                    Time: 07:37:05
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: 4.48 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.53 m/s²
                    Steering_angle-Data: -8.500 °
                    Yaw_rate-Data: -0.221 rad/s
   Part No SW: 4KE 959 655     HW: 4KE 959 655
   Component: AirbagVW32    H36 3122
   Serial number: 003XPM00D65L
   Coding: AAFCF0C0002000009A5400FFF80D41A800C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 0B43A1F923CF35A3369-805E
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2019010332500000
   Coding: 03F002
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2019012394400000
   Coding: 03F002
   Subsystem 3 - Part No SW: -----------    HW: 480 001 512 18
   Serial number: 35700000000733281635
   Subsystem 4 - Part No SW: -----------    HW: 480 001 512 18
   Serial number: 35800000000877E8763X
   Subsystem 5 - Part No SW: -----------    HW: 480 030 301 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351001C18645548048B0
   Subsystem 6 - Part No SW: -----------    HW: 480 030 301 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352001C18F7CD0D06FA.
   Subsystem 7 - Part No SW: -----------    HW: 480 020 901 19
   Component: FrontSensor_D  000 0149
   Serial number: 3550001B32E7F5156603
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 020 901 19
   Component: FrontSensor_P  000 0149
   Serial number: 3560001B92F0DDC4A20K
   Sensor High Voltage System 1:
   Subsystem 9 - Part No SW: -----------    HW: 480 020 612 18
   Component: HVSensor_gSat  000 0149
   Serial number: 3510001A72E698B493FM
   Side Sensor B-Pillar Driver Front:
   Subsystem 10 - Part No SW: -----------    HW: 480 020 612 18
   Component: SideSens_B_Df  000 0149
   Serial number: 3520001A72ECF895822J
   Side Sensor B-Pillar Passenger Front:
   Subsystem 11 - Part No SW: -----------    HW: 480 020 612 18
   Component: SideSens_B_Pf  000 0149
   Serial number: 3550001B32E698B44189
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Fault Frequency: 20
                    Reset counter: 58
                    Mileage: 12892 km
                    Date: 2020.05.05
                    Time: 19:06:00
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 79AFEB3179533733145-802C
   Part No SW: 4KE 920 795 B    HW: 4KE 920 795
   Component: FHybRDWACC--- H13 0031
   Coding: 850400C87C90000801A6E170B284680008000100
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 46D550CD782D88CB297-8012
16777046 - Charger for HV Battery
          U1139 00 [008] - No Communications
          [BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
                    Reset counter: 36
                    Mileage: 12935 km
                    Date: 2020.05.06
                    Time: 19:42:15
1246810 - Activatable Functions
          B18D3 F4 [008] - Authentication of Transmission Failed
                    Reset counter: 50
                    Mileage: 13089 km
                    Date: 2020.05.11
                    Time: 09:06:17
   Part No SW: 4K1 907 468 D    HW: 4K1 907 468 C
   Component: Gateway       H04 0322
   Serial number: 1DF05028243901
   Coding: 02030005000100C000810000005B01329C8A004718000000090000DF00000000
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x.rod
   VCID: 3635200D08CD184BB97-8062
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Component: J367-BDMConti  H03 1051
   Serial number: 7674960100190114008D
   Control module for steering wheel touch recognition:
   Subsystem 3 - Part No SW: 4N0 419 508     HW: 4N0 419 508
   Component: J1158 KLR  H44 0030
   Serial number: 18295043106S00304401
8 Faults Found:
131687 - Control Module for Emergency Call and Communications
          U1421 00 [008] - No Communication
          [Timeout_Node_0x67_DiagAdress_0075_ConBox]
                    Reset counter: 50
                    Mileage: 13691 km
                    Date: 2020.05.23
                    Time: 10:48:01
262669 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BAP_Timeout_DoorLocking]
                    Reset counter: 56
                    Mileage: 14278 km
                    Date: 2020.06.05
                    Time: 18:06:25
262693 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BAP_Timeout_BatteryControl]
                    Reset counter: 53
                    Mileage: 13489 km
                    Date: 2020.05.14
                    Time: 07:14:34
262933 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BAP_Timeout_RemoteService]
                    Reset counter: 56
                    Mileage: 14278 km
                    Date: 2020.06.05
                    Time: 18:06:25
8913155 - Development Code 4
          B2F04 00 [009] - -
          [RWB_TME_Init_Abwurf_Dauerinit]
                    Reset counter: 251
                    Mileage: 12905 km
                    Date: 2020.05.05
                    Time: 19:49:41
8913156 - Development Code 5
          B2F05 00 [009] - -
          [RWB_BCME_Init_Abwurf_Dauerinit]
                    Reset counter: 250
                    Mileage: 12891 km
                    Date: 2020.05.05
                    Time: 19:01:20
8978691 - Unknown Error Code
          B18D3 F1 [008] - Unknown Error Elaboration
                    Reset counter: 44
                    Mileage: 13536 km
                    Date: 2020.05.15
                    Time: 14:46:04
8978692 - Unknown Error Code
          B18D3 F3 [008] - Unknown Error Elaboration
                    Reset counter: 56
                    Mileage: 12949 km
                    Date: 2020.05.07
                    Time: 18:59:02
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 18000398473018
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 34311A051EB10A5B873-8060
12665088 - Databus
          [Timeout Message Klemmen_Status_01]
                    Reset counter: 56
                    Mileage: 14278 km
                    Date: 2020.06.05
                    Time: 18:06:23
                    Result lock conditions: invalid
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Lock sensor: operated
                    Unlock sensor: not activated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: On
                    Clamp 15: On
                    Clamp 15 Status: invalid
                    Remote Start: active
                    Driver door: closed
                    Central locking locked external: locked
                    Central locking safed external: Vehicle secured
                    Clamp Request: Yes
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c timeout
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    Signature IMS OK: No
                    IMS responded: No
                    Positive authentification in current KL15 cycle: No
                    Lifestate: Immobilizer download obtained
                    Learn mode: Adapted
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 655.35 km/h
                    UBat internal: 11.9 V
                    UMotorBridge: 6.5 V
                    Lock condition engine speed: Condition not met
                    Lock condition clamp S: Condition not met
                    Lock condition clamp 15: Condition not met
                    Lock condition E2E clamp status: Condition not met
                    Lock condition timeout clamp status: Condition not met
                    Lock condition vehicle speed: Condition not met
                    Lock condition E2E vehicle speed: Condition not met
                    Lock condition timeout vehicle speed: Condition not met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition met
                    Lock condition selector lever position parking: Condition not met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition not met
                    Lock condition E2E distance pulse: Condition not met
                    Lock condition difference distance pulse: Condition not met
12665089 - Databus
          [Timeout Message ZV_02]
                    Reset counter: 56
                    Mileage: 14278 km
                    Date: 2020.06.05
                    Time: 18:06:24
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Clamp S: On
                    Clamp 15: On
                    Driver door: closed
                    Clamp Request: Yes
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.5 V
12666378 - Databus
          [Timeout Message Klemmen_Steuerung_01]
                    Reset counter: 56
                    Mileage: 14278 km
                    Date: 2020.06.05
                    Time: 18:06:27
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Clamp S: On
                    Clamp 15: On
                    Driver door: closed
                    Clamp Request: Yes
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.5 V
12666385 - Databus
          [Timeout Message Kessy_12]
                    Reset counter: 56
                    Mileage: 14278 km
                    Date: 2020.06.05
                    Time: 18:06:24
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Clamp S: On
                    Clamp 15: On
                    Driver door: closed
                    Clamp Request: Yes
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.5 V
12666387 - Databus
          [Timeout Message WFS_01]
                    Reset counter: 56
                    Mileage: 14278 km
                    Date: 2020.06.05
                    Time: 18:06:24
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Clamp S: On
                    Clamp 15: On
                    Driver door: closed
                    Clamp Request: Yes
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    IMS responded: No
                    Learn mode: Adapted
                    UMotorBridge: 6.5 V
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0044
   Serial number: 00000355664429
   Coding: 00581A400000B4010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Part No SW: 4M0 959 593 M    HW: 4M0 959 593 J
   Component: TSG FS        007 0387
   Serial number: 0000353279745
   Coding: 001DDA0143000480A000B002
   Shop #: WSC 00535 218 00000
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: B4110101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313F1311E1A33F73EC5-8064
   Part No SW: 8W0 907 064 GH    HW: 8W0 907 064 DH
   Component: BCM2 MLBevo   025 0424
   Coding: 017400030FB103616301A0046C00C80200004000804F02582F0400000504823B001F0100010F13
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016_AU58.rod
   VCID: 08499EF532B95EBB1BB-805C
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY183062V1R
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000045952201
   Rear Light Left 1:
   Subsystem 3 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   Component: T1 LH ECE HD  H10 0403
   Serial number: A1W700005LV
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11406418
   Dedicated Short Range Communication Aerial:
   Subsystem 5 - Part No SW: 4N1 927 753     HW: 4N1 927 753
   Component: NFCTGS  H13 0050
   Serial number:            382905855
   Antenna 2 for short-range communication:
   Subsystem 6 - Part No SW: 4N0 959 428 A    HW: 4N0 959 428 A
   Component: NFCMIKO  H41 0034
   Serial number: 4418000245201012
   Rear Light Left 2:
   Subsystem 7 - Part No SW: 4KE 945 429     HW: 4KE 945 429
   Component: T2 LH ECE HD  H10 0403
   Serial number: A1WK00007VR
   Rear Light Right 1:
   Subsystem 8 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Component: T1 RH ECE HD  H10 0403
   Serial number: A1WD0000786
   Rear Light Right 2:
   Subsystem 9 - Part No SW: 4KE 945 430     HW: 4KE 945 430
   Component: T2 RH ECE HD  H10 0403
   Serial number: A1WL00007VR
65732 - Databus
          [Engine control module: Motor_14: no signal/no communication]
                    Reset counter: 55
                    Mileage: 14103 km
                    Date: 2020.06.01
                    Time: 18:07:07
                    Supply voltages-Supply voltage: Terminal 30: 12.636 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.609 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.636 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                    general_additional_freeze_frame-coprocessor_spi_status: 00000000
                    general_additional_freeze_frame-dataflash_status: 00000000
                    general_additional_freeze_frame-interior_temperature: -50.0 °C
                    general_additional_freeze_frame-Operating_Status: 00000000 00000000
                    general_additional_freeze_frame-production_mode: not active
                    general_additional_freeze_frame-reset_cause: 00000000
                    general_additional_freeze_frame-Reset_counter: 0
                    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 00 80
                    general_additional_freeze_frame-Transport_Mode: not active
                    general_additional_freeze_frame-Vehicle speed: Not available
                    can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
65605 - Databus
          [Brake control module: ESP_21: no signal/communication]
                    Reset counter: 55
                    Mileage: 14103 km
                    Date: 2020.06.01
                    Time: 18:07:07
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.622 V
65729 - Databus
          [Brake control module: ESP_05: no signal/communication]
                    Reset counter: 55
                    Mileage: 14103 km
                    Date: 2020.06.01
                    Time: 18:07:07
131193 - Virtual Radio Key
          B16E9 29 [008] - Signal Implausible
                    Fault Frequency: 29
                    Reset counter: 58
                    Mileage: 14000 km
                    Date: 2020.05.29
                    Time: 20:10:32
                    Supply voltages-Supply voltage: Terminal 30: 65.535 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 65.535 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 65.535 V
                    general_additional_freeze_frame-production_mode: active
                    general_additional_freeze_frame-Stall_current_cutoff_level: Not available
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: Not available
                    general_additional_freeze_frame-terminal_control_intern_status: FF FF FF FF FF FF
                    general_additional_freeze_frame-Transport_Mode: Not available
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJ7D002445
   Coding: 0115160000AAAA2FAA0000010002
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411EA45AE519ADB173-8070
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 0EF 907 080 C    HW: 0EF 907 080 C
   Component: CUFZD683L0AD0 H02 0005
   Revision: --------    Serial number: -00125.10.18000
   Coding: 01000000000000000000
   Shop #: WSC 10349 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003007
   ROD: EV_DMCM2HITACAU516_003.rod
13828096 - Component protection
          U1115 00 [047] - No basic setting for SHE key
          [CmpntPrtctn_SHEKeyNoCnfg]
                    Mileage: 12891 km
                    Date: 2020.05.05
                    Time: 15:18:55
   Part No SW: 4M0 959 592 M    HW: 4M0 959 592 J
   Component: TSG BFS       007 0387
   Serial number: 0000360553005
   Coding: 001DDA0143000480A000B000
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 45D757C1452B83D320D-8010
   Part No SW: 4KE 035 063 A    HW: 4KE 035 063
   Component: MU-H-LND-EU   046 2538
   Coding: 0115760100000000C3111102C00802302F0001E4037008008E
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_AU27.rod
   Subsystem 1 - Part No: V03 959 804 BL
   Component: MIB2P_EU_Q419  0411
   Subsystem 2 - Part No SW: 4KE 919 605     HW: 4KE 919 605
   Component: DU AU516 High  H41 0144
   Serial number: INX00116101800130154
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 A    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004418000241010013
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4KE 919 603     HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0144
   Serial number: INX00119101800140466
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800780905006
7205 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Battery management (0x25) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 52
                    Mileage: 12962 km
                    Date: 2020.05.08
                    Time: 14:45:01
                    Voltage terminal 30: 14.4 V
                    BAP-BAP_Function_ID: 10
6190 - Display Module 1 for Multimedia System
          B1297 FC [008] - Haptic Unit Defective
                    Reset counter: 50
                    Mileage: 13734 km
                    Date: 2020.05.24
                    Time: 09:32:03
                    Voltage terminal 30: 12.9 V
   Part No SW: 4M0 907 383 E    HW: 4M0 907 383
   Component: Anhaenger     H27 0253
   Revision: 9C001003    Serial number: 0501911391
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
   Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H15 0250
   Coding: 0215060103002005C20040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 333319191BBF0D639E9-8066
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8781-0
   Coding: 33B0
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 4ACD64FD6C356CABCDF-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AD    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2311
   Serial number: 1201191193
   Coding: 98D86083DA4010
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 0E45A8ED50DD008BD17-805A
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130469760
   Coding: 303030
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
   Component: ConBox        H09 0232
   Serial number: 005CCA11F120292
   Coding: 01C0E0FFC040800000
   ASAM Dataset: EV_ConBoxAU651 002004
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809FE75D2797EBB3BB-807C
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145RLK00043
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C21322536E1C21B4F3-8068
9004 - Databus
          [MESSAGE_GE_16_TIMEOUT]
                    Reset counter: 49
                    Mileage: 13691 km
                    Date: 2020.05.20
                    Time: 15:08:06
                    Freeze_frame_common-Internal_fault_code: 0C 06
                    Temperatures-Interior temperature: 19.00 °C
                    Temperatures-Control Module temperature: 0.00 °C
                    Voltage terminal 30: 12.50 V
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 4KE 915 233 F    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0231
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU58.rod
   VCID: 41DF43D15103AFF31C5-8014
   Battery Junction Box:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 B
   Component: BJB_MLBBEV  H12 0369
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0291
   Coding: 0421840000000000000C060000D4462E189E57000000000000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D80000009000800080000000000080400000A0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 7F5B0529677719032A1-802A
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 51
                    Reset counter: 58
                    Mileage: 12908 km
                    Date: 2020.05.06
                    Time: 07:37:06
   Part No SW: 4M0 959 595 M    HW: 4M0 959 595 J
   Component: TSG HFS       006 0387
   Serial number: 0000360561597
   Coding: 000DD80100000480A000B000
   ROD: EV_DCU2RearDriveMAXHCONT_AU58.rod
   VCID: 48C95EF572399EBBDBB-801C
   Component: TSG HBFS      006 0387
   Serial number: 0000360561596
   ROD: EV_DCU2RearPasseMAXHCONT_AU58.rod
196650 - Motors for Central Locking
          B122B 12 [008] - Short to Plus
                    Reset counter: 47
                    Mileage: 13608 km
                    Date: 2020.05.17
                    Time: 20:07:38
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 B    HW: 4KE 965 429
   Component: TME-Max       H08 0311
   Serial number: 0017640
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002035
   ROD: EV_ThermContrVISAU49X_AU58.rod
   VCID: 49CF5BF1693367B3C45-801C
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Component: J848 HV-PTC  200 0204
   Serial number: -00105.0V.3A20370116
   Subsystem 3 - Part No SW: 4G0 816 797 B    HW: 4G0 816 797 B
   Component: J842 EKK es33  H03 0004
   Serial number: 00000000018092100748
   Geber für Kältemitteldruck/Kältemitteltemperatur 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Coolant heater:
   Subsystem 5 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00105.1V.2C20370080
   Refrigerant Expansion Valve 2:
   Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000150542289
   Refrigerant Shut Off Valve 2:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130515295
   Refrigerant Shut Off Valve 3:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130515303
   Refrigerant Shut Off Valve 4:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130515291
   Refrigerant Shut Off Valve 5:
   Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130515301
   Radiator shutter:
   Subsystem 11 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20181209060404054408
   Radiator Shutter 2:
   Subsystem 12 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V550KJS2  H12 0109
   Serial number: 20181114020103053861
   Coolant valve 1:
   Subsystem 13 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000039605
   Coolant valve 2:
   Subsystem 14 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000019454
   Coolant valve 3:
   Subsystem 15 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000031023
   Coolant valve 4:
   Subsystem 16 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000026154
Address C6: Batt. Chrg. (J1050)       Labels:* None
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0020
   Serial number: ---------------
   Coding: 2B48844542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
2097680 - Charging Socket B
          P33E4 00 [040] - Communications Error
                    Reset counter: 21
                    Mileage: 13094 km
                    Date: 2020.05.11
                    Time: 17:54:09
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     005 0002
   Coding: 628040051602
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
   VCID: 75B7E701554B535370D-8020
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0202
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
   VCID: 3537270115CB1353B0D-8060
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 C    HW: 0EF 907 180 C
   Component: CUBZE683L0AD0 H02 0005
   Revision: --------    Serial number: -00106.11.18000
   ASAM Dataset: EV_DMCM2HITACAU516 003007
   VCID: 372B2D090FC7E143A21-8062
                    Mileage: 12891 km
                    Date: 2020.05.05
                    Time: 15:18:55
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 71BFD31121237F73AC5-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4N0 035 773 A    HW: 4N0 035 773 A
   Component: WLC Front NFC H11 0057
   Coding: 808000
   ASAM Dataset: EV_Charg1MobilDevicAU651 004001
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 2C010265C681529BDF3-8078
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
   VCID: 3FDB452927F7D9036A1-806A
Address 8111: Rearview Mirror Right (J1030)       Labels:* None
   Part No SW: 4KE 907 181 B    HW: 4KE 907 181 A
   Component: VAS H31 0026
   Coding: 00010807
   ASAM Dataset: EV_RearVLeftFicosAU516 001003
   ROD: EV_RearVLeftFicosAU516.rod
   VCID: 40D946D55A09A6FB13B-8014
15469832 - Light sensor
          C11B1 04 [009] - Internal System Fault
          [Brightnessensor: defect]
                    Mileage: 24 km
                    Date: 2019.03.18
                    Time: 08:41:57
Address 8112: Rearview Mirror Left (J1031)       Labels:* None
   Part No SW: 4KE 907 182 B    HW: 4KE 907 182 A
   Coding: 00010807
   ASAM Dataset: EV_RearVRightFicosAU516 001003
   ROD: EV_RearVRightFicosAU516.rod
End----------(Elapsed Time: 03:05, VBatt start/end: 13.2V/13.2V)-----------
46 -- Central Conv should have Adaptation Channels for "Acoustic acknowledge signal" on a per-key basis. Check if they are On or Off.
UWSCSI
Norway
C?ID=134408
I have been down that road without success, Uwe... They should all be "On", but maybe I missed a turn somewhere. I will check again.
TBAx
C?ID=287144
I am by means not a expert on the MLBevo platform, but I think you need to set Byte 4 Bit 6 in your central convenience module (46). This should be labeled as "horn_acknowledment".
There are some more adaptions that are used with the sounder. It would be great, if you'd add an adaption channel map of said module.
Don't forget to enable the function inside the HMI (CAR -> settings -> central locking).
bluetomato
C?ID=407511
Were you able to figure out #2 above? I'd like to disable that feature as well.
UWSCSI
Norway
C?ID=134408
Hi there...
I have had no success disabling the rear wiper. Gone trough every Byte/Bit in the adaption that I can find. The only thing I am able to do, is to disable the rear wiper in total.
Quite annoying that I can not figure this. out...
Same with the audible sound for the alarm... no joy at all...
UWSCSI
Norway
C?ID=134408
So I finally managed to get the audible sound to go active when locking the car.
I had to set adaption for each and every option for this in the 46 module.
In addition I had to change the coding Byte 4, bit 3 and 4 to make it happen.
The rear wiper I belive is linked to the rain sensor in the front. If rain sensor is active and sensing rain and the car is put i Reverse, the rear wiper activates. I have not been able to disable this function.
hadez16
C?ID=289891
Comfort rear wiper cannot be deactivated for MLBevo platform.
