FOBs remotes won't program when I've replaced BCM - Tiguan 2013
nickpi
Greece
C?ID=40501
I've replaced BCM on my 2013 Tiguan in order to retrofit bi-xenons
Old BCM was 5K0 937 086 M , new one is a highline 5K0 937 087 T . Unit bought used.
The problem I'm facing is that I cannot program FOBS (remotes). Flashes won't blink and when looking for error codes, I get error 01179 - Invalid key programming.
I've followed all instructions by Ross-Tech very carefully.
Any ideas?
Full scan with new BCM is as follows:
Monday,17,April,2017,10:48:58:52699
VCDS Version: 17.1.3.0 (x64)
VIN: WVGZZZ5NZDW043218   License Plate: 8554
Mileage: 117720km-73147mi   Repair Order:
Chassis Type: 5N (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4C 52 53 56 61 62 72
VIN: WVGZZZ5NZDW043218   Mileage: 117720km-73147miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 LE    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H28 4571
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00190012040401080000
   ASAM Dataset: EV_ECM20TDI01103L906018LE 003009
   ROD: EV_ECM20TDI01103L906018LE.rod
   VCID: 78F43811C31E9081D1-802C
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AR    HW: 5N0 614 109 AR
   Component: J104   C6 450M VD56 0006
   Revision: --H07---    Serial number: 00000006258606
   Coding: 0037947
   VCID: 7BFE271D3A28BB99BC-802E
   Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004003
   VCID: 79F23D15F8148989AE-802C
   Part No SW: 5K0 937 087 T    HW: 5K0 937 087 T
   Component: BCM PQ35 H    021 0068
   Revision: BK021001
   Coding: 46180A3880251AC0408800C0340081644B51AA88436D81606480C7000041
   VCID: 468886E9F16A367193-8012
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 08101  013 0204
   Serial number: N1955119   °204!
   Coding: 009795
   Component: RLS 051012 05  54  0403
   Coding: 02304D
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__20J VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PLTU4Q.
   Coding: 0012362
   VCID: 7CFC24013F26BCA1B5-8028
   Subsystem 1 - Serial number: 6332MTS661652712
   Subsystem 2 - Serial number: 6342MTS670032702
   Subsystem 3 - Serial number: 6351HTS6P6IVBBKR
   Subsystem 4 - Serial number: 6361HTS6CUTADBKR
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Mileage: 117724 km
                    Date: 2017.04.17
                    Time: 10:45:13
   Part No SW: 5K0 953 501 BD    HW: 5K0 953 569 J
   Revision: FF010041    Serial number: 20121006300001
   Coding: 5180040000
   VCID: 6DDA1945BC5C252932-8038
   Part No SW: 5N0 920 883 A    HW: 5N0 920 883 A
   Component: KOMBI         H05 0505
   Coding: 111F01
   VCID: 3260CA3965E2BAD12F-8066
   Part No SW: 7N0 907 530 AC    HW: 7N0 907 530 AC
   Component: J533  Gateway H48 1633
   Revision:   H48       Serial number: 270912F2000492
   Coding: 356002
   VCID: 71E20535A864C1C916-8024
                    Reset counter: 86
                    Mileage: 117724 km
                    Date: 2017.04.17
                    Time: 10:45:13
   Component: IMMO          H05 0505
   VCID: 6AD012598DB2321157-803E
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0005716407
   Coding: 0200BC
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 3874F811839E508111-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1504
   Serial number: 00000007278896
   Coding: 000090
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.285 1101
   Revision: 1AH03837    Serial number: 00122690267701
   Coding: 0000258
   VCID: 3D7AE90564BC75A9C2-8068
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0005756361
   Coding: 0200BC
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3972FD15B8944989EE-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1504
   Serial number: 00000007283631
   Coding: 000090
   Revision:   H19       Serial number: 00000000511436
   Coding: 0026167
   VCID: 3668F629418AA6F103-8062
Address 56: Radio
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AC
   Component: Batt.regelung H48 1633
   Coding: 030F1859
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900271979
End-------------------------(Elapsed Time: 02:22)--------------------------
Have you looked at MVBs 091 and 092 for clues?
NEtech
C?ID=56995
And Adaptation channel 19..
nickpi
Greece
C?ID=40501
Thanks for replying Uwe!!!
you can check results by yourself below:
Address 09: Cent. Elect. (5K0 937 087 T)
21:42:13 Group 091: Remote Control
0 Remote Key Number
000 00 0 Remote Control Buttons
2 Immobilizer Key Recognition
0 Number of Adapted Remotes
21:42:13 Group 092: Remote Conntrol
no Value Fixed code
no Value Code In Reception Range
no Value Variable Code Algorithm
______________________________________________________
Any idea on what should I do?? no clues other than everything described on Ross Tech pages.....
Best regards,
nickpi
Greece
C?ID=40501
Thanks for replying!
Thanks for replying NEtech!
Ch19 shows that facory mode is disabled.
Dana
Western PA, USA
Per an email I was worried the replacement (used) BCM may not be compatible with the car/existing remotes.
We usually direct all tweak and retrofits to our forum
http://forums.ross-tech.com
.. but make sure you de-activated Channel 019: Factory Mode and followed
all of the Replacement Steps at the bottom of this page first:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(5K)_Body_Control_Module
If factory mode was already disabled and the remote(s) still will not
match you may have a compatibility problem with the new BCM and the
existing remotes.
If that's the case I would suggest joining the R-T forum and create a
new thread within the Retrofits section.  You would want to post the
complete Auto-Scan with the factory condition module and coding in
addition to the scan in the current condition.
   If the BCM was sourced brand new from a VW dealer please include the
complete part number of the replacement (i.e. 5K0-937-087-AB-Z02 which
is the replacement according to PartsLink24 by VIN).
   If the BCM was sourced used it might not be possible to determine the
index code (Z02 for example) but the VIN from the donor car may add
clarity if you have it.
Unfortunately that base part number 5K0 937 087 T has 100 possible index/color codes so it won't be easy to pin down which index code it is but I think that would be for 315MHz remotes. Take a look at it and see if any of the writing on the new box confirms the incorrect frequency. The direct replacement per VIN (5K0-937-087-AB-Z02) shows 433MHz.
nickpi
Greece
C?ID=40501
315Mhz remotes
existing remotes.
So Dana, Thanks again once more for replying.....
Do you think if I'll try to replace my remotes with those of 315Mhz will work ?
Dana
Western PA, USA
You could try that but .. does that key separate from the remote fob? Some of the 2011+ model years (even without KESSY) are all one piece so you can't just slip on a remote like the good old days.
nickpi
Greece
C?ID=40501
Hello again
Actually test didn't work, I've just ordered another BCM, the AB one....
