2002 Mk4 Jetta Immobilizer issue
tryin2vw
C?ID=44327
Back story: Drove the car to work, 45 minutes from home. Worked for 9 hours and went to start the car, the immo light comes on and the car dies after one second. I have tried several things suggested on other forums, but no luck. This is a 2002 Jetta TDI, straight stock, 445,000 miles, 1.9T. I have tested the resistance from the cluster to the immo ring and found it to be about 23-24 ohms through the wires, steady even prodding the wires. The lock cylinder was removed and the resistance for the immo ring checked and it was the same, rock steady.
The Immibilizer light continues to flash when any key is placed in the ignition. I have the SKC code, but it will not allow me to enter anything into the cluster. When logging into the instrument cluster, no lockout occurs. I have been able to recode the WSC in the ECU with the SKC code so think the code is proper. I cannot recode the WSC in the cluster, i tried several times.
When in 17-Instruments, blocks 21 and 22 return the ERROR statement. I have the column apart with the air bag out, that is the reason for that particular code.
In the past, there were 3 keys that worked, now there are none.
I have suspicions, but any help would be appreciated.
Latest autoscan:
Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: Release 18.9.1(x64) Data version: 20190114 DS296.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,23,April,2019,17:55:59:23395
VIN: 3VWSP69M42M011724 License Plate:
Mileage: Repair Order:
Chassis Type: 9M (01 - MyVW TDI)
Scan: 01 03 15 17 19 46
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 FD
Component: 1,9l R4 EDC G000SG 4102
Coding: 00002
Shop #: WSC 00066
VCID: 57B774EAB55607F2CC-4B00
3VWSP69M42M011724 VWZ7Z0A3842382
19561 - Valve for Intake Manifold Flap (N239)
P3105 - 35-10 - Open or Short to Ground - Intermittent
P1570 - 35-00 -
Readiness: 0 0 1 0 1
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0004097
VCID: 2A51FD1E86A44A1AA3-513C
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
VCID: 3A71CD5E2604FA9AD3-4B00
32-00 - Resistance Too High
00532 - Supply Voltage B+
Self-Diagnosis Log
Page 2
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V58
Coding: 07232
Shop #: WSC 58350
VCID: 3163EA72FB7239C262-5102
01176 - Key
65-10 - Unauthorized - Intermittent
01176 - Key
07-00 - Signal too Low
01179 - Incorrect Key Programming
35-00 - -
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70E52F7630F870CA2D-5102
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 3777D46A1516E7F22C-4B00
Component: 1H Tõrsteuer.FS KLO 0002
Component: 1H Tõrsteuer.BF KLO 0002
Component: 1H Tõrsteuer.HL KLO 0002
Component: 1H Tõrsteuer.HR KLO 0002
End-------------------------(Elapsed Time: 01:05)--------------------------
tryin2vw
C?ID=44327
Immediately prior to this happening, there were no known codes or CEL showing
Send me cluster, keys and engine ecu with credentials of ownership and I can check it for you or remove immobilizer which is recommended for car of this age.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Jack I sent him here from whortex.
I couldn't understand why it shows no key in MB 022?
I wanted him to change the WSC in cluster to prove SKC was correct.
He couldn't change it so I thought wrong SKC.
But he can change the WSC in ECU with the SKC so that would tell me the SKC is good.
Once he ohmed the coil for key and still has nothing in MB 022 for keys. So I sent him here cause I am lost.
I don't think he wants to send it out unless he has too.
Seems to know his stuff and he wants to fix it. I think it's become personal. LOL
Also did I hear you right? Do an immobilizer delete. Wow times are a changing.....
Good Luck
tryin2vw
C?ID=44327
vwtech, these things always become personal because I want to fix it right.
vwtech
Wilkes-Barre, PA
C?ID=7573
Oh Jack will fix it right if you send cluster keys and ECU. But I just know you want to fix it.
But I think cluster is bad. And Like Jack said with a car this old who's gonna steal it?
So immobilizer delete makes sense. Because of age and use this shit is old and it breaks.
But a used cluster will not work unless you have the donor SKC and you said you got your SKC years ago.
So you have to pay someone again to get the SKC for a used cluster.
Plus I think you want to keep the mileage you almost got a 1/2 million.
Good Luck
tryin2vw
C?ID=44327
I just changed the timing belt for the 3rd time in February, so want to go to about 600k at this point, maybe further. The car is driven about 30-35k miles per year since it was acquired by me. It is my daughter's car, and she works 46 miles from home, one way. The TDI goes over 500 miles between fills, so she gets a week per tank. I have kept MK3's running well into the 350k miles and some B5's running to about the same, with me changing the timing belts when required. It gives me some satisfaction to do some of this as it is significantly different from my day job.
I think Jack has commented previously on 'tex post many years ago, but he had so many posts, he would not remember specifics because I do not. I just remember the screen name.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
It is most likely bad Cluster . Not very rare problem on Jetta.Golf but it happens time to time.
I have seen this problem lately , I guess it is Age of those cars .
I was banned due to calling out flat out fraud and advertisers complaining that I did stuff for free and wasn't a paid for advertiser, so I was forced to advertise in Whoretex & to give stuff away and indeed I did, until they still banned me after not renewing the contractual agreement & because I spoke the truth when someone was being robbed.
Good Luck
In some cases, parts are not made available and a car this old still has an alarm system that aids in starter lock out.
If someone really wants the car, they will get it.
I have brand new TDI clusters for Jokeswagen or reman.
In my own TDI car the light for IMMO flashes to remind me why I run an Immo defeat when condition exists & to not worry about it when the same issue ensues only my car starts and runs!
Hidden Toggle switch!
KISS method applies here........
Admin Note: Please don't use the [Print] function in VCDS to post scans here. The formatting it produces, while optimitized for a sheet-fed printer, is much harder to read here than the original, plain text files that VCDS produces when you use [Copy] or [Save], and that it saves surreptitiously to your Logs sub-folder.
_Val
Latvia
C?ID=356659
Can you dump 24c08 chip and compare it with dumps posted on internet? Maybe chip itself is bad and needs for a change.
Defeating immo you will never find out what exactly went wrong with this cluster. :D
vwtech
Wilkes-Barre, PA
C?ID=7573
Jack to do immobilizer delete does he still need to send you cluster, ECU and keys?
Or just the ECU?
Good Luck
Nope but if he wants to know what's wrong he does or he can just send the engine ecu.
Dumping the eeprom won't really necessarily give any insight either.
tryin2vw
C?ID=44327
Thanks for the support. I suspected it was the cluster after all the troubleshooting and I bought one with the same part number. It was taken to a local tuner I know who cloned the cluster, so same SKC. After some reassembling (the cluster, ECU and a couple of other things), the keys were able to be recognized and immobilizer light is no longer visible or blinking. Thanks for all of the support and guidance.
tryin2vw
C?ID=44327
Now on to finding why the N239 valve shows open or short.
Last autoscan:
Sunday,28,April,2019,08:54:21:23395
VCDS Version: 18.9.1.0 (x64)
Mileage:    Repair Order: me5
   Coding: 00002
   Shop #: WSC 00066
   VCID: 57B774EAB55607F2CC-4AE6
Readiness: 0 0 1 1 1
   Coding: 0004097
   VCID: 2A51FD1E86A44A1AA3-5120
   Coding: 12340
   Shop #: WSC 00066
   VCID: 3A71CD5E2604FA9AD3-5102
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 07232
   Shop #: WSC 09519
   Coding: 00006
   Coding: 00258
   Shop #: WSC 00066
End-------------------------(Elapsed Time: 01:14)--------------------------
The current N239 is new within 6 months due to the old one being 17 years old and it crumbled.
You may have used substandard part or hooked up backward causing a pull, but check wiring for FOD!
tryin2vw
C?ID=44327
Bought it a Febi, pn 1K0-906-283. The N239 coil has a resistance of about 33 ohms and operates easily from the battery. I followed a vacuum diagram when connecting it, even used a different color tube to make sure the connections were on the correct ports.
With a cold engine, there is a bit over 10 V across the connector, so I suspect chaffed wires or FOD somewhere. I did not go to ground from either side.
It's only two wires, so stop dicking around and overlay or change controller if found faulty.:p
Jetta 97
C?ID=81680
Pull that isolation from top of the connector and most likely you will find meted wires to each other, This happens because of the heat in back of the engine over years and that isolation will keep heat to much, Repair wires and just put GOOD electrical tape instead that isolation.
