Basic settings for DCC
Deluxson24
C?ID=242930
Hey guys,
I am just finishing the retrofit of the dynamic chassis control on my vw golf mk6, and am having some trouble with doing the basic settings. I have managed to successfully code the module and wire everything. The only fault code i have left is "basic settings not performed". When i try to perform the basic settings, it says error/requirement not met. So i was wondering what's wrong? And what the min and max values are for the sensors?
Svtweb
C?ID=11754
jack the car up in the air and let all 4 wheels hang at their lowest point. Then retry the basic settings.
Deluxson24
C?ID=242930
Hey, i tried doing the basic settings with the wheels of the ground and also while it was on the ground, but it kept saying error. I'm not sure what's wrong, because there is no other fault code stored in the module except it hasn't had basic settings performed. Is there anything specific i need to check before doing the basic settings?
m87a
Bosnia and Herzegovina
C?ID=156900
For basic setting you need to lift your car so that wheel are hung and sensors are reading values,
Address 14: Susp. Elect. (J250) Login: 31564, Basic Settings: channell: 1 Go ON/OFF.
Deluxson24
C?ID=242930
I done as you have said exactly, my mechanic lifted my car on his ramp and we tried the same procedure. I'm not sure why it's not working?
Deluxson24
C?ID=242930
Sorry I forgot to post the autoscan of my car, as I wasn't on my computer yesterday.
Friday,09,September,2016,11:41:09:06975
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN: WVWZZZ1KZ9W511078   License Plate: G7 DLO
Mileage: 106740km-66325mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9W511078   Mileage: 106740km-66325miles
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016     HW: 03C 906 016
   Component: MED17.5.5       G   3546
   Revision: L3H04---    Serial number:
   Coding: 0000072
   VCID: 5CB7CE219F30B8A292-8008
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Revision: 00H30001
   Coding: 163B400D092300FB680B02EB90210080300150
   VCID: 7AFBA8B9F5C46692E0-802E
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 28
                    Mileage: 106742 km
                    Date: 2016.09.09
                    Time: 11:37:46
                    Count: 2
                    Count: 12288
                    Count: 8258
                    Count: 41984
                    Count: 64256
   Part No SW: 3C8 907 336     HW: 3C8 907 336
   Component: Climatic      120 0102
   Revision: 00004001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6ADB98F98D64D61210-803E
   Part No SW: 1K0 937 087 E    HW: 1K0 937 087 E
   Component: BCM PQ35  H+  103 0575
   Revision: 00103 AG
   Coding: 46180A3AF821F1C044080080340008EC45550488536D8960E48408040000
   Shop #: WSC 00152 210 91233
   VCID: 3365459D922E57DA63-8066
   Component: Wischer 13020  21  0501
   Coding: 009795
   Component: RLS 230209 05  54  0402
   Coding: 0730AD
   Subsystem 4 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HO  H08 9001
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56231203401265
   Coding: 149001
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_VW36.rod
   VCID: 44871641CF80E062CA-8010
Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
   Revision: 00000000    Serial number: 30101500300001
   Coding: 000180
   VCID: 275DA1CD56F62B7ACF-8072
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 28
                    Mileage: 106741 km
                    Date: 2016.09.09
                    Time: 10:55:32
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2D0960CE
   Coding: 00003136
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77FDB18DCED67BFA9F-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 33304044ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 22254145ZZZZZZZZZZZZ
   Serial number: 18471A3FZZZZZZZZZZZZ
   Serial number: 163E1827ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 0305D55D420E275AB3-8056
   Part No SW: 5K0 920 972     HW: 5K0 920 972
   Coding: 170B00
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 6DD193E5BC8AC12A75-8038
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Revision:   H07 01    Serial number: 110209F2001148
   Coding: E9A97F06000202000003
   VCID: 377D718D4656BBFA5F-8062
   Component: IMMO          H03 0607
   Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
   Component: Tuer-SG         008 2042
   Coding: 0000756
   VCID: 79F9B7B530C26D8AE9-802C
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 69     2501
   Revision: 00H15000
   VCID: 2C575EE18F10082222-8078
   Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
   Coding: 0000758
   VCID: 7AFBA8B935C46692E0-802E
   Coding: 1446940
   VCID: 34674681572050E27A-8060
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Coding: 00000022
Address 56: Radio
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
   VCID: 7BF5ADBD3AFE5F9AFB-802E
End-------------------------(Elapsed Time: 02:16)--------------------------
Deluxson24
C?ID=242930
This pictures show the values for my front level sensors, and if I am correct they are within specification to run the basic settings.
This is the screen I am showed after loging in with the security code '31564'
This is the screen I get after pressing the 'on/off/next' button to do the basic settings.
I was wondering if anything is wrong here, for basic settings not to be allowed to complete?
golfi_vend
Tartu, Estonia
C?ID=195131
I've heard that VCDS can't perform basic setting for whatever reason and ODIS must be used.
I haven't tried myself so i can't comment.
JimmyCBX tried, but ended up using ODIS or was it VAS-PC
m87a
C?ID=156900
