Forced OBD readiness with VCDS
amizan
C?ID=340128
I have done a repair on a 2012 Touareg TDI with the help of VCDS but my OBD readiness is not resetting.
I saw some postings that tests can be run with the old Vag-com but my VCDS interface does not support those in Basic Settings.
Is there a way to force OBD II readiness with VCDS.
right now, when I click "readiness", in the engine module, it is stating that all systems are ready, however when I click OBD-II functions and hit on OBD readiness, two of the modules are not ready
O2 heating
Catalytic Converter
Does anyone know how to force them to be ready with a test or something? I have driven 300 miles already and they have not reset.
There is no way to "Force Readiness" on any vehicle. You may be able to force certain tests, but there's always the question whether all proper conditions have been met.
Looking at the data for your ECU, there don't seem to be tests explicitly for O2 Heating or the Catalytic Converter, but there is:
IDE00553 -- Automatic test sequence
However, I don't have an actual procedure for it.
amizan
C?ID=340128
So the two monitor had not shown ready after driving 500 miles BUT CA BAR rules say that a Diesel can pass smog with two monitors ready (only EVAP for gas cars) which the smog guy didn't know. So all set and roadworthy finally! Thank you and VCDS for making this project succcesful !!
Moxnix
C?ID=212386
Reset my service interval and and may have deleted some codes and now I can't get car inspected because of OBD readiness issues. Any clues how to speed this up to return to inspection station ?
Tuesday,09,July,2019,14:54:00:30397
VIN: WAURNAF48HN070849   License Plate: EGR
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Failed or Incomplete
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Passed
Oxygen sensor heater monitoring:  Passed
Exhaust Gas Recirculation:  Failed or Incomplete
Readiness Status: 1000 0100
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Failed or Incomplete
Catalyst Heating: Passed
Catalytic Converter(s): Passed
That's this car, right?
https://forums.ross-tech.com/showthread.php?14425
I would try this Basic Setting in the Engine:
After initiating Basic Settings, the hold a foot on the brake pedal and floor the accelerator pedal. The ECU will then holdd different RPM points and run through all of the tests. While in Basic Settings, the Show Measuring Data button be used to display "IDE00727 Test steps still to be performed" or similar to watch the remaining steps count down to zero.
Moxnix
C?ID=212386
Thanks for the quick response, it is in fact the same car but it has a manual transmission, can I put it in first with e brake and wheel chock and perform the same procedure just letting up a little on the clutch? I have also read that if you have a full tank of gas the evap monitor may not perform a test.
On an automatic car, this would be done with the shifter in Park. On a manual car: Neutral. Service brake must be held. There should be no need to touch the clutch.
Moxnix
C?ID=212386
So I am basically flooring the car in neutral?
Yes, but only after initiating the Basic Setting, and while holding the brake pedal firmly with your left foot. Assuming the Basic Setting is active, the ECU should then run the engine at the speeds it deems necessary to conduct the tests.
Moxnix
C?ID=212386
Got it, out to the garage I go
Moxnix
C?ID=212386
Well right you are again, the only thing left is the Evap system but I do have a full tank of gas and I believe that has to be between 1/3 to 3/4 full for that to reset itself, so i will do some driving. Fantastic support, thanks so much and I will post later!
Tuesday,09,July,2019,18:29:56:30397
VIN: WAURNAF48HN070849   License Plate: TEST SYSTEMS
Readiness Status: 0000 0100
Exhaust Gas Recirculation: Passed
Moxnix
C?ID=212386
Done and done
Thanks to the software and advice emission inspection was no problem.
spelk3
C?ID=274542
I need to get my 2015 Gti smog check done in California. All of the tests are ready except the fuel system. Is there anyway to get the fuel system monitor “ready”? I’ve driven through several tanks of gas but the fuel system stays “not ready”. Car is stock except for the intercooler. ECU was reset at the 30k service.
So this car has an aftermarket intercooler, but it isn't chipped? :confused:
Please post an Auto-Scan and also the OBD-II Mode 9 data.
spelk3
C?ID=274542
Car was custom tuned, ECU and TCU using Accessport. Accessport was completely uninstalled and car returned to stock before the 30k service. Sold the car to a friend straight from the mechanic. He’s been driving it since mid December and the only monitor that is not ready is the fuel system.
I should have access to the car tomorrow and I’ll get the scans.
What are modes in VCDS OBD2 0x33?
Modes 01-01, 03, 07, 09
Please post ALL data.
spelk3
C?ID=274542
Tuesday,25,February,2020,10:53:55:64160
VCDS Version: 19.6.2.2 (x64)
VIN: 3VW4T7AU4FM036473   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU4FM036473   Mileage: 50839km-31589miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 091D00124424002F0000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C79FEF947F1972F29-8078
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4511
   Revision: 03253104    Serial number: TFK01407160154
   ROD: EV_TCMDQ250021.rod
   VCID: 297707ED48038207D2-807C
          P1734 00 [002] - -
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 52324000000257
   Coding: 01FA6BA134230972007B020781C62980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44A9B659CF617F6FC1-8010
   Part No SW: 5G0 907 426 R    HW: 5G0 907 426 R
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00020004200100000000000012000000
   VCID: 3A55C8A1BDA5399FAB-806E
   Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86580909140633
   Coding: 000018464041804969E44000001407201000000000000000000000000000
   Shop #: WSC 00066 790 00074
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
   ROD: EV_BCMBOSCH_013.rod
   VCID: 46ADAC51F95D4D7FDF-8012
   Component: WWS    140720  043 0581
   Serial number:         140930225756
                    Fault Frequency: 73
                    Reset counter: 185
                    Mileage: 49733 km
                    Date: 2020.02.05
                    Time: 11:48:58
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM0112ZH
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51878F0D00139AC77A-8004
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140001D3KF0-
   Coding: 30325A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 708 14
   Serial number: 3570000000053685C01C
   Subsystem 3 - Part No SW: -----------    HW: 480 000 508 14
   Serial number: 35800000000B52A0A01C
   Subsystem 4 - Part No SW: -----------    HW: 480 401 108 14
   Serial number: 3510002B516DB811C22+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 108 14
   Serial number: 3520002B516DB813106Z
   Subsystem 6 - Part No SW: -----------    HW: 480 402 107 14
   Serial number: 3550002C515F3C325181
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 107 14
   Serial number: 3560002C715F3C30D315
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20140804500089
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FA3B9B5A6871CB79C-806A
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
                    Reset counter: 166
                    Mileage: 50482 km
                    Date: 2020.02.17
                    Time: 08:57:38
                    Ubat 30 Voltage: 14.30 V
                    Ignition State: On
                    Terminal 15: 13.50 V
                    A/D #1: 0.00 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BBD090A2180CF0502087A001000000000000000
   VCID: 6BFB3DE5827F501760-803E
   Part No SW: 5Q0 907 530 S    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2186
   Revision: --------    Serial number: 22081410001813
   Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti_011.rod
   VCID: 41A7BF4DD0736A47EA-8014
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29140001587730094323
   Coding: 29FFFF
   Serial number: 100914060500QK
   Coding: 003E03200000040000000000
   VCID: 40A1BA49DB79634FE5-8014
   Serial number: 00000000000003513103
   Coding: 011000
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 354FDB9D94BBD6E746-8060
   Serial number: 100914060502LY
   Serial number: 00000000000003615340
   Coding: 191000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 148
                    Mileage: 50024 km
                    Date: 2020.02.08
                    Time: 16:30:08
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B01608141195
   Coding: 02730000FF00000021220001001800001F0203040100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64E956D96FA11F6F21-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS500L03
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Shop #: WSC 00066 790 00123
   ROD: EV_OCULowMQB.rod
   VCID: 0225704195F5B15FB3-8056
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 146
                    Time: 00:00:00
   Serial number: 140724201680
End-------------------------(Elapsed Time: 03:20)--------------------------
mode 9
Tuesday,25,February,2020,11:07:28:64160
VCDS Release 19.6.2 (x64):  Generic OBD2
Mode 9 : Calibration Identification
Type 02 - VIN : 3VW4T7AU4FM036473 (Address E8)
Type 04 - Calibration ID : 5G0259A 0005AXAJ (Address E8)
Type 04 - Calibration ID : 0D9300041T  4511 (Address E9)
Type 06 - Calibration Verification Number : AC61822F (Address E8)
Type 06 - Calibration Verification Number : 0000D6C1 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 143
    Ignition cycle count : 464
    Conditions completion count / Specified conditions encountered count
         Catalyst monitor bank 1 : 103 / 137
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 174 / 137
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 82 / 119
         AIR monitor : 73 / 31
         EVAP monitor : 18 / 30
         Secondary O2 Sensor monitor bank 1 : 93 / 137
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : ECM- (Address E8)
Type 0A - Controller Name : TCM- (Address E9)
mode 1-01
Tuesday,25,February,2020,10:59:17:64160
Fuel System:  Failed or Incomplete
Evaporative system monitoring:  Passed
Secondary air system monitoring:  Passed
spelk3
C?ID=274542
mode 3
Thursday,27,February,2020,11:01:41:64160
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
mode 7
Thursday,27,February,2020,11:02:45:64160
Mode 07: Pending emission related fault codes
mode 9
Thursday,27,February,2020,11:08:59:64160
    OBD Monitoring Conditions Encountered count : 148
    Ignition cycle count : 480
         Catalyst monitor bank 1 : 107 / 142
         O2 Sensor monitor bank 1 : 180 / 142
         EGR-VVT monitor : 84 / 122
         AIR monitor : 75 / 33
         EVAP monitor : 20 / 32
         Secondary O2 Sensor monitor bank 1 : 97 / 142
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
spelk3
C?ID=274542
Still have the fuel system monitor “not ready”. Any ideas?
