How to change dome light behaviour and activate cornering lights in C8/4K A6?
santti
C?ID=379770
is it possible to change dome light behaviour when opening doors? By default only the corresponding dome to the opening door is turned on, but is there any known coding or adaption change to get them all activated at the same time?
Another question is concerning cornering lights with low level leds? Is it possible to active cornering fuction By coding?
Saturday,18,January,2020,18:51:24:43746
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(VMWare)
VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZF20KN12xxxx   License Plate: xxx-xxx
Mileage: 36855km-22900mi   Repair Order:
Chassis Type: F2-AU58 (4N1)
Scan: 01 02 03 09 15 16 17 19 42 44 46 52 5F 80 81 A5 AC BB BC D6
          D7
VIN: WAUZZZF20KN12xxxx   Mileage: 36855km-22900miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DEZD)       Labels: None
   Part No SW: 05L 906 027 D    HW: 05L 907 309
   Component: R4 2.0l TDI   H22 6901
   Revision: E1H22---
   Coding: 0A2540322324050C34002000000000000000000000000000
   ASAM Dataset: EV_ECM20TDI01105L906027D 005007
   ROD: EV_ECM20TDI01105L906027BB.rod
   VCID: 2D070970CD9B904F521-8079
   Part No SW: 4K0 927 153 D    HW: 0HK 927 156 B
   Component: 0CK 20TDI RdW H01 0002
   Revision: --H01---    Serial number: 0000001102
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 2E050E7CC09DEB576BB-807B
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041190128001650
   Part No SW: 4K0 907 379 P    HW: 4K0 907 379 A
   Component: ESP9 Plus     H06 0854
   Coding: 0CAA499714A40A9711A0489A008552D2F5B9C0309228508812004A4BAF9D03
   ASAM Dataset: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 42DD4ACC64057F379F3-8017
   Part No SW: 4N0 907 063 GG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0653
   Coding: 07000943E11800CD074C070818AD8068130B3310000600970100080039321A010840083242560108000001000001001A0000000000010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 79AFED204953FCEF8E9-802D
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001904120402652
   Coding: 7DC727
   Serial number: 23021672X81A955555A0
   Coding: 02006E
   Light switch:
   Subsystem 3 - Part No SW: 4K1 941 501     HW: 4K1 941 501
   Component: E1 - LTM  H05 0053
   Serial number: 16S17.05.1900300853
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE111121823311833
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AE    HW: 4K0 947 135 AE
   Component: Dachmodul  H42 0415
   Serial number: C00272757
   Coding: 0D0104
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H09 2720
   Serial number: 003YZM053WAF
   Coding: AACCF0C00CC00000985400FFF00D40AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4ACD62EC5C35A777573-801F
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2019131725400000
   Coding: 04F001
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2019115110700000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 002 305 19
   Serial number: 357000000000F7605B3J
   Subsystem 4 - Part No SW: -----------    HW: 480 002 305 19
   Serial number: 358000000007F9605B3T
   Subsystem 5 - Part No SW: -----------    HW: 480 031 805 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351001C20004E4B0FD54
   Subsystem 6 - Part No SW: -----------    HW: 480 031 805 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352001C2000C21713E4Q
   Subsystem 7 - Part No SW: -----------    HW: 480 032 205 19
   Component: FrontSensor_D  002 0149
   Serial number: 355001C20CED50C08E1L
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 032 205 19
   Component: FrontSensor_P  002 0149
   Serial number: 356001C20CED15103D16
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 031 105 19
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C201EB6190396.
   Subsystem 10 - Part No SW: -----------    HW: 480 002 105 19
   Serial number: I0M00000000EE7D8AAB+
   Subsystem 11 - Part No SW: -----------    HW: 480 002 105 19
   Serial number: I0N00000000BE7D8AAB$
   Part No SW: 4N0 907 129 S    HW: 4N0 907 129 S
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 41DF45C06103642F869-8015
   Part No SW: 4K0 920 701 C    HW: 4K0 920 701 C
   Component: TDieRDW------ H07 0189
   Coding: 81A420C2688000080C40A0609080000008001000
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2517F150956BA80F9A1-8071
   Part No SW: 4N1 907 468 AL    HW: 4N1 907 468 AB
   Component: Gateway       H14 0045
   Revision: AA010003    Serial number: 038AA510719517
   Coding: 02010005002006405A860002005B0132CC1A000710000000097F078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003170
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   VCID: 025D8ACC2485BF37DF3-8057
   Subsystem 1 - Part No SW: 4N0 951 523 H    HW: 4N0 951 523 H
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 74186313001905150632
8531970 - Quiescent Current
          U1406 00 [009] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 222
                    Mileage: 36855 km
                    Date: 2020.01.18
                    Time: 18:49:02
                    Total static current-current total quiescent current: 70 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
                    EM_vehicle_state: 02 1C
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS002 0189
   Serial number: YE007SDK33417
   Coding: 001CDB0040000480A000B000
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 3E253E3C10FD1BD7FBB-806B
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Coding: 94002101010000
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D1A0CD4A5CFB70F3-8067
   Part No SW: 4N0 907 064 CB    HW: 4N0 907 064 B
   Component: BCM2 MLBevo H14 0164
   Coding: 01340000002000E06301A0000400000203020000804B04502F04000000040030001F0100000011
   ASAM Dataset: EV_BCM2CONTIAU651 009009
   ROD: EV_BCM2CONTIAU651_009_AU58.rod
   VCID: 71BFD5001123B4AF369-8025
   Ignition key:
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS002 0189
   Serial number: YE007SDK2840C
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 3D2739301DFB00CFE21-8069
   Part No SW: 4K0 035 136 B    HW: 4K0 035 136 A
   Component: MU-H-N-EU     046 9815
   Coding: 01850100FF0A000043110001000800002F0008C40370080002
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 2313EF489B5F563FF45-8077
   Subsystem 1 - Part No SW: 4K1 919 604 G    HW: 4K1 919 604 F
   Component: DU AU58x Top  H71 0170
   Serial number: BHB00130041903200629
   Subsystem 2 - Part No: V03 959 800 EG
   Component: Gracenote2  1008
   Volume Control 1:
   Subsystem 3 - Part No SW: 4K1 919 616 A    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004419000047201027
   Display Unit 5 For Multimedia System:
   Subsystem 4 - Part No SW: 4K1 919 603 G    HW: 4K1 919 603 F
   Component: DU AU58x Bot  H71 0170
   Serial number: BHB00118051903130118
   Media socket:
   Subsystem 5 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051900210792004
Address 80: Batt. reg. aux. accum. (A1)       Labels: None
   Part No SW: 4K0 915 101     HW: 4K0 915 101
   Component: MQ-BMS        H20 0127
   Serial number: 18000047306002
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: 6099A044CAC90D27A97-8035
   Part No SW: 4K1 713 041 H    HW: 4K1 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 19.136 40269
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 2809F864E279B567A17-807D
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AA    HW: 4N0 907 107 F
   Component: zFAS Var A    H08 0291
   Coding: 04018200000000000000060000000424189D5600000000000000000000000000001900000000000000000000000000000000000000000000000000000000000000006200008000B000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001_AU58.rod
   VCID: 7EA5FE3C507DDBD7BBB-802B
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 80A 907 355 F    HW: 80A 907 355 D
   Component: SCR-Stg-G4H08 0004
   ASAM Dataset: EV_RDCMHelbaAU426 003011
   ROD: EV_RDCMHelbaAU426_003.rod
   VCID: 2C010474F681994745F-8079
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS003 0189
   Serial number: YE007SD414558
   Coding: 000CD90000000480A000B000
   VCID: 40D940C46A096D27897-8015
   Component: TSG HBFS003 0189
   Serial number: YE007SD41289A
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 DC    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H06 0031
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU38.rod
   VCID: 72BDDA0C14258FB7CF3-8027
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU38.rod
End----------(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.1V)-----------
hadez16
C?ID=289891
First topic: Unit 09, Coding, deactivate Byte 10 Bit 0
Second topic: Experimental!
New Coding Unit 09: 07000944E11800CD074C070818AD8068130B3310000600970100080039321A010842083242560108000001000001001A0000000000010100000000000000000000
If that does not work, try: 07000944E11800CD074C070818AD8068130B3310000600970100080039321A010852083242560108000001000001001A0000000000010100000000000000000000
You need to drive to check if its working, not in standstill.
santti
C?ID=379770
Thanks a lot! Gotta try those in few days.
