Warning display after KW shock install on Audi 2016 S3
smiles77
C?ID=268542
After replacement of OEM shocks with KW shocks, the suspension fault display now comes on maybe after 10 miles. When the car is restarted, the code is off only to reappear after another couple of miles. The car has been slightly lowered with the shock install. I have posted the autoscan. Yes, we havehe DCC resistors installed and have been in contact with KW.
Sunday,06,October,2019,12:15:43:54023
VCDS Version: 19.6.2.0 (x64)
VIN: WAUF1GFF9G1030501   License Plate: RC 66R8
Mileage: 107970km-67089mi   Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 6C A5 A9 BB BC
VIN: WAUF1GFF9G1030501   Mileage: 107970km-67089miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Revision: --H13---
   Coding: 0A1D00122466000E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
   ROD: EV_ECM20TFS0208V0906259H.rod
   VCID: 45AFA4C0C472E167D4-8010
17178 - Databus
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4903
   Revision: 06253104    Serial number: TFK01507151448
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 538B8A983A264FD74A-8006
   Revision: 00000000    Serial number: 61885000001108
   Coding: 31FF6B9254230A6C017C030041C4698CD62A5080C08296B6184150D48208
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 7AD5073CFD0C5E9FE9-802E
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 165
                    Mileage: 106969 km
                    Date: 2019.08.05
                    Time: 10:47:42
   Revision: 00021000    Serial number: 0374834977
   Coding: 030C0C
   VCID: 3A55C73CBD8C9E9FA9-806E
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000707976
   Coding: 03000014010000000000000000001400
   VCID: 334BEA189AE66FD76A-8066
   Serial number: D4394FB7000000000001
   Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061520400821
   Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 012770D090DA0D47A8-8054
   Component: WWS371 150717  042 0585
   Serial number:         150725015637
   Coding: 0A47F7
   Serial number: 24114778
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 29 05 2015  00000019
   Serial number: 00000000000033149633
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000FW78Q00000
   Coding: 101F00
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 227
                    Mileage: 107696 km
                    Date: 2019.09.15
                    Time: 17:44:34
204293 - Remote key 1
          B1479 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 227
                    Mileage: 107889 km
                    Date: 2019.10.05
                    Time: 10:44:32
   Revision: --------    Serial number: 39331521007490
   Coding: 0070150011
   VCID: 43ABBAD8CA46DF57FA-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 N    HW: 5Q0 907 567 N
   Component: ACC3          H10 0400
   Serial number: 13091703070475
   Coding: 01261701FE0309
   Shop #: WSC 27775 002 1048576
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 46ADA3CCF974EA7FDD-8012
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       280715004
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
3149829 - Valve for Damping Adjustment Front Left
          C1040 1D [008] - Current Implausible
                    Reset counter: 228
                    Mileage: 107895 km
                    Date: 2019.10.05
                    Time: 10:49:31
                    COM: 00 33 09 33 00 0D 01 00 13 00
                    Voltage terminal 30: 14.4 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Vehicle_level_sender_PWM-Left front: Not available
                    Vehicle_level_sender_PWM-Right front: Not available
                    Vehicle_level_sender_PWM-Left rear: 90.8 %
                    Vehicle_level_sender_PWM-Right rear: 61.6 %
                    AMR state: 6
                    Damping adjustment indicator lamp: On
                    Dampening adjustment: current Highside-Left front: -19 mA
                    Dampening adjustment: current Highside-Right front: -16 mA
                    Dampening adjustment: current Highside-Left rear: 0 mA
                    Dampening adjustment: current Highside-Right rear: 5 mA
                    Dampening adjustment valve: current Lowside-Left front: -8 mA
                    Dampening adjustment valve: current Lowside-Right front: -3 mA
                    Dampening adjustment valve: current Lowside-Left rear: -14 mA
                    Dampening adjustment valve: current Lowside-Right rear: 3 mA
                    ESP automatic engagement: activated
                    Fall-back level: 00 00 06 42
3153925 - Valve for Damping Adjustment Front Right
          C1041 1D [008] - Current Implausible
                    Reset counter: 228
                    Mileage: 107894 km
                    Date: 2019.10.05
                    Time: 10:48:38
                    COM: 02 33 09 33 00 0D 01 00 0D 00
                    Voltage terminal 30: 14.3 V
                    Vehicle_level_sender_PWM-Left front: 35.2 %
                    Vehicle_level_sender_PWM-Left rear: 15.6 %
                    Vehicle_level_sender_PWM-Right rear: 15.2 %
                    AMR state: 0
                    Damping adjustment indicator lamp: OFF
                    Dampening adjustment: current Highside-Left front: 2459 mA
                    Dampening adjustment: current Highside-Right front: -8 mA
                    Dampening adjustment: current Highside-Left rear: 1135 mA
                    Dampening adjustment: current Highside-Right rear: 1073 mA
                    Dampening adjustment valve: current Lowside-Left front: 2442 mA
                    Dampening adjustment valve: current Lowside-Right front: 3 mA
                    Dampening adjustment valve: current Lowside-Left rear: 1127 mA
                    Dampening adjustment valve: current Lowside-Right rear: 1077 mA
                    ESP automatic engagement: not activated
   Serial number: 003GCR02ZJZK
   Coding: 9DCCFCC0000000005000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47B3AEC8FE7EF37726-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34230167A04081570148
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34230168A04081570353
   Coding: 333135
   Occupant Detection:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Serial number: 694000000000001DH35F
   Coding: 303337
   Subsystem 4 - Part No SW: -----------    HW: 480 002 707 15
   Serial number: 357000000006000DB518
   Subsystem 5 - Part No SW: -----------    HW: 480 002 707 15
   Serial number: 35800000000FF00DB51X
   Subsystem 6 - Part No SW: -----------    HW: 480 402 207 15
   Serial number: 35100029F1B7E8E1023A
   Subsystem 7 - Part No SW: -----------    HW: 480 402 207 15
   Serial number: 35200029F1B7E8E4C27U
   Subsystem 8 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 35500029F1A91E7261AE
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 3560002A11A91E71A341
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8V0 953 521 GR    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 02081508490053
   Coding: E818
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 10014594CBB074CF37-8044
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8V0 920 972 B    HW: 8V0 920 972 B
   Component: KOMBI         H03 6420
   Coding: 0BCD181B7F88D7050281E8001800000000000000
   VCID: 3D5FCC20ACA2A9A78C-8068
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 21071510801799
   Coding: 0101000830085A005B00023C980B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75CF1400D41231E784-8020
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 14 07 2015  F0049179
   Serial number: HA1-00008.06.15
   Coding: 0001
   Revision: 00000000    Serial number: 15000176510003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3449E9049FE868EF73-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H05 0080
   Serial number: 0374187880
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3851DD3483808C8F5F-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0080
   Serial number: 0372243119
   Coding: 030211
   Serial number: 070715BG703316
   Coding: 005D1B205C00048000000003
   Coding: 9102
   VCID: 3753DE088E9E83F756-8062
   Part No SW: 8V0 035 465 D    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0420
   Serial number: AUZ8ZAFN90196DW
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 3957D830B88A9587A0-806C
   Serial number: 100715BG919537
   Coding: 005D13205E00048000000003
   VCID: 42A5BFDCD55CD65FF1-8016
   Coding: 0122000123200400
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FA3B628A6AEBBB79E-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
   Component: MU-H-LNS-US   H43 0394
   Serial number: A302H0FB017550
   Coding: 017301020000000021220002041A00102F000225010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY203QUA
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000004061500030111
   Component: Gracenote  --- 3006
6667 - Optical Data Bus for Information Electronics 1
          U10CA 00 [008] - Intermittent Disruption
                    Reset counter: 228
                    Mileage: 104874 km
                    Date: 2019.06.08
                    Time: 14:43:20
                    Voltage terminal 30: 13.7 V
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -19 °C
                    Temperature of MOST transceiver-Current: 31 °C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
   Component: MQB RVC Mid   H07 0140
   Coding: 027300010201000300
   ASAM Dataset: EV_2CamSysRearPASE 006016
   ROD: EV_2CamSysRearPASE.rod
   VCID: 3041E5146BF054CF17-8064
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000399125
   Coding: 0100000000010303000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C59C124B7B8A0AFBB-8068
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 150701200993
   VCID: 7DDF0C20EC2269A7CC-8028
0006 - Actuator for Structural Accoustics
          P193A 00 [009] - Open Circuit
                    Fault Frequency: 27
                    Reset counter: 188
                    Mileage: 104695 km
                    Date: 2019.06.04
                    Time: 15:03:51
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 240715BGG1795B
   Coding: 004D13204000048000000002
   Serial number: 240715BGN16786
One copy of your Auto-Scan would have been sufficient. Is there a reason you posted eight times? All of those scans appear to have the same time-stamp. Would you mind if I reduced the clutter in that post?
It looks to me like whatever KW resistors told/sold you to put in place of the the front dampers aren't doing what they're supposed to do.
smiles77
C?ID=268542
Uwe,
Yes, please reduce the clutter! I am a Mac guy and the PC just gives me fits. Thanks for correcting my screw up. I also used the forum a few years ago to update my 2007 Rabbit. Ross Tech made it possible to retrofit. Your group is terrific! The shop (Nothing Leaves Stock) that did the install believed that KW had it figured out-they didn't. Maybe there is a coding change that could rectify the suspension fault display. Naturally, we are still in contact with KW.
Thanks.
OK, Post #1 has been de-cluttered. :)
smiles77
C?ID=268542
Thanks Uwe!
m87a
Bosnia and Herzegovina
C?ID=156900
as Uwe said it looks like 2 front resistors are not working, did you try to replace 2 in front with 2 in the back? As for coding you can't disable checks, also coding out el suspension will require rewiring height sensor for headlights...
smiles77
C?ID=268542
KW sent new front resistors which we just installed- same suspension fault as before except we are out another $342. KW said they would credit the new resistors IF they new ones worked- they did not. Looks like the other fix is to run another wire after turning off DCC. Anybody got some ideas?
Thanks in advance.
m87a
C?ID=156900
this is pretty self explanatory, resistors sent by kw are not appropriate for this module, why? who knows, maybe the pulse for checking is different or expecting different resistance, but KW should fix this.
Disabling DCC is a lot more than just running one wire, you would need new wires run directly to 55 AFS from leveling sensor (I don't know on MQB if leveling sensor is the same for DCC and non DCC cars) also coding 55 for one sensor directly connected instead sharing info via can with DCC, code out 14 DCC from gateway, 5F etc...
Try to work with KW to sort it out, items bought are not working as declared etc..., also just plugging 2 "working" resistors is easiest way.
Wait, what? $342 for some resistors? :confused:
smiles77
C?ID=268542
Uwe, Yeppers! I paid about $400 originally for the "KW DCC kit" when the shocks were installed (suspension fault light goes on) and after consultation with KW they thought the kit was not installed correctly but they would send another set of new resistors for an additional charge. If they fixed the problem they would not charge- problem is still there. So I paid about $750 for the DCC kits and the problem still is there.
