Sunday,15,March,2020,17:00:07:60834
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name:
VIN: WAUENCF51JA129563 License Plate:
Mileage: 30391km-18884mi Repair Order:
Chassis Type: F5-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F 6C
6D 81 A5 A9 BB BC CA CF D6 D7
VIN: WAUENCF51JA129563 Mileage: 30391km-18884miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels:. 06K-907-425-V2.clb
Part No SW: 8W0 906 259 J HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0002
Revision: --H15---
Coding: 1A2500322326010E34280000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
ROD: EV_ECM20TFS020_AU49.rod
VCID: 48C95FD9323D2167415-801C
17186 - Databus
17178 - Databus
23081 - Implausible Data Received from Steering Column Control Module
U0429 00 [032] - -
14874 - Camshaft Position Sensor (G40)
P0341 00 [096] - Implausible Signal
Mileage: 29224 km
Date: 2020.02.29
Time: 17:29:43
Engine speed: 1402.00 /min
Normed load value: 25.5 %
Coolant temperature: 10 °C
Intake air temperature: 11 °C
Voltage terminal 30: 11.601 V
Unlearning counter according OBD: 9
CAM_SP_IND_VCP[IN_1]: 0.000 °
CAM_VCP[IN_1]: 42.297 °
PWM_HLD_VCP[IN_1]: 12.500 %
Engine: operating status: IS
STATE_PWM_VCP[IN_1]: HLD
STATE_VCP: passive
Engine oil temperature: 9.0 °C
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 BA HW: 0CJ 927 156
Component: 0CL 20TFSINAR H05 0001
Revision: --H05--- Serial number: 0000000831
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU49.rod
VCID: 015F82FD5187D02FC6B-8054
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180171000039
21023 - No Communication with Diagnostic Gateway
U0146 00 [032] - -
22348 - Selector Lever
P0919 00 [032] - Malfunction
22351 - Selector Lever
P085D 00 [032] - Malfunction
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 Q HW: 8W0 907 379 J
Component: ESP9 Plus H10 0775
Coding: 18AA409A28A40A9F11A3489700805292E5359A180214508812004A49A7AC59
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 53F378B5FB7B92BF247-8006
292608 - Switch for Electric Parking Brake
C100C 01 [032] - Electrical Failure
442624 - Indicator Lamp for Electronic Parking Brake
C11FC 14 [032] - Open or Short to Ground
153600 - Steering Assistance Function
C11EF F1 [096] - Unexpected Values from Steering Assist Module
4532483 - Steering Angle Sensor
C0529 00 [032] - Not Calibrated
6293504 - Steering Angle Sensor
C2008 00 [032] - Signal Qualification
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0251
Coding: 140805095548000D10000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D14BE90E150507ADD-8010
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002543233
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 5080153900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 87500363E00810CD0515971918AC98B9110B3D08000000000000000020001A010A690122025705
VCID: 025D8DF15481CB37DF1-8056
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 050618 036 0471
Serial number: 00000001805290301894
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 21563837X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AK HW: 4M0 941 531 AK
Component: E1 - LDS H06 0008
Serial number: 28 03 2018 01380012
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z012602
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180611185947 01062
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE113041823610455
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00863956
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000059627004
66657 - Local Databus 5
U1506 00 [008] - No Communications
Reset counter: 120
Mileage: 27830 km
Date: 2020.02.11
Time: 20:18:50
average_Voltage_terminals: 12.20 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 11.00 °C
interior_temperature: 20.50 °C
Vehicle speed: 0.00 km/h
66658 - Local Databus 6
U1507 00 [008] - No Communications
Reset counter: 120
Mileage: 27830 km
Date: 2020.02.11
Time: 20:18:50
196720 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Fault Frequency: 29
Reset counter: 120
Mileage: 29796 km
Date: 2020.03.08
Time: 13:16:22
average_Voltage_terminals: 13.00 V
Outside air temperature sensor-Outside air temperature on CAN: 12.50 °C
interior_temperature: 12.50 °C
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0107
Serial number: 003UQ00315ZH
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4DC76ECDDD5FC44F723-8018
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0173S01599
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0178S00012
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180009PM0708
Subsystem 4 - Part No SW: ----------- HW: 442 062 706 18
Serial number: 3577Y0099279D02434A%
Subsystem 5 - Part No SW: ----------- HW: 442 062 706 18
Serial number: 3587Y00B527DBDE293BT
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 106 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700AF2A77571E2BS
Subsystem 7 - Part No SW: ----------- HW: 442 0B2 006 18
Serial number: 3527700A729299631444
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 106 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A72AEF870B14S
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 106 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A72AEF870E11T
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GK HW: 4M0 907 129 GK
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7F5B04052773A6DFB0F-802A
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 890 G HW: 8W5 920 890 G
Component: FBenUSA H19 0377
Coding: 01E741C72988CF0502236D601800000008000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 47CB5CE53F232E1F48F-8012
Part No SW: 8W6 907 468 F HW: 8W6 907 468 E
Component: Gateway H43 0123
Revision: 7B000002 Serial number: 0287B773918629
Coding: 030100010000064029070000005900126C180007100000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
Subsystem 1 - Part No SW: 36A 953 509 C HW: 36A 953 509 C
Component: J453 MFL H04 0002
Serial number: 20170109105555 RD058
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0136468404
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78A9EF19025D91E7F15-802C
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000330825135
Coding: 005C1B400000B0010000010101010000000000000000000000000000000000
VCID: 79AFEA1D395788EF8EB-802C
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 E HW: 4M0 907 566
Component: MRR1Rear H20 0430
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 372B2C254FC35E9F38F-8062
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0129
Serial number: 0000329063667
Coding: 005F4B625E00108000010432
VCID: 43D348F50B1B023F947-8016
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42DD4DF114010B379F1-8016
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Coding: 013400004FB100C0658BA0006E01080233024000810026502F0400000F04803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
Ignition key:
Subsystem 1 - Part No SW: 4M0 959 754 AK HW: 4M0 959 754 AK
Component: ID-Geber H40 0105
Serial number: 3618000103681006
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY181421QES
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099409366
Subsystem 4 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: 12045793
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Reset counter: 120
Mileage: 26923 km
Date: 2020.01.30
Time: 19:50:03
Supply voltages-Supply voltage: Terminal 30: 12.337 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.392 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.392 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAJJA04H61W
Coding: 0194030800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
VCID: 76B5E1210849E797E39-8022
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0129
Serial number: 0000329102500
Coding: 005F4B225E00108000010430
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 D HW: 8W5 035 880
Component: MU-P-LNS-US 034 1320
Serial number: A798F0JB111166
Coding: 019403020000000053220002041A00102F000EE501700904FE
VCID: 40D947F91A0D1927895-8014
Subsystem 1 - Part No SW: V03 959 803 AF HW: -----------
Component: NAR 2020 --- 0076
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00118051800820292
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK115061800020901
Component: Gracenote2 --- 3012
B11CF 53 [009] - Deactivated
Reset counter: 8
Mileage: 27830 km
Date: 2020.02.11
Time: 22:56:42
Voltage terminal 30: 12.4 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0294030102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 333318355BBBB2BF047-8066
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0166
Revision: -------- Serial number: 32005184600000
Coding: 0630
ASAM Dataset: EV_DeckLidCONTIAU736 001016
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 G HW: 8W1 713 041 J
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18062748001940
ROD: EV_GSMWaehlZFAU736.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H17 0050
Coding: 0404090300000203022023A2A50000FC00F0C020C000
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 H HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0008
Serial number: 180525201207
VCID: 46D551E138293717B39-8012
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0130
Serial number: 0000329884414
Coding: 000F4B220000108040000020
VCID: 45D756ED052F3C0FBA3-8010
Component: TSG HBFS 005 0130
Serial number: 0000329887109
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 228000049301
VCID: 3D273E0D6DFF74CFE23-8068
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 E HW: 4M0 907 590
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 34311B295EB5B5871DD-8060
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176BCCA52F037E9F18F-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----(Elapsed Time: 02:06, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Address 17,8W5 920 890 G,recoded (Long Coding-exp),from,01E741C72988CF0502236D601800000008000000,to,01E741C72988CF0502236D641800000008000000,(06335/790/00001),
Ever since I changed front bumper grille, I've been getting warnings on front parking aid sensors not working. Does B10FC / 02069: Open circuit indicate that the connectors are disconnected?
I am almost certain that I plugged in all connectors when installing the new grille, but was wondering if there could be any other symptoms like sensors need calibration or something, before taking off the front bumper out again which is much of a work.
Thanks in advance for your input.
