Thursday,11,April,2019,18:50:21:19087
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 18.9.1.0 (x64) HEX-NET CB: 0.4437.4
VIN: WVWVF7AU3HWNNNNNN License Plate:
Mileage: 35436km-22018mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
55 5F 75 A5 A9
VIN: WVWVF7AU3HWNNNNNN Mileage: 35436km-22018miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 K HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122466000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259K 001004
ROD: EV_ECM20TFS0208V0906259K_VW37.rod
VCID: C8DC064E73F9F40AD5-809D
23126 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
Part No SW: 0D9 300 014 Q HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5006
Revision: 06454104 Serial number: TFK01611171596
ROD: EV_TCMDQ250021.rod
VCID: A600A8F6D9AD027A07-80F3
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 63426000000482
Coding: 01FA6BA154260973457D030540C76980D62A90A2C0029637184050D8C2A8430000000012121212B835351919323200
VCID: F9BAB38A78935D821A-80AD
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0425484538
Coding: 032C0C
VCID: BB366982322FAF9248-80EF
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002000420010000010500401211140A
VCID: ED9297DA3CDBF12286-80B9
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 BL HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061633500203
Coding: 00011B46C041A2E169E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 8444D27E0F51106A79-80D1
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 161111 043 0551
Serial number: 161130202128
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y16M12D12H17M56S45
Coding: 00A8DD
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331634803055
Coding: 0071155011
VCID: C3C611624ADFD75200-8097
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Component: ACC BOSCH MQB H10 0620
Coding: 350040C151FFC428949C810530301600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002005
VCID: BC346A9E3721A8AA41-80E9
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 12111641350945
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: B83C768E0319848AA5-80ED
Component: AirbagVW20 010 0830
Serial number: 003GCR06MS0S
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: C7DE05727EE7FB72DC-8093
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000066LC38
Coding: 30324E
Subsystem 2 - Part No SW: ----------- HW: 480 000 812 16
Serial number: 35700000000C702D9E1U
Subsystem 3 - Part No SW: ----------- HW: 480 000 712 16
Serial number: 35800000000986DCFF19
Subsystem 4 - Part No SW: ----------- HW: 480 400 912 16
Serial number: 3510001A5234EB14428Z
Subsystem 5 - Part No SW: ----------- HW: 480 400 912 16
Serial number: 3520001A1230E744975Y
Subsystem 6 - Part No SW: ----------- HW: 480 400 712 16
Component: FrontSensor_D 000 6149
Serial number: 3550001A7230E745739%
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 712 16
Component: FrontSensor_P 000 6149
Serial number: 3560001A7230E74472D2
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 06121604221682
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 895AC34A28734D020A-80DD
Part No SW: 5G1 920 858 B HW: 5G1 920 858 B
Component: KOMBI 304 8311
Coding: 03AD081A7F88CF0502887B0B5400000000000000
VCID: AF2E4DD2F6574332F4-80FB
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005668972
Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
VCID: FCB4AA9E77A168AA01-80A9
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160001990120016424
Coding: 35FFFF
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00018.11.16
Coding: 0001
VCID: CAD83C466DF5061AC3-809F
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000212828010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: B42442BE1F7160EA89-80E1
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0422735008
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0423359837
Coding: 020111
Component: TSG FS 020 0041
Serial number: 251116EKO34972
Coding: 003E13208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012646542
Coding: 111000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9102
ROD: EV_SteerAssisMQB_013.rod
VCID: BA386C863D15969A53-80EF
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GBA02TRWB
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
Component: TSG BFS 020 0041
Serial number: 131116EKC51192
Coding: 003E13208000040000800000
VCID: C2C8146655C5DE5A0B-8097
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012565890
Coding: 091000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 022202000B000400
VCID: C0CC1E6E5BC9CC4A1D-8095
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0751
Coding: 027300020000000051220002001808009F0207F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: B22844A6E5656EDA9B-80E7
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX00GDB
Subsystem 2 - Part No SW: 3G0 919 866 BB HW: -----------
Component: NAR 2017 --- 0525
B11CF 53 [009] - Deactivated
Reset counter: 80
Mileage: 35175 km
Date: 2019.04.03
Time: 19:31:20
Voltage terminal 30: 12.0 V
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 136 mA
SDARS_tuner_status_2-Reception quality: weak_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0570
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 12121612K23013
Coding: 0003070000000201002213548040890084000E100020
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 161121201396
End----(Elapsed Time: 02:03, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
