Hello
Im very sad to say that I have put myself in this sh*tty situation again.
Removed the cluster from a A3 without saving any codings and now it has lost the codings for ABS and the steering wheel (something)
I made a full scan and i upload the file here
I hope I can still get same help as I did with an Audi A1 that I had like 2 months ago
which worked very good
the reason I didnt save it cause I didnt have the VCDS with me which is very stupid of me
But I am really sorry and I hope someone nice here can help me
regards
regards
Sunday,25,March,2018,12:59:53:62265
VCDS Version: 18.1.0.2
VIN: WAUZZZ8PXBA166748 License Plate: UNKNOWN
Mileage: 138230km-85892mi Repair Order: Audi A3 Lost coding
Chassis Type: 8P-AU35 (8P0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 61 62 72 77
VIN: WAUZZZ8PXBA166748 Mileage: 138230km-85892miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 N HW: 03L 906 023 L
Component: 1,6l R4 CR td H23 8864
Revision: --H23--- Serial number: AUX7Z0K4FNC0MB
Coding: 00254016032401080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM16TDI02103L906023N 003010
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 315157F860DA63CD0A-8064
7332 - Mass Air Flow Sensor (G70)
P0103 00 [167] - Signal too High
Mileage: 253332 km
Date: 2016.11.17
Time: 23:03:50
Engine speed: 1110.50 /min
Normed load value: 10.2 %
Coolant temperature: 4 °C
Intake air temperature: 8 °C
Voltage terminal 30: 12.649 V
Engine speed: 0 /min
Battery voltage: 11.2 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
Readiness: 1110 1000
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 G HW: 0AM 927 769 D
Component: GSG DSG AG7 411 9060
Revision: 00041014 Serial number: CU501104276070
Shop #: WSC 44321 001 1048576
VCID: 2D694B88B4E2072D2E-8078
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Reset counter: 10
Mileage: 138238 km
Date: 2016.11.17
Time: 23:02:32
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 1142201209280000881204E890210051390800
VCID: 76DBA4E4C13404F59F-8022
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 8
Mileage: 138238 km
Date: 2016.11.17
Time: 23:17:42
Count: 16387
Count: 13
Count: 20736
Count: 128
Count: 32000
Count: 1
Count: 65280
Count: 15872
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 8
Mileage: 138238 km
Date: 2016.11.17
Time: 23:03:12
Count: 16387
Count: 12
Count: 13056
Count: 8196
Count: 52480
Count: 1
Count: 65280
Count: 7424
Reset counter: 8
Mileage: 138238 km
Date: 2016.11.17
Time: 23:03:12
Count: 16387
Count: 12
Count: 13056
Count: 48
Count: 52480
Count: 1
Count: 65280
Count: 7424
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0170
Revision: 000410 Serial number: 8P0820043BN
VCID: 79C1AFD8302A6B8DF2-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 G HW: 8P0 907 063 G
Component: BCM PQ35 M 107 0615
Revision: 00107 AG
Coding: 46000A2FA0051AC0207040E00000015C421A2AAA004DC12AE4008F800041
VCID: 38476ADC8BA0B2854D-806C
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 8
Mileage: 138238 km
Date: 2016.11.17
Time: 23:02:33
Voltage: 14.60 V
Term 50 On
Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H09 0250
Revision: -------- Serial number: 003JU0023KC3
Coding: 30314238303830303035554A304C38503053
ROD: EV_Airba10AURB4.rod
VCID: 52933874051C78D553-8006
Serial number: 3572DRB40000DA98DACI
Serial number: 3582DRB40000DA98A2C8
Serial number: 35128RB4000061B5B82J
Serial number: 35228RB4000061CA3CCW
Serial number: 35547RB4000062E6BCD1
Serial number: 35647RB4000062E6BA1V
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 46BB14243154D475CF-8012
Component: E0221 H02 0100
Part No SW: 8P0 920 932 G HW: 8P0 920 932 G
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 2244K004078358
Coding: 0256128
Shop #: WSC 50741 143 61874
VCID: 38476ADC4BA0B2854D-806C
Part No SW: 8P0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H43 0311
Revision: H43 Serial number: 020511F2000691
Coding: 352102
VCID: 335D5DF092C651DD78-8066
Revision: D0H01004 Serial number: AUX7Z0K4FNC0MB
Shop #: WSC 00137 211 56823
01176 - Key
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0131252
VCID: 49A11F18204A3B0D22-801C
00943 - Heated Exterior Mirror; Driver Side (Z4)
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 232 3201
Revision: 00H20000
VCID: 345F5EEC57C856E561-8060
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 14.4 V
PD
Temperature: 3.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Reset counter: 8
Mileage: 138238 km
Date: 2016.11.17
Time: 00:03:11
Voltage: 13.50 V
DD
Temperature: 4.0°C
Reset counter: 48
Mileage: 138238 km
Date: 2016.11.17
Time: 00:03:49
Voltage: 12.25 V
DD
Temperature: 5.0°C
Reset counter: 48
Mileage: 138238 km
Date: 2016.11.17
Time: 22:46:25
Voltage: 14.25 V
DU
Temperature: 10.0°C
RPM: 1498 /min
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158086938104
VCID: 365B64E441B444F55F-8062
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0131252
VCID: 4AA32014254C30152B-801E
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
Component: R Concert2+ H03 0293
Revision: 00H03000 Serial number: AUZ1Z3L2303067
Coding: 0710011
VCID: 72D398F46D5C18D5B3-8026
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 0311
Coding: F30B185A
VCID: 74DF9EECD74816E5A1-8020
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370411737
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 06314 000 1012544
VCID: 42B308341D7CE855E3-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 43BD0D300266E15DE8-8016
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005374278
Coding: 0001292
VCID: 74DF9EEC174816E5A1-8020
End-------------------------(Elapsed Time: 01:57)--------------------------
