Lost ABS coding on a 2012 VW Polo
j11
New Member
Hi guys, does anybody know how to get the correct coding for the ABS module once its been lost?
The vehicle is a 2012 VW polo.
Where did you see it last? ;)
Seriously, how did it get "lost"?
In order for anyone to have any real chance of helping you, they're going to need to see an Auto-Scan from this car. That will show the exact ABS module as well as other equipment. There's no guarantee that this will get you a correct coding, but without it, it's pretty much impossible.
automech
Poland
C?ID=14925
If it's Bosch 8.2i system, I will be able to calculate it. Post scan first.
j11
New Member
I can't add image here for some reason but here is the data from the scan:
Address 03: ABS Brakes
Control Module Part Number: 6R0 907 379 BE
Component and/or Version: ESP8.2i front H05 0001
Software Coding: 000000000000000000000000000000000000
Work Shop Code: WSC 00788
VCID: 0200FD2C99EA423179F-8057
automech
Poland
C?ID=14925
ok....... Auto-scan does not look like that... but at least post VIN number (necessary for calculating)
j11
New Member
I've got a copy of the auto scan but i can't upload images and its too much text to add.
Vin number is: WVWZZZ6RZDY111344
automech
Poland
C?ID=14925
Reactions: j11
j11
New Member
Thanks a lot! I'll try it and let you know
j11
New Member
I get error 22 when I try that code 'conditions not correct or request sequence error'
automech
Poland
C?ID=14925
Post a full scan.
LN-TAL
Norway
C?ID=13729
Select all the text in the auto scan file, ctrl + A will do the trick. Then head to this forum, reply to this thread, and if necessary, hit the «Go advanced» button.
You will now see a button with # sign. If you hover the mouse cursor over it, it will say something like «Wrap (code) tags around selected text». Paste your autoscan in the middle of the code tag, and viola :)
riczi82
New Member
Poland
Hi guys, does anybody know how to get the correct coding for the ABS module once its been lost? My VIN number is: WVWZZZ6RZCY125440.
riczi82
New Member
Poland
Yup OP please post an auto-scan to authenticate it or see your importer at local dealer for SVM.
Additionally please get verified to identify the respective ghetto.
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: DRV 17.1.3.0
Datenstand: 20170224 DS267.4
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY125440   KFZ-Kennzeichen:
Kilometerstand: 75500km   Reparaturauftrag:
Fahrzeugtyp: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 37 44 56 69
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY125440   Kilometerstand: 75500km
01-Motorelektronik -- Status: Fehler 0010
03-Bremsenelektronik -- Status: Fehler 0010
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
37-Navigation -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
Adresse 01: Motorelektronik (J0000-CFWA)       Labeldatei: DRV\03P-906-021-CFW.clb
   Teilenummer SW: 03P 906 021     HW: 03P 907 425 A
   Bauteil: R3 1.2 DCM3.7 H08 9505
   Revision: 11003001    Seriennummer:
   Codierung: 00114014002400080000
   Betriebsnr.: WSC 12345 123 12345
   ASAM Datensatz: EV_ECM12TDI03103P906021 001016
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C66AD664FA86697A-8030
3 Fehlercodes gefunden:
14108 - Schalter für GRA (E45)
          P0568 00 [047] - unplausibles Signal
          bestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 106
                    Kilometerstand: 74499 km
                    Datum: 2017.05.31
                    Zeit: 16:26:44
                    Motordrehzahl: 0.00 /min
                    Normierter Lastwert: 0.0 %
                    Fahrzeuggeschwindigkeit: 0 km/h
                    Kühlmitteltemperatur: 78 °C
                    Ansauglufttemperatur: 55 °C
                    Umgebungsluftdruck: 980 mbar
                    Spannung Klemme 30: 12.132 V
                    Verlernzähler nach OBD: 28
                    Geschwindigkeitsregelanlage: Schalterstellung: 00
                    Geschwindigkeitsregelanlage: Status: 00000000
                    Status Klemme 15: On
                    Geber für Motortemperatur im Motorblock: Rohwert: 78 °C
                    Geschwindigkeitsregelanlage: Sollgeschwindigkeit: 0 km/h
15878 - Einspritzventil Zylinder 1 (N30)
          P0201 00 [136] - elektrischer Fehler im Stromkreis
          Warnleuchte EIN - Sporadisch - bestätigt - geprüft seit letzter Löschung
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 2
                    Kilometerstand: 75126 km
                    Datum: 2017.06.16
                    Zeit: 11:14:57
                    Motordrehzahl: 824.75 /min
                    Normierter Lastwert: 24.3 %
                    Kühlmitteltemperatur: 63 °C
                    Ansauglufttemperatur: 23 °C
                    Umgebungsluftdruck: 990 mbar
                    Spannung Klemme 30: 8.281 V
                    Status des Motors: Engine running
                    Raildruckregelung: Status: RPC_TL_IMV_ONLY
                    Mittlere Einspritzmenge: 3.7 mg/stroke
                    Umgebungsluftdruck: 99 kPa
                    Spannung Klemme 30 stabilisiert: 1.0 V
                    Gaspedalweg-Position: 0.0 %
                    Startersteuerung: Interlock- oder P/N-Signal: 00010000
                    Status Klemme 87: On
                    Geber für Motortemperatur im Motorblock: Rohwert: 63 °C
                    Startersteuerung: Klemme 50: 00000000
                    Übersetzungsverhältnis: 0
                    Kraftstoffdruck: 22800 kPa rel
16305 - Steuergerät unplausibel
          P0607 00 [088] - -
          Sporadisch - bestätigt - ungeprüft seit letzter Löschung
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 2
                    Datum: 2000.00.00
                    Zeit: 00:00:00
                    Motordrehzahl: 148.00 /min
                    Spannung Klemme 30: 6.406 V
                    P_L_Wraf_heater_voltage-Voltage: 8.00 V
                    P_L_Wraf_htr_volt_set_point-Voltage: 8.00 V
                    P_L_Wraf_rl_cc_val_cal_cnt2-Value: 0
                    P_L_Wraf_rl_value-Resistance_value: 36.49 KOhm
                    Lambdasondenheizung Bank 1 Sonde 1: Widerstand: 94.301
                    Lambdasonde 1 Bank 1: Spannungsrohwert O2-Signal: -0.0000 mA
                    Lambdasonde Bank 1 Sonde 1: Status-Status: P_L_WRAF_ASIC_FAILURE_DEFINITION
                    Lambdasonde 1 Bank 1: Tastverhältnis Sondenheizung-PWM rate: 100.0 %
                    P_L_Wraf_vmux_cnts-counts: 177.985 counts
                    Lambdasonde 1 Bank 1: Ri-Abgleichwert: 0.953
                    Lambdasonde 1 Bank 1: Spannungswert Ri-Signal: gefiltert: 1.734 V
                    Spannung der Lambdasonde Bank 1 Sonde 1 (Breitbandsonde): 250.000
                    Spannung der Lambdasonde Bank 1 Sonde 1 (Breitbandsonde): 250.000 V
                    P_L_Wraf_ip_temp_compensation-Compensation_value: 0.0487 mA
                    P_L_Wraf_back_pressure_estimate-Back_pressure_estimate: 0.996 bar
                    Kraftstoffdruck: 0 kPa rel
Adresse 03: Bremsenelektronik (J104)       Labeldatei: DRV\6R0-907-37x-ABS82.clb
   Teilenummer SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Bauteil: ABS8.2 front  H03 0001
   Revision: --------
   Codierung: 000000000000000000000000000000000000
   Betriebsnr.: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
1 Fehler gefunden:
01042 - Steuergerät nicht codiert
                    Fehlerstatus: 01100000
                    Fehlerpriorität: 0
                    Fehlerhäufigkeit: 60
                    Verlernzähler: 92
                    Kilometerstand: 75085 km
                    Zeitangabe: 0
                    Datum: 2017.06.10
                    Zeit: 04:16:18
                    Hex Wert: 0x0005
                    Hex Wert: 0x0000
                    Hex Wert: 0x1213
                    Hex Wert: 0x149D
                    Hex Wert: 0x00FF
                    Hex Wert: 0x007F
                    Hex Wert: 0x7F00
                    Hex Wert: 0x0000
Adresse 08: Klima-/Heizungsel. (J301)       Labeldatei: Keine
   Teilenummer SW: 6R0 820 045 M    HW: 6R0 820 045 M
   Bauteil: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 3878F3A28BC8CB8111-806C
Adresse 09: Zentralelektrik (J519)       Labeldatei: DRV\6R0-937-08x-09.clb
   Teilenummer SW: 6R0 937 086 K    HW: 6R0 937 086
   Bauteil: BCM PQ25 M++4 H46 0251
   Revision: BD046001    Seriennummer: 0432 289111394
   Codierung: 3CB02BBF08A1000000200EC02C2B0CD00000410F60060000200000000000
   Betriebsnr.: WSC 12469 483 00190
   VCID: 44809752C7009F618D-8010
   Subsystem 1 - Teilenummer SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labeldatei: 6R0-959-801.CLB
   Bauteil: J386__TSG_FT  008 1611
   Seriennummer: KU0KU013101100017372
   Codierung: 18BC30
   Subsystem 2 - Teilenummer SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labeldatei: 6R0-959-802.CLB
   Bauteil: J387__TSG_BT  008 1611
   Seriennummer: KU0KU012101100015536
   Codierung: 08BC30
4 Fehlercodes gefunden:
03431 - Ansteuerung Standlicht links
            007 - Kurzschluss nach Masse - Sporadisch
                    Fehlerstatus: 00100111
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 129
                    Kilometerstand: 75342 km
                    Zeitangabe: 0
                    Datum: 2017.06.23
                    Zeit: 18:15:12
03432 - Ansteuerung Standlicht rechts
            006 - Kurzschluss nach Plus - Sporadisch
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 129
                    Zeitangabe: 0
                    Datum: 2017.06.23
                    Zeit: 18:15:12
                    Fehlerpriorität: 2
                    Verlernzähler: 129
                    Kilometerstand: 75011 km
                    Zeitangabe: 0
                    Datum: 2017.06.09
                    Zeit: 17:23:03
00968 - Blinkleuchten rechts
            010 - Unterbrechung/Kurzschluss nach Plus - Sporadisch
                    Fehlerpriorität: 2
                    Verlernzähler: 129
                    Zeitangabe: 0
                    Datum: 2017.06.09
                    Zeit: 17:23:03
Adresse 15: Airbag (J234)       Labeldatei: DRV\5K0-959-655.clb
   Teilenummer SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Bauteil: VW10Airbag01M H09 0020
   Revision: --------    Seriennummer: 003GX00Z1RD%
   Codierung: 00314D
   ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 4A9CB96AED24491177-801E
   Crashsensor für Seitenairbag Fahrerseite:
   Seriennummer: 3575HRB40690TGJGGGOF
   Crashsensor für Seitenairbag Beifahrerseite:
   Seriennummer: 3585HRB40510TGJEB0FI
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Seriennummer: 3515RRB40650Q8K6F0C9
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Seriennummer: 3525RRB40650Q8K6H8NV
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei: DRV\5K0-920-xxx-17.clb
   Teilenummer SW: 6R0 920 861 G    HW: 6R0 920 861 G
   Bauteil: KOMBI         H03 0505
   Seriennummer: 00000000000000
   Codierung: 140A00
   ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod
   VCID: 397EF6A6B8C2D289EE-806C
Adresse 19: Diagnoseinterface (J533)       Labeldatei: DRV\6N0-909-901-6R.clb
   Teilenummer SW: 6N0 909 901     HW: 6R0 937 086
   Bauteil: GW-K-CAN TP20 H46 0251
   Revision: BD046001
   Codierung: 002200
   VCID: 70E80B82A33853C119-8024
Adresse 25: Wegfahrsperre (J334)       Labeldatei: DRV\5K0-920-xxx-25.clb
   Teilenummer SW: 5K0 953 234     HW: 5K0 953 234
   Bauteil: IMMO          H03 0505
   Seriennummer:
   Codierung: 000000
   Betriebsnr.: WSC 00000 000 00000
   ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03009
   VCID: 6ADC19EA8DE4A91157-803E
Adresse 37: Navigation
nicht erreichbar
Adresse 44: Lenkhilfe        Labeldatei: DRV\6Q0-423-156.clb
   Teilenummer: 6R0 423 156 B
   Bauteil: LenkhilfeTRW        V277
   Codierung: 10130
   VCID: 2F6AC8FEEA860C3940-807A
Adresse 56: Radio
nicht erreichbar
Adresse 69: Anhänger        Labeldatei: RETROFIT69.lbl
   Teilenummer SW: SW0 408     HW: 5F0 07V 010 1
   Bauteil: TOWBARMODULE ECS    0010
   Codierung: 0000001
   VCID: 76E43D9A015C7DF1C3-8022
Ende----------------------------(Dauer: 02:21)-----------------------------
Adresse 09,6R0 937 086 K,Anpassungskanal 28,geändert von,1,auf,0,
Adresse 09,6R0 937 086 K,umcodiert (Lange Codierung),von,3CB02BBF08A1000000200EC02C2B0CD00000410F60060000200000000000,auf,3CB02BBF08A1000000200EC02C6B0CD00000410F60060000220000000000,(12469/483/00190),
Adresse 09,6R0 937 086 K,umcodiert (Lange Codierung),von,3CB02BBF08A1000000200EC02C6B0CD00000410F60060000220000000000,auf,3CB02BBF08A1000000200EC02C6B0CD00000410F60060000230000000000,(12469/483/00190),
Adresse 09,6R0 937 086 K,umcodiert (Lange Codierung),von,3CB02BBF08A1000000200EC02C6B0CD00000410F60060000230000000000,auf,3CB02BBF08A1000000200EC02C6B0CD00000410F60060000200000000000,(12469/483/00190),
tyretrax
C?ID=322125
scan included
VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4411.4
VIN: WVWZZZ6RZAU031522   License Plate: POLO 6R
Mileage: 126770km-78771mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 37 44 56
VIN: WVWZZZ6RZAU031522   Mileage: 126770km-78771miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine (J623-CAYA)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 BL    HW: 03L 906 023 D
   Component: R4 1.6l TDI   H13 9979
   Revision: --H13---    Serial number:
   Coding: 00114014000500080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023BL 003015
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 71AA3C31A0B9DFCCDB-8024
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Shop #: WSC 02069 000 00000
   VCID: 4DD280C110C1DB2C9F-8018
03306 - Coding Not Valid
                    Reset counter: 91
                    Mileage: 126775 km
                    Date: 2012.12.09
                    Time: 04:24:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1209
                    Hex Value: 0x148F
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
                    Fault Status: 11101100
                    Reset counter: 91
                    Mileage: 126775 km
                    Date: 2012.12.09
                    Time: 04:24:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x12B1
                    Hex Value: 0x098F
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
                    Reset counter: 91
                    Mileage: 126775 km
                    Date: 2012.12.09
                    Time: 04:24:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1211
                    Hex Value: 0x148F
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
                    Fault Status: 01100101
                    Reset counter: 91
                    Mileage: 126775 km
                    Date: 2012.12.09
                    Time: 04:24:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1251
                    Hex Value: 0x1B8F
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
00532 - Supply Voltage B+
                    Fault Status: 10100010
                    Reset counter: 131
                    Mileage: 126775 km
                    Date: 2012.12.09
                    Time: 06:39:09
                    Hex Value: 0x0003
                    Hex Value: 0x0003
                    Hex Value: 0x1224
                    Hex Value: 0x036E
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 A    HW: 6R0 820 045 A
   Component: Climatic      024 0500
   Revision: 2001S024
   VCID: 2C14ED454F1BF224A8-8078
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 7918 km
                    Date: 2010.12.26
                    Time: 16:48:21
                    Reset counter: 131
                    Mileage: 126026 km
                    Date: 2012.11.17
                    Time: 08:59:33
                    Reset counter: 131
                    Mileage: 126775 km
                    Date: 2012.12.09
                    Time: 06:39:14
   Part No SW: 6R0 937 086 D    HW: 6R0 937 086 D
   Component: BCM PQ25 M++4 H46 0207
   Revision: BD046001    Serial number: 0145 338090778
   Coding: 24B02BBF08A10000003000003D2B0CD00000410F60060000200000000000
   Shop #: WSC 31414 790 31414
   VCID: 3D32D001A4616BAC0F-8068
   Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU010.12.0911490
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU014.12.0913078
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU016.12.0914577
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU015.12.0911585
   Coding: 08BC32
                    Fault Frequency: 25
                    Reset counter: 131
00538 - Reference Voltage
                    Fault Status: 00101011
                    Reset counter: 131
                    Reset counter: 107
                    Mileage: 126026 km
                    Date: 2012.11.16
                    Time: 10:25:59
                    Reset counter: 107
                    Mileage: 126027 km
                    Date: 2012.11.17
                    Time: 00:33:43
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag00B H09 0018
   Revision: --------    Serial number: 003DW00CC4UK
   Coding: 003042
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 42C8A3FDD59F145472-8016
   Serial number: 3572SRB40000A6989B2D
   Serial number: 3582SRB40000A1D119B5
   Serial number: 3516GRB40339DB9L2K91
   Serial number: 3526GRB402R9DB9LBCAR
   Part No SW: 6R0 920 961 D    HW: 6R0 920 961 D
   Component: KOMBI         H03 0205
   Coding: 440200
   VCID: 373EC2298E5D41FCD5-8062
   Part No SW: 6N0 909 901     HW: 6R0 937 086 D
   Component: GW-K-CAN TP20 0207
   Coding: 002300
   VCID: 70AC3935A3B3D6C4D4-8024
                    Mileage: 126113 km
                    Date: 2012.11.27
                    Time: 02:59:28
   Component: IMMO          H03 0205
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
   VCID: 6A982B5D8D6F2C149A-803E
   Part No SW: 1T0 035 680 D    HW: 1T0 035 680 C
   Component: RNS-MID       H52 4120
   Revision: AB001001    Serial number: VWZ6Z7L9089026
   Coding: 04000442040000800000
   VCID: 2F2EFA497E0D893C8D-807A
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V12  8195
6 Faults Found:
01523 - Microphone for Telephone (R38)
                    Fault Frequency: 223
                    Reset counter: 91
                    Mileage: 125078 km
                    Date: 2012.08.27
                    Time: 17:07:19
                    Reset counter: 131
                    Mileage: 126027 km
                    Date: 2012.11.17
                    Time: 00:33:01
                    Fault Frequency: 14
                    Reset counter: 131
                    Mileage: 126026 km
                    Date: 2012.11.16
                    Time: 16:40:41
                    Fault Frequency: 35
                    Reset counter: 131
                    Mileage: 125072 km
                    Fault Frequency: 11
                    Reset counter: 107
                    Mileage: 126024 km
                    Reset counter: 107
                    Mileage: 126024 km
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10130
   Shop #: WSC 31414
   VCID: 2E10E74DED07803486-807A
6 Faults Found:
                    Fault Frequency: 35
                    Reset counter: 131
                    Mileage: 125072 km
                    Fault Frequency: 11
                    Reset counter: 107
                    Mileage: 126024 km
                    Reset counter: 107
                    Mileage: 126024 km
                    Reset counter: 91
                    Mileage: 125078 km
                    Date: 2012.08.27
                    Time: 17:07:19
                    Reset counter: 131
                    Mileage: 126027 km
                    Date: 2012.11.17
                    Time: 00:33:01
                    Fault Frequency: 14
                    Reset counter: 131
                    Mileage: 126026 km
                    Date: 2012.11.16
                    Time: 16:40:41
End----------(Elapsed Time: 01:24, VBatt start/end: 12.5V/12.5V)-----------
tyretrax
C?ID=322125
thanks will try in morning , and let u know
thanks
slawa9
New Member
hi mate. can you help me to please. my abs module lost long coding
Control Module Part Number: 6R0 907 379 AK
VIN: WVWZZZ6RZBU057026
FULL SCAN
Sunday,07,October,2018,18:06:11:39140
VCDS Version: 18.2.1.2 (x64)
VIN: WVWZZZ6RZBU057026   License Plate: EJ11VZF
Mileage: 152930km-95026mi   Repair Order:
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBU057026   Mileage: 152930km-95026miles
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 M    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 8319
   Coding: 00110016000400080000
   ASAM Dataset: EV_ECM12MPI02103E906019M 001005
   ROD: EV_ECM12MPI02103E906019A.rod
   VCID: 2E532F0C718FA13485-807A
Readiness: 0010 0101
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0001
   Revision: --------
   VCID: 071DBAA8B2B5D07C66-8052
                    Reset counter: 129
                    Mileage: 152937 km
                    Date: 2013.02.15
                    Time: 21:53:02
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x3209
                    Hex Value: 0x14B2
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Reset counter: 129
                    Mileage: 152937 km
                    Date: 2013.02.15
                    Time: 21:53:02
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x3211
                    Hex Value: 0x14B2
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 F    HW: 6R0 820 045 F
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 3169347068B1BECC98-8064
                    Reset counter: 169
                    Mileage: 152935 km
                    Date: 2011.09.07
                    Time: 22:12:55
   Part No SW: 6R0 937 085 D    HW: 6R0 937 085
   Component: BCM PQ25 M+   H46 0230
   Revision: BB046001    Serial number: 0390 010110938
   Coding: 7CB02BBF08A10040002008003D280C900040410F60060000200000000000
   VCID: 3C771544BFF343A43B-8068
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0-KU003.12.1010622
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0-KU014.12.1013809
   Coding: 08BC30
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00E02G+
   Coding: 003237
   VCID: 4A9B439CED27ED14B9-801E
   Serial number: 3575HRB40550C15I90HM
   Serial number: 3585HRB40590BI7S71VP
   Serial number: 3515RRB405D6V144C9OK
   Serial number: 3525RRB405505MUMDP62
   Part No SW: 6R0 920 960 E    HW: 6R0 920 960 E
   Component: KOMBI         H05 0304
   Coding: 440200
   VCID: 377D0A688ED560FCD6-8062
   Part No SW: 6N0 909 901     HW: 6R0 937 085
   Component: GW-K-CAN TP20 0230
   Coding: 002300
   VCID: 70EFF174A33BF7C4D7-8024
   Component: IMMO          H05 0304
   VCID: 6ADBE31C8DE70D1499-803E
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11250
   Shop #: WSC 31414
   VCID: 2F6D3208EA85A83C8E-807A
   Part No SW: 5M0 035 156 C    HW: 5M0 035 156 C
   Component: Radio         510 0521
   Revision: R0510001    Serial number: VWZ5Z1K0437238
   Coding: 0000020002
   Shop #: WSC 00000 000 31414
   VCID: 2959DC104061C60C50-807C
End-------------------------(Elapsed Time: 02:26)--------------------------
