Audi A6 2006 F4 Rear exterior lighting problem.
Pinpointdiag
Scotland
C?ID=90374
Hi all i am looking for a bit of advice with this job.
The vehicle had been off the road for a few months. It has been at other repair shops before coming to me.
It had ABS and engine management faults that were easy enough to fix. And the customer asked me to
fix a number of lighting faults as well. I left that untill last as i thought that would be easy enough,
I found a few faults, blown bulbs and bad connections but i am left with a fault that is causing a problem.
The car is an A6 avant and has light clusters on the rear wing/fender and the tailgate/trunk lid. The problem is
the left hand outer light unit was full of water and the stop/tail light did not work. Also the tail light bulbs
on the tailgate are illuminating but very dimly.
I replaced the left hand outer light and bulb holder as it was obviosly letting in water and the bulb holder was corroded
However the light still did not work. There are two bulbs in this light unit one is a direction indicator and it functions normally.
The other bulb is the one causing the problem. Its a single filament 21 watt bulb that when lit with full battery voltage lights up as the stop light bulb. And it does that correctly.
But swithched on as the Tail light with a lower voltage. It comes on and flashes twice then goes out and flags the fault code. It will also do this if the brake is applied and it is already lit full voltage.
Now i know the comfort module must have a test stratagy to protect the circuit rather than fuses.
and i know the single filament bulb should light dim or bright depending on function, Tail light or brake light, Therefore two different voltages. I tested all the wiring from the comfort module and all seemed ok but to be sure i cut and swapped the two wires for the left and right side at the comfort module plug and the fault moved to the opposite side.
it also had an after market towbar addaptor. Which i removed just in case.
So at this point it looked like to me that the control module had a fault. so i got a second hand one to try.
With matching part number. after fitting it looked like the fault was fixed and the other four bulbs on the tailgate were now brighter matching the outer one but the coding was obviously wrong as it had new faults with the direction indicators. So i altered the coding to match the original and we are back to the same fault as before.
So It looks to me like the coding has been wrong from the start as the car is righthand drive and the existing
code before i touched it is not high enough to include RHD. I have tried altering the coding to include RHD that made
no difference. There are other options that the car has definately not got - HID front lights or LED rear lights for instance. But there are other options that i am unsure of.
I've refitted the original module as the replacement made no difference but also had component protection enabled.
Could the fault just be incorrect programming? if so how do i find the correct coding? Or do I just have to try all the options. And if it is incorrect coding, could that happen by itself?
Thanks for reading.
Alan.
Thursday,02,April,2020,19:05:08:05279
VCDS Version: 19.6.2.2
VIN: WAUZZZ4F66N135251   License Plate: SC06 GOA
Mileage: 269670km-167565mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53 56
          61 62 72 76
VIN: WAUZZZ4F66N135251   Mileage: 269670km-167565miles
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 HS    HW: 028 101 255 7
   Component: R4 2,0L EDC G000SG  9673
   Revision: --H02---    Serial number:
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 7BF1AF083AF1FF97F0-802E
005512 - Engine Mount Solenoid Valves (N144/N145)
               P1588 - 000 - Open Circuit
                    Mileage: 269671 km
                    Date: 2020.03.31
                    Time: 15:17:24
                    Voltage: 11.70 V
                    Bin. Bits: 00101000
                    Torque: 0.0 Nm
                    Torque: 351.4 Nm
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
                    Mileage: 269671 km
                    Date: 2020.03.31
                    Time: 15:17:29
                    Voltage: 11.70 V
                    Bin. Bits: 00101000
                    Temperature: 11.7°C
                    (no units): 16.0
Readiness: 0 0 0 1 1
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
   Component: ESP 8.0 front   H04 0090
   Coding: 0020855
   Shop #: WSC 02325 785 00200
   VCID: 2C535C548F1FA82F29-8078
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10604000325884
   Coding: 0000145
   Shop #: WSC 00847 210 80521
   VCID: 63C1F768A2412757D8-8036
   Subsystem 1 - Part No: 4F0 910 131 D
   Component: FBSAUDIC6 EZS   H45 0070
   Component: FBSAUDIC6 IDG   H39 0040
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4F0 910 769 B    HW: 4F0 035 769 B
   Component: MMI Cockpit     H55 0010
   Revision: C51500BE    Serial number: AUZ6Z3ECB936F3
   Coding: 0100102
   Shop #: WSC 02323 785 00200
   Component: Bedienteil MMIC6H03 0050
   Subsystem 2 - Serial number: 00000000311409
   Subsystem 3 - Serial number: 0110.01.060000000100011190ÿ
   Subsystem 4 - Serial number: 011190ÿ
   Part No SW: 4F0 910 043     HW: 4F2 820 043 H
   Component: KLIMABETAETIGUNGH12 0170
   Revision: 00000030    Serial number: 00000000220187
   Coding: 0001300
   VCID: 5BB1CF889A311F9790-800E
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 85
                    Mileage: 269671 km
                    Date: 2020.04.02
                    Time: 17:43:40
                    Temperature: 12.0°C
                    Reset counter: 85
                    Mileage: 269671 km
                    Date: 2020.04.02
                    Time: 17:43:40
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0000101
   Shop #: WSC 02335 785 00200
   VCID: 2A5F5A4C85EBB61FDB-807E
   Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H11 0040
   Coding: 00022800
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
Address 0E: Media Player 1        Labels: Redir Fail!
   Coding: 0100102
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4E AIRBAG AUDI8RH29 0280
   Revision: 08H29000    Serial number: 0037LD0CEHJK
   Coding: 0013381
   VCID: 295DA54080EDBD07D2-807C
   Subsystem 1 - Serial number: 6332CSME0E23094F8
   Subsystem 2 - Serial number: 6342CSME0E453D618
   Subsystem 3 - Serial number: 6352QSME087120757
   Subsystem 4 - Serial number: 6362QSME08714A75K
   Subsystem 5 - Serial number: 63734SME086E1F3BG
   Subsystem 6 - Serial number: 63834SME08681B777
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026053510119
   Coding: 0102042
   VCID: 66C7EE7C5173527F3F-8032
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 L
   Component: KOMBIINSTR. M73 H11 0660
   Revision: 00200000    Serial number: 4RA72VWD5
   Coding: 2308443
   Shop #: WSC 00999 067 57207
   VCID: 1E37869CC9A34ABFB7-804A
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 13008061050171
   Coding: ECEE53C43B2104
   Shop #: WSC 02334 785 00200
   VCID: 2759A37896F98B77C4-8072
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBG8234089
   VCID: 1C338C94DFBF58AF59-8048
Address 37: Navigation        Labels: Redir Fail!
   Coding: 0100102
   Component: TSG FA          H12 0080
   Revision: 00-00000
   Coding: 0003610
   Shop #: WSC 02327 785 00200
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01009694450000
   Coding: 0000763
   VCID: 2E57565CB903DA3F07-807A
02738 - Bulb for Tail/Brake Light; Left
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 85
                    Mileage: 269671 km
                    Date: 2020.04.02
                    Time: 17:58:50
Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
   Part No SW: 4F0 910 223 C    HW: 4F0 035 223
   Component: Amp.-ASK        H10 0320
   Revision: 33S00001    Serial number: 01001060202052
   Coding: 0000103
   Revision:             Serial number: 00000000175665
   Coding: 0001104
   VCID: 5EB7C69C89230ABFF7-800A
   Component: TSG BF          H12 0080
   Revision: 00-00000
   Coding: 0003610
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0000111
   VCID: 5DB5C190842511A7EE-8008
Address 56: Radio        Labels: Redir Fail!
   Coding: 0100102
   Revision: 00000000    Serial number: 00000000184828
   Shop #: WSC 00838 210 00659
   VCID: 2341B768E2C1675798-8076
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2512080097
   Coding: 344630393135313035432056413032353132303830303937
   Shop #: WSC 00000 384 00290
02272 - Quiescent Current Stage 1
                    Mileage: 269671 km
                    Date: 2020.04.02
                    Time: 17:44:54
                    Mileage: 269671 km
                    Date: 2020.04.02
                    Time: 17:48:04
02276 - Quiescent Current Stage 5
                    Mileage: 269671 km
                    Date: 2020.04.02
                    Time: 17:48:14
02274 - Quiescent Current Stage 3
                    Mileage: 269671 km
                    Date: 2020.04.02
                    Time: 17:54:45
                    Mileage: 269671 km
                    Date: 2020.04.02
                    Time: 17:54:56
   Coding: 0003074
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Coding: 0003074
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0030
   Revision: 00H09000    Serial number: 11720601003968
   Coding: 0000016
End-------------------------(Elapsed Time: 02:44)--------------------------
gokarty
C?ID=401142
Alan, did you check each fuse in all fuse boxes individually? Also, check all connections the harness using a DMM. It would also help to ensure you have no earth/ground issues
You can try finding a reference scan for your vehicle here
If that doesn't help, the folks over at Ross Tech can search if they have any documented scans for your car
Also, please look at this link, not the same problem as yours but very similar
^^ You can try what's suggested in post #2
Hope this helps!
--gokarty
Pinpointdiag
Scotland
C?ID=90374
Hi, thanks for replying, I have replaced the complete light. The light works at full intensity when the brake is applied. And when the complete circuit from the module to the lamp has been swapped with its counterpart on the opposite side. The fault moved to the opposite side and the bad side works. I tested feeds and earths with dmm and power probe at the outset.
I’m confident there is no feed or earth fault.
The pins from the control module are pin 1 and pin 7 for left hand and right hand, both pins have two wires but only one wire in each is connected as if the harness is utilising the spare wires in other applications.
Unless the wrong bulbs have been fitted some where else.
Thanks again for looking.
Pinpointdiag
Scotland
C?ID=90374
Maybe I should have asked, will I be able to find info on coding or the as built information so I can select the correct coding for the vehicles vin.
Using erWin
I have seen posts for other coding issues where a list has been posted with information that looks like it could be from the RTFB
Regards Alan
Mr. M
Leicestershire, UK
C?ID=256600
That coding definitely looks wrong. Can you post up the build sticker from the spare wheel well?
Pinpointdiag
Scotland
C?ID=90374
https://imgur.com/NiNpQqL
I have found that if I change the code to, for example, with LED the 1 light that’s causing the problem then works as it should.
But the car doesn’t have LEDs so off course other lights then work incorrectly. I have tried other alterations without success.
I’d think I need to work out the correct code.
Pinpointdiag
Scotland
C?ID=90374
https://imgur.com/XhB6wAg
This above from the car.
And I found a pr decoder and got this but I am unsure if it’s any good as nothing seems to apply to the coding calculator
I have never had any problem coding modules on VAG before. But I'm confused with this one.
https://imgur.com/7NRfjS7
Im not sure why these images are not showing up yet. The one in the previos post would not work yesterday and when ilooked today it was there.
Mr. M
Leicestershire, UK
C?ID=256600
If you have not tried it already, try 0001019.
Out of curiosity, what was the coding of the replacement module as delivered?
Because you're linking to imgur pages rather than actual images. An image ends in .jpg, .png, or .gif
I fixed your previous post, as well as he most recent one.
Pinpointdiag
Scotland
C?ID=90374
The fix.
Thanks for correcting my attached photo’s Uwe.
Yes I got the full list of pr codes from Erwin and I think the correct code is 0001019 as you say Mr M. Thanks for checking for me. However the fault was still present.
The wiring to the light with the problem had to be good as when it was swapped at the module with its counterpart on the opposite side the fault stayed on the same pin. And moved to the other light. Proving the wiring. Earth etc.
The wiring diagram showed the second wire at the pin was a redundant wire. Used for a high line version only.
I then noticed if I put the car in reverse and the reversing lights were on the faulty bulb worked. And the code cleared. As soon as I knocked it out of reverse the code returned. Odd but possibly pointing to a bad earth.
I had noticed the four bulbs on the tailgate looked slightly dimmer than the two on the wings, but the lenses of the outer light clusters are much clearer than the inner as if they have been replaced at some time. And all four inners looked the same. All these bulbs are 21w and have duel function from a single filament. Low light output is around 4 volts and you can here them humming so a PWM feed. Anyway previously I had discounted them as being anything to do with it as they were on different pins from the module.
So I then had a closer look at them and found a bad earth at the inner left light cluster. And that was the cause of the problem.
The inner right had tarnished bulb contacts on both bulbs. Different fault same effect. But not enough to switch off the other outer bulb.
So it’s fixed, a high resistance fault on one light that still works causes another light with no fault to fail it’s self test and switch it’s self off. While the faulty one carries on working. Doh. :banghead:
Although the coding may have been incorrect it wasn’t anything to do with the fault. On the up side I found out about how to determine the coding from the build sticker and rtfm.:)
