2017-5N-Tiguan-Sedan-CCTA 2.0 L-Auto Trans-USA J527 STEERING FAULT IN TRANS
Mills83
C?ID=136383
Hello I have a 2017 Tiguan Sedan from a collision center that has had the J527 (Steering Module/Clockspring) replaced. Module was origionaly coded with ODIS. After replacement and coding the wrench light is illuminated in cluster and fault 18275 Powertrain Bus/P1867 Missing message from Steering Wheel J527 set in Auto Trans Module.
Performed capacitive battery reset using a test light and as suspected fault is still latched. Utilizing the VCDS I can see no coding errors in Steering J527 or Auto Trans modules but I would like a second opinion to know if my coding is correct. Also I contacted 2 different dealer parts departments and both tell me there are 3 possible SCCM/Clocksprings available and catalog will not properly specify without reading part number from old part. Unfortunately the tech has tossed the part in the bin and it is long gone! :banghead: I'm suspicious that the vehicle has the wrong part numbers so we have ordered the other potential p/n modules. No ETA yet when they will arrive. Interesting part is if I look up based on VIN on other aftermarket sites they show I have the correct part but I'm not entirely sold given what VW parts tells me. Additionally I pin tested each circuit at J527 and nothing suggests possible opens in data lines down/up stream from module.
Would like help double checking coding in Auto Trans and Steering module J527 please. Also any other insight or suggestions on my situation would be very much appreciated.
Regards Skyler.
Thursday,02,April,2020,09:26:12:41049
VCDS Version: 20.4.0.1
VIN: WVGBV7AX7HK045804   License Plate: VVY233
Mileage: 30040km-18665mi   Repair Order: 330706
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 4C 52 53 5F 62 72
VIN: WVGBV7AX7HK045804   Mileage: 30040km-18665miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 KB    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 3231
   Revision: P3H08---    Serial number:
   Coding: 0423010A190F0060
   Shop #: WSC 00040 028 00001
   VCID: 75EBEE841C616F2E21-8020
Readiness: 0110 0101
   Part No SW: 09G 927 750 PP    HW: 09G 927 750 PP
   Component: AQ 250 6F           3435
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 07348 004 1048576
   VCID: 0E19A16819F73CF680-805A
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527)
                    Reset counter: 201
                    Mileage: 30032 km
                    Date: 2020.03.31
                    Time: 03:30:31
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 CN    HW: 5N0 614 109 CN
   Component: J104   C6 450M VD46 0023
   Revision: --H07---    Serial number: 00000009298375
   Coding: 0005161
   VCID: 79F3E2B430790B4E45-802C
   Part No SW: 561 907 426 F    HW: 561 907 426 F
   Component: AC Manuell    H03 0506
   Revision: 00001K02
   Coding: 0010001002
   Shop #: WSC 00040 028 00018
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1E39D12801178C7610-804A
   Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
   Component: BCM PQ35 B    122 0186
   Revision: BG122001
   Coding: EF1A0A1B80232EC4008800C11000044448010086524D8960648000000040
   VCID: 3D7B36A4A4D1F76E29-8068
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 100517  24  0664
   Coding: 009795
   Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
   Component: J234__005 VW10 HI   5418
   Revision: 36023000    Serial number: 003MAP6KD7H.
   Coding: 0012341
   VCID: 7DFBF6A42451376E69-8028
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000UHVF
   Subsystem 3 - Serial number: 0024.03.170000300000630116ÿ†63
   Subsystem 4 - Serial number: 630116ÿ†6332MTS6341511870ÿ†63
   Subsystem 5 - Serial number: 511870ÿ†6342MTS6265511876ÿ†63
   Subsystem 6 - Serial number: 511876ÿ†6351HTS6VQC3NEKJSÿ†63
   Subsystem 7 - Serial number: 3NEKJSÿ†6361HTS66N23NEKR%ÿ†63
   Subsystem 8 - Serial number: 3NEKR%ÿ†63727TS69OUITEKJ-ÿ†63
   Subsystem 9 - Serial number: ITEKJ-ÿ†63827TS6PK9GTEKJQÿ
   Subsystem 10 - Serial number: GTEKJQÿ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20191025100302
   Coding: 5980040000
   VCID: 0201855895AF489614-8056
   Part No SW: 5N0 920 973 M    HW: 5N0 920 973 M
   Component: KOMBI         H02 1104
   Coding: 221F010000
   Shop #: WSC 00040 028 00058
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3E7931A8A1D7EC7630-806A
   Part No SW: 7N0 907 530 BH    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1682
   Revision:   H57       Serial number: 300517F1000801
   Coding: 356022
   VCID: 77F7E48CC66D1D3E33-8022
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00029.04.17
   Coding: 0001
   Shop #: WSC 00040 028 00008
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 52A17518054F1816E4-8006
   Component: IMMO          H02 1104
   VCID: 6AD1CDF88DDFB0D6BC-803E
   Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0601
   Revision: 13100010    Serial number: 0010982374
   Coding: 0004B4
   Shop #: WSC 00040 028 00056
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 3A713DB8BDFFC0560C-806E
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  010 1505
   Serial number: 00000009890503
   Coding: 000490
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.285 1501
   Revision: 1BH04843    Serial number: 00171430029901
   Coding: 0000258
   VCID: 428145581D2F889654-8016
   Part No SW: 5N0 959 702 H    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0601
   Revision: 15100010    Serial number: 0011004698
   Coding: 0004B4
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 3B7F38BCB2C5F95E17-806E
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  010 1505
   Serial number: 00000009892580
   Coding: 000490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H21       Serial number: 00000000017846
   Coding: 0026156
   VCID: 387527B04BF3D246FA-806C
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 561 035 150 B    HW: 561 035 150 B
   Component: MU-E--ER      056 7227
   Serial number: 23061700010694
   Coding: 02130600FF00000041220001001000009F0000140000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 0C1DAB60A7EB0EE66E-8058
End-------------------------(Elapsed Time: 02:36)--------------------------
Vehicle-specific information
Vehicle Data
Basic data
Make: V
Model Year: 2017
Description: Tiguan 2.0 Track4M147 TSIA6A
Sales Type: 5N21V3
Delivery date: Jul 20, 2018
Engine Code: CCTA
Transmission Code: SGU
Colors
TYPE COLOR
CODE
LACQUER NUMBER (LACQUER BODY/ROOF
NO.) DESCRIPTION
Interior DM Titan Black
Exterior
(Body/roof) D5/D5 LA5J Pacific Blue Metallic/Pacific Blue
Metallic
PR-Numbers
CON.
NO. NO. ORIGIN FAMILY DESCRIPTION
1 0AE L STV Front stabilizer bar
2 0BC L STH Rear stabilizer bar
3 0EW L EDF Installation differentiation for transmission AQ450 -- vehicle components --
4 0F4 L KRS Fuel system for turbo SI engine
5 0FH E FAD Osnabrueck manufacturing sequence
6 0KA L KAE Without decals and emblems
7 0NW L SZU Nameplate set "TSI"
8 0SS L SAU Labels/plates in English and French
9 0TA L ZFM Without floor mats
10 0VM L BTA Information kit in American English
11 0Y4 L KLZ Cold and tropical climatic zones (US)
12 0YF L GKH Weight range 6 installation control only, no requirement forecast
13 1AS L BRS Electronic Stability Control (ESC), including Electronic Differential Lock (EDL)
14 1D8 L AHV Trailer hitch preparation (wiring, bumper, and cross bar with mounting plate)
15 1E4 L AKB Pollen filter / odor filter
16 1EB L TYP Without identification plate
17 1G9 L RER Space-and weight-saving spare wheel
18 1JL L DFH Rear shock absorption
19 1KU L BAH Disk brakes in rear
20 1MG L LRA Steering wheel (3-spoke)
21 1N3 L LEN Electromechanical power steering with variable assistance and active return
22 1NP L RAA Hub cap
23 1PA L ABR Standard wheel bolts
24 1Q1 L TGL Mass damper for steering wheel, 26.5 Hz
25 1S1 L BOW Tool kit and jack
26 1SA L TWU Without additional front underbody guard
27 1T0 L VBK Without first aid kit and warning triangle
28 1U8 L KLT Without folding table on front seat backrest
29 1VG L TWL Installation parts for four-cylinder engine
30 1X1 L ATA 4MOTION® all-wheel drive system
31 1Y0 L DIF Without differential lock
32 1Z2 L KRM Initial fuel filling
33 1ZD L BAV Power-assisted front vented disc brakes and rear solid disc brakes
34 2A8 L UEA Delivery equipment for shipment
35 2G1 L EBB Insert for the filling up of unleaded fuel
36 2H0 L CHA Without Dynamic Drive Control
37 2JC L STF Off-road bumper with increased approach and departure angle in body color,
bumper lower parts and sill in black
38 2UA L SWP Standard design
39 2WA L ZBR Without additional tires
40 3B7 L ZKV LATCH (Lower Anchors and Tethers for Children),child seat anchor points
41 3C8 L SHM 3-point seat belt, center rear with US label
42 3CA L TRW Without partition
43 3FA L DEI Without roof insert (standard roof)
44 3GN L LBH Luggage compartment floor removable
45 3H2 L LER Fold-flat front passenger seat
46 3K0 L SKS Without safety head restraint system
47 3L3 L SIE Front seats with height adjustment
48 3M3 L SZL Passenger car design
49 3S0 L DAR Deletion of roof rails
50 3SB L SFR Standard seats
51 3T9 L KOH Three rear head restraints
52 3TB L SFL Standard seat in front, left
53 3U0 L GPR Without luggage compartment cover
54 3ZD L SHA 3-point safety belts for all seating positions
55 4A0 L SIH Without seat heater
56 4AF L TSV Cloth door trim with front and rear door storage pockets
57 4B0 L SSL Without chrome-plated protective side molding
58 4E0 L SDH Tailgate/trunk lid unlocking from outside
59 4GF L WSS Heat-insulated glass
60 4K0 L TKV 2 radio-frequency remote transmitter key fobs with lock, unlock, trunk release, and
panic button
61 4KC L SSH Green heat-insulating glass
62 4L2 L IRS Dimming breakaway interior rearview mirror
63 4M6 L BEH 2 cup holders, front with cover, 1 in rear
64 4QQ L RSV Front safety belts, heigh-adjustable, with pretensioners and load limiters
65 4U0 L GNF Without luggage nets/pockets on backrests
66 4UM L AIB Driver and front passenger,front and side thorax airbag supplemental restraint
system
67 4X3 L SAB Side Curtain Protection® head airbags, front and rear
68 4ZE L ZIE Black window trime
69 5C1 L KSA Body measures for increased safety requirements
70 5D2 L TRF Carrier frequency 315 MHz
71 5J0 L HES Without rear spoiler
72 5K4 L LAC Transport protection cover (shape- adapted system) with additional transport
protection measures
73 5KN L HIS 40/20/40-split folding rear seat with sliding bench adjustment and rear centerarmrest
with 2 cupholders
74 5MA L EIH Anthracite Metallic interior trim
75 5RR L ASR Right exterior mirror: convex (US)
76 5SH L ASL Left exterior mirror: flat (US)
77 5XX L SON Illuminated visor vanity mirrors for driver and front passenger
78 5ZF L KOV Front headrests
79 6A0 L FEU Without fire extinguisher
80 6E3 L MAS Front center armrest, adjustable, with storage compartment
81 6KL L KUG Chrome-plated radiator grille frame and fins
82 6M0 L GPS Without tie down straps/net/pocket
83 6NC L HIM Headliner
84 6P2 L KZH Rear license plate carrier (NAR)
85 6Q1 L SAG Plastic gearshift knob/handle
86 6SE L KBB Carpeted trunk with compartment light and tie-down hooks in cargo area
87 6T0 L INL Without interior light in footwell
88 6W3 L KZV Front license plate carrier (small, NAR)
89 6XN L ASE Power adjustable and heated exterior mirrors
90 7A0 L CDW Without CD changer/CD player
91 7AG L EDW Anti-theft alarm system with Immobilizer theft-deterrent system
92 7B3 L STD Three 12V power outlets (front/rear center consoles, cargo area)
93 7E0 L WSA Without heat accumulator/auxiliary heater
94 7G0 L FVS Without preparation for VTS (vehicle tracking system)
95 7GB L AGM Emission standard ULEV2
96 7JJ L AED Vehicle class differentiation 5N0-
97 7K6 L RDK Tire Pressure Monitoring System (TPMS)
98 7L3 L SNA Without start-stop system without regenerative braking
99 7M5 L EIL Without protective film for scuff plate
100 7N1 L ALS Sunglasses holder
101 7P4 L LOR Manually adjustable lumbar support
102 7Q0 L NAV Without navigation device
103 7QA L CDR Without CD/DVD for navigation
104 7R4 L SLE Side turn signals and marker lights (turn signals with white lens)
105 7X0 L EPH Without park distance control
106 7Y0 L SPU Without lane change assist
107 8G0 L LIA Without light control
108 8GU L GEN Alternator 140 A
109 8ID L HSW Halogen headlights with clear, lightweight, chip-resistant polycarbonate lenses
110 8K4 L FLS Daytime Running Lights (DRL)
111 8L6 L ANT Window diversity antenna
112 8N4 L SWS Windshield wipers, variable intermittent
113 8Q0 L LWR Without headlight range control
114 8RM L LSE 8 speakers
115 8S5 L LEL 2 reading lights in front
116 8SJ L SBR Rear combination lamp, standard design (NAR)
117 8T0 L GRA Without cruise control system (CCS)
118 8TA L NEL Without rear fog lamp
119 8W1 L WWA Warning light for washer fluid level andfor lamp failure of headlamp, taillamp, and
brake light
120 8WA L NES Without front fog lamps
121 8X0 L SWR Without headlamp washer system
122 8Y1 L SNH Two-tone horn
123 8Z6 L MKU Hot country
124 9A0 L TAA Without taxi alarm system
125 9JF L RAU Non-smoker's package (NAR)
126 9M0 L ZUH Without electric auxiliary heater/ fuel-fired parking heater
127 9P7 L SGK Visual and acoustic seat belt reminder, electric contact in buckle
128 9Q5 L MFA Multi-function trip computer with trip time, length, speed, fuel consumption, current
fuel consumption, miles to empty
129 9T0 L BWD Without heated washer nozzles
130 9WC L AUD Without "Multimedia" in vehicle
131 9Y1 L ATE Outside temperature display
132 9Z0 L BTR Operating voltage 12 V
133 9ZX L VTV Bluetooth® with audio streaming for compatible devices
134 A60 L KRR Category 0
135 A8C I AUS Comfort equipment
136 AV2 L LRV Driving on the right (NAR)
137 B0W L BLB Component parts set, complying with vehicle type for California, various parts
138 BU2 L TPL Legal requirements for USA 2 States with CARB requirement
139 C23 E COC Operating permit, alteration
140 CL1 P RAD 17" Philadelphia alloy wheels
141 D2L I MOT 4-cylinder SI engine 2.0 l/147 kW (16V) turbo FSI, homogeneous, base engine is
T59/T61/TQ2/TU2/TD6/TN6/TL5/T6E
142 E0A L AAU No special edition
143 EL0 L ONL Without online service
144 EM0 L MKE Without driver alert system
145 F0A L FZS No special purpose vehicle, standard equipment
146 FB0 L LAK Standard paint coating
147 FC0 L IND Without customized installation
148 G0R I GSP 6-speed automatic or DSG for four-wheel drive note: family EDF
149 G34 L DFV Shock absorption in front
150 GP1 L PAM Vehicles with special upgrade measures
151 HV0 P REI 17" all-season tires 235/55 R17
152 I6W L RAO Touchscreen sound system with 5.0" color display
153 J1L L BAT Battery 280 A (60 Ah)
154 K8G I KAR Hatchback
155 KA1 L KSU Rearview camera
156 KH6 L HKA Climatic manual single-zone climate control with pollen filter and rear passenger
ventilation in center console
157 KL0 L KZB Standard license plate lighting
158 L03 L GKV Suspension range 03 installation control only, no requirement forecast
159 L0L L LEA Left-hand drive
160 N4C L SIB Woven fabric seating surfaces
161 NY0 L BGK Standard battery/alternator capacity
162 NZ0 L RUF Without call feature
163 QE0 L ALG Without storage compartment package/box
164 QG0 L WIV Without service interval prolongation
165 QH0 L SPR Without voice control
166 QI7 L SEA Service indicator 10 000 miles or 1 year(fix)
167 QJ0 L CHR Without aluminum/chrome package
168 QK0 L KAS Without multifunction camera
169 QN0 L SVS Without drawers under front seats
170 QQ0 L LCP Without add. lights (interior lighting)
171 QR0 L KMP Without compass/road sign display/ dynamic road sign display
172 QV0 L TVE Without TV reception/digital radio reception
173 TQ2 I GMO 4-cylinder SI engine 2.0 l unit 06J.B
174 U5C L INS Instrument cluster, mph speedometer USA
175 UF0 L ESS Without external electric interface
176 UG0 L AFH Without hill start assist/hill descent control/comfort driving assist
177 UH1 L FSB Electric parking brake
178 V0A L REL Tires without specification of tire brand
179 VF0 L FHW Standard pedal cluster
180 VL0 L FGS Standard pedestrian protection measures
181 WZ2 G Wheel package USA MY18
182 X9A G Equipment options subset for USA
Jef
HQ
Coding looks good to me for both TCM and J527. This seems to be a bit of a "base" model vehicle.
Using PL24 to look up the J527 part number... it doesn't give a part number, it states to use a scan tool and see what the original part number is. So I can't say if 5K0 953 569 AL is correct or not....
Do you have a scan of this vehicle BEFORE the J527 was replaced? Or do you have the old part?
Dana
Western PA, USA
I don't see any obvious problems either but NAR market cars are rarely born 8T0 - GRA Without cruise control system (CCS). Tiggy Sue isn't a good baseline since it has the "Premium" package with KESSY and MFSW. I found one scan in our forum based on the 01-Engine coding: 2017 VW Tiquan-S Trailer controller coding help
.. and with the exception of Trailer Retrofit related DTCs ALL of the modules are coded the same. Address 16 however was another part number:
Part No SW: 5K0 953 501 CL HW: 5K0 953 569 AJ
Revision: FF010042 Serial number: 20170706201341
Coding: 5980040000
The old one was tossed so .. if we use that as a trustworthy baseline example the newest replacement for AJ is AL which is already installed.
If this doesn't start to make any sense I'd be tempted to re-code a handful of the modules back to the same value in an attempt to refresh the confusion out of it. Also, Battery Jesus time?
Mills83
C?ID=136383
Thank you gentlemen for the great help I just got back to the car today and they installed a second J527 this time p/n 5K0-953-569-BC. The good news is the wrench light and TCM fault is now gone yay! The bad news is new module won't accept coding giving a "Coding Rejected Error 31 Request out of Range". using coding 5980040000 :banghead: So it seems this module perceives this as improper coding unless there's something in the coding process I'm not aware of like a special login of sorts or requires ODIS not sure? Also is it possible for VCDS to the steering end stop learn once this is resolved? As of now they ordered the 3rd and final possible J527 shown in catalog according to dealer. Part should be here Monday so I'll know more then. Thanks again for the tips guys let me know what you think please thanks so much!
AUTO SCAN AFTER J527 REPLACED FOR 2ND TIME WITH P/N 5K0-053-569-BC
Friday,03,April,2020,17:07:15:41049
04-Steering Angle -- Status: Cannot be reached 1100
   Coding: 0000840
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Fault Frequency: 9
                    Reset counter: 191
                    Mileage: 30032 km
                    Date: 2020.04.01
                    Time: 03:30:31
   Coding: 0005161
   Revision: 00001K02
   Coding: 0010001002
   Revision: BG122001
   Coding: 009795
                    Reset counter: 70
                    Mileage: 30041 km
                    Date: 2020.04.03
                    Time: 00:34:44
                    Voltage: 11.65 V
   Coding: 0012341
   Part No SW: 5K0 953 569 BC    HW: 5K0 953 569 BC
   Component: LENKS.MODUL   018 0230
   Revision: --X01---    Serial number: 20190621200302
   Coding: 4882400000
   Shop #: WSC 01286 386 08256
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7AF1FDB8FD7F00564C-802E
365080 - Controls in Steering Wheel
                    Reset counter: 70
                    Mileage: 30041 km
                    Date: 2020.04.03
                    Time: 01:21:59
   Coding: 221F010000
   Coding: 356022
                    Reset counter: 70
                    Mileage: 30041 km
                    Date: 2020.04.03
                    Time: 01:36:01
   Coding: 0001
16653 - Databus
                    Fault Frequency: 11
                    Reset counter: 70
                    Mileage: 30041 km
                    Date: 2020.04.03
                    Time: 00:34:41
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
                    Fault Status: 11100100
                    Fault Frequency: 11
                    Reset counter: 70
                    Mileage: 30041 km
                    Date: 2020.04.03
                    Time: 00:34:41
                    (no units): 4.0
                    Voltage: 11.70 V
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
End-------------------------(Elapsed Time: 02:37)--------------------------
Reactions: Jef
Jef
HQ
Then I think you still have a wrong J527 part number
5980040000 coding breaks down as follows:
Byte 0 : 59
  • Bit 0 = G85
  • Bit 3 = Auto trans but no kessy
  • Bit 4 = rear wiper
  • Bit 6 = trip computer via wiper staulk
Byte 1 : 80
  • Bit 7 = ignition switch via J527
Byte 2 : 04
  • Bit 2 = horn only with Term15
Byte 3 : 00
Byte 4 : 00
The currently installed J527 is coded to 4882400000
Byte 0 : 49
Missing Byte 0 for G85
Byte 1 : 82
Byte 2 enabled for multi function steering wheel
Byte 2: : 40
See if the currently installed J527 accepts coding of 4982400000. This just adds G85 steering angle. My guess is it won't. I find 3 examples of 5K0 953 569 BC and non of them have G85 enabled.
Mills83
C?ID=136383
To illustrate coding error prompt as presented by VCDS
Mills83
C?ID=136383
Just to show how base model this car is
Mills83
C?ID=136383
Limited badge on the back hmm I didn't see that listed in the build sheet.....
Mills83
C?ID=136383
Coding: 5980040000
Nice job researching that Dana thank you! You make great points and I agree the 17 VW Tiguan in archives seems to be a match minus the additional trailer module and all fitted modules are a perfect match in coding. Further down in thread I posted a picture of the Steering wheel and you can see it's not equipped with cruise or buttons. I'm not sure how VW does it but when the suffix letter changes in module part number do we assume it's a newer/updated superseded part and won't likely present any compatibility issues? if that's the case then I see little reason to think moving from back from the AL back to the older AJ would be of any value in this case but I'll defer to you with that thought.
Today I installed the second J527 dealer test part 5K0-953-569-BC (We had previously installed the AL). Wrench light went out and trans fault now clears. But I get coding rejected error 31 when attempting to code it with what we've agreed is likely the correct coding for the car 5980040000. I did go for the battery reset and no miracles achieved. Body shop decided to get the third J527 listed by dealer which he says is the AK and should have it Monday. Seems that is just the previous part to the AL series so I have my doubts. Going to get back with it Monday. Throwing out old parts and a very inadequate dealer parts catalog is sure creating a lot of confusion to what should probably be an easy job :banghead:
Just want to make sure I'm not chasing my tail here but are you sure the VCDS software is up for the task with this car? It definitely doesn't require any special online login to code this particular module and VCDS will be able to perform the steering end stop learns after it's coded?
Mills83
C?ID=136383
Byte 0 : 59
  • Bit 0 = G85
Byte 1 : 80
Byte 2 : 04
Byte 3 : 00
Byte 4 : 00
Byte 0 : 49
Byte 1 : 82
Byte 2: : 40
Thanks Jef for your research and insight with this car. I wish it wasn't true but yes they tossed the old part and no pre scan was done sadly so we're shooting from the hip with this one! I can try the test coding you posted Monday and see if it's accepted. Like I asked Dana I do want to make sure that the VCDS is up for the task with this car. You feel confident the J527 doesn't require any online security login on this car. Also it can take car of the steering end stop setting after? I just want to make sure I'm not overlooking something simple. Hope it doesn't require ODIS but either way just need to know.
FOD!
It would be wise to install correct part number!
Jef
HQ
Every car sold since maybe 2008 or 2009 should have at least 1 paperless report (like an auto-scan, but with a lot of trash tossed in) from when the PDI was done. There should be a paperless report on this. I'm 99.9% sure you have a wrong part number... call up the VW parts department and request they pull up a paperless report. That should have the original part number listed, as well as coding. The folks in the parts department may not know how to pull paperless reports, but they do have access... they may need to get some one from service to show there were to find the info.
To any one else who stumbled across this thread....
Vehicle Identification No.WVGBV7AX7HK045804
ModelTiguan 4Motion
TIG
Date of production26.07.2017
Model year2017
Sales type5N21V3
Engine CodeCCTA
Transmission CodeSGU
Did you follow instruction of microfiche?
Did you accommodate? 5K0-953-259B well did you?
Special editionsE0ANo special edition
Lockable wheel bolts1PAStandard wheel bolts
Vehicle class differentiation units/platform components7JJVehicle class differentiation -5N0-
Hill start assistUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard7GBEmission standard ULEV 2
Trailer hitch1D8Trailer hitch preparation
airbag4UMAirbag für Fahrer und Beifahrer (NAR) mit Beifahrer-Airbag-Deaktivierung (zweistufig)
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Storage compartment packageQE0Without storage compartment package/box
Storage compartment7N1Overhead storage compartment
Aerials8L6"diversity" window antenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X1Four-wheel drive
Outside temperature display9Y1Outside temperature display
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8CComfort equipment
Brake type in rear1KUDisc brakes in rear
batteriesJ1LBattery 280 A (60 Ah)
Brake type, front1ZDDisc brakes in front (Geomet D)
Beverage holders4M6Beverage holders
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0WComponent parts set, complying with vehicle type for California, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ASElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
Chrome packageQJ0Without aluminum/chrome package
General operating permit, alterationsC23Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAWithout roof insert (standard roof)
Suspension system in rear1JLRear shock absorption
Suspension system in frontG34Shock absorption in front
Differential lock1Y0Without differential lock
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Installation differentiation for components0EWInstallation differentiation for transmission AQ450 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MADecorative inserts
Scuff plates7M5Without protective film for scuff plate
Park distance control7X0Without park distance control
Electric interface for external use UF0Without external electric interface
Manufacturing sequence differentiation0FHOsnabrueck manufacturing sequence
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K4Separate daytime running light -- NAR --
Parking brakeUH1Parking brake
Vehicle tracing system7G0Without preparation for VTS (vehicle tracking system)
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YFWeight range 6 installation control only, no requirement forecast
Weight category front axleL03Suspension range 03 installation control only, no requirement forecast
Base engineTQ24-cylinder SI engine 2.0 l unit 06J.B
Luggage netting/pocket on backrest(s)4U0Without luggage nets/pockets on backrests
Luggage compartment cover3U0Without luggage compartment cover
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T0Without cruise control system (CCS)
Transmission specificationsG0R6-speed automatic transmission for four-wheel drive
Rear spoiler5J0Without rear spoiler
Molded headliner6NCMolded headliner
Rear seats5KNRear seat bench/backrest, split folding
Heating and air-conditioning systemKH6Air conditioning system with electronic control
Headlamps8IDHalogen twin headlamps
Customized installationFC0Without customized installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8GHatchback
Camera/distance sensorQK0Without multifunction camera
Luggage compartment floor covering6SELuggage compartment floor covering in flat needle-punched nonwoven
Folding table1U8W/o folding table on front seat backrest
Climatic zones0Y4Cold and tropical climatic zones (US)
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Rear head restraints3T9Three rear head restraints
Head restraints5ZFFront head restraints
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Tire categorizationA60Category 0
Fuel systems0F4Fuel system for turbo SI engine
Body measures5C1Body measures for increased safety requirements
Camera systems/accident sensorsKA1With rear view camera system (type 1)
Radiator grille6KLRadiator grille
License plate lightingKL0Standard license plate lighting
Rear license plate carrier6P2Rear license plate carrier (NAR)
Front license plate carrier6W3Front license plate carrier (small, NAR)
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GNVariable luggage/load compartment floor
Light package (lighting)QQ0Without add. lights (interior lighting)
Steering system arrangementL0LLeft-hand drive
Reading lamp8S52 reading lights in front
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H2Backrest release for right front seat
Light control systems8G0Without Light Assist
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels1MGSteering wheel
Driving on the left/on the rightAV2Driving on the right (NAR)
Speaker installation8RM8 speakers (passive)
Headlight range control8Q0Without headlight range control
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q5Multi-function display with control
Driver alert systemEM0Without driver alert system
Engine cooling8Z6Hot country
Engine specificationsD2L4-cylinder SI engine 2.0 l/147 kW (16V) turbo FSI, homogeneous, base engine is T59/T61/TQ2/TU2/TD6/TN6/TL5/T6E
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WAWithout fog lights
Online servicesEL0Without online service
Upgrading measuresGP1Vehicles with special upgrade measures
Hubcaps1NPHub cap
WheelsCL1Alloy wheels 7J x 17
RadiosI6WMIB2 Entry PQ radio NAR
Smoker's/non-smoker's package9JFNon-smoker's package (NAR)
Tire pressure monitoring system7K6Tire pressure monitoring system
tireHV0All-season tires 235/55 R17 99H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G9Space-saving spare wheel for temporary use, radial tire (5-hole)
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
Call featureNZ0without emergency call control unit
WZ2Tire package for USA MY18
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q1Gearshift knob/handle in plastic
Special labels/plates0SSLabels in English and French
Tail lamp assemblies8SJRear combination lamp, standard design (NAR)
Locking mechanism for boot lid/cover rear4E0Tailgate/trunk lid unlocking from outside
Service indicatorQI7Service indicator 10 000 miles or 1 year (fix)
Front seat, left3TBStandard seat in front, left
Front seat, right3SBStandard seat in front, right
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN4CSeat trim covers in fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0Without seat heater
Safety head restraint system3K0Without safety head restraint system
Side lights7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Start-stop system/regenerative braking7L3Without start-stop system without regenerative braking
Horns8Y1Two-tone horn
sun visors5XXSun visors with mirror, illuminated (NAR)
Audio-response system/voice controlQH0without voice control
Lane change assist/lane keeping system7Y0Without lane change assist
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B0with no protective side strip
power outlet7B312-volt outlet(s)
Bumper2JCComfort bumpers
Rear stabilizer bar0BCRear stabilizer bar
Front stabilizer bar0AEFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M3Passenger car design
Nameplate set0NWNameplate set "TSI"
Special alarm systems9A0Without taxi alarm system
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5 Hz
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsBU2Legal requirements for USA 2 States with CARB requirement
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAWithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Assembly parts for engine (drive bearing)1VGInstallation parts for four-cylinder engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBOhne Typschild
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first aid kit and warning triangle
Telephone / telematics9ZXTelephone preparation for cellphone
LongLife Service RegimeQG0Without LongLife Service Regime
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TAwithout floor mats
Decorative trims4ZEBlack decorative trims
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Auxiliary heating system9M0Without auxiliary heater/parking heater
Mills83
C?ID=136383
Okay the dealer sent 2 more test SCCM modules. First Installed module ending in AS and that unit was completely wrong so much that vehicle wouldn't even power mode on. So I installed the next unit ending in AK. It accepted coding and basic settings just fine. Unfortunately the fault in trans "18275 - Powertrain Data Bus / P1867 - 000 - Missing Message from Steering Wheel (J527) is set and wrench is back in cluster. Essentially back to where I started from replacement module 1. The body shop is called dealer and is waiting for paperless report as suggested by Jef so we can verify p/n coding etc before any more work is done from this point forward.
Auto Scan with new SCCM J527 ending in AK
Monday,06,April,2020,16:35:21:41049
VIN: WVGBV7AX7HK045804   License Plate: 18666
   Coding: 0000840
                    Fault Frequency: 14
                    Reset counter: 201
                    Mileage: 30032 km
                    Date: 2020.04.02
                    Time: 03:30:31
   Coding: 0005161
   Revision: 00001K02
   Coding: 0010001002
   Revision: BG122001
   Coding: 009795
   Coding: 0012341
   Part No SW: 5K0 953 569 AK    HW: 5K0 953 569 AK
   Revision: --X01---    Serial number: 20191129200260
   Coding: 5980040000
   VCID: 01038A5490A9538E0D-8054
   Coding: 221F010000
   Coding: 356022
   Coding: 0001
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
End-------------------------(Elapsed Time: 02:27)--------------------------
Psssttt...... Where oh where is your Kessy?
Hey VWatttts dis do do.....?
Coding: 5980040000
Part No SW: 5K0 953 501 DM HW: 5K0 953 569 AP
Coding: 110A140000
Coding: 5980040000
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 J HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1403
Revision: Serial number:
Coding: 032C0C
Address 01: Engine (CCT)       Labels: None
   Coding: 0423010A190F0160
   Part No SW: 09G 927 750 PP    HW: 09G 927 750 NK
   Coding: 0000840
Address 03: ABS Brakes        Labels: None
   Component: J104   C6 450M VD13 0023
    Coding: 0005161
   Coding: 032C0C
   Revision: 00001K02
   Coding: 0010001002
   Revision: BG122001
   Coding: EF1A0A1B80232EC4008800C11000044448010086564D89F064800000A040
   Coding: 0012341
   Coding: 110A140000
   Coding: 221F010000
   Coding: 356022
   Serial number: HA1-00023.03.17
   Coding: 0001
   Coding: 000007
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Coding: 4900000000000000
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Revision:   H20       Serial number:
   Coding: 0026156
   Part No SW: 5C0 035 200 D    HW: 5C0 035 200 D
   Component: MU-S-S-US     H41 0447
   Coding: 02130600FF00000011220001001808009F0100D40020010002
0x09 differences compare.........?
Compare all modules to scans of net yet?
Coding: EF1A0A1B80232EC4008800C11000044448010086524D896064 8000000040
Mills83
C?ID=136383
"Did you follow instruction of microfiche?"
Well I've certainly been trying to :confused:
"Did you accommodate? 5K0-953-259B well did you?"
Not sure about that number it comes up as a $5 cover :)
It was a hint just like all the other posts, with me you must join the KDF program and work with power though joy to extricate yourself.
Mills83
C?ID=136383
Coding: 5980040000
Coding: 110A140000
Coding: 5980040000
Coding: 032C0C
   Coding: 0000840
    Coding: 0005161
   Coding: 032C0C
   Revision: 00001K02
   Coding: 0010001002
   Revision: BG122001
   Coding: 0012341
   Coding: 110A140000
   Coding: 221F010000
   Coding: 356022
   Coding: 0001
   Coding: 000007
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
"Psssttt...... Where oh where is your Kessy?"
Looking at vehicle and options report this car doesn't appear to have the Kessy J518 Steering Lock.
Looking at vehicle and options report this car doesn't appear to have the Kessy J518 Steering Lock.​
Yes but scans on net show otherwise and with same build, maybe there is a discrepancy huh?
Sometimes the book is wrong is all I'm saying, that is why further cross checks are needed, no?
