- Joined
- Oct 17, 2017
- Messages
- 982
- Reaction score
- 505
- Location
- Northwest UK
- VCDS Serial number
- C?ID=321059
Greetings
Please ignore all errors as the car has a flat battery and was involved in an accident and is being charged up. I'll post a proper scan when I've finished the body repairs.
It is a 2014 Golf MK7 that has Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H ABS pump which I'm pretty sure is not compatible with blind spot assist, unless someone can advise otherwise.
I think it'll need to be changed to a 3Q0 one. If so would there be any recommendations someone could make or wold any 3Q0 part number suffice? Would it be possible to recode a second hand ABS module or am I better avoiding this altogether??
VCDS Version: 18.9.1.0 (x64)
Dealer/Shop Name: VW UK
VIN: WVWZZZAUZEP074956 License Plate: BLUE
Mileage: 52284km-32487mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP074956 Mileage: 52284km-32487miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 011D0012036505082000
Shop #: WSC 00028 028 00072
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AFC4FC4FDD1809A93-802E
21605 - Sensor for Ambient Air Temperature (G17)
P0070 00 [175] - Malfunction
Mileage: 52285 km
Date: 2018.11.24
Time: 14:05:53
Coolant temperature: 35 °C
Intake air temperature: 40 °C
Voltage terminal 30: 12.540 V
Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 184.6 °C
Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: -0.0 °C
Particle filt.inlet temp.sens.1 bank 1: raw value: 38.9 °C
Particle filter outlet temp.sens.1 bank 1: raw value: 25.3 °C
Shut-off timer: last engine shut-off time: 5 s
U0428 00 [032] - -
Mileage: 52284 km
Date: 2018.12.04
Time: 00:00:12
Coolant temperature: 6 °C
Intake air temperature: 5 °C
Voltage terminal 30: 11.640 V
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [047] - -
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:23
Engine speed: 2397.50 /min
Normed load value: 100.0 %
Vehicle speed: 56 km/h
Coolant temperature: 91 °C
Intake air temperature: 105 °C
Voltage terminal 30: 14.540 V
Limitation: accelerator pedal: 418.9 Nm
Cruise Control System (CCS): status-Bits 0-7: 0
selected gear-Bits 0-7: 3
Readiness: 1 1 0 0 0
Part No SW: 0D9 300 040 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4305
Revision: 03252204 Serial number: TFK01401250588
Shop #: WSC 00028 028 00066
ROD: EV_TCMDQ250021.rod
VCID: 224C57A435C1285AEB-8076
21159 - Gear R
P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Component: ESC H31 0557
Revision: 00000000 Serial number: 6054400000042F
Coding: 01FA8AA1242709700380060541C92980512490C0608294F3F8625078C202
Shop #: WSC 00028 028 00241
VCID: 7CF049DCF7E5BEAA81-8028
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 250
Mileage: 52284 km
Date: 2018.12.04
Time: 00:01:03
8192 - Databus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:23
8196 - Databus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:23
Reset counter: 210
Mileage: 52284 km
Date: 2018.12.04
Time: 00:01:03
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00120104202100001000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 35669CF8944FAFE23E-8060
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.29
Time: 08:55:58
Outside air temperature: 63.0 °C
Engine speed: 900 /min
Temperature after evaporator: 7.0 °C
System run time-Engine running time: 2 s
System run time-Terminal 15 on: 6 s
459527 - Databus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 14:05:54
1048834 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Fault Frequency: 20
Reset counter: 245
Mileage: 48603 km
Date: 2018.09.28
Time: 08:01:21
Voltage terminal 30: 11.4 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
Auxiliary heater: in stages-Act.val.: 1
P1719 00 [008] - -
Fault Frequency: 76
Reset counter: 248
Mileage: 48249 km
Date: 2018.09.24
Time: 04:20:09
Voltage terminal 30: 13.9 V
Auxiliary heater: in stages-Act.val.: 3
B10CD 00 [008] - -
Reset counter: 250
Mileage: 52284 km
Date: 2018.12.04
Time: 01:14:56
Voltage terminal 30: 10.6 V
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011405501740
Coding: 03001842C241027B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
VCID: 79FE50C8F8D78B829A-802C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140216 042 0551
Serial number: 140218200751
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y14M02D28H03M27S12S8
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140340CLY
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000028780639
7 Faults Found:
5386 - Bulb for Front Right Turn Signal
B11EA 15 [009] - Open or Short to Plus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:23
6922 - Bulb for Low Beam Headlamp Right
B1218 15 [009] - Open or Short to Plus
Reset counter: 210
Time: 00:00:00
8714 - Bulb for Left Fog Lamp
B121F 15 [009] - Open or Short to Plus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.29
Time: 09:04:32
8970 - Bulb for Right Fog Lamp
B1220 15 [009] - Open or Short to Plus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.29
Time: 09:04:25
137217 - Outside temperature sensor
B103F 1B [009] - Resistance Too High
Fault Frequency: 12
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 14:05:52
204546 - Remote key 2
Reset counter: 14
Mileage: 43719 km
Date: 2018.07.31
Time: 09:04:02
550420 - Databus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:23
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331403702212
Coding: 0071151011
VCID: 3E7483D4A1796CBAEF-806A
7 Faults Found:
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Reset counter: 250
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:30
1112596 - Front Right Parking Aid Sensor
B10FA 14 [009] - Open or Short to Ground
Reset counter: 210
Mileage: 52284 km
Date: 2018.12.13
Time: 03:18:25
1112084 - Front Left Center Parking Aid Sensor
B10F8 14 [009] - Open or Short to Ground
Reset counter: 210
Mileage: 52284 km
Date: 2018.12.13
Time: 03:18:25
1112340 - Front Right Center Parking Aid Sensor
B10F9 14 [009] - Open or Short to Ground
Reset counter: 210
Mileage: 52284 km
Date: 2018.12.13
Time: 03:18:26
1111826 - Front Left Parking Aid Sensor
B10F7 12 [009] - Short to Plus
Reset counter: 210
Mileage: 52284 km
Date: 2018.12.13
Time: 03:18:52
13637426 - Databus
Reset counter: 250
Mileage: 52284 km
Date: 2018.12.04
Time: 00:01:03
13637888 - Databus
Fault Frequency: 9
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 14:05:52
Address 13: Auto Dist. Reg
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR03W5K4
Shop #: WSC 00028 028 00061
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F0ABED0E6F3A5B2A4-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B28021450347
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B27021450365
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 402 14
Serial number: 35767000000705E00F0Q
Subsystem 4 - Part No SW: ----------- HW: 480 002 702 14
Serial number: 35867000000A4B251F0Y
Subsystem 5 - Part No SW: ----------- HW: 480 402 502 14
Serial number: 3516502BB142B1C08210
Subsystem 6 - Part No SW: ----------- HW: 480 402 802 14
Serial number: 3526502A312F6292D3FI
Subsystem 7 - Part No SW: ----------- HW: 480 402 402 14
Serial number: 3556502C112F62954096
1054981 - Databus
Fault Frequency: 9
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 14:05:56
1050117 - Databus
Reset counter: 250
Mileage: 52284 km
Date: 2018.12.04
Time: 00:01:03
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 03031404220519
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7BF24AC0F2EBB99288-802E
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 252 2210
Coding: 27A419082780260001886A01040000
VCID: 2858458C53FDC20AB5-807C
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 250
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:26
16776960 - Databus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:22
16776961 - Databus
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:22
13639936 - Databus
Fault Frequency: 13
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 14:05:52
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 04031410800267
Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_010.rod
VCID: 3F8AFED0A67365B2E4-806A
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H15 0038
Serial number: 29140000230530104075
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 5289432703
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
Fault Frequency: 21
Reset counter: 210
Mileage: 52284 km
Date: 2018.12.04
Time: 00:01:04
Supply voltage: Terminal 30: 11.5 V
Terminal 15: On
66054 - Extended CAN Bus (SAE Bus C)
U0047 00 [008] - Performance
Fault Frequency: 17
Reset counter: 250
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:25
Supply voltage: Terminal 30: 14.6 V
Terminal 15: On
65798 - Extended CAN in One-Wire Mode
U0054 00 [008] - -
Reset counter: 250
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:27
Terminal 15: On
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000093468588
Coding: 003B0220D001048000001000
VCID: 4480F13CCF95066AB9-8010
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004375448
Coding: 0D0000
65558 - Heated Exterior Mirror
B11F8 14 [009] - Open or Short to Ground
Fault Frequency: 21
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:37
65650 - Turn Signal in Exterior Mirror
B11FD 13 [009] - Open Circuit
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:23
65654 - Motor for mirror fold-in
B11F6 13 [009] - Open Circuit
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 14:16:14
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 418EF828D087134292-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000093350543
Coding: 003B0020DE01048000801000
VCID: 4382F220CA9B015280-8016
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004391698
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 874 HW: 5G0 035 874
Component: MU-S-ND-ER 040 0430
Serial number: V7F02202142644
Coding: 02730001FF00000021111201002800001F0100160100010045
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 67DA06B09E630D727C-8032
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NJ9037N4
Subsystem 2 - Part No SW: 5G0 919 866 F HW: -----------
Component: ECE 2014 --- 0036
6917 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 250
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:27
Voltage terminal 30: 14.4 V
6939 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 250
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:26
U1111 00 [009] - -
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:30
Voltage terminal 30: 14.5 V
BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 210
Mileage: 52285 km
Date: 2018.11.24
Time: 13:46:29
