So I took the plunge and added a 2013 Audi Allroad Premium Plus to my collection.
I got the car home and did it's first VCDS scan. I did the scan with the engine off and the key in the "ignition" slot. I have only used my HEX-CAN VCDS for my 2005 Allroad. I'm getting a few "Fault Codes" some of which I know about or understand and then some I do not. Here is some of my scan:.. I will only post "Status: Malfunction 0010" to save some boring details... haha I will also list a # for each for easy replies. Thanks in advance...
ALSO, if the car has a fault code, do these fault codes stay in memory and can not be cleared because I see the dates and they are older. I have not tried to clear any faults since I just got this car and want to make sure everything is good.
MALFUNCTION #1
Address 01: Engine (DET-CPMA) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0008
Revision: ECH09---
Coding: 722A0013242600062000
Shop #: WSC 29412 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
ROD: EV_ECM20TFS0118K5907115F.rod
VCID: 35617EAC944F33ECC7-8060
1 Fault Found:7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [044] - -
Mileage: 126315 km
Date: 2017.07.17
Time: 11:33:33
Engine speed: 1299.00 /min
Normed load value: 27.8 %
Coolant temperature: 30 °C
Intake air temperature: 27 °C
Voltage terminal 30: 13.829 V
selected gear-Bits 0-7: 0
MALFUNCTION #2
Part No SW: 8K9 907 379 M HW: 8K9 907 379 M
Component: ESP8 quattro H09 0100
Coding: 0E1D18
Shop #: WSC 06334 000 00000
VCID: 4C973B48EFC5522488-8018
02214 - Tire Pressure Warning
Reset counter: 138
Mileage: 140820 km
Date: 2018.04.23
Time: 08:50:59
Hex Value: 0x5100
Hex Value: 0x4006
Hex Value: 0x1221
Hex Value: 0x1BAF
Hex Value: 0x0000
MALFUNCTION #3
Part No SW: 8K1 820 043 N HW: 8K1 820 043 N
Revision: C1000000 Serial number: 01030420121313
Coding: 6480208000
Shop #: WSC 06335 000 00000
VCID: 336540B4923B2DDCE9-8066
03270 - Ventilation Reduced due to Engery Management
Reset counter: 139
Mileage: 139682 km
Date: 2017.12.07
Time: 07:31:41
Bin. Bits: 01
03269 - Functionality Linited due to Energy Management
Reset counter: 127
Mileage: 140708 km
Date: 2018.01.16
Time: 13:14:03
MALFUNCTION #4
Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H10 0025
Revision: 1Y030014 Serial number: 1441Y123260163
Coding: 00C303FF00
VCID: 3F8D1C84AE73F9BC1D-806A
Serial number: 0307597001
02252 - Generator
Reset counter: 101
Mileage: 126315 km
Date: 2017.07.17
Time: 11:34:28
Bin. Bits: 11111
Voltage: 14.00 V
Count: 6
Bin. Bits: 10000
Fault Frequency: 9
Reset counter: 127
Mileage: 140707 km
Date: 2018.01.15
Time: 08:11:28
Bin. Bits: 10111
Voltage: 11.30 V
Reset counter: 127
Mileage: 140708 km
Date: 2018.01.16
Time: 13:13:44
Bin. Bits: 11111
Voltage: 10.50 V
Count: 6
