Possible ASAM Data missing
Somnus
SLC, USA
C?ID=215931
So, this is the first time using HEX-NET wirelessly with VCDS-Mobile. I run an auto-scan on my 2017 GTI and, as expected, there is no ASAM data for it stored on my HEX-NET yet.
After completing the auto-scan it prompts me to download ASAM data, which I did, and now it it seems to be in an update loop in which it continually says "updated rod data needed" when trying to update it via VCDS Interface Config.
Attached is the auto-scan after "Updating" my HEX-NET as well as the HEX-NET's info.
VCDS Mobile 0.4411.0.4
VIN: 3VW4T7AU4H
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU4H
Address 01: Engine  (CXCA J623)	Labels: 5G-01.lbl
	Part No SW: 5G0 906 259 L	HW: 06K 907 425 B
	Revision: --H13---
	Coding: 091D00124424002F0000
	Shop #: WSC 00066 790 00149
	ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
	ROD: N/A
	VCID: 3731B8DF3A950CC913296186F5-8062
	No ASAM data for: "EV_ECM20TFS0205G0906259L"
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Part No SW: 0D9 300 042 S	HW: 02E 927 770 AS
	Component: DQ250-6F MQB  H54 5007
	Revision: 06454104
	ROD: N/A
	VCID: 29156EA7FC21AA39959DC7FE23-807C
	No ASAM data for: "EV_TCMDQ250021"
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Part No SW: 5Q0 614 517 AQ	HW: 5Q0 614 517 AF
	Component: ESC           H62 0400
	Revision: 00000000
	Coding: 01FA6BA13424096F807A020780C92980D62C90014001943400435050C009430000000012121212B835351919323200
	Shop #: WSC 01383 790 50316
	ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
	ROD: N/A
	VCID: 80439303AFDB0B7162038212B8-80D5
	No ASAM data for: "EV_Brake1UDSContiMK100ESP"
016401 - ROD - Unknown faultcode
Address 08: Auto HVAC  (J301)	Labels: 5G0-907-426.clb
	Part No SW: 5GM 907 426 E	HW: 5GM 907 426 E
	Component: AC Manuell    H03 1801
	Revision: 00001K04
	Coding: 00020004200100000000000000000002
	ASAM Dataset: EV_ACManueBHBVW37X 004134
	ROD: N/A
	VCID: 4AD7F12B596781217CE7306AFE-801F
	No ASAM data for: "EV_ACManueBHBVW37X"
	Subsystem 1 -
	Subsystem 2 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
	Part No SW: 5Q0 937 087 AN	HW: 5Q0 937 087 AN
	Component: BCM PQ37BOSCH 032 0223
	Revision: --------
	ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
	ROD: N/A
	VCID: 8751881F8AF53C492349D146E5-80D2
	No ASAM data for: "EV_BodyContrModul1UDSBosc"
	Subsystem 1 - 	Part No SW: 5G1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component: MÝ
6 Faults Found:
919560 - ROD - Unknown faultcode
006666 - ROD - Unknown faultcode
006922 - ROD - Unknown faultcode
017162 - ROD - Unknown faultcode
017674 - ROD - Unknown faultcode
017930 - ROD - Unknown faultcode
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 5Q0 959 655 J	HW: 5Q0 959 655 J
	ROD: N/A
	VCID: 47D1C81F4A757C4963C91146A5-8012
	No ASAM data for: "EV_AirbaVW20SMEVW37X"
	Subsystem 1 - 	Part No SW: 4M0-959-339-B
	Component: 00Z
	Subsystem 2 - 	Component: ---
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
	Subsystem 5 - 	Component: ---
	Subsystem 6 - 	Component: ---
Address 16: Steering wheel  (J524)	Labels: 5Q-16.lbl
	Part No SW: 5Q0 953 521 P	HW: 5Q0 953 569 A
	Revision: FF034034
	Coding: 0410
	Shop #: WSC 66564 385 16448
	ROD: N/A
	VCID: 3FC1D0FF12A53489DB79B9E60D-806A
	No ASAM data for: "EV_SMLSVALEOMQB"
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5G1 920 856 B	HW: 5G1 920 856 B
	Component: KOMBI         344 8311
	Coding: 0BBD090AA180CF0502087A001000000000000000
	ROD: N/A
	VCID: 2D1D9AB7C8C9B61979C5F30E77-8078
	No ASAM data for: "EV_DashBoardVDDMQBAB"
16777020 - ROD - Unknown faultcode
Address 19: CAN Gateway  (J533)	Labels: None
	Part No SW: 3Q0 907 530 B	HW: 3Q0 907 530 B
	Component: GW MQB Mid    514 5286
	Coding: 0101000870085900FB0000281C0F00000001050000000000000000000000
	Shop #: WSC 00066 790 07030
	ROD: N/A
	VCID: 2E1F9DBBC5CFCD0140CFFC3A62-807B
	No ASAM data for: "EV_GatewNF"
	Subsystem 1 -
	Subsystem 2 - 	Component: 1ÿÿ
Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
	Part No SW: 5Q0 959 593 E	HW: 5Q0 959 593 B
	Coding: 003E03200000020000000000
	ROD: N/A
	VCID: 43C9DC0F7E4D5069BFA1E53651-8016
	No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
Address 44: Steering Assist  (J500)	Labels: 3Q-44.lbl
	Part No SW: 3QM 909 144	HW: 3QM 909 144
	Coding: 8102
	ROD: N/A
	VCID: 0C5B37331393DF118E7B8682A4-8059
	No ASAM data for: "EV_SteerAssisMQB"
Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
	Part No SW: 5Q0 959 592 E	HW: 5Q0 959 592 B
	ROD: N/A
	VCID: 42C7D90B61575961B497D80A66-8017
	No ASAM data for: "EV_DCUPasseSideEWMAXKLO"
Address 5F: Information Electr.  (J794)	Labels: 3Q-5f.clb
	Part No SW: 3Q0 035 844 A	HW: 3Q0 035 844 A
	Component: MU-S-S-US     710 0751
	Coding: 02730000FF00000051220001001808009F0203D40120010002
	ROD: N/A
	No ASAM data for: "EV_MUStd4CDELP"
	Subsystem 1 - 	Part No SW: 3G0-919-605-H
	Component: ABT_Std-2
Address 75: Telematics  (J949)	Labels: 5QE-035-285.clb
	Part No SW: 5QE 035 285 A	HW: 5QE 035 285 A
	Component: OCULowMQBUS   007 0570
	ROD: N/A
	No ASAM data for: "EV_OCULowMQB"
Address A9: Struct. Borne Sound  (J869)	Labels: 5G-a9.lbl
	Part No SW: 5G0 907 159	HW: 4H0 907 159 A
	Shop #: WSC 00000 000
	ROD: N/A
	VCID: EB99D4AFB65DF829A7311D16C9-80BE
	No ASAM data for: "EV_SoundActuaGen2AU64X"
CB: 0.4411
FW: 0.254
CFB: 0.10
BL: 0.28
DS: 00000050
Any ideas? My guess is that the ASAM data isn't available yet, or I am doing it wrong.
EDIT: more or less the same issue as bramsey here: http://forums.ross-tech.com/showthread.php?12550-Autoscan-on-2017-GTI
There's more/new ASAM data coming for Mobile. It's currently in alpha testing, but not quite ready for prime time yet.
Somnus
SLC, USA
C?ID=215931
Good to know! I will keep an eye out for the update.
n0vac
C?ID=321709
I'm having the same problem as OP. I just bought a HEX-NET interface and used VCDS Mobile to run an Auto-Scan on my 2018 Octavia. After Auto-Scan was completed, it prompted me to download ASAM data from the server, but when I tried to do that, it got stuck in "0% Preparing to update..." and I canceled. I have tried it again with the same result. When I check updates from Interface Config, it always finds updated rod data.
I guess there's no ASAM data for 2018 Octavia yet?
VCDS Mobile:
VIN: TMBJD9NE5J01xxxxx
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44 47
	 4B 52 5F 6C 6D 75 A5 D6 D7
Address 01: Engine  (CJSA: J623)	Labels: 06K-907-425-V1.clb
	Part No SW: 8V0 906 264 H	HW: 06K 907 425 B
	Component: 1.8l R4 TFSI  H13 0005
	Revision: --H13---
	Coding: 0C25003A2464050B1000
	Shop #: WSC 73430 031 00000
	ASAM Dataset: EV_ECM18TFS0208V0906264H 001007
	ROD: N/A
	VCID: 41C5D6076FC4429C068DCF1E6B-8014
	No ASAM data for: "EV_ECM18TFS0208V0906264H"
Address 02: Auto Trans  (J743)	Labels: 0C-02.clb
	Part No SW: 0CW 300 041 G	HW: 0AM 927 769 E
	Component: GSG DQ200G2_M H05 1003
	Revision: 00005026
	ROD: N/A
	VCID: 3935BEE707141A5C4E3D77BED3-806C
	No ASAM data for: "EV_TCMDQ200021"
	Part No SW: 5Q0 614 517 CF	HW: 5Q0 614 517 AD
	Revision: 00000000
	Coding: 25076A913428216F4077060440C629A4562C8402600294743641F0F0C0A2430000000012121212B8586C384E4484EE
	ROD: N/A
	VCID: 77B178DF7180CC2C78A9218635-8022
	No ASAM data for: "EV_Brake1UDSContiMK100IPB"
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 5Q0 959 435 C	HW: 5Q0 959 435
	Component: VWKESSYMQB    021 0803
	Revision: 00021000
	Coding: 032C0C
	Shop #: WSC 73430 790 00063
	ASAM Dataset: EV_KessyHellaMQBAB 002020
	ROD: N/A
	VCID: 3C3BA7F308262F74555B96C234-8069
	No ASAM data for: "EV_KessyHellaMQBAB"
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5E0 907 044 AT	HW: 5E0 907 044 AT
	Component: Climatronic   H04 2001
	Revision: 00001K00
	Coding: 02010004004111011005000D0010102A
	Shop #: WSC 73430 031 00063
	ASAM Dataset: EV_ACClimaBHBVW37X 006146
	ROD: N/A
	No ASAM data for: "EV_ACClimaBHBVW37X"
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
	Part No SW: 5Q0 937 086 BM	HW: 5Q0 937 086 BH
	Component: BCM PQ37BOSCH 034 0242
	Revision: --------
	Shop #: WSC 73430 790 00000
	ROD: N/A
	VCID: 864F851B866A25A4F33FC45AEA-80D3
	Subsystem 1 - 	Part No SW: 5E1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component: MÝ
	Subsystem 2 -
	Subsystem 3 -
Address 10: Park/Steer Assist  (J791)	Labels: 5Q0-919-298.clb
	Part No SW: 5QA 919 298 C	HW: 5QA 919 298 A
	Component: PLA 3.0 12K
	Coding: 0271167051
	ROD: N/A
	VCID: 50E3E343B4AEBB14992372D228-8005
	No ASAM data for: "EV_EPHVA2CAU3700000"
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 J	HW: 3QF 907 572
	Component: ACC BOSCH MQB H10 0654
	Coding: 330060C141FFC728949C810520400600000000000000000000
	ASAM Dataset: EV_ACCBOSCHVW416 002006
	ROD: N/A
	VCID: 3E3FADFB1E3A3D647B6FACFA12-806B
	No ASAM data for: "EV_ACCBOSCHVW416"
Address 14: Susp. Elect.  (J250)	Labels: 5Q0-907-376.clb
	Part No SW: 5Q0 907 376 B	HW: 5Q0 907 376 A
	ROD: N/A
	VCID: 3833BBE33C1E0354B1336AB2E0-806D
	No ASAM data for: "EV_DRCONTITEMIC"
	Part No SW: 3Q0 959 655 BJ	HW: 3Q0 959 655 BJ
	Component: Airbag VW21   006 0703
	Revision: --------
	Coding: 98FCC000000000005C5400CC000840000065
	ROD: N/A
	VCID: 8751881F81603CAC8849D146E5-80D2
	No ASAM data for: "EV_AirbaVW21TS6VW48X"
	Subsystem 1 - 	Part No SW: --------------@
	Component: ---
	Part No SW: 5Q0 953 521 LA	HW: 5Q0 953 569 B
	Component: Lenks.Modul   100 0245
	Revision: FF036036
	Coding: 6414
	ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
	ROD: N/A
	VCID: 7CBB67F348A6EF7415DB56C274-8029
	No ASAM data for: "EV_SMLSVALEOMQBLRH"
291104 - ROD - Unknown faultcode
	Part No SW: 5E0 920 750 E	HW: 5E0 920 750 E
	Component: KOMBI         303 0310
	Coding: 07A509187D840008018B6B0B5001000800000000
	ROD: N/A
	VCID: 260F659BE6AA85A4137FA4DACA-8073
Address 18: Aux. Heat  (J364)	Labels: 5Q0-963-272.clb
	Part No SW: 5Q0 963 272 H	HW: 5Q0 963 272 H
	Component: STH-MQB       008 0075
	Coding: 9309
	ASAM Dataset: EV_AuxilParkiHeateWOS 002018
	ROD: N/A
	VCID: 3B39A4EF0D28284C5C518DD639-806E
	No ASAM data for: "EV_AuxilParkiHeateWOS"
	Part No SW: 3Q0 907 530 G	HW: 3Q0 907 530 C
	Component: GW MQB High   436 4304
	Revision: --------
	Coding: 0B0100047F085900EB00025A9C0F00010001070000000000000000000000
	ROD: N/A
	VCID: 33298CCF2578E00C84013576A1-8066
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
	Revision: 00000000
	Coding: 5D00000000000000
	ROD: N/A
	VCID: 342B8FD32076E7349D0B3E629C-8061
	No ASAM data for: "EV_ELVMarquMQB"
Address 36: Seat Mem. Drvr  (J810)	Labels: None
	Part No SW: 5Q0 959 760 B	HW: 5Q0 959 760 B
	Component: Sitzmemory    H08 0022
	Coding: 0010000000000500018280808080000000008181000000D400
	ROD: N/A
	No ASAM data for: "EV_SeatMemorDriveSide"
Address 3C: Lane Change  (J1086)	Labels: None
	Part No SW: 5Q0 907 686 C	HW: 5Q0 907 686 C
	Component: HRE_Master    H12 0080
	Coding: 02011103
	ROD: N/A
	VCID: 3D3DAAF7133C267C6265A3CE27-8068
	No ASAM data for: "EV_HREntryHella"
	Part No SW: 5Q4 959 593 E	HW: 5Q4 959 593 B
	Coding: 001D0920DE00040000001100
	ROD: N/A
	VCID: 47D1C81F41E07CACC8C91146A5-8012
	No ASAM data for: "EV_DCUDriveSideEWMAXCONT"
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 5Q0 909 144 T	HW: 5Q0 909 144 R
	Component: EPS_MQB_ZFLS  129 1072
	Coding: 9307
	ROD: N/A
	VCID: 45CDC2177BEC6EBC3AB5FB2EBF-8010
Address 47: Sound System  (J525)	Labels: None
	Part No SW: 81A 035 223	HW: 81A 035 223
	Component: MIB2_amp_P_SK H10 0410
	Revision: 00000001
	Coding: 0373020000AA002AAA0000000000
	ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
	ROD: N/A
	VCID: D9F59E6767547A5CEE7D573E33-808C
	No ASAM data for: "EV_AMPMst16C4Gen2ALPI"
Address 4B: Multifunc. Module  (J745)	Labels: None
	Part No SW: 3Q0 907 338	HW: 3Q0 907 338
	Coding: 000000070100046A06003D01010000000000000000000000000000000000
	ROD: N/A
	VCID: F2A7C9CB9AE22904CF77684A76-80A7
	No ASAM data for: "EV_MultiModulContiVW48X"
	Part No SW: 5Q4 959 592 E	HW: 5Q4 959 592 B
	Coding: 001D0120DE00040000001100
	ROD: N/A
	VCID: 46CFC51B46EA65A433BF045AAA-8013
	No ASAM data for: "EV_DCUPasseSideEWMAXCONT"
Address 5F: Information Electr.  (J794)	Labels: 56-5f.clb
	Part No SW: 565 035 043 A	HW: 565 035 043
	Component: MU-H-N-EU     H54 1163
	Coding: 037302010000000051110002000802232F0103E401200500BE
	ROD: N/A
	VCID: 10632343742EFB14D9A3B2D2E8-8045
	No ASAM data for: "EV_MUHig4CGen2HBAS"
	Subsystem 1 - 	Part No SW: 5E0-919-606-D
	Component: ABT_High-2
	Subsystem 2 -
	Subsystem 3 -
Address 6C: Back-up Cam.  (J772)	Labels: 5Q-6c.lbl
	Part No SW: 5Q0 980 556 B	HW: 5Q0 980 556 B
	Coding: 047302012600201F000040
	ROD: N/A
	No ASAM data for: "EV_CamSysRVRVCPANAMQBAB"
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 5E0 959 107 A	HW: 5E0 959 107
	Component: HDSG-Modul    H01 0746
	Revision: 42001001
	Coding: 1233074002
	ASAM Dataset: EV_HDSGSk462 301136
	ROD: N/A
	VCID: 2A1791ABF2B2A1C437A7D0EA1E-807F
	No ASAM data for: "EV_HDSGSk462"
Address 75: Telematics  (J949)	Labels: None
	Part No SW: 5NA 035 284 B	HW: 5NA 035 284 B
	Component: OCULowMQBLGE  H17 0717
	Revision: --------
	Coding: 03730201EA421A0D3B1CBE000045400382E608
	ASAM Dataset: EV_OCULowMQBLGE 004044
	ROD: N/A
	No ASAM data for: "EV_OCULowMQBLGE"
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q-a5.clb
	Part No SW: 3QD 980 654	HW: 3Q0 980 654 A
	Component: MQB_B_MFK     H08 1272
	Coding: 020307020000040100222354C150A90094000E200020
	ROD: N/A
	VCID: 08530B230C7EB3D401535A7250-805D
	No ASAM data for: "EV_MFKBoschMQBB"
Address D6: Light Ctrl Left 2  (A31)	Labels: None
	Part No SW: 7P5 941 591 AD	HW: 7P5 941 591 A
	Component: LED1L         H06 0005
	ROD: N/A
	VCID: 7EBF6DFB5EBAFD643BEF6CFA52-802B
	No ASAM data for: "EV_LED_PLUS_L_KEBODAVW416"
Address D7: Light Ctrl Right 2  (A27)	Labels: None
	Component: LED1R         H06 0005
	ROD: N/A
	No ASAM data for: "EV_LED_PLUS_R_KEBODAVW416"
VCDS:
Saturday,17,March,2018,16:15:28:47078
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
VIN: TMBJD9NE5J01xxxxx   License Plate:
Chassis Type: NE-SK37 (3Q0)
VIN: TMBJD9NE5J01xxxxx   Mileage: 3840km-2386miles
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Revision: --H13---
   ROD: EV_ECM18TFS0208V0906264H_SK37.rod
   VCID: 41CAAF8AD03E2C4C57-8014
Readiness: 1110 0001
   Revision: 00005026    Serial number: CU501709226410
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 393AC76AB8EE748C1F-806C
   Revision: 00000000    Serial number: 62727000000270
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 77BE0152CE7AA2FC29-8022
   Revision: 00021000    Serial number: 0455672552
   Coding: 032C0C
   VCID: 3C34DE7EB7DC41A404-8068
   Revision: 00001K00
   Revision: --------    Serial number: 865822091700X3
   ROD: EV_BCMCONTI.rod
   VCID: 06407C96B990CB7422-8052
   Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 170904  051 0915
   Serial number: 887353F0401724702280
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: S4Y17M09D25H16M51S04
   Coding: 00885D
   Serial number: 000308417617271
   Coding: 0271167051
   ROD: EV_EPHVA2CAU3700000_009_AU37.rod
   VCID: 50EC9ACE0B54D5C4C8-8004
   VCID: 3E30D476A1C053B42A-806A
   Serial number: 14081741350089
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 383CC26E83E46D84E0-806C
   Revision: --------    Serial number: 003W5PK4KKEE
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 075E7192BE9AD27C59-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 002 209 17
   Serial number: 357000000005661C882K
   Subsystem 2 - Part No SW: -----------    HW: 454 001 909 17
   Serial number: 358000000004A70DD82U
   Subsystem 3 - Part No SW: -----------    HW: 454 802 109 17
   Serial number: 3510020343012000000O
   Subsystem 4 - Part No SW: -----------    HW: 454 802 109 17
   Serial number: 35200856E1D12000000H
   Subsystem 5 - Part No SW: -----------    HW: 454 801 509 17
   Serial number: 35500CC77D510000000R
   Revision: FF036036    Serial number: 20171004500428
   Coding: 6414
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CB41E7EF75C81A444-8028
   VCID: 26001C165950EB7442-8072
   Coding: 9309
   VCID: 3B36DD62B2D2469C0D-806E
   Component: R64 D208L  004 0401
   Serial number: 00000000000000325085
   Revision: --------    Serial number: 0006870145
   ROD: EV_GatewNF_VW27.rod
   VCID: 3326F5429A828EDCD5-8066
   Subsystem 2 - Part No SW: 3V0 919 719 D    HW: 3V0 919 719 D
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000B1547150917
   Serial number: 7588600000170930055E
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H25 0780
   Serial number: 0080095
   Revision: 00000000    Serial number: 17000282318006
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424F65E9F8C89E4CC-8060
   Serial number: Y0006QIE21019
   Serial number: 0454102354
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D32D37AACC648AC33-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0455437412
   Coding: 020111
   Serial number: 0000281455527
   VCID: 47DEB192FE1A127C99-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000016688805
   Coding: 010200
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C2BB9AC416006C6B-8010
   Revision: 00000001    Serial number: SKZ8Z1HJE02VRR6
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59FA67EA58AE948C3F-800C
   Serial number: 26091710521684
   VCID: 72A83046A518C7D41E-8026
   Serial number: 0000281063084
   VCID: 46C0BC96F9100B7462-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000016737778
   Coding: 190200
   Serial number: A856I0HB013538
   VCID: 106C5ACECBD495C488-8044
   Subsystem 1 - Part No SW: 5E0 919 606 D    HW: 5E0 919 606 D
   Component: ABT_High-2  H50 9130
   Serial number: SKZ6ZHT2782281
   Subsystem 2 - Part No SW: V03 959 801 JP    HW: -----------
   Component: ECE 2018  --- 0166
   Component: Gracenote2  --- 1016
   Revision: 42001001    Serial number: 251700664
   Coding: 1233074002
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 2A18E8264D48CF1466-807E
   Revision: --------
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   Serial number: 04091741P10311
   ROD: EV_MFKBoschMQBB_VW27.rod
   VCID: 085C72AEB384DD0450-805C
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EB01476E14093B46A-802A
   ROD: EV_LED_PLUS_R_KEBODAVW416.rod
End----------(Elapsed Time: 02:08, VBatt start/end: 12.6V/12.5V)-----------
Hmm.. It wouldn't shock me if a few of those were missing from VCDS-Mobile, but not as many as you've got there.
I know Shaun is working on a big update for the data in VCDS-Mobile. Let's see what he says...
n0vac
C?ID=321709
Thanks Uwe! Forgot to mention, that if I select an individual module, it first checks the ASAM data, but then gives me the following warning:
And here are the screenshots from the ASAM update after the Auto-Scan was completed. I waited about 10 minutes, but nothing happened:
Shaun
If you want to try some more recent data, put your HEX-NET on the beta channel (VCIConfig -> Advanced -> Change Channel, then check for updates again).
Once you've got the beta updates downloaded, try doing another Autoscan and then see if you can download more ASAM data.
n0vac
C?ID=321709
I switched to the beta channel, checked and installed updates and ran Auto-Scan again. Now there were a lot less modules, that were missing the ASAM data. I had to run Auto-Scan and download missing ASAM data about 4-5 times and now they all seem to be installed. Thanks Shaun!
VCDS Mobile 0.4417.0.4
	Revision: --H13---
	ROD: EV_ECM18TFS0208V0906264H.rod
	VCID: 41C5D6076FC4429C068DCF1E11-8014
	Revision: 00005026
	ROD: EV_TCMDQ200021_SK37.rod
	VCID: 3935BEE707141A5C4E3D77BEA9-806C
	Revision: 00000000
	ROD: EV_Brake1UDSContiMK100IPB_036.rod
	VCID: 77B178DF7180CC2C78A921864F-8022
	Revision: 00021000
	Coding: 032C0C
	VCID: 3C3BA7F308262F74555B96C24E-8069
	Revision: 00001K00
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
	Revision: --------
	ROD: EV_BodyContrModul1UDSBosc_018.rod
	VCID: 864F851B866A25A4F33FC45A90-80D3
	Component: MÝ
	Subsystem 2 -
	Subsystem 3 -
	Coding: 0271167051
	ROD: EV_EPHVA2CAU3700000_009_SK37.rod
	VCID: 50E3E343B4AEBB14992372D252-8005
	ROD: EV_ACCBOSCHVW416_002.rod
	VCID: 3E3FADFB1E3A3D647B6FACFA68-806B
	ROD: EV_DRCONTITEMIC_SK37.rod
	VCID: 3833BBE33C1E0354B1336AB29A-806D
	Revision: --------
	VCID: 8751881F81603CAC8849D1469F-80D2
	Component: ---
	Revision: FF036036
	Coding: 6414
	VCID: 7CBB67F348A6EF7415DB56C20E-8029
291104 - Temperature Sensor for Heated Steering Wheel
	B1455 01 [008] - Electrical Failure
		Fault Status: 01110001
		Reset Counter: 1
		Mileage: 4457021 km
		Time: 00:00:00
	ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
	VCID: 260F659BE6AA85A4137FA4DAB0-8073
	Coding: 9309
	VCID: 3B39A4EF0D28284C5C518DD643-806E
Address 19: CAN Gateway  (J533)	Labels: 3Q-19.clb
	Revision: --------
	ROD: EV_GatewNF_SK37.rod
	VCID: 33298CCF2578E00C84013576DB-8066
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
	Revision: 00000000
	ROD: EV_ELVMarquMQB_004.rod
	VCID: 342B8FD32076E7349D0B3E62E6-8061
	ROD: EV_SeatMemorDriveSide_002.rod
Address 3C: Lane Change  (J1086)	Labels: 5Q0-907-686.clb
	Coding: 02011103
	ROD: EV_HREntryHella.rod
	VCID: 3D3DAAF7133C267C6265A3CE5D-8068
	VCID: 47D1C81F41E07CACC8C91146DF-8012
	Coding: 9307
	VCID: 45CDC2177BEC6EBC3AB5FB2EC5-8010
Address 47: Sound System  (J525)	Labels: 81-47.clb
	Revision: 00000001
	VCID: D9F59E6767547A5CEE7D573E49-808C
	VCID: F2A7C9CB9AE22904CF77684A0C-80A7
	VCID: 46CFC51B46EA65A433BF045AD0-8013
	VCID: 10632343742EFB14D9A3B2D292-8045
	Subsystem 2 -
	Subsystem 3 -
Address 6C: Back-up Cam.  (J772)	Labels: 5Q0-980-556.clb
	ROD: EV_CamSysRVRVCPANAMQBAB_006.rod
	Revision: 42001001
	Coding: 1233074002
	VCID: 2A1791ABF2B2A1C437A7D0EA64-807F
Address 75: Telematics  (J949)	Labels: 5N-75.clb
	Revision: --------
	ROD: EV_OCULowMQBLGE_004_SK37.rod
	ROD: EV_MFKBoschMQBB_SK37.rod
	VCID: 08530B230C7EB3D401535A722A-805D
	VCID: 7EBF6DFB5EBAFD643BEF6CFA28-802B
