Fresh from dealer with many options.
Autoscan:
Adaption maps
01
02
2B
03
3C
4B
05
5F
6D
08
09
10
13
15
17
19
47
75
A5
Autoscan:
Friday,27,September,2019,12:51:15:57784
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4513.4
Dealer/Shop Name: LeVWFreaks.eu
VIN: WVWZZZ3CZLE****** License Plate:
Mileage: 20km-12mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 47 4B 52
5F 6C 6D 75 A5 BB BC D6 D7
VIN: WVWZZZ3CZLE****** Mileage: 20km-12miles
Address 01: Engine (J623-DKZA) Labels: None
Part No SW: 3G0 907 115 HW: 06K 907 309 B
Component: R4 2.0l TFSI H60 0002
Revision: O1H60000
Coding: 012540322464050B34100000000000000000000000000000
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_ECM20TFS0113G0907115 001004
ROD: EV_ECM20TFS0113G0907115_VW48.rod
VCID: 619CAF2751C7B18FA57-8034
37273 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [038] - Implausible Signal
Mileage: 20 km
Date: 2019.09.27
Time: 12:47:15
Engine speed: 805.50 /min
Normed load value: 3.5 %
Coolant temperature: 61 ∞C
Intake air temperature: 28 ∞C
Voltage terminal 30: 12.560 V
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0GC 300 044 J HW: 0GC 927 711 H
Component: GSG DQ381 H06 2404
Revision: 00H06V09
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061_VW37.rod
VCID: 2F38191F579357FF633-807A
Part No SW: 5Q0 614 517 FA HW: 5Q0 614 517 BR
Component: ESC H82 0190
Revision: 00000000 Serial number: 62319000003130
Coding: 0EEC7A8F31233B6C477A060060CC49705E8CDCE2600692753842F078D2A24A0B0003000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 75B4EB77F54F2D2FE9F-8020
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0524076333
Coding: 1F20000723
Shop #: WSC 05311 115 00106
ASAM Dataset: EV_KessyHellaMQBAB 004052
VCID: 45D45BB7E52FFDAFB9F-8010
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11915606
Part No SW: 5G0 907 044 FA HW: 5G0 907 044 FA
Component: Climatronic H04 2202
Revision: 00001K10
Coding: 11020004200410011115100E8010D832
ASAM Dataset: EV_ACClimaBHBVW37X 006150
VCID: 6B80CD0FA30BEBDF0FB-803E
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 086 CF HW: 5Q0 937 086 BR
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: J53F02081900YY
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: 005A8AA3BA8D1887CA9-8054
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 190706 042 0607
Serial number: 190731190759
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: USER\5Q0-955-547.LBL
Component: RLHS 051 0206
Serial number: SBY19M08D21H15M13S44
Coding: 0008EE
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 12 05 2019 10000028
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1921037ZR
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000544564
Ceiling Light Module:
Subsystem 6 - Part No SW: 3G0 947 105 C HW: 3G0 947 105 C
Component: J528 Dachelek H08 0009
Serial number: 19082100010025C
Coding: F38380
Steering Column Switch:
Subsystem 8 - Part No SW: 5Q1 953 521 BJ HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0100050820190C202818
Subsystem 9 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0929641
Subsystem 10 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0930580
Subsystem 11 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0642466
Subsystem 12 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0930584
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000150057319222
Coding: 0271267851
Shop #: WSC 05311 115 00081
ASAM Dataset: EV_EPHVA2CAU3700000 009048
ROD: EV_EPHVA2CAU3700000.rod
VCID: 55F48BF7158F4D2FC9F-8000
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5Q0 907 572 R HW: 3Q0 907 567 A
Component: ACC BOSCH MQB H01 0771
Coding: 32057F535DFFC728949C812481400600000000000000000066
ASAM Dataset: EV_ACCBOSCHVW416 003014
ROD: EV_ACCBOSCHVW416_003.rod
VCID: 46D65CBBD829F6B7B05-8012
Part No SW: 3Q0 959 655 CP HW: 3Q0 959 655 CP
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z4PFJZY64
Coding: 98CCC0C0000000005C5400CF000840000065
Shop #: WSC 05311 000 08193
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0E46A49BF0D97EF7485-805A
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705 0238T01439
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1040
Serial number: 3G0857706 0234T00570
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 002 306 19
Serial number: 35700000000A0BEC5B3
Subsystem 4 - Part No SW: ----------- HW: 454 002 306 19
Serial number: 3580000000016BEC5B3-
Subsystem 5 - Part No SW: ----------- HW: 454 802 606 19
Component: SideSensor_Dr 301 0148
Serial number: 351004E74EC18000000U
Subsystem 6 - Part No SW: ----------- HW: 454 802 006 19
Component: SideSensor_Pr 301 0148
Serial number: 352004BD1E518000000O
Subsystem 7 - Part No SW: ----------- HW: 454 802 206 19
Component: FrontSensor_D 304 0149
Serial number: 35500DB151819000000J
Part No SW: 3G0 920 320 A HW: 3G0 920 320 A
Component: KOMBI 502 4192
Coding: 05A400186F8C00080188624B1001000880700100
Shop #: WSC 05311 115 00153
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 1B60DDCF332BDB5F3FB-804E
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0009935149
Coding: 0B0900047F085900F91042DE180F00000001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF.rod
VCID: 70BADA638A2D08073A9-8024
Component: 4-01-09-01-04
Subsystem 2 - Part No SW: 3G0 959 442 K HW: 3G0 959 442 K
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036191192160
Coding: 2F0B00
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003001908170571
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H27 0810
Serial number: 3110500
Address 23: Brake Booster (J539) Labels: None
Part No SW: 3Q0 909 059 G HW: 3Q0 909 059 A
Component: EBKV H06 0069
Serial number: BPA085200819013
Coding: 0102C100340000C618638C31000049922449920400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
VCID: 3B203D4F93EBBB5FDFB-806E
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000214614011
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 3330156FBBBB731F07B-8066
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 C HW: 3Q0 959 760 C
Component: Sitzmemory H06 0026
Serial number: Y0007SH737486
Coding: 001000020000050081C280808080000000008181000000F440
ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0149
Serial number: 00000523203640
Coding: 52A54640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392C274799D7894FCD7-806C
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0320
Serial number: YE007SGO3033A
Coding: 003F1A20D200028000001000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
VCID: 49CC5787C93719CF5D7-801C
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 131F0000
Shop #: WSC 00015 115 00312
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C223E5396E5BC67D61-8068
Address 47: Sound System (J525) Labels:* None
Part No SW: 3G0 035 466 HW: 3G0 035 466
Component: AMPeth16C H07 3027
Serial number: A1130A00003058
Coding: 24010000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB 001005
ROD: EV_AMPEthMQB_VW48.rod
VCID: 629EA02B54C1AA97BCD-8036
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 F HW: 3Q0 907 338 F
Component: FCM MQB High 004 0367
Serial number: 16081911602359
Coding: 000000070B0003CA01000F11000300040000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 382A2243A2DD9047329-806C
Dedicated Short Range Communication Aerial:
Subsystem 1 - Part No SW: 3G1 959 121 HW: 3G1 959 121
Component: R350 NFCTGS 701 0509
Serial number: 0000000000B34B110139
Antenna 2 for short-range communication:
Subsystem 2 - Part No SW: 3G0 980 611 HW: 3G0 980 611
Component: J524 NFCMIKO H09 0059
Serial number: 31900000000002659557
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0320
Serial number: YE007SH720012
Coding: 003F1020DE00028000001000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
VCID: 48CA5283D23DE0C7429-801C
Part No SW: 3G5 035 816 A HW: 3G5 035 816 A
Component: MU-O-ND-EU H12 0152
Serial number: VWZAZ2W1126776
Coding: 24810000000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_VW48.rod
VCID: 2708F13F7F630FBFAB3-8072
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG059673
Coding: 01840101E20F200000204014
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 R HW: 5Q0 959 107 H
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C737-6331-8
Coding: 0108
VCID: 47C851BFDF23EFBF4B3-8012
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 HW: 5WA 035 284
Component: OCUGen3High H20 0083
Serial number: 0000000907VIPA1
Coding: 024810001968A8209005460160502E07
ASAM Dataset: EV_OCUGen3High 002115
ROD: EV_OCUGen3High_VW37.rod
VCID: 035085AFAB9B039FD7B-8056
0081 - Databus
Reset counter: 40
Mileage: 19 km
Date: 2019.09.25
Time: 17:44:34
Voltage terminal 30: 11.7 V
1190912 - Ethernet Databus Branch 1
U122C 00 [008] - No Communication
Reset counter: 40
Mileage: 19 km
Date: 2019.09.25
Time: 17:44:33
Ethernet counter checksum error: branch 1: 0
Ethernet counter connection interruptions: branch 1: 1
7246 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[RemoteServices (0x4E) - Funktionseinschr‰nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Reset counter: 40
Mileage: 19 km
Date: 2019.09.25
Time: 15:09:36
Voltage terminal 30: 11.9 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H11 1027
Serial number: E33417008192350
Coding: 00000898216CC020109E10001030008000410000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 72BED06B84213A17CCD-8026
Part No SW: 5Q0 959 595 K HW: 8W1 959 595 D
Component: TSG HFS004 0320
Serial number: YE007SG921081
Coding: 000E10200100028000001000
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
VCID: 4BC06D8FC34B0BDF6FB-801E
Component: TSG HBFS004 0320
Serial number: YE007SGA0221C
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 992 941 572 CA HW: 992 941 572 C
Component: LED1L H08 9002
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X.rod
VCID: 6492A6334ED5A4A74E1-8030
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H08 9002
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 02:13, VBatt start/end: 12.8V/12.9V)-----------
Adaption maps
01
IDE01945-Engine run-in oil pressure,active ,1
IDE02332-Deactivate production mode,00 00 00 ,3
IDE04158-Activation of start-stop function,active ,1
IDE04617-Protective function,OFF ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,0.25 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,-1.19 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,0.00 °,2
IDE06736-Timing deviation: current value exhaust bank 1,0.00 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,1 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,1 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,not active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,not active ,1
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE07903-Adaptation of ash mass,0.00 g,2
02
IDE00001-Production mode,not activated ,3
2B
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,tested ,1
03
IDE00001-Production mode,not active ,3
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire pressure monitoring display,2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake booster,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07292-Brake pre-filling,completed successfully ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG130301-Developer_Function_121,not activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
3C
IDE00001-MAS15623-Production mode-Deactivation of lane change assistance and exit warning,not active ,3
IDE00001-MAS15624-Production mode-Deactivation of Cross traffic assistant rear and pre sense rear,not active ,3
IDE00001-MAS15692-Production mode-Parking lock: malfunction,not active ,3
IDE00001-Production mode-,OFF ,3
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,3
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,3
IDE05982-lane change assist. control module calibration values,-10.24 °,2
IDE05983-lane change assist. control module 2 calibration values,-10.24 °,2
IDE06218-MAS04607-Test bench data for calibration: production-Body height left front wheel house edge,0.00 mm,25
IDE06218-MAS04608-Test bench data for calibration: production-Body height right front wheel house edge,0.00 mm,25
IDE06218-MAS04609-Test bench data for calibration: production-Body height left rear wheel house edge,0.00 mm,25
IDE06218-MAS04610-Test bench data for calibration: production-Body height right rear wheel house edge,0.00 mm,25
IDE06218-MAS04612-Test bench data for calibration: production-Transverse position: vehicle: front axle,0 mm,25
IDE06218-MAS04613-Test bench data for calibration: production-Transverse position: vehicle: rear axle,0 mm,25
IDE06218-MAS04614-Test bench data for calibration: production-X-coordinate: Doppler simulator: left,0 mm,25
IDE06218-MAS04615-Test bench data for calibration: production-Y-coordinate: Doppler simulator: left,0 mm,25
IDE06218-MAS04616-Test bench data for calibration: production-Z-coordinate: Doppler simulator: left,0.00 mm,25
IDE06218-MAS04617-Test bench data for calibration: production-X-coordinate: Doppler simulator: right,0 mm,25
IDE06218-MAS04618-Test bench data for calibration: production-Y-coordinate: Doppler simulator: right,0 mm,25
IDE06218-MAS04619-Test bench data for calibration: production-Z-coordinate: Doppler simulator: right,0.00 mm,25
IDE80015-Analysis 15,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,42
4B
IDE03641-Presentation run dynamic AFS light,active ,1
IDE03642-Presentation mode,not active ,1
IDE03679-Adaptive light functions,active ,1
IDE08418-Matrix light: total dimming,100.8 %,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,12
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,12
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,12
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,12
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,12
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,12
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,12
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,12
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,12
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,12
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,12
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,12
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,12
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,12
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,12
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,12
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,12
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,12
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,12
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,12
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,12
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,12
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,12
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,12
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,12
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,12
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,12
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,12
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,12
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,12
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,12
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,12
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,12
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,12
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,12
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,12
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,12
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,12
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,12
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,12
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,12
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,12
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,12
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,12
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,12
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46,OFF ,12
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47,OFF ,12
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48,OFF ,12
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49,OFF ,12
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50,OFF ,12
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51,OFF ,12
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52,OFF ,12
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53,OFF ,12
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54,OFF ,12
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55,OFF ,12
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56,OFF ,12
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57,OFF ,12
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58,OFF ,12
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59,OFF ,12
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60,OFF ,12
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61,OFF ,12
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62,OFF ,12
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63,OFF ,12
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64,OFF ,12
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65,OFF ,12
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66,OFF ,12
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67,OFF ,12
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68,OFF ,12
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69,OFF ,12
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70,OFF ,12
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71,OFF ,12
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72,OFF ,12
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73,OFF ,12
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74,OFF ,12
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75,OFF ,12
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76,OFF ,12
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77,OFF ,12
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78,OFF ,12
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79,OFF ,12
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80,OFF ,12
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81,OFF ,12
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82,OFF ,12
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83,OFF ,12
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84,OFF ,12
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85,OFF ,12
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86,OFF ,12
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87,OFF ,12
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88,OFF ,12
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89,OFF ,12
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90,OFF ,12
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,12
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,12
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,12
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,12
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,12
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,12
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,12
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,12
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,12
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,12
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,12
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,12
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,12
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,12
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,12
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,12
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,12
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,12
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,12
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,12
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,12
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,12
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,12
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,12
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,12
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,12
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,12
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,12
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,12
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,12
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,12
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,12
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,12
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,12
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,12
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,12
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,12
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,12
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,12
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,12
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,12
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,12
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,12
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,12
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,12
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46,OFF ,12
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47,OFF ,12
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48,OFF ,12
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49,OFF ,12
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50,OFF ,12
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51,OFF ,12
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52,OFF ,12
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53,OFF ,12
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54,OFF ,12
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55,OFF ,12
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56,OFF ,12
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57,OFF ,12
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58,OFF ,12
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59,OFF ,12
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60,OFF ,12
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61,OFF ,12
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62,OFF ,12
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63,OFF ,12
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64,OFF ,12
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65,OFF ,12
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66,OFF ,12
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67,OFF ,12
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68,OFF ,12
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69,OFF ,12
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70,OFF ,12
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71,OFF ,12
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72,OFF ,12
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73,OFF ,12
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74,OFF ,12
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75,OFF ,12
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76,OFF ,12
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77,OFF ,12
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78,OFF ,12
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79,OFF ,12
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80,OFF ,12
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81,OFF ,12
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82,OFF ,12
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83,OFF ,12
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84,OFF ,12
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85,OFF ,12
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86,OFF ,12
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87,OFF ,12
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88,OFF ,12
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89,OFF ,12
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90,OFF ,12
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,30 %,12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,30 %,12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,30 %,12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,30 %,12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,50 %,12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,50 %,12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,50 %,12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,50 %,12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,75 %,12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,75 %,12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,80 %,12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,80 %,12
IDE12488-Antenna 1 for short-range communication,40 00 01 05 3F 14 05 0A 48 05 01 28 00 00 00 00 F0 03 14 00 A4 04 00 0F A0 00 00 07 02 00 00 00 00 00 00 01 00 00 01 FF 10 00 00 00 00 00 00 00 14 1E ,50
IDE12489-Antenna 2 for short-range communication,00 A1 00 05 0A 14 00 02 02 32 0A 00 00 00 00 00 0A 03 64 00 A4 04 00 0F A0 00 00 07 02 00 00 00 00 00 00 01 00 00 01 00 10 00 00 03 00 00 00 00 00 00 ,50
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1,OFF ,3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2,OFF ,3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3,OFF ,3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4,OFF ,3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5,OFF ,3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6,OFF ,3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7,OFF ,3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8,OFF ,3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9,OFF ,3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10,OFF ,3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11,OFF ,3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12,OFF ,3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13,OFF ,3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14,OFF ,3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15,OFF ,3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16,OFF ,3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17,OFF ,3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18,OFF ,3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19,OFF ,3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20,OFF ,3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1,OFF ,3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2,OFF ,3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3,OFF ,3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4,OFF ,3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5,OFF ,3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6,OFF ,3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7,OFF ,3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8,OFF ,3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9,OFF ,3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10,OFF ,3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11,OFF ,3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12,OFF ,3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13,OFF ,3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14,OFF ,3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15,OFF ,3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16,OFF ,3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17,OFF ,3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18,OFF ,3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19,OFF ,3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20,OFF ,3
IDE13611-Cornering lamp in operation,not active ,1
IDE13612-Matrix head lamps: steering angle,9600.00 °,2
IDE14431-Wireless charging: functions-,11 ,2
IDE14431-Wireless charging: functions-,level 1 ,2
ENG153902-NFC_FS_debug_switch,00 ,1
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
05
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE03251-Stop release for start-stop function,Always ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE09735-CU tailgate opener: sensor 1: threshold value 1,85 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,25 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,25 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,30 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,30 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,2 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,31 ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,2 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,31 ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,140 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,170 ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,0 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,0 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,1 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,27 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,11 ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,165 ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,158 ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,204 ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,220 ,1
IDE09755-CU tailgate opener: sensor 1: burst length,16 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,16 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,2 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,31 ,1
IDE09759-CU for tailgate opener: reset all counters,Unknown (224),1
IDE09760-CU for tailgate opener: check sum,170 ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,2 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,31 ,1
IDE09831-CU for tailgate opener: play protection increments,6 ,1
IDE09832-CU for tailgate opener: play protection decrements,25 ,1
IDE09833-CU for tailgate opener: play protection threshold active,255 ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,5 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,60 ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,16 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,16 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,0 ,1
IDE09839-CU for tailgate opener: parameter set version,30 ,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,1B ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,0E ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5
ENG248425-EasyOpen_optical_active,not activated ,1
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,7 B,1
ENG107595-MCTX settling phase,10 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG244880-Minimum_holdtime_ak,500 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG153707-IDE00047-Rear_lid_power_opening_control_unit_data_set_upload-Parameter set version,0 ,37
ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1,1 ,37
ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2,1 ,37
ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3,1 ,37
ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4,1 ,37
ENG153707-IDE80005-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 5,25 ,37
ENG153707-IDE80006-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 6,25 ,37
ENG153707-IDE80007-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 7,30 ,37
ENG153707-IDE80008-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 8,30 ,37
ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9,2 ,37
ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10,31 ,37
ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11,2 ,37
ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12,31 ,37
ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13,140 ,37
ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14,10 ,37
ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15,10 ,37
ENG153707-IDE80016-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 16,0 ,37
ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17,0 ,37
ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18,0 ,37
ENG153707-IDE80019-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 19,0 ,37
ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20,active ,37
ENG153707-IDE80021-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 21,not active ,37
ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22,not active ,37
ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23,Bottom ,37
ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24,static ,37
ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25,3 ,37
ENG153707-IDE80026-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 26,not active ,37
ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27,Dynamic ,37
ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28,5 ,37
ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29,6 ,37
ENG153707-IDE80030-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 30,active ,37
ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31,30 ,37
ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32,2 ,37
ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33,12 ,37
ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34,4 ,37
ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35,Do not reset ,37
ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36,16 ,37
ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37,16 ,37
ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38,16 ,37
ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39,16 ,37
ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40,2 ,37
ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41,31 ,37
ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42,2 ,37
ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43,31 ,37
ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44,224 ,37
ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45,10 ,37
ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46,10 ,37
ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47,0 ,37
ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48,0 ,37
ENG153707-IDE80049-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 49,0 ,37
ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50,0 ,37
ENG153707-IDE80051-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 51,6 ,37
ENG153707-IDE80052-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 52,25 ,37
ENG153707-IDE80053-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 53,255 ,37
ENG153707-IDE80054-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 54,5 ,37
ENG153707-IDE80055-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 55,60 ,37
ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56,220 ,37
ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type,27 ,37
ENG153707-MAS14087-Rear_lid_power_opening_control_unit_data_set_upload-time delay activation,Activation after 2s ,37
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1
ENG244883-Speed_ threshold_for_start_request_plausibilisation,10 km/h,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126938-Terminal_15_adaption_body_control_module,Default ,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG244884-Toggle_offtime_other_doorhandle,2.00 s,1
ENG244885-Toggle_offtime_same_doorhandle,2.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
5F
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248773-Production mode-p_mode_id_20,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,manual ,1
IDE00768-Country identification: country of sale,EE ,2
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02125-MAS08233-Voice operation for telephone-other,installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,installed ,1
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of loudspeakers-channel_1_lower_threshold,255 ,121
IDE02476-ENG248531-Electrical test of loudspeakers-channel_1_upper_threshold,255 ,121
IDE02476-ENG248533-Electrical test of loudspeakers-channel_10_lower_threshold,255 ,121
IDE02476-ENG248535-Electrical test of loudspeakers-channel_10_upper_threshold,255 ,121
IDE02476-ENG248537-Electrical test of loudspeakers-channel_11_lower_threshold,255 ,121
IDE02476-ENG248539-Electrical test of loudspeakers-channel_11_upper_threshold,255 ,121
IDE02476-ENG248541-Electrical test of loudspeakers-channel_12_lower_threshold,255 ,121
IDE02476-ENG248543-Electrical test of loudspeakers-channel_12_upper_threshold,255 ,121
IDE02476-ENG248545-Electrical test of loudspeakers-channel_13_lower_threshold,255 ,121
IDE02476-ENG248547-Electrical test of loudspeakers-channel_13_upper_threshold,255 ,121
IDE02476-ENG248549-Electrical test of loudspeakers-channel_14_lower_threshold,255 ,121
IDE02476-ENG248551-Electrical test of loudspeakers-channel_14_upper_threshold,255 ,121
IDE02476-ENG248553-Electrical test of loudspeakers-channel_15_lower_threshold,255 ,121
IDE02476-ENG248555-Electrical test of loudspeakers-channel_15_upper_threshold,255 ,121
IDE02476-ENG248557-Electrical test of loudspeakers-channel_16_lower_threshold,255 ,121
IDE02476-ENG248559-Electrical test of loudspeakers-channel_16_upper_threshold,255 ,121
IDE02476-ENG248561-Electrical test of loudspeakers-channel_17_lower_threshold,255 ,121
IDE02476-ENG248563-Electrical test of loudspeakers-channel_17_upper_threshold,255 ,121
IDE02476-ENG248565-Electrical test of loudspeakers-channel_18_lower_threshold,255 ,121
IDE02476-ENG248567-Electrical test of loudspeakers-channel_18_upper_threshold,255 ,121
IDE02476-ENG248569-Electrical test of loudspeakers-channel_19_lower_threshold,255 ,121
IDE02476-ENG248570-Electrical test of loudspeakers-channel_19_upper_threshold,255 ,121
IDE02476-ENG248573-Electrical test of loudspeakers-channel_2_lower_threshold,255 ,121
IDE02476-ENG248575-Electrical test of loudspeakers-channel_2_upper_threshold,255 ,121
IDE02476-ENG248577-Electrical test of loudspeakers-channel_20_lower_threshold,255 ,121
IDE02476-ENG248579-Electrical test of loudspeakers-channel_20_upper_threshold,255 ,121
IDE02476-ENG248581-Electrical test of loudspeakers-channel_21_lower_threshold,255 ,121
IDE02476-ENG248583-Electrical test of loudspeakers-channel_21_upper_threshold,255 ,121
IDE02476-ENG248585-Electrical test of loudspeakers-channel_22_lower_threshold,255 ,121
IDE02476-ENG248587-Electrical test of loudspeakers-channel_22_upper_threshold,255 ,121
IDE02476-ENG248589-Electrical test of loudspeakers-channel_23_lower_threshold,255 ,121
IDE02476-ENG248591-Electrical test of loudspeakers-channel_23_upper_threshold,255 ,121
IDE02476-ENG248593-Electrical test of loudspeakers-channel_24_lower_threshold,255 ,121
IDE02476-ENG248595-Electrical test of loudspeakers-channel_24_upper_threshold,255 ,121
IDE02476-ENG248599-Electrical test of loudspeakers-channel_3_lower_threshold,255 ,121
IDE02476-ENG248601-Electrical test of loudspeakers-channel_3_upper_threshold,255 ,121
IDE02476-ENG248603-Electrical test of loudspeakers-channel_4_lower_threshold,255 ,121
IDE02476-ENG248605-Electrical test of loudspeakers-channel_4_upper_threshold,255 ,121
IDE02476-ENG248607-Electrical test of loudspeakers-channel_5_lower_threshold,255 ,121
IDE02476-ENG248609-Electrical test of loudspeakers-channel_5_upper_threshold,255 ,121
IDE02476-ENG248611-Electrical test of loudspeakers-channel_6_lower_threshold,255 ,121
IDE02476-ENG248613-Electrical test of loudspeakers-channel_6_upper_threshold,255 ,121
IDE02476-ENG248615-Electrical test of loudspeakers-channel_7_lower_threshold,255 ,121
IDE02476-ENG248617-Electrical test of loudspeakers-channel_7_upper_threshold,255 ,121
IDE02476-ENG248619-Electrical test of loudspeakers-channel_8_lower_threshold,255 ,121
IDE02476-ENG248621-Electrical test of loudspeakers-channel_8_upper_threshold,255 ,121
IDE02476-ENG248623-Electrical test of loudspeakers-channel_9_lower_threshold,255 ,121
IDE02476-ENG248625-Electrical test of loudspeakers-channel_9_upper_threshold,255 ,121
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,49 ,121
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,49 ,121
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,49 ,121
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,49 ,121
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,49 ,121
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,49 ,121
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,49 ,121
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,49 ,121
IDE02476-ENG126164-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,49 ,121
IDE02476-ENG126166-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,49 ,121
IDE02476-ENG126168-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,49 ,121
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,49 ,121
IDE02476-ENG126170-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,49 ,121
IDE02476-ENG126172-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,49 ,121
IDE02476-ENG126174-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,49 ,121
IDE02476-ENG126176-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,49 ,121
IDE02476-ENG126178-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,49 ,121
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,49 ,121
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,49 ,121
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,49 ,121
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,49 ,121
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,49 ,121
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,49 ,121
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,49 ,121
IDE02502-Confirmation of installation change,ED 69 ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,not activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,not activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,not activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,not activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,not activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,not activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Databus extended ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,Ethernet ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Databus extended ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,Databus drivetrain ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Databus Infotainment ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,not activated ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Comfort data bus ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,not activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Databus Infotainment ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,not activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,not activated ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Comfort data bus ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,Comfort data bus ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,Comfort data bus ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Comfort data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,not activated ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,not activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Comfort data bus ,256
IDE04307-ENG260500-Vehicle function list BAP-ENI2_0x56,not activated ,256
IDE04307-ENG258203-Vehicle function list BAP-ENI2_0x56_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Comfort data bus ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,not activated ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Databus drivetrain ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Comfort data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,not activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Databus extended ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Comfort data bus ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,not activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,not activated ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,Databus Infotainment ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,Comfort data bus ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Databus extended ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Databus extended ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Databus Infotainment ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Comfort data bus ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE04330-Transfer of release code for a SWaP function,00 ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,0 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,not activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,not activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-Gnss update rate,1 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dBµV,28 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,32 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11122-Country identification: country of sale HMI,EE ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,01 ,1
IDE12364-ENG122340-Head-Up-Display: configuration-crossroad_detail_map_compression_mode,RLE ,3
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,0 ,3
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,OFF ,3
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,Master ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Master ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Master ,2
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG248412-5_ghz_wlan,OFF ,1
ENG248413-alphabetic_scrollbar,On ,1
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG252010-Car_net,we_connect ,1
ENG248423-channel_band_width_802_11ac,80MHz ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,BAP ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,BAP ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,OFF ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,1 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,IP_streaming ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,BAP ,8
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,0 ,12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,10 ,12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,50 ,12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,100 ,12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,220 ,12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,253 ,12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,2 %,12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,2 %,12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,6 %,12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,10 %,12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,80 %,12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,100 %,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,not installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,not installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,not installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,not installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,not installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,not installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,00 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,external_ethernet ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,OFF ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,On ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP_over_CAN_and_IP ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_without_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,usb_only ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,usb_only ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG101416-function_configuration_connectivity-Reserved_1,OFF ,6
ENG248430-ENG99458-function_configuration_connectivity-Reserved_2,not installed ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,On ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,OFF ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,OFF ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,OFF ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,not activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,On ,6
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,1 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,On ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,OFF ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,EU ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,On ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,On ,4
ENG248433-ENG248828-function_configuration_navigation-vza,not activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,OFF ,4
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,installed ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,Deactivated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG98891-function_configuration_phone-Reserved,OFF ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,On ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248435-ENG251555-function_configuration_pso-iaa_function,activated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,Deactivated ,2
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,activated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,EU_RdW ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,EU_Band_III-N ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,EU_RdW ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,activated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,automatic_without_time_scaling ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,On ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,native_hmi_only ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,1 ,8
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc,not_active ,3
ENG248437-ENG245031-function_configuration_rvc-rvc_low_black_screen_trunk_open,not activated ,3
ENG248437-ENG244966-function_configuration_rvc-rvc_low_black_screen_velocity_threshold,not activated ,3
ENG248437-ENG245015-function_configuration_rvc-rvc_low_failsafe,not activated ,3
ENG248437-ENG248807-function_configuration_rvc-rvc_low_lid_close_delay_time,0 s,3
ENG248437-ENG248808-function_configuration_rvc-rvc_low_videofailure_detection_time,0 ,3
ENG248438-ENG248523-function_configuration_sound-brand_sound,Dynaudio ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248439-ENG248632-function_configuration_speech-country_language_change,no_country ,2
ENG248439-ENG138660-function_configuration_speech-SDS_Region_Flag,no_region ,2
ENG244879-ENG137647-function_configuration_sw_update-UOTA,OFF ,1
ENG244879-ENG167532-function_configuration_sw_update-UOTA_2,OFF ,1
ENG244879-ENG249952-function_configuration_sw_update-UOTA_onboard_tester,Not available ,1
ENG248440-function_configuration_swap_fod,swap_active_fod_not_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,IVI_partition_only ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,FBAS ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,Deactivated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248442-geocoordinate_create,do_not_create ,1
ENG248443-geocoordinate_show,do_not show ,1
ENG248448-ENG248814-ipv4_address_of_subnet_1_on_ccu-segment_1,10 ,4
ENG248448-ENG248815-ipv4_address_of_subnet_1_on_ccu-segment_2,173 ,4
ENG248448-ENG248816-ipv4_address_of_subnet_1_on_ccu-segment_3,201 ,4
ENG248448-ENG248817-ipv4_address_of_subnet_1_on_ccu-segment_4,1 ,4
ENG248449-ENG248814-ipv4_address_of_subnet_1_on_mib-segment_1,10 ,4
ENG248449-ENG248815-ipv4_address_of_subnet_1_on_mib-segment_2,173 ,4
ENG248449-ENG248816-ipv4_address_of_subnet_1_on_mib-segment_3,201 ,4
ENG248449-ENG248817-ipv4_address_of_subnet_1_on_mib-segment_4,2 ,4
ENG248450-ENG248814-ipv4_address_of_subnet_2_on_ccu-segment_1,10 ,4
ENG248450-ENG248815-ipv4_address_of_subnet_2_on_ccu-segment_2,173 ,4
ENG248450-ENG248816-ipv4_address_of_subnet_2_on_ccu-segment_3,202 ,4
ENG248450-ENG248817-ipv4_address_of_subnet_2_on_ccu-segment_4,1 ,4
ENG248451-ENG248814-ipv4_address_of_subnet_2_on_mib-segment_1,10 ,4
ENG248451-ENG248815-ipv4_address_of_subnet_2_on_mib-segment_2,173 ,4
ENG248451-ENG248816-ipv4_address_of_subnet_2_on_mib-segment_3,202 ,4
ENG248451-ENG248817-ipv4_address_of_subnet_2_on_mib-segment_4,2 ,4
ENG248454-ENG248814-ipv4_address_of_subnet_4_on_ccu-segment_1,10 ,4
ENG248454-ENG248815-ipv4_address_of_subnet_4_on_ccu-segment_2,175 ,4
ENG248454-ENG248816-ipv4_address_of_subnet_4_on_ccu-segment_3,202 ,4
ENG248454-ENG248817-ipv4_address_of_subnet_4_on_ccu-segment_4,1 ,4
ENG248455-ENG248814-ipv4_address_of_subnet_4_on_mib-segment_1,10 ,4
ENG248455-ENG248815-ipv4_address_of_subnet_4_on_mib-segment_2,175 ,4
ENG248455-ENG248816-ipv4_address_of_subnet_4_on_mib-segment_3,202 ,4
ENG248455-ENG248817-ipv4_address_of_subnet_4_on_mib-segment_4,2 ,4
ENG248456-ENG248814-ipv4_address_of_the_wlan_ap-segment_1,10 ,4
ENG248456-ENG248815-ipv4_address_of_the_wlan_ap-segment_2,173 ,4
ENG248456-ENG248816-ipv4_address_of_the_wlan_ap-segment_3,189 ,4
ENG248456-ENG248817-ipv4_address_of_the_wlan_ap-segment_4,1 ,4
ENG248457-ENG248814-ipv6_address_of_subnet_1_on_ccu-segment_1,FD 30 ,8
ENG248457-ENG248815-ipv6_address_of_subnet_1_on_ccu-segment_2,E0 8E ,8
ENG248457-ENG248816-ipv6_address_of_subnet_1_on_ccu-segment_3,C0 31 ,8
ENG248457-ENG248817-ipv6_address_of_subnet_1_on_ccu-segment_4,00 01 ,8
ENG248458-ENG248814-ipv6_address_of_subnet_1_on_mib-segment_1,FD 30 ,8
ENG248458-ENG248815-ipv6_address_of_subnet_1_on_mib-segment_2,E0 8E ,8
ENG248458-ENG248816-ipv6_address_of_subnet_1_on_mib-segment_3,C0 31 ,8
ENG248458-ENG248817-ipv6_address_of_subnet_1_on_mib-segment_4,00 01 ,8
ENG248459-ENG248814-ipv6_address_of_subnet_2_on_ccu-segment_1,FD 30 ,8
ENG248459-ENG248815-ipv6_address_of_subnet_2_on_ccu-segment_2,E0 8E ,8
ENG248459-ENG248816-ipv6_address_of_subnet_2_on_ccu-segment_3,C0 31 ,8
ENG248459-ENG248817-ipv6_address_of_subnet_2_on_ccu-segment_4,00 02 ,8
ENG248460-ENG248814-ipv6_address_of_subnet_2_on_mib-segment_1,FD 30 ,8
ENG248460-ENG248815-ipv6_address_of_subnet_2_on_mib-segment_2,E0 8E ,8
ENG248460-ENG248816-ipv6_address_of_subnet_2_on_mib-segment_3,C0 31 ,8
ENG248460-ENG248817-ipv6_address_of_subnet_2_on_mib-segment_4,00 02 ,8
ENG248463-ENG248814-ipv6_address_of_subnet_4_on_ccu-segment_1,64816 ,8
ENG248463-ENG248815-ipv6_address_of_subnet_4_on_ccu-segment_2,57486 ,8
ENG248463-ENG248816-ipv6_address_of_subnet_4_on_ccu-segment_3,49201 ,8
ENG248463-ENG248817-ipv6_address_of_subnet_4_on_ccu-segment_4,512 ,8
ENG248464-ENG248814-ipv6_address_of_subnet_4_on_mib-segment_1,64816 ,8
ENG248464-ENG248815-ipv6_address_of_subnet_4_on_mib-segment_2,57486 ,8
ENG248464-ENG248816-ipv6_address_of_subnet_4_on_mib-segment_3,49201 ,8
ENG248464-ENG248817-ipv6_address_of_subnet_4_on_mib-segment_4,512 ,8
ENG248465-ENG248814-ipv6_address_of_the_wlan_ap-segment_1,FD 30 ,8
ENG248465-ENG248815-ipv6_address_of_the_wlan_ap-segment_2,E0 8E ,8
ENG248465-ENG248816-ipv6_address_of_the_wlan_ap-segment_3,C0 31 ,8
ENG248465-ENG248817-ipv6_address_of_the_wlan_ap-segment_4,01 03 ,8
ENG152375-ENG152428-Logging_Configuration-Interface,00 ,3
ENG152375-ENG152494-Logging_Configuration-loglevel,00 ,3
ENG152375-ENG98732-Logging_Configuration-Memory,00 ,3
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 28 02 50 02 50 02 28 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 48 ,40
ENG252007-Privacy_mode,not activated ,2
ENG248469-same_ssid_for_2_4_and_5_ghz,Yes ,1
ENG248470-sortorder,sortorder_1 ,1
ENG117919-Startup_Screen_Sticker_HMI,02 00 ,2
ENG248475-wlan_ap_local_net_dhcp_lease_time,72 H,1
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,12 ,1
6D
IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
IDE00001-MAS10735-Production mode-Calibration,not active ,3
IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
IDE02158-Program opening stop,1249 ,2
IDE03435-Detection area upper,10 ,2
IDE03776-Offset for maximum programmable opening stop,40 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,4 min,2
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,1 ,4
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,224 ,4
IDE09511-Minimum opening height of tailgate,400 ,2
IDE09512-Deactivation of tailgate,active ,1
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
IDE09520-Offset for opening height after basic setting,0 ,2
IDE10408-Opening height in production mode,60 %,2
IDE10695-Dectivation of the luggage compartment cover,not active ,1
IDE10703-Luggage compartment cover: tolerance of the block counter,0 ,2
IDE10704-Luggage compartment cover: maximum no. of block drives,0 ,2
IDE10705-Luggage compartment cover: number bloom drives,0 ,2
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,0 ,4
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0 ,4
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,0 ,4
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,0 ,4
IDE10708-Luggage compartment cover: adjust. track tolerance,0 ,2
IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,not active ,2
ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active ,2
ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active ,2
ENG131232-MAS08212-Ausstattungen aktivieren-Engine 2,not active ,2
ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,not active ,2
08
IDE00001-Production mode,Deactivating ,3
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1
IDE01479-Gear ratio of engine - A/C compressor,0.00 ,1
IDE01483-Blower voltage for voice operation,not activated ,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01493-Air quality sensor sensitivity,Maximum ,1
IDE01503-Runtime for compressor run-in basic setting,10 s,1
IDE01536-Post-heating of parking heater,0 min,1
IDE02155-Reset all counters,not activated ,1
IDE03176-Duration of compressor run in,0 s,1
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06546-Interior target temperature for production routines,22 °C,1
IDE06547-Air distribution for production routines,No effect ,1
IDE06593-Recirculation air for production routines,No effect ,1
IDE07108-Climate modes,Matching coding ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE07301-Remote start function: activation of seat heating,Seat heater front ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.,4 °C,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,15 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20 °C,1
IDE07307-Remote start function: activation stage of seat heating,2 ,1
IDE07308-Remote start function: activation stage of seat ventilation,2 ,1
IDE07398-Blower logic for manual adjustment,Matching coding ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE12229-Filtering of interior air: store,not active ,1
IDE13676-Remote start function: rear window defogger,activated ,1
IDE13677-Remote start function: seat climate control takeover,activated ,1
IDE80006-Analysis 6,not activated ,1
IDE80007-Analysis 7,00000000 00000000 ,2
IDE80008-Analysis 8,not active ,1
MAS05739-CO2 compressor on-time reduction,Matching coding ,1
MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
MAS07251-Cut-in behavior,Matching coding ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
MAS17226-Remote start function: windshield defogger can be activated,activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
ENG122846-ENG99777-dimming_characteristic_3-Y1,3 %,12
ENG122846-ENG100480-dimming_characteristic_3-Y2,3 %,12
ENG122846-ENG100773-dimming_characteristic_3-Y3,6 %,12
ENG122846-ENG100631-dimming_characteristic_3-Y4,12 %,12
ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %,12
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %,12
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
ENG248446-HMI_View_Switch,Yes ,1
ENG130577-Knockout_timer_activation,not activated ,1
09
SW:5Q0-937-086-CF HW:5Q0-937-086-BR --- Cent. Elect.
Component:BCM PQ37BOSCH 038 0303, Coding:000000000000000000000000000000000000000000000000000000000000
EV_BodyContrModul1UDSBosc,020001,EV_BCMBOSCH_020_VW27.rod
Friday,27,September,2019,12:54:47:57784
VCDS Version: Release 19.6.1 (x64) Data version: 20190529 DS308.0
VCID: 005A8AA3BA8D1887CA9-8054
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
IDE01550-Service position,153.296551 °,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,300 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,300 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,300 ms,10
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,not installed ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,100.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe,installed ,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,activ ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,Yes ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,26 08 00 16 24 00 7F 06 00 80 02 00 7F 00 00 00 26 18 00 18 24 00 7F 07 00 80 04 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 38 00 22 12 16 7F 00 00 00 00 00 00 00 00 00 01 42 00 23 13 17 7F 00 00 00 00 00 00 00 00 00 35 52 00 5D 52 00 7F 08 09 7F 00 00 00 00 00 00 35 53 00 5E 52 00 7F 08 0A 7F 00 00 00 00 00 00 20 00 00 00 1E 00 7F 28 00 80 00 00 00 00 00 00 24 00 00 00 3F 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 04 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 C2 28 29 ,172
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,1 ,30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,17.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,17.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,27.50 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,26.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,27.50 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,26.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG249923-A/C heater function via remote control-pa_RSt_MOD_verbaut,not installed ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,24.890085 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,1 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,50 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht,installed ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,8.296695 °,2
IDE10299-Alternating park position 2,24.890085 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.40 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.60 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000101 ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00111100 ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000010 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000 ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00011100 ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000 ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000 ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,127 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,127 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,127 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,127 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,127 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,127 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,127 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0.5 s,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,64 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,20 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,170 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,30 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,30 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,11 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,255 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,250 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,100 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,160 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,190 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,230 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,238 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,255 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,175 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,170 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,250 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,230 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,230 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,230 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,255 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,230 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,210 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,210 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,64 ,30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin,3 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,24 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,1 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,4 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,5 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,4 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,3 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,3 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,255 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,255 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,226 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,3 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,88 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,178 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,198 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,255 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,255 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,175 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,78 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,138 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,255 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,255 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,255 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,255 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,182 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,149 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,114 ,30
MAS05055-lower turn position,26.296677 °,2
MAS05056-upper turn position,171.296533 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,30 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,30 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,110 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,140 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,160 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,200 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,255 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,255 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,255 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,255 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,255 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,255 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,255 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,255 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,255 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,255 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,115 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,90 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,70 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,100 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,255 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,235 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,235 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,255 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,225 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,225 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,200 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,160 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,120 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,90 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,40 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,30 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,30 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,30 ,60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,40 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,90 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,110 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,60 ,60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,50 ,60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,10 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,30 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,65 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,120 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,195 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,220 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,255 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,255 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,255 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,255 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,240 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,3 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,2 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,27 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,17 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,60 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,43 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,125 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,200 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,255 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,255 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,255 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,255 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,247 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,255 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,255 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,244 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,42 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,19 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,19 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,42 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,255 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,255 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,255 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,255 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,255 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,255 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,255 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,255 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,146 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,65 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,20 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,3 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,38 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,60 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,30 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,32 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,8 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,34 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,79 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,138 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,59 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,6 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,24 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,70 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,19 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,3 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,1 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,32 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,20 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,9 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,1 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,28 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,63 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,142 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,188 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,255 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,255 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,255 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,255 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,255 ,60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,I-panel ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,multicolor ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,12 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,16 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,20 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,21 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,installed ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,installed ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,not active ,13
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,not active ,13
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,1.00 ,13
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,1.00 ,13
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,0.73 ,13
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,0.14 ,13
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,1.00 ,13
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,0.86 ,13
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,1.00 ,13
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,0.86 ,13
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,1.00 ,13
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,0 ms,22
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,200 ms,22
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,2000 ms,22
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,400 ms,22
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,600 ms,22
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,800 ms,22
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,1000 ms,22
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,1200 ms,22
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,1400 ms,22
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,1600 ms,22
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,1800 ms,22
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,0.0 %,22
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,0.5 %,22
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,100.0 %,22
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,2.0 %,22
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,5.0 %,22
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,10.0 %,22
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,20.0 %,22
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,40.0 %,22
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,80.0 %,22
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,95.0 %,22
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,99.0 %,22
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,6 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,19 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,3 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,8 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,18 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,21 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,21 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Wechselblinken_Warnblinken_Bremsblinken ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_aktiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,3000 ms,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Keine_Spannungsanforderung ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,nfc ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,active ,3
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141685-Front_wash_function,10 ,2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
ENG126651-ENG115658-Kennlinie Abdimmen-x0,0 ,22
ENG126651-ENG101574-Kennlinie Abdimmen-X1,200 ,22
ENG126651-ENG115664-Kennlinie Abdimmen-x10,2000 ,22
ENG126651-ENG99557-Kennlinie Abdimmen-X2,400 ,22
ENG126651-ENG102140-Kennlinie Abdimmen-X3,600 ,22
ENG126651-ENG102936-Kennlinie Abdimmen-X4,800 ,22
ENG126651-ENG103548-Kennlinie Abdimmen-X5,1000 ,22
ENG126651-ENG113992-Kennlinie Abdimmen-X6,1200 ,22
ENG126651-ENG115661-Kennlinie Abdimmen-x7,1400 ,22
ENG126651-ENG115662-Kennlinie Abdimmen-x8,1600 ,22
ENG126651-ENG115663-Kennlinie Abdimmen-x9,1800 ,22
ENG126651-ENG115659-Kennlinie Abdimmen-y0,100.0 ,22
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,99.0 ,22
ENG126651-ENG115668-Kennlinie Abdimmen-y10,0.0 ,22
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,95.0 ,22
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,80.0 ,22
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,40.0 ,22
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,20.0 ,22
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,10.0 ,22
ENG126651-ENG115665-Kennlinie Abdimmen-y7,5.0 ,22
ENG126651-ENG115666-Kennlinie Abdimmen-y8,2.0 ,22
ENG126651-ENG115667-Kennlinie Abdimmen-y9,0.5 ,22
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,45.5 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,45.5 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,45.5 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,45.5 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,41.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,37.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,32.5 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,28.5 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,24.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,minimize ,16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,16 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,08 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,38 - LED Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Quittierungsfunktion 1 ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links aktiv (beide Phasen) ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,39 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,10 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,3A ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,20 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parking light right ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Quittierungsfunktion 1 ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links aktiv (beide Phasen) ,16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,Blinken links Hellphase ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Quittierungsfunktion 1 ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts aktiv (beide Phasen) ,16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,Blinken rechts Hellphase ,16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,minimize ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,18 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,18 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,38 - LED Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Quittierungsfunktion 1 ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts aktiv (beide Phasen) ,16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,25 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,25 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,2E ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0C ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake light ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Rear lid open ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,Brake light ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,38 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,00 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,34 - LED Bremsleuchten ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake light ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,29 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0A ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,32 - allgemeine LED bis 12W ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2A ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,Parking light right ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,22 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,38 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Nebellicht links ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Abbiegelicht links ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,23 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,42 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Nebellicht rechts ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Abbiegelicht rechts ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,127 ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,5D ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,52 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,53 - LED LeiMo3G o Open Load ,16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Versorgungsbedarf der LED-LeiMo3G-Module ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,127 ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,5E ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,53 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,53 - LED LeiMo3G o Open Load ,16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Versorgungsbedarf der LED-LeiMo3G-Module ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,Parking light right ,16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,minimize ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,32 - allgemeine LED bis 12W ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Coming Home oder Leaving Home aktiv ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 24 00 7F 06 00 80 02 00 7F 00 00 00 26 18 00 18 24 00 7F 07 00 80 04 00 7F 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 18 00 99 1A 00 7F 21 00 80 18 00 19 22 00 00 38 18 00 7F 1A 00 80 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 10 00 39 08 09 7F 00 00 00 00 00 00 00 00 00 2B 20 00 3A 08 0A 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001 ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.50 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,25.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,40 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,45 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,50 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,57 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,not installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,installed ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,7 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 2.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,not active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
ENG122927-RLS_close_glazing,2.0 s,1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
ENG122929-RLS_LIN_Communication,4 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,1
ENG122935-RLS_Washer_Front,15 s,1
ENG122926-RLS_wiper_position_parking,15 s,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2550 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,84 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,166 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,250 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,370 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,active ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,installed ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,active ,7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal,Inverted ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
Elapsed Time: 02:06
10
IDE00001-Production mode,Deactivating ,3
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble,not activated ,1
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble,not activated ,1
IDE00845-Wheel circ.,2070 mm,2
IDE01165-Park assist activation tone,On ,1
IDE01167-Convertible offset for volume level 1,255 ,1
IDE01168-Increment for convertible volume levels,255 ,1
IDE01169-Audio reduction request,On ,1
IDE02328-Distance to curb,15 cm,1
IDE03782-Switch-off speed for parking assist,15 km/h,1
IDE03783-Switch-on speed for parallel parking assist,37 km/h,1
IDE04159-Deactivation of start-stop function,Start-stop function in control module active ,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE11215-Automatic Activation,activated ,1
IDE14666-Parking aid: personalization,activated ,1
MAS01426-Speaker volume for rear park assist,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 1 ,1
MAS01428-Speaker volume for front park assist,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 7 ,1
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners,0.234 1/m,6
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners,0.180 1/m,6
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang,1.185 m,6
MAS12129-Customer-oriented off-road trip,not activated ,1
MAS12843-Maneuvering brake function,activated ,1
13
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01795-Heated lens,OFF ,1
IDE01949-Distance basic setting option,On ,1
IDE03642-Presentation mode,not active ,1
IDE04330-Transfer of release code for a SWaP function,00 ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,On ,1
IDE09564-Distance change via speed adjustment,On ,1
IDE09565-Prioritized target object display,OFF ,1
IDE10280-Constant delay after transfer request,Yes ,1
IDE12516-Predictive speed limit regulation,activated ,1
MAS19336-Active participant function activated,activated ,1
15
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE06314-Calibration data: pre-crash,60 00 00 60 E0 00 08 60 80 FF A0 F8 E0 60 E8 60 60 83 ,18
IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,activated ,4
IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,activated ,4
IDE06527-MAS00478-Adaptation pre-crash-Reserved,2 ,4
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,not defined ,8
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined ,8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined ,8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,activated ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,activated ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed ,8
MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined ,8
17
IDE00001-Production mode-,No ,3
IDE00295-Oil temperature display,On ,1
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,estonian ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,12 H,1
IDE00501-Minute,52 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,9 mon,1
IDE00504-Day,27 d,1
IDE00510-ESI: distance driven from inspection,1 km,3
IDE00511-ESI: time from inspection,2 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,0 km,2
IDE00819-Day counter,21 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,8.2 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS02957-Units adjusted-Time,24h ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,2
IDE03352-FIX: Time since last time-dependent inspection,2 d,2
IDE03372-Source for synchronization of time,GPS ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,No ,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Not available ,1
IDE07221-Cylinder shut-off,Display ,1
IDE11086-Service notification,30 d,1
IDE11932-MAS01877-Display of colour adjustment-Red,0 ,3
IDE11932-MAS01878-Display of colour adjustment-Green,0 ,3
IDE11932-MAS01879-Display of colour adjustment-Blue,0 ,3
IDE12211-China variant,No ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12467-Tubes illustration,Version 3 ,1
IDE12722-Driving profile display,No ,1
IDE13094-Tachometer end value,Version 0 ,1
IDE13607-MAS16698-Lock display contents-Lock infotainment list,No ,9
IDE13607-MAS16699-Lock display contents-Lock function lists,No ,9
IDE13607-MAS16700-Lock display contents-Lock MFA displays,No ,9
IDE13607-MAS16701-Lock display contents-Dynamic image lock,No ,9
IDE13607-MAS16702-Lock display contents-Lock functional animation,No ,9
IDE13607-MAS16703-Lock display contents-lock,No ,9
IDE13607-MAS16704-Lock display contents-Lock system status animation,No ,9
IDE13607-MAS16705-Lock display contents-Lock operating support animation,No ,9
IDE13607-MAS16706-Lock display contents-List time out,0 s,9
IDE13607-MAS17250-Lock display contents-Map locked,No ,9
IDE13607-MAS17251-Lock display contents-Piloted driving locked,No ,9
IDE13607-MAS17283-Lock display contents-Vehicle model locked,No ,9
IDE13607-MAS17284-Lock display contents-Cover intensity locked,100 %,9
IDE13607-MAS17285-Lock display contents-Number of list entries blocked,0 ,9
IDE14184-Active participant personalization,Yes ,1
IDE14220-Vehicle speed warning for India-,No ,1
IDE14220-Vehicle speed warning for India-,60 s,1
IDE14984-R Logo,no R logo ,1
IDE14986-ACC illustration China,No display ,1
IDE15073-ENG249922-Digital Key 3-number_of_repeats_of_authentication_of_central_locking,05 ,3
IDE15073-ENG249951-Digital Key 3-time_for_waiting_of_receive_of_message_MDK_ZV_Resp,00 0A s,3
IDE15113-Shift exit warning,Car exit warning ,1
IDE15132-Activate/deactivate development messages via Ethernet,not active ,1
MAS01299-Offroad,No display ,1
ENG253348-3D_speed,not active ,1
ENG114742-Activation of Development Messages,not active ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,14 ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,96 ,12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,02 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,04 ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,32 ,12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,01 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,01 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,03 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,06 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,01 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,01 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,03 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,06 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,28 ,12
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 96 ,24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 78 ,24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,00 E6 ,24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,01 F4 ,24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 32 ,24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 64 ,24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 96 ,24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 0C ,24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 0C ,24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 23 ,24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,00 46 ,24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,01 F4 ,24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG119833-Display_Save_CP,Yes ,1
ENG119874-Gas_functionality,not active ,1
ENG251650-GPS_speed,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,auto_lowbeam_foglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG249798-MDK_coding-,00 ,8
ENG249798-MDK_coding-,01 ,8
ENG249799-ENG249828-MDK_parameter-AZK bConfig COV,00 ,36
ENG249799-ENG249829-MDK_parameter-AZK num Time resp KY,800 ms,36
ENG249799-ENG249830-MDK_parameter-AZK num Time resp MDK,800 ms,36
ENG249799-ENG249831-MDK_parameter-AZK num Time resp WFS,5000 ms,36
ENG249799-ENG249904-MDK_parameter-MDK num Time Zv Cmd High,200 ms,36
ENG249799-ENG249905-MDK_parameter-MDK num Time Zv Cmd Low,100 ms,36
ENG249799-ENG249929-MDK_parameter-Rep Cmd Apdu,01 ,36
ENG249799-ENG249930-MDK_parameter-Rep User Auth,01 ,36
ENG249799-ENG249944-MDK_parameter-Time Esm Aktiv,10 s,36
ENG249799-ENG249945-MDK_parameter-Time Out Mob Dev Key Cmd,30 s,36
ENG249799-ENG249946-MDK_parameter-Time Out Resp Apdu,500 s,36
ENG249799-ENG249947-MDK_parameter-Time Out Ticket Table,120 s,36
ENG249799-ENG249948-MDK_parameter-Time Out VTAN Dec,30 s,36
ENG249799-ENG249949-MDK_parameter-Time Out VTAN Resp,10 s,36
ENG249799-ENG249950-MDK_parameter-Time SKC1,15 s,36
ENG249799-ENG249953-MDK_parameter-Veh Arch,00 ,36
ENG249800-ENG249840-MDK_parameter_2-Dev Param 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG249800-ENG249841-MDK_parameter_2-Dev Param 2,14 02 46 46 46 32 32 32 02 C8 C8 05 0A 1E 64 01 0A 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG103063-Mileage,20 km,3
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG153765-Second_digital_speed,No display ,1
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG98918-Sport,No display ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
19
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
IDE00002-Transport mode,not active ,1
IDE01211-Static current measuring mode,not activated ,1
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01459-Energy management heat output control status,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
IDE01860-Generator specified voltage value variable,10.6 V,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,69 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE04186-Battery terminal recognition,connected ,1
IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
IDE06541-Distance left for deactivation of transport mode,50 ,1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE07838-Counter for inconsistent states,0 ,2
IDE08348-Start/stop start voltage limit,7.8 V,1
IDE08624-MKE Check box,activated ,1
IDE10735-Number requests autonomous recharging,3 ,1
IDE10736-Cyclization limitation request battery service,0 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,not activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
IDE11689-48V-System: locking,regular operation ,1
IDE13756-Diagnosis filter: activation,not active ,1
IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,200 km,2
IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,20 km,2
MAS16372-Security version number,2 ,2
SFT271921-IDE02583-Multi Function Steering Wheel Control Module-Steering wheel Tiptronic switch,installed ,3
SFT271921-MAS04733-Multi Function Steering Wheel Control Module-Two-stage,not active ,3
SFT271921-MAS06614-Multi Function Steering Wheel Control Module-Version,ACC ,3
SFT271921-MAS09758-Multi Function Steering Wheel Control Module-Temperature sensor,installed ,3
SFT271921-MAS19102-Multi Function Steering Wheel Control Module-Dimming after-run,active ,3
SFT271921-MAS19103-Multi Function Steering Wheel Control Module-Local data bus: wake-up function,not active ,3
SFT271921-MAS19104-Multi Function Steering Wheel Control Module-Alarm horn wake-up function,not active ,3
SFT272190-Control module for steering wheel touch recognition,data_set_2 ,3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1
ENG137850-MVK_Warning,regular operation ,1
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
47
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of loudspeakers-channel_1_lower_threshold,18 ,121
IDE02476-ENG248531-Electrical test of loudspeakers-channel_1_upper_threshold,22 ,121
IDE02476-ENG248533-Electrical test of loudspeakers-channel_10_lower_threshold,18 ,121
IDE02476-ENG248535-Electrical test of loudspeakers-channel_10_upper_threshold,22 ,121
IDE02476-ENG248537-Electrical test of loudspeakers-channel_11_lower_threshold,18 ,121
IDE02476-ENG248539-Electrical test of loudspeakers-channel_11_upper_threshold,22 ,121
IDE02476-ENG248541-Electrical test of loudspeakers-channel_12_lower_threshold,18 ,121
IDE02476-ENG248543-Electrical test of loudspeakers-channel_12_upper_threshold,22 ,121
IDE02476-ENG248545-Electrical test of loudspeakers-channel_13_lower_threshold,18 ,121
IDE02476-ENG248547-Electrical test of loudspeakers-channel_13_upper_threshold,22 ,121
IDE02476-ENG248549-Electrical test of loudspeakers-channel_14_lower_threshold,18 ,121
IDE02476-ENG248551-Electrical test of loudspeakers-channel_14_upper_threshold,22 ,121
IDE02476-ENG248553-Electrical test of loudspeakers-channel_15_lower_threshold,18 ,121
IDE02476-ENG248555-Electrical test of loudspeakers-channel_15_upper_threshold,22 ,121
IDE02476-ENG248557-Electrical test of loudspeakers-channel_16_lower_threshold,18 ,121
IDE02476-ENG248559-Electrical test of loudspeakers-channel_16_upper_threshold,22 ,121
IDE02476-ENG248561-Electrical test of loudspeakers-channel_17_lower_threshold,18 ,121
IDE02476-ENG248563-Electrical test of loudspeakers-channel_17_upper_threshold,22 ,121
IDE02476-ENG248565-Electrical test of loudspeakers-channel_18_lower_threshold,18 ,121
IDE02476-ENG248567-Electrical test of loudspeakers-channel_18_upper_threshold,22 ,121
IDE02476-ENG248569-Electrical test of loudspeakers-channel_19_lower_threshold,18 ,121
IDE02476-ENG248570-Electrical test of loudspeakers-channel_19_upper_threshold,22 ,121
IDE02476-ENG248573-Electrical test of loudspeakers-channel_2_lower_threshold,18 ,121
IDE02476-ENG248575-Electrical test of loudspeakers-channel_2_upper_threshold,22 ,121
IDE02476-ENG248577-Electrical test of loudspeakers-channel_20_lower_threshold,18 ,121
IDE02476-ENG248579-Electrical test of loudspeakers-channel_20_upper_threshold,22 ,121
IDE02476-ENG248581-Electrical test of loudspeakers-channel_21_lower_threshold,18 ,121
IDE02476-ENG248583-Electrical test of loudspeakers-channel_21_upper_threshold,22 ,121
IDE02476-ENG248585-Electrical test of loudspeakers-channel_22_lower_threshold,18 ,121
IDE02476-ENG248587-Electrical test of loudspeakers-channel_22_upper_threshold,22 ,121
IDE02476-ENG248589-Electrical test of loudspeakers-channel_23_lower_threshold,18 ,121
IDE02476-ENG248591-Electrical test of loudspeakers-channel_23_upper_threshold,22 ,121
IDE02476-ENG248593-Electrical test of loudspeakers-channel_24_lower_threshold,18 ,121
IDE02476-ENG248595-Electrical test of loudspeakers-channel_24_upper_threshold,22 ,121
IDE02476-ENG248599-Electrical test of loudspeakers-channel_3_lower_threshold,18 ,121
IDE02476-ENG248601-Electrical test of loudspeakers-channel_3_upper_threshold,22 ,121
IDE02476-ENG248603-Electrical test of loudspeakers-channel_4_lower_threshold,18 ,121
IDE02476-ENG248605-Electrical test of loudspeakers-channel_4_upper_threshold,22 ,121
IDE02476-ENG248607-Electrical test of loudspeakers-channel_5_lower_threshold,18 ,121
IDE02476-ENG248609-Electrical test of loudspeakers-channel_5_upper_threshold,22 ,121
IDE02476-ENG248611-Electrical test of loudspeakers-channel_6_lower_threshold,18 ,121
IDE02476-ENG248613-Electrical test of loudspeakers-channel_6_upper_threshold,22 ,121
IDE02476-ENG248615-Electrical test of loudspeakers-channel_7_lower_threshold,18 ,121
IDE02476-ENG248617-Electrical test of loudspeakers-channel_7_upper_threshold,22 ,121
IDE02476-ENG248619-Electrical test of loudspeakers-channel_8_lower_threshold,18 ,121
IDE02476-ENG248621-Electrical test of loudspeakers-channel_8_upper_threshold,22 ,121
IDE02476-ENG248623-Electrical test of loudspeakers-channel_9_lower_threshold,18 ,121
IDE02476-ENG248625-Electrical test of loudspeakers-channel_9_upper_threshold,22 ,121
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,29 ,121
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,29 ,121
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,29 ,121
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,29 ,121
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,29 ,121
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,29 ,121
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,29 ,121
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,29 ,121
IDE02476-ENG126164-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,29 ,121
IDE02476-ENG126166-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,29 ,121
IDE02476-ENG126168-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,29 ,121
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,29 ,121
IDE02476-ENG126170-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,29 ,121
IDE02476-ENG126172-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,29 ,121
IDE02476-ENG126174-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,29 ,121
IDE02476-ENG126176-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,29 ,121
IDE02476-ENG126178-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,29 ,121
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,29 ,121
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,29 ,121
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,29 ,121
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,29 ,121
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,29 ,121
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,29 ,121
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,29 ,121
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,-128 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,not installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,not installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,not installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,not installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,not installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,00 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,external_ethernet ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248438-function_configuration_sound,Dynaudio ,2
75
IDE00608-MAS00713-Type of fuel-Petrol,installed ,1
IDE00608-MAS00716-Type of fuel-Diesel,not installed ,1
IDE00608-MAS00717-Type of fuel-Petroleum gas,not installed ,1
IDE00608-MAS00718-Type of fuel-Natural gas,not installed ,1
IDE00608-MAS00720-Type of fuel-Battery / electric,not installed ,1
IDE00608-MAS03131-Type of fuel-Hydrogen,not installed ,1
IDE00761-MAS08397-After-run time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-After-run time-Short term energy budget,1000 mAh,5
IDE00761-MAS08399-After-run time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Number 1 for Info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages,activated ,1
IDE02330-Number 2 for Info call,empty ,5
IDE02331-Number 2 for roadside assistance,empty ,5
IDE02332-Deactivate production mode,00 00 00 ,3
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252043-Vehicle function list CAN-Clima,activated ,3
IDE03581-ENG252092-Vehicle function list CAN-Dash_Board,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG252080-Vehicle function list CAN-Front_door_co_driver,activated ,3
IDE03581-ENG252077-Vehicle function list CAN-Front_door_driver,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE03581-ENG252094-Vehicle function list CAN-seat_memory_driver,activated ,3
IDE03581-ENG252083-Vehicle function list CAN-Steering_Column_Electronics,activated ,3
IDE04307-IDE01762-Vehicle function list BAP-Doors,activated ,11
IDE04307-IDE03031-Vehicle function list BAP-Seat adjustment,activated ,11
IDE04307-IDE03111-Vehicle function list BAP-Interior light,activated ,11
IDE04307-MAS00688-Vehicle function list BAP-Multifunction indicator,activated ,11
IDE04307-MAS00903-Vehicle function list BAP-Service interval display (SID),activated ,11
IDE04307-MAS01118-Vehicle function list BAP-Climate control,activated ,11
IDE04307-MAS01282-Vehicle function list BAP-Wiper,activated ,11
IDE04307-MAS01891-Vehicle function list BAP-Lane assistant,not activated ,11
IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,11
IDE04307-MAS02957-Vehicle function list BAP-Time,not activated ,11
IDE04307-MAS03385-Vehicle function list BAP-Lane change assistance,activated ,11
IDE04307-MAS03420-Vehicle function list BAP-Head-Up Display,not activated ,11
IDE04307-MAS03853-Vehicle function list BAP-Road sign detection,not activated ,11
IDE04307-MAS04219-Vehicle function list BAP-Parking heater,not activated ,11
IDE04307-MAS05087-Vehicle function list BAP-ACC,activated ,11
IDE04307-MAS05506-Vehicle function list BAP-Stopping distance reduction,activated ,11
IDE04307-MAS06010-Vehicle function list BAP-Ambient light,activated ,11
IDE04307-MAS06012-Vehicle function list BAP-Reversible seat belt tensioner,not activated ,11
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,11
IDE04307-MAS08072-Vehicle function list BAP-Driving profile selection,not activated ,11
IDE04307-MAS08785-Vehicle function list BAP-Parking aid,activated ,11
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,11
IDE04307-ENG258892-Vehicle function list BAP-info_settings_msg_bus,by_Ethernet ,11
IDE04307-ENG245026-Vehicle function list BAP-infotainment_settings_0x50,not activated ,11
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,11
IDE04307-ENG152569-Vehicle function list BAP-remote_services_profile_0x4E,activated ,11
IDE04307-ENG244983-Vehicle function list BAP-road_experience_management_0x5B,not activated ,11
IDE04307-ENG258850-Vehicle function list BAP-road_experience_management_2_0x67,not activated ,11
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,11
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,not activated ,11
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,255 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,60 min,2
IDE07699-Mobile network operator,info.m2mcubic.com ,21
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,OFF ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,OFF ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,On ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,On ,1
IDE09244-Fuel tank volume,70 l,1
IDE11108-Remote vehicle immobilizer safety protocol,Fazit4MyCar ,1
IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,not activated ,5
IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,activated ,5
IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,5 s,5
IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,10 s,5
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Maximum private sphere in shape 2 ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,not activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic setting not recognized Guest: services,Workshop settings adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic setting not recognized Guest: campaigns with interest weighting,Workshop settings adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic setting not recognized Guest: campaigns with consent,Workshop settings adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,No display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,No display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE14995-ENG98891-Private sphere mode: workshop settings-Reserved,0 ,7
IDE15042-MAS19716-Private sphere mode: customer settings-Services,Maximum private sphere in shape 2 ,3
IDE15042-MAS19722-Private sphere mode: customer settings-Data collector,not activated ,3
IDE15042-MAS19887-Private sphere mode: customer settings-Display info window for current privacy settings,No display ,3
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
MAS01078-Vehicle type,Passenger car (category M1) ,1
MAS03876-active SIM card,internal ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://mod3vkmsmbbreg-0.prd.ece.vwg-connect.com:443/mbb/vehicles/v2/deviceRegistered ,86
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,86
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,MBB ,86
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08366-MAS01487-Keypad-LED,Direct ,1
MAS08366-MAS10536-Keypad-Keys,Three button keypad ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13395-Transmission_status_activation-,activated ,5
MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,0 d,5
MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-StepsBelowThreshold,5 %,3
MAS13840-Gnss data transmission rate,1 Hz ,2
MAS13841-Gnss min height,5 °,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17427-MAS00220-Door configuration-Left rear door,installed ,1
MAS17427-MAS00221-Door configuration-Right rear door,installed ,1
MAS17427-SFT271922-Door configuration-Left rear door control module,installed ,1
MAS17427-SFT271923-Door configuration-Right rear door control module,installed ,1
MAS17439-Wifi hotspot mobile phone connection: network operator,wifi.m2mcubic.com ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name,blank ,5
MAS17461-Wifi hotspot mobile phone connection: password,blank ,5
MAS17554-Digital key: backend notification,activated ,1
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18217-IDE09602-Activation status for local hazard warning service-Locale hazard warning,OFF ,1
MAS18217-MAS18218-Activation status for local hazard warning service-Crash,OFF ,1
MAS18217-MAS18219-Activation status for local hazard warning service-Breakdown,OFF ,1
MAS18217-MAS18220-Activation status for local hazard warning service-Loss of traction,OFF ,1
MAS18217-MAS18221-Activation status for local hazard warning service-Visual obstruction,OFF ,1
MAS18217-MAS18222-Activation status for local hazard warning service-Hydroplaning,OFF ,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS18701-Setting the product data,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 C6 02 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3296
MAS19210-Maximum waiting time to transfer UserID from IAA,150 ms,1
MAS19211-Delay time for synchronization with memory site,400 ms,1
MAS19213-Operation during severe BAP errors while storing data,Operation fortführen ,1
MAS19214-Maximum synchronization of an unused shadow drive,28 d,1
MAS19215-Waiting time until change to settings is transferred,60 s,2
MAS19216-Number of extensions until transfer is completed,3 s,1
MAS19218-Delay time for picking up changes,120 s,1
MAS19219-Maximum waiting time for HMI availability,5 min,1
MAS19220-Download before activating driver (driver already stored),Do not perform download ,1
MAS19221-Maximum storage duration,120 s,1
MAS19222-Maximum waiting time before storing is canceled,5 s,1
MAS19233-Identify Authorize Authenticate - user management,installed ,1
MAS19239-Time window for key recognition,5 s,1
MAS19240-Authorization level after-run time,30 s,1
MAS19241-Key recognition mode setting,automatic ,1
MAS19242-User images display,On ,1
MAS19243-BCM user switching,OFF ,1
MAS19244-Permanent safety mode setting,On ,1
MAS19335-Maximum duration of relocation,60 s,1
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG244879-function_configuration_sw_update,On ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG247336-MAS01424-Geofencing_Area_Height-max.value,4294967294 m,8
ENG247336-MAS01425-Geofencing_Area_Height-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,2147483647 °,8
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2147483648 °,8
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,2147483647 °,8
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2147483648 °,8
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Driving direction,30 °,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG153744-supress_climatisation_settings,not activated ,1
ENG153745-supress_climatisation_temperature,not activated ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
A5
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.000 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.000 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.000 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,0 mm,8
