Before fitting MFSW
Address 42: DTCs cleared
Address 56: DTCs cleared
After fitting MFSW
When I try to code the MFSW it tells me error 31
Original coding =5080160000
attempted new code 108A160000
any ideas? I am assuming the slip ring module should be correct as it is a highline van?
Bruceabz
Wednesday,15,May,2019,11:13:35:59107
VCDS Version: 18.9.1.0 (x64)
Dealer/Shop Name: B Ross
Workshop Code: 123 12345 000000
VIN: WV1ZZZ2KZFX029472 License Plate: SL64NVR
Mileage: 150050km-93236mi Repair Order: may 2019
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 77
VIN: WV1ZZZ2KZFX029472 Mileage: 150050km-93236miles
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TF HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9979
Revision: --H43--- Serial number: 00000000000000
Coding: 00114014032500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 7DF79E27EC178DA2B6-8028
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 433C400D09240303C20F02EB901BC081A0000020
Shop #: WSC 35110 377 08192
VCID: 7EF5992BE91196BAAF-802A
Part No SW: 7N0 907 426 BT HW: 7N0 907 426 BT
Component: AC Manuell H20 0607
Revision: 00001004
Coding: 0010004002
VCID: 071BFCCFBECBD7729C-8052
Part No SW: 5K0 937 086 S HW: 5K0 937 086 S
Component: BCM PQ35 M+ 122 0174
Revision: BD122001
Coding: 491A583E8025F16A088800829000016403017288524F8160648000000040
VCID: 44812BC3C77D3C6AB9-8010
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 12060 21 0501
Coding: 009795
Subsystem 2 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 2K0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0004
Revision: -------- Serial number: 32901419102259
Coding: 108001
ASAM Dataset: EV_EPHVA14VN3370000 001006
ROD: EV_EPHVA14VN3370000.rod
VCID: 70E9B713AB45F0CA2D-8024
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02Q H07 0013
Revision: -------- Serial number: 003HL00RT0DO
Coding: 000000000000000000000000000000003251
VCID: 3567460794A795E23E-8060
Part No SW: 5K0 953 521 DN HW: 5K0 953 569 AF
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140704201109
Coding: 5080160000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7BF3903FF203839288-802E
Part No SW: 2K0 920 976 E HW: 2K0 920 976 E
Component: KOMBI H03 0905
Coding: 480800
VCID: 3363781F9AD38BD210-8066
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 140714F1001608
Coding: 357401
Component: IMMO H03 0905
VCID: 6ADDA57B8D990A1A63-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 48993FF33B55180A55-801C
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 397F4A3770BF7182DA-806C
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 479B3CCF364B17725C-8012
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: RCD310 EU H05 5006
Revision: -----09S Serial number: VWZ4Z2P1279677
Coding: 05000200010013
VCID: 72EDBD1BAD49C2DADB-8026
00856 - Radio Antenna
Fault Status: 00100111
Reset counter: 224
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666462728
Coding: 0A01010000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3C715323B78D44AAC1-8068
End-------------------------(Elapsed Time: 02:41)--------------------------
Revision: 00H46001
Revision: 00001004
Coding: 0010004002
Revision: BD122001
Coding: 009795
Coding: 108001
Coding: 5080160000
Coding: 480800
Coding: 357401
Coding: 0000560
Revision: 00H22000
Coding: 0000560
After fitting MFSW
Friday,31,May,2019,15:12:10:59107
VIN: WV1ZZZ2KZFX029472 License Plate: SL64NVL
Mileage: 150400km-93454mi Repair Order:
VIN: WV1ZZZ2KZFX029472 Mileage: 150400km-93454miles
Revision: 00H46001
Revision: 00001004
Coding: 0010004002
Revision: BD122001
Coding: 009795
Coding: 108001
Coding: 5080160000
B1149 13 [009] - Open Circuit
Reset counter: 235
Mileage: 150407 km
Date: 2019.05.31
Time: 00:00:00
Coding: 180800
Shop #: WSC 12345 123 00000
Coding: 357401
Coding: 0000560
Revision: 00H22000
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.0 V
PD
Temperature: 18.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Coding: 0000560
Reset counter: 16
Bruceabz
