Can-bus problems after retrofitting Side Assist VW Tiguan 2018
Thore Smevik
Norway
C?ID=32745
I have retrofitted Area view 2, which works fine, and Side Assist, also named Blind spot, in my Tiguan AD1. The problem occurs when I plug in the connector to the radars, other controllers on that can-bus branch stops working with errors. That means The ACC, J428, Traffic sign display, Dynamic lights (AFS). They all work fine, before plugging in the radars. I have made a separate connector that connects the two can-bus wires and 12v supply, in order to switch in and out.
I attached the VCDS full scan without the radars connected, with no errors, and one new scan after connecting the two radars, master unit J769, 3Q0907566 E on the right side, and slave J770, 3Q0907590 E on the left side according to the original documentation from Erwin. The only thing I changed with VCDS is updating the Can gateway with the 2 extra controllers. The controllers comes from an Audi Q3, and are bought on ebay with original wire harness. It is strange because both the radar controllers seem to work fine, with no error in VCDS, but there is no light in the LEDS in the mirrors. They should light up 2 seconds when you turn the ignition on, checked on car with side assist original.
I have double checked the connectors if the two can-bus wires could be switched around, but when testing this, the radars can not be accessed in VCDS anymore, so the connection must be right. The controllers had “component protection”, but my local VW dealer removed that successfully. I also have tested the LEDs in the mirrors, by supplying +/- 12 v to the two wires that leads to the door mirrors, and they work fine.
One interesting observation is that controller A5, Frt Sens. Drv. Assist (R242), starts displaying error message “0646 - Control Module Incorrectly Coded”, and which leads to the conclusion that it could be a coding problem. Controller J428- ACC gives the message “0803 - Databus U1123 00 [009] - Received Error Message [FAULT_BV1_FEHLER], and finally the Instrument panel J285, show in VCDS “13636608 - Control Module Incorrectly Coded U1014 00 [009]”
I have not found any valid documentation to code the other controllers by installing the side assist controllers. The Side Assist radars should be correct coded, since they have been used before. I know I need a calibration, but that must wait until it works.
Anybody have any info on coding Side Assist on the MBQ platfform?
Thursday,20,June,2019,09:14:32:18230
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVGZZZ5NZJW452340   License Plate:
Mileage: 2208km-1371mi   Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 22 29 2B 36 39 3C
          42 44 4B 52 5F 69 6C 6D A5 BB BC CA CF D6 D7
VIN: WVGZZZ5NZJW452340   Mileage: 2208km-1371miles
4B-Multifunc. Module -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 LD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 5062
   Revision: R7H26---
   Coding: 011D003A24761D083000
   ASAM Dataset: EV_ECM14TFS01104E906027LD 001004
   ROD: EV_ECM14TFS01104E906027LD.rod
   VCID: 71BFD47B412D69EF35B-8024
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 0D9 300 014 S    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01805240821
   ROD: EV_TCMDQ250021.rod
   VCID: 2809F91FB2776827A25-807C
   Revision: 00000000    Serial number: 61558000001771
   Coding: 0AEE6A9A3425236E477A070462C34950562CC4E2E046927D38225078C22A4200002F641A1B13111435351919323200
   VCID: 77ABEA632F4937DFFBF-8022
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0483377773
   Coding: 132C2C0723
   VCID: 3E253F4740F3C697F89-806A
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11081571
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RF938698
   Coding: 0010000000000500818280808180000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3D27384B4DF5DD8FE13-8068
   Part No SW: 5NB 907 044 J    HW: 5NB 907 044 J
   Component: AC Automat    H35 4301
   Revision: 20K09000    Serial number: 00000E00971275
   Coding: 00020024204111011105100C0010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 47CB5AA31F29875F4BF-8012
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001816102461
   ROD: EV_BCMBOSCH_018.rod
   VCID: 094F9C9B49BD312F9DB-805C
   Subsystem 1 - Part No SW: 5NB 955 119 A    HW: 5NB 955 119 A  Labels: 1KX-955-119.CLB
   Component: 326 LL 180522  033 0372
   Serial number: 00000001805160303283
   Component: RLHS  052 0107
   Serial number: SAY18M06D18H00M41S47
   Coding: 00A8DD
   Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0029
   Serial number: 002904187498051
   Coding: 0231563A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3C21354F56EFD487D6D-8068
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H02 0233
   Coding: 320067CB58FF8728749C8145804087
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 70
                    Mileage: 2208 km
                    Date: 2019.06.20
                    Time: 09:11:36
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 41 °C
                    Longitudinal_acceleration_vehicle_reference: -0.28 m/s²
   Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
   Component: AirbagVW21    006 0339
   Serial number: 003VXR482R6C
   Coding: 98FCC0C00C0000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 0A4DA3974CBB3A37941-805E
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1040
   Serial number: 5NB857705C0159S00027
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1040
   Serial number: 5NB857706C0156S00068
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 006 18
   Serial number: 35700000000EF6156E2Z
   Subsystem 4 - Part No SW: -----------    HW: 480 001 006 18
   Serial number: 35800000000CF6156E2Y
   Subsystem 5 - Part No SW: -----------    HW: 480 401 406 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001C129D6792B220
   Subsystem 6 - Part No SW: -----------    HW: 480 401 506 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001BD29D6791926D
   Subsystem 7 - Part No SW: -----------    HW: 480 401 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001B12A0DFC475CK
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 406 18
   Component: PedP_Sensor_D  003 6149
   Serial number: 2280001B12A0DFC525CF
   Subsystem 9 - Part No SW: -----------    HW: 480 401 406 18
   Component: PedP_Sensor_P  003 6149
   Serial number: 2290001B12A0DFC6F48P
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 401 406 18
   Component: PedP_Sensor_C  003 6149
   Serial number: 2300001AF29F25E4B83I
   Subsystem 11 - Part No SW: -----------    HW: 480 000 206 18
   Serial number: I0M00000000560543E2-
   Subsystem 12 - Part No SW: -----------    HW: 480 000 206 18
   Serial number: I0N00000000C50543E20
   Part No SW: 5Q0 953 521 FG    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0225
   Revision: FF035035    Serial number: 20180615500123
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA1F54F166F148796D-8028
   Part No SW: 5NA 920 791 B    HW: 5NA 920 791 B
   Component: KOMBI         409 3197
   Coding: 03A400186F84000801886B031401000000000000
   VCID: 42DD4BB7340BA2779C1-8016
          U1014 00 [009] - -
                    Reset counter: 70
                    Mileage: 2208 km
                    Date: 2019.06.20
                    Time: 09:11:36
   Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 K
   Component: STH-MQB       008 0080
   Coding: 1309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   Component: R64 D208L  004 0402
   Serial number: 00000000000000482164
   Component: GW MQB High   518 5323
   Serial number: 31051810804220
   Coding: 030500347F085708FB07225E1E0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3829295F62D7F8A7325-806C
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 1501820181002061AP2B
   Coding: 2F0000
   Serial number: 7064218204
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00015.05.18
   Coding: 0101
   VCID: 4CC1658F064F640766D-8018
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45D750AB2525954FB93-8010
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 18000202610001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331E737BB11BFF077-8066
   Serial number: Y0006RF835204
   Coding: 001000020000050001C280808180000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 14C002
   Shop #: WSC 06385 790 00016
   VCID: 3A2D33575CDBEAB7C41-806E
   Serial number: 040318EC322512
   Coding: 003F1B20D200048000001000
   VCID: 43D34EB32B11AB7F977-8016
   Part No SW: 5QF 909 144 A    HW: 5QF 909 144 A
   Component: EPS_MQB_ZFLS  507 5581
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 48C9599F12378827425-801C
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 07061810804128
   Coding: 000000050100085201104F010A0000000000000000000000000000000000
   VCID: 72BDDB77442B52F7CC1-8026
13705999 - Databus
          U1123 00 [137] - Received Error Message
          [Kamera_FDD_Funktionsstatus_Fehler received error status]
                    Reset counter: 70
                    Mileage: 2208 km
                    Date: 2019.06.20
                    Time: 09:11:36
   Serial number: 020618EES2350A
   Coding: 003F1120DE00048000001000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Coding: 02730601FF0000005111010100880A231F0500E4012000008E
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323D1B7784AB12F70C1-8066
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV1581098
   Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
   Component: ECE1 2018  --- 0915
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0482399816
   Coding: 0100000202000000
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG001547
   Coding: 01230606A20F200000204094
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   VCID: 392F2C5B59DDE1AFCDB-806C
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0266
   Revision: --------    Serial number: 31960853600000
   Coding: 0AA8
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   VCID: 46D557A718239E57B09-8012
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 04051812P13124
   Coding: 000307060000040100221345C150A90094000E200040
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Reset counter: 70
                    Mileage: 2208 km
                    Date: 2019.06.20
                    Time: 09:11:36
                    Control Module temperature: 26 °C
                    Outside air temperature: 15.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 459.1 s
                    mid: 00 29
                    Status of camera: System malfunction
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 010618EF109864
   Coding: 002A11200101048000001000
   Serial number: 010618EF104349
   Coding: 208040732602
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   VCID: 372B2A636FC9F7DF3BF-8062
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 005981BF7A877067CA5-8054
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 02:25, VBatt start/end: 12.2V/12.2V)-----------
siLc
Tallinn, Estonia
C?ID=330192
In A5 the appropriate checkbox was called "Lane Change assist installed". If you also have Rear Cross Traffic Alert with those Side assist radars, then there is another coding bit in A5, which I don't know off the top of my head.
darkchina811
ITALY
C?ID=333184
module 17 definitely needs to be coded for BSD retrofitting, I did it no longer than two weeks ago but don't have the coding at hand.
take a look at the "spanish bible" here https://goo.gl/D37qgp
it is based on a Golf 7 but since both cars are MQB then you can get plenty of inspiration.
downtime
C?ID=280813
Also ABS module needs recoding for the RCTA to work.
golfi_vend
Tartu, Estonia
C?ID=195131
My notes for BSD:
But spanish pdf is better. I need to recheck all my adaptions too :)
Coding
03 - ABS - Brakes
  Byte 29 Bit 7 - RCTA Installed
10 - Park/Steer Asssist
  Byte 3 Bit 6 Side Assist/RCTA Installed
17 - Instrument Cluster
  Byte 5 Bit 3 - Lane Change Assist Installed
  Byte 11 Bit 3 - Lane Change Assist Information (BAP) Installed
  Byte 12 Bit 6 - Something?
19 - Can Gateway
  Installation List:
  3C-Lane Change - Active
A5 - lane
  Byte 11 Bit 4 - Blind Spot Detection installed
Adaption
5F-Information Electr.
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A ---> Activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus ---> Databus extended
Thore Smevik
Norway
C?ID=32745
Update
Thanx for coding suggestions, here is an update from today.
Two steps forward and one backwards.
I Just found out that the Tiguan AD1 (2016+) is not based on the MBQ for the assistant systems. There is a difference between "Blind Spot" on the Golf VII, and the "side Assist" on Tiguan, Passat and Touran, and Audi Q3. They have different controllers from the Golf, hence the coding may be different.
But I have managed to get rid of all error messages. I borrowed a 2019 Tiguan at the local dealer with factory installed "Side Assist" and compared all coding of the actual controllers.
But still it will work. When trying to activate it on the menu on the NAV display, it immediately says" Function not available for time beeing" (Translated from Norwegian), and the mark is cleared.
I attach a new autoscan with no errors.
Any ideas?
hursday,20,June,2019,22:35:07:18230
VIN: WVGZZZ5NZJW452340   License Plate: SA CODED OK
   Revision: R7H26---
   CAN Converter 01:
   Coding: 132C2C0723
   Coding: 00A8DD
   Coding: 0231567A51
   Coding: 80000D
   Coding: 80000D
   Coding: 0C10
   Coding: 07A40018EF8C000801886B0B1401000000000000
   Coding: 1309
   ROD: EV_GatewNF.rod
   Coding: 2F0000
   Coding: 0101
   Revision: --------
   Coding: 14C002
   Coding: 931F0000
   Coding: 01230601A70F200000614094
   Coding: 0AA8
   Coding: 000307060100040100221357C150A90094000E200040
   Revision: --------
   Coding: 14C002
End----------(Elapsed Time: 02:21, VBatt start/end: 12.4V/12.4V)-----------
downtime
C?ID=280813
Did you solve this? I'm also planning on doing the same thing as I bought a 2017 Tiguan R-line which has almost every option except side assist and panoramic sunroof. Sunroof is no go as retrofit, but side assist is doable.
One practical question about wiring. Did you have to drill out the front door woofers to gain access to the wiring? Or does the mirror wiring already have all the necessary wires so that you only need to connect the side assist indicators wiring to the connector on car body side? Elsa states that the wiring is already complete to the highest options spec.
To your specific problem one request. Can you pull up the adaptation map from your 5F module and post it here? Most likely the issue is with the menu adaptations.
Thore Smevik
Norway
C?ID=32745
Side Assist works OK, trailer assist as well!
All problems now solved!:D:D
I have a summary of the code changes as an Excel document, which I can not attach here, all formatting disappears ! I also tried to print it as a PDF-file, but can not attach that either.
Regarding your question about cabling in the doors. Yes, I drilled out the pop nails and removed the loudspeaker to gain access to the original wires through the door. The two cables for the LED in the mirrors are on pin 9 and 10 on the 27 pin connector between the door and chassis. Pin 9 and 10 was empty originally, I also have the highest options original.
I have not calibrated the two radars, it costs too much at the VW dealer. I find that it works OK, with the calibration that was done on the car where the radars were taken from
downtime
C?ID=280813
Ok thank you. That's what I don't like, drilling the speaker out. Not a biggie but I hate it anyway :D
And thanks but I'll manage without the coding instructions. I know what to do. And I also have all the wiring diagrams etc. But I'll ask if there's some issues with the coding etc.
The complete side assist kit which I ordered from our friendly Chinese bazar, has modules that are pre-calibrated. I have my doubts about the calibration sticking to the modules when they're installed to a different car but let's see. The A5 camera for example instantly loses it's calibration when it's installed to a new car.
Thanks for the reply. And enjoy the side assist :D
darkchina811
ITALY
C?ID=333184
the A5 stores the vehicle's VIN, so it "intentionally" drops the calibration if transplanted.
MQB 3C radars don't store the VIN and don't need static calibration anyway. you just drive a bit and they do their thing :)
downtime
C?ID=280813
5Q0 radars don’t need static calibration. 3Q0 do.
That is stated in official repair instructions as well. Golf, Leon and A3 use radars with dynamic calibration, Tiguan, Q3 etc. Use different radars which need static cal.
EduardJS
Romania
C?ID=307521
Does anyone know the difference between 2Q0, 3Q0 and 5Q0 in the A5 (camera) module?
I'd like to retrofit the following on a Q3 Sporback 2020, which I've recently bought for my wife, while I own a simple Q3 built in June 2019
- ACC (car has lane assist and cruise control)
- Side assist (it just has the presense basic, which preps the cabin and displays the warning on the dash, but does not break)
My old Q3 comes with 3Q0 (was configured with the driver assistance package), which among other things, does the braking as well, when presense detects a collision.
So I'm just not sure if I need a 3Q0 upgrade, in which case I'd also need a static calibration that's very expensive through the dealer.
Thing is, the car it also has Matrix LEDs, as well as traffic sign recognition, which I guess all are dealt with in the A5 module.
So, coming back to the question, when does one need a 3Q0 upgrade, or a 5Q0 one?
I have the same front distance radar sensor on the Sporback, as on the Q3 (which does have ACC), so I'm guessing the ACC is also being dealt with the A5 module, otherwise, why would they use the same radar sensor on a car with no ACC? Though I'd guess it's used for collision detection, which then means, I could simply upgrade the A5 module and add ACC with just some coding?
downtime
C?ID=280813
Sorry I don't understand the question? Do you have A5 at all or are you planning on retrofitting A5?
Without autoscan not easy to say what you would need if you want to retrofit but as the car is that new I would say minimum is 3Q0 camera. 5Q0 does not work with a newer ACC anymore.
2Q0 is also retrofittable but you won't get traffic sign recognition to work in that as that is behind SWaP.
stefan147
Greece
C?ID=361962
If I understand correctly the ACC radar is already there but only functioning as the Pre Sense radar since ACC was not chosen as an option.
In other words you need one of those hackers who "upgrade" the existing radar and make it work as ACC radar too. Plus new stalk of course. Static calibration is not mandatory since the hackers upload each model's measuments by hand into ODIS. The A5 camera should be good as is.
EduardJS
Romania
C?ID=307521
@stefan147 correct. All in all, ACC is not a must, but I'd really like upgrading that presense-basic to presense-plus (so it also breaks for my wife whenever a collision is detected) ... and since the front sensor itself seems to be the same between the two, I assumed the presense is dealt with by the A5 camera?
@downtime 2Q0 is also retrofittable but you won't get traffic sign recognition to work in that as that is behind SWaP.
Weird, my car already has traffic sign recognition ... with that 2Q0 A5 module from factory.
To conclude, ACC is not necessary as I hardly ever used it, in Romania, roads are quite twisted.
1. I will retrofit side assist, which I'm quite sure will not require anything else, aside the radars plus the wiring and the new wing covers for the LEDs.
2. I would really like some help with regards to getting the presense to actually break as well, instead of just prepping the cabin.
So, I might have phrased it incorrectly a bit, basically my question is how does one upgrade from presense-basic to presense-plus.
The reason for comparingthe two cars I have was that the old Q3 has the breaking/ side assist but the new one does not, and the only hardware difference is in the A5 module, as it has a 3Q0 while the new Q3 has a 2Q0, and my worry was that I'd need to recalibrate it via the dealership.
Thanks for taking the time to deal with my inquiry. I will make a new post though, with the DIY steps, once I manage pulling it off.
downtime
C?ID=280813
Then of course the traffic sign will work if you already have it from factory. Retrofitting 2Q0 camera will have this issue. Not factory one if you have bought navi and traffic sign recognition as part of it.
Sorry I still don't get it. You mean you would swap 2Q0 to 3Q0 camera? I would not do it. 2Q0 camera has been appraised by much improved lane assist and assist functionality overall compared to 3Q0.
My guess in this case would be that pre-sense plus is also behind SWaP as it needs coding change to the pre-sense radar module. Most likely when you code the module 13 to pre-sense plus it will start to complain about the missing FeC for it.
EduardJS
Romania
C?ID=307521
No no, I only wanted to "upgrade" thinking 3Q0 or 5Q0 are a must in order to have stuff like presense plus, or ACC, since the radar sensor is the same on both cars.
That's why I asked if anyone knows the difference between 2Q0, 3Q0 and 5Q0
Yeah, I started thinking the same after looking at the hardware difference between the two cars, and the A5 module (3Q0 vs 2Q0) being the only one. What about the FeC part of things, do I need to go to a dealership in order to enable them?
They are quite dumb and not really eager to help tbh, hence me asking about it here on the forums.
Could you detail a bit why and how do you know 2Q0 is better and if it supports the presense-plus ? Just curious as I don't know where you
Regards
downtime
C?ID=280813
You can't enable safety related FeCs as they are not officially retrofittable or aftersales options. So I think as someone already mentioned earlier, most likely your only option is to retrofit ACC which means changing the radar and get someone to hack it remotely. Then you should have the needed things.
2Q0 is superior camera to 3Q0.
EduardJS
Romania
C?ID=307521
Ok ... that's unfortunate. I was unaware at the time I configured the car, with regards to what exactly presense (basic) does.
I'll fiddle with the coding tomorrow and see what's possible. Guess I'll stick to simply retrofitting side assist, and whatever else can be done (assist wise) via coding.
LATER EDIT: Just trying to make sure, as I'm officially confused. Was looking on Kufatec for some cables and I found this ACC retrofit.
Thing is, this also adds that "city emergency brake" ... but since my front radar sensors are the same on both cars, does it not mean that the "emergency breaking" is only via coding / adaptation? Pardon my idiocy if that's not the case.
Regards
downtime
C?ID=280813
The Kufatec retrofit (at least it used to be) a round radar which does not have SWaP yet. That is not going to work in your car. Too old hardware.
