WiFi hotspot via Audi Connect
jakematic
NC USA
C?ID=129085
Been rolling this around in my mind for weeks and haven't come to a solid conclusion.
Any pros/cons to making the primary network the in-vehicle WiFi ?
Two downsides I can think of:
  • finding VCHN's IP address sans app
  • MOST bus or wireless gateway goes funky, but HEX-NET should revert to my phone's hotspot if properly configured/on
Appreciate your input. Thanks-Jake
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Jake,
Finding the IP isn't that much of an issue - there is an additional Android/iPhone app (sort of like a launcher) which determines the IP as well (the Android app can also be installed on current BlackBerry models running OS 10.2.1 or newer). The major advantage would be the cloud functions running through your vehicle WIFI/T-Mobile. As far as MOST issues go, you won't get that far if the MOST isn't working in general but reality is that you would use regular VCDS instead of VCDS-Mobile to diagnose it - currently Ring Break Diagnostics is not part of VCDS-Mobile.
BTW, the HEX-NET can be switched from Infrastructure to Access Point Mode with a simple tap to the button - so even if the vehicle WIFI is giving you troubles that should be an easy fix. :)
jakematic
NC USA
C?ID=129085
Perfect, thank you Sebastian.
Very excited about HEX-NET since I am laptop-less at the moment, and like my Amex I don't leave home without VCDS :D
<waits impatiently at door for FedEx>
Yep, in a car in which I was paying for Audi Connect anyway, I'd sure use it to give my HEX-NET cloud access!
I would expect that the DHCP server in the Audi Connect router will try to assign the same IP address to the HEX-NET every time (assuming it hasn't run out of slots). Most DHCP servers try to do that these days.
If you're using an Android phone/tablet, we have a little 'launcher' / 'browser wrapper' app that will find your HEX-NET for you. It's not in the Play Store yet, but can downloaded and side-loaded.
If you're using an iOS device, we have such an app coming, but since iOS doesn't offer the ability to side-load apps, you'll have to wait until we submit it to Apple and they bless it. In the meanwhile, I might suggest installing a network scanner such as Fing.
jakematic
NC USA
C?ID=129085
Well it turned out connecting to Audi Connect isn't such a great idea unfortunately.
Tried it today and during the Auto Scan the WIFI get's reset and dropped both HEX-NET and my iPad.
Three attempts later, tried to connect to my iPhone but that failed.
Likely user error - far too many people were cutting across the nose of my A8L at high speed [edit: in a parking lot] so I returned to the office.
Confirmed since that it will connect to my iPhone just fine.
Somewhere along the way the Auto Scan was lost - I think when the ASAM download failed.
Possibly when I had to do the 45 second reset to get it to go into AP mode.
The CPU light is now alternating between red/green on my office network.
Will try again with my phone later or tomorrow....
EDIT: Waited about 15 minutes, removed power, and re-powered via USB and the CPU light is normal now.
Please don't play while driving. Despite my general lack of altruism, I believe I would suffer from considerable remorse if you got yourself killed while messing with this. ;)
jakematic
NC USA
C?ID=129085
Absolutely not!
I got a haircut and sat in the parking lot :)
Then the phone exploded and had to return to the office...
jakematic
NC USA
C?ID=129085
Some new observations regarding Apple device hotspots:
- neither Fing nor iNet will scan the WiFi network when in hotspot mode
- sometimes the hotspot needs to be turned on/off a couple times for HEX-NET to connect
Keep in mind this is iOS code that is not GA yet, so.....
Because I've encountered so many self-induced / learning curve issues it still hasn't let me create my Cloud id.
It did sync though so I presume the docid will attach itself to my account later ?
jakematic
NC USA
C?ID=129085
Lesson learned - don't overthink and go crazy with the network profiles like I did.
Audi Connect does not seem viable; will investigate further.
Deleted all profiles, added iPhone hotspot and it connects like a champ now.
Fing and iNet work if you manually scan 172.20.10.x on Apple devices.
Thanks for all the updates. Could we ask you to put your phone on Audi Connect and do whatever quality-of-connection benchmarks you an think of back to VCDS-Cloud.com? Your Audi Connect is via T-Mo's 3G service, right? I'm kinda curious whether there are latency or packet-loss issues? Oh, and does your phone get data through a different provider / cell network?
jakematic
NC USA
C?ID=129085
Only test I can think of is a traceroute.
Yes it is 3G, my phone is also T-Mobile.
I don't think it's Audi Connect itself - the WiFi goes offline during the Autoscan as observed on phone and tablet.
It is either on address 09 or 46, will confirm and get ASAM data downloaded today.
Interestingly 04, 09 is missing from the scan:
#hndoc:?docid=00000135&xt=hnh:2804D7B08EDAEB7D330ADD2ECBF99E2D3ECFEAFD436E025A56DC1892A7EAC3C1
VCDS Mobile 0.4009.0.4
VIN: WAURVAFD6CN014370
Gateway Installation list:
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8D-Multicont. Seat Rear,PS -- Status: OK 0000
8F-Pretension. Front Left -- Status: OK 0000
90-Pretension. Front Right -- Status: OK 0000
Address 01: Engine  (CDRA
 -----)	Labels:4H-01.lbl
	Part Number SW: 4H0-907-560-C	HW: 4H0-907-560
	Component: 4.2l V8/4V    H07 0004
	Revision: N5H07---
	Coding: 0106000A290F0268
	Shop #: WSC 02313 785 00200
	ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
	VCID: 2A1791ABD5B2A1427A5D8
No fault codes found.
Address 02: Auto Trans  (J217)
	Part Number SW: 4H1-927-158-BR	HW: 0BK-927-156-K
	Component: 0BK 42 FSIUSA H08 1001
	Revision: --H08---
	Coding: 000002
	ASAM Dataset: EV_TCMALX51011 002018
	VCID: 814596078844021A8BF77
Address 03: ABS Brakes  (J104)	Labels:4H0-907-379.clb
	Part Number SW: 4H0-907-379-C	HW: 4H0-907-379-C
	Component: ESP PREMIUM   H10 0273
	Revision: --------
	Coding:
	Shop #: WSC 02311 785 00200
	ASAM Dataset: EV_ESPPremi 005006
	VCID: 322789CBFD62E982C20D0
Address 05: Acc/Start Auth.  (J393)	Labels:8K0-907-064-05.clb
	Part Number SW: 4H0-907-064-BD	HW: 4H0-907-064-BD
	Component: BCM2 2.0      H31 0330
	Coding: 0D872000000000000000
	VCID: 6C9B57B31FC66772C8C1E
	Subsystem 1 - 	Shop #: WSC 02313 785
	Subsystem 2 - 	Part Number: 4H0-905-852-C
	Component: J764 ELV MLB H39 0046
Address 06: Seat Mem. Pass  (J521)
	Part Number SW: 4H0-959-760-E	HW: 4H0-959-760-E
	Revision: AA000000
	Coding: C018B60085043201010001010101112131313333283333
	VCID: 352DB2D70C0CE6BAE7EF3
Address 08: Auto HVAC  (J255)
	Part Number SW: 4H0-820-043-H	HW: 4H0-820-043-H
	Component: Klima 4 Zonen H20 0072
	Coding:
	VCID: 250D6297BCAC8E3A578F3
Address 0e: Media Player 1  (R161)
	Part Number SW: 4H0-035-108-E	HW: 4H0-035-108
	Component: DVDCAlpine    H42 0190
	Revision: AA001001
	VCID: 2207798BAD82610232AD0
Address 10: Park/Steer Assist  (J446)	Labels:4H0-919-475-7X2.clb
	Part Number SW: 4H0-919-475-L	HW: 4H0-919-475-C
	Component: PARKHILFE ACC H07 0043
	Revision: 11001001
	Coding: 280902
	VCID: 3B39A4EF2A2828CA11AB5
Address 13: Auto Dist. Reg  (J428)
	Part Number SW: 4H0-907-561-A	HW: 4H0-907-561
	Component: ACC3          H15 0160
	Coding: 3601020201
	ASAM Dataset: EV_AdaptCruisContrAU64X 001012
	VCID: 29156EA7D0B4AA5A7367F
016896 - ROD - Unknown faultcode
		Fault Status: 01000010
		Reset Counter: 1
		Mileage: 66212 km
		Time: 00:00:00
140288 - ROD - Unknown faultcode
		Reset Counter: 1
		Mileage: 66212 km
		Time: 00:00:00
Address 15: Airbags  (J234)
	Part Number SW: 4H0-959-655-D	HW: 4H0-959-655-D
	Component: Airbag10.43   H41 0041
	Revision: --------
	Coding: 303143303230303030314A55304C34483053
	VCID: 3731B8DF16000CAAF5D39
	Subsystem 1 - 	Part Number: 4H0-959-339
	Component: BF-Gewichtss.H02 0040
	Serial Number: 5850000R1190801Y2Nªª
	Subsystem 2 - 	Serial Number: 3575HRB405D0NI366PV.
	Subsystem 3 - 	Serial Number: 3585HRB40550Q3SK39JQ
	Subsystem 4 - 	Serial Number: 3515JRB404R0Q8K4FOSG
	Subsystem 5 - 	Serial Number: 3525JRB404R0Q8K46G6L
	Subsystem 6 - 	Serial Number: 3554VRB40610M5SO0H1M
	Subsystem 7 - 	Serial Number: 3564VRB40610M5SO493L
Address 16: Steering wheel  (J527)
	Part Number SW: 4H0-953-568-G	HW: 4H0-953-568-G
	Revision: --------
	Coding: 0000BC
	VCID: 3731B8DF160014AAF5D39
	Subsystem 1 - 	Part Number: 4H0-951-528-L
	Component: E221 - MFL   H04 0009
Address 17: Instruments  (J285)	Labels:4H0-920-xxx-17.clb
	Part Number SW: 4H0-920-980-H	HW: 4H0-920-980-H
	Component: TBenUSAACC--- H38 0373
	Revision: 32480030
	Coding: 0B4F08015700D705020000
	ASAM Dataset: EV_RBD4K 004040
	VCID: 302383C3F36EDB92B419A
Address 19: CAN Gateway  (J533)
	Part Number SW: 4H0-907-468-F	HW: 4H0-907-468-C
	Component: J533--Gateway H08 0213
	Revision: --------
	Coding: 00C1034A00
	VCID: 342B8FD30776E7B2D0F16
	Subsystem 1 - 	Part Number: 4H0-915-181
	Component: J367-BDM     H07 0140
	Serial Number: 00000000005650628220
Address 28: HVAC, Rear  (E265)
	Part Number SW: 4H0-919-158-D	HW: 4H0-919-158-D
	Component: Klima Fond    H15 0062
	Coding:
	VCID: 312586C7F864D29ABB177
Address 34: Level Control  (J197)
	Part Number SW: 4H0-907-553-C	HW: 4H0-907-553
	Component: LUFE-DAEMPFER H17 0096
	Coding: 008002
	ASAM Dataset: EV_AirSuspe 003022
	VCID: 2C1B97B3DF46BF728841E
Address 36: Seat Mem. Drvr  (J136)
	Revision: AA000000
	Coding: C018BF8085853201030001010101112131313333203333
Address 3b: Sensor Elect.  (J849)
	Part Number SW: 4H0-907-637	HW: 4H0-907-637
	Component: SARA 6D       H02 0015
	Revision: --------
	Coding:
	ASAM Dataset: EV_SARA 006014
	VCID: EC9BD7B39FC6FF7248C1E
3801346 - ROD - Unknown faultcode
Address 3c: Lane Change
	Part Number SW: 4H0-907-566-A	HW: 4G0907568
	Component: J769  SWA MasterH01  0030
	Revision: 00H01000	Serial Number: 6PZ 010 287-07
	VCID: 2E1F9DBBE95A5562A6354
	Subsystem 1 - 	Part Number: 4H0-907-568-A
	Component: J770  SWA Slave H02  0030
	Serial Number: 6PZ 010 287-27
Address 42: Door Elect, Driver  (J386)
	Part Number SW: 4H0-959-793-M	HW: 4H0-959-793-E
	Component: TSG FA        H02 0166
	Revision: --------
	Coding: 011F1F205E0062C202000017
	Shop #: WSC 02312 785 00200
	VCID: 43C9DC0F52D8480A595BD
Address 46: Central Conv.  (J393)	Labels:4H0-907-064-46.clb
	Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
	Subsystem 1 - 	Part Number: 4H0-959-719
	Component: GTO BF       H01 0070
	Subsystem 2 - 	Part Number: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 3 - 	Part Number: 4H4-959-591
	Component: J245  007C   H06 0005
	Coding: 020200
	Subsystem 4 - 	Part Number: 4H0-947-135-BR5;Ô
	Component: DachelektroniH11 0080
	Coding: 070000
	Subsystem 5 - 	Part Number: 4H4-959-591
	Component: J394  0014   H06 0005
	Coding: 020200
	Subsystem 6 - 	Part Number: 4H4-959-591
	Component: J392  006A   H06 0005
	Coding: 020200
	Subsystem 7 - 	Part Number: 4H4-959-591
	Component: J867  00E0   H06 0005
	Coding: 020200
Address 47: Sound System
	Part Number SW: 4G0-035-223-B	HW: 4G0-035-223-A
	Component: 0130H07
	Revision: CJ007000
	Coding: 030000
	VCID: 1C7B47738FE657F2F8E1E
Address 48: Seat, Rear, DS  (J876)
	Part Number SW: 4H0-959-860	HW: 4H0-959-860
	Component: MEM-FS-Fond   H06 0153
	Revision: AA000000
	Coding: 001892800000300D0A00392038193A2039203B3B202020
	VCID: F1A5C6C7B8E40A9A7B977
Address 52: Door Elect, Pass.  (J387)
	Part Number SW: 4H0-959-792-E	HW: 4H0-959-792-E
	Component: TSG BF        H02 0166
	Revision: --------
	Coding: 011F1F205E0062C202000007
	VCID: 3A37A1EB251209C20ABD8
Address 53: Parking Brake  (----)	Labels:4H0-907-801.clb
	Part Number SW: 4H0-907-801-E	HW: 4H0-907-801-A
	Revision: --------
	Coding:
	Shop #: WSC 00000 000
Address 56: Radio  (R)
	Part Number SW: 4H0-035-082-B	HW: 4H0-035-082
	Component: Radio U SIRIU H52 0076
	Revision: AB001007
	Coding: 020007010000000001
	VCID: 20037383A38E731224B9A
Address 5b: Seat,Rear,PS  (J877)
	Component: MEM-BFS-Fond  H06 0153
	Revision: AA000000
	Coding: 001896800000300D0A00392038193A2039203B3B382020
Address 5f: Information Electr.  (J794)	Labels:4E0-035-6xx-5F.clb
	Part Number SW: 4H0-035-746-D	HW: 4H0-035-746
	Component: H-BNT-NA      H48 0423
	Revision: --------
	Coding: 020200000001F9EF7D128B0E00000003140001000000000000
	VCID: 29156EA7D0B4B25A7367F
	Subsystem 1 - 	Part Number: 8R0-060-884-AD5;Ô
	Component: NAR 2011     0505
	Subsystem 2 - 	Part Number: 4H0-919-604-D
	Component: DU8 D4 SV NB H47 0021
	Subsystem 3 - 	Part Number: 4H1-919-600-F
	Component: E380 BDT D4  H09 0064
	Subsystem 4 - 	Part Number: 8R0-060-961-B
	Component: CD-Database  3371
Address 62: Door, Rear Left  (J388)
	Part Number SW: 4H0-959-795-A	HW: 4H0-959-795-A
	Component: TSG HL        H04 0167
	Revision: --------
	Coding: 010F1F20420062C202000007
	VCID: 3935BEE7201402DA03C7F
02111 - Motor for Window Regulator
		Fault Status: 00100101
		Reset Counter: 154
		Mileage: 13138 km
		Date: 2014.01.19
		Time: 13:08:53
Address 6c: Back-up Cam.	Labels:4H0-907-441.clb
	Part Number SW: 4H0-907-441-A	HW: 4H0907441
	Component: SG Rueckfahrkamera   0061
	Revision: --H04---	Serial Number: 525 PA8J17D1M2
	Coding: 1080003
	VCID: 260F659BC1AA1D225E85C
Address 6d: Trunk Elect.  (----)
	Part Number SW: 4H0-959-107-R	HW: 4H0-959-107-M
	Component: HDSG-Modul    H11 0039
	Revision: 10011001
	Coding: 0210044100
	VCID: 3D3DAAF7343C26FA2F9FB
Address 6f: Centr. Conv. II  (J773)
	Part Number SW: 4H0-907-412	HW: 4H0-907-412
	Revision: --------
	Coding:
	ASAM Dataset: EV_Ambie 001008
	VCID: E389BC8F7218B00AF91BD
Address 72: Door, Rear Right  (J389)
	Component: TSG HR        H04 0167
	Revision: --------
Address 81: Gear Shift  (J587)
	Part Number SW: 4H1-927-731-A	HW: 4H1-927-731-A
	Component: GSM-LL        H07 0083
	Revision: 0L0D5012
	Coding:
	VCID: 2B1994AFDA48B84A814B5
Address 85: On Board Cam.  (J852)
	Part Number SW: 4G0-907-217	HW: 4H0-907-217-A
	Component: DPC-SG        H24 0036
	Revision: --------
	Coding:
	VCID: E58DA2977C2CCE3A170F3
Address 88: Multicont. Seat Driver  (J873)
	Part Number SW: 4H0-907-182-H	HW: 4H0-907-182-H
	Coding:
	VCID: 2F2180BFEE50C46AAD231
Address 89: Multicont. Seat Pass.  (J872)
	Coding:
Address 8a: Multicont. Seat Rear,DS  (J875)
	Part Number SW: 4H0-907-182-G	HW: 4H0-907-182-G
	Component: IVB           H08 0042
	Coding:
	ASAM Dataset: EV_IVBDriveSideRear 001003
	VCID: 2E1F9DBBE95ACD62A6354
Address 8b: Adaptive Cruise 2  (J428)
	Part Number SW: 4H0-907-541-A	HW: 4H0-907-541
	Coding: 3601020201
	ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
	VCID: 2711689FC6A09C2A65739
		Reset Counter: 1
		Mileage: 66212 km
		Time: 00:00:00
Address 8d: Multicont. Seat Rear,PS  (J874)
	Coding:
	ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8e: Image Processing  (J851)	Labels:4G0-907-107.clb
	Part Number SW: 4G0-907-107-C	HW: 4H0-907-107
	Component: BV-SG         H29 0036
	Coding:
	ASAM Dataset: EV_BC7 001001
	VCID: 260F659BC1AA85225E85C
Address 8f: Pretension. Front Left  (J854)	Labels:4H0-980-94x-RGS.clb
	Part Number SW: 4H0-980-945-B	HW: 4H0-980-945-B
	Coding:
	ASAM Dataset: EV_RGS_L 002004
Address 90: Pretension. Front Right  (J855)	Labels:4H0-980-94x-RGS.clb
	Part Number SW: 4H0-980-946-B	HW: 4H0-980-946-B
	Coding:
	ASAM Dataset: EV_RGS_R 002004
Sunday,10,June,2012,11:52:47:50323
VCDS Version: Release 11.11.3
Data version: 20120401
JakeWare Solutions
Chassis Type: 4H0
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
          46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8B 8D
          8E 8F 90
Address 01: Engine (------CDRA)       Labels: None
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Revision: N5H07---
   ROD: EV_ECM42FSI0114H0907560C.rod
   VCID: 2A5108844DE4089
9587 - Production Mode Active
          U1103 00 [032] - -
                    Fault Frequency: 0
                    Reset counter: 0
                    Time: 00:00:00
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
   Revision: --H08---
   Coding: 000002
   ROD: EV_TCMALX51011_AU64.rod
   VCID: 81030F281012AB1
   Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
   Coding: 44E6F20022674F00E200
   ROD: EV_ESPPremi_AU64.rod
   VCID: 326110E46534409
   Part No SW: 4H0 907 064 BD    HW: 4H0 907 064 BD
   VCID: 6CDDCE9C8F90D69
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Revision: AA000000    Serial number: 00000014753132
   VCID: 356B2BF89C5A571
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Coding: 480122BECC
   ROD: EV_AirCondiFront_AU64.rod
   VCID: 254BFBB824FA271
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001073731
   Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
   VCID: 6ED9C494B98C249
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110724  H35 0040
   Coding: 0045F7
   Component: RLS  H04 0003
   Coding: 025523
   Component: E1 - LDS  H07 0044
   Component: USHL4.2  H30 0030
   Coding: 100000
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Coding: 020300
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Revision: AA001001
   VCID: 2241E0A43DD4D09
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Revision: 11001001    Serial number: 55901126901403
   Coding: 280902
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 3B7F3DC0B27E811
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Coding: 3601020201
   ROD: EV_AdaptCruisContrAU64X_AU64.rod
   VCID: 2953F78848E2031
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Revision: --------    Serial number: 003JS0016EK5
   ROD: EV_AirbaAU10BPAAU64X_AU64.rod
   VCID: 377721F08E56A51
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R1190801Y2N
   Serial number: 3575HRB405D0NI366PV.
   Serial number: 3585HRB40550Q3SK39JQ
   Serial number: 3515JRB404R0Q8K4FOSG
   Serial number: 3525JRB404R0Q8K46G6L
   Serial number: 3554VRB40610M5SO0H1M
   Crash sensor for front airbag; passenger side:
   Serial number: 3564VRB40610M5SO493L
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90815KIN0002H
   Coding: 0000BC
   VCID: 377721F08656A51
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 980 H    HW: 4H0 920 980 H
   Revision: 32480030    Serial number: 658270911593012
   Coding: 0B4608015700D705020000
   ROD: EV_RBD4K_AU64.rod
   VCID: 30651AEC6B38729
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1110824000963
   Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
   Revision: --------    Serial number: 00000000254143
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU64.rod
   VCID: 346D16FC9F204E9
   Control unit for battery monitoring:
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Serial number: 00000000005650628220
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Coding: 0000000000
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 31631FE860327B1
Address 34: Level Control (J197)       Labels: None
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Coding: 008002
   ROD: EV_AirSuspe_AU64.rod
   VCID: 2C5D0E9C4710169
   Revision: AA000000    Serial number: 00000014727766
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Revision: --------    Serial number: EJ1BPA3100XW8S0
   ROD: EV_SARA_AU64.rod
   VCID: ECDD4E9C0790569
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Revision: 00H01000    Serial number: 6PZ 010 287-07
   VCID: 2E590494B90C649
   Part No: 4H0 907 568 A
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Revision: --------    Serial number: 0000120547259
   VCID: 438F4520C28EF91
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0159921986
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H11 0080
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Coding: 020200
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000025817
   Coding: 030000
   VCID: 1C3DDE5C1FB0E69
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Revision: AA000000    Serial number: 00000014816977
   VCID: F1E35FE828B2BB1
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Revision: --------    Serial number: 0000120382709
   VCID: 3A7138C4B544B89
   Revision: --------    Serial number: 00000000147982
   ROD: EV_ParkiBrake.rod
Address 56: Radio (R)       Labels: None
   Part No SW: 4H0 035 082 B    HW: 4H0 035 082
   Revision: AB001007    Serial number: 155HY0B7511356
   VCID: 2045EAAC33D8C29
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Revision: AA000000    Serial number: 00000014816966
   Part No SW: 4H0 035 746 D    HW: 4H0 035 746
   Revision: --------    Serial number: 035JZ0B7504356
   VCID: 2953F78840E2031
   Subsystem 2 - Part No SW: 4H0 919 604 D    HW: 4H0 919 604 D
   Subsystem 3 - Part No SW: 4H1 919 600 F    HW: 4H1 919 600
            000 -  -  - Intermittent
                    Reset counter: 69
                    Mileage: 502 km
                    Date: 2012.06.01
                    Time: 13:07:41
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00010000
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Revision: --------    Serial number: 0000120482526
   VCID: 397327C8B042B31
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Revision: --H04---    Serial number: 525 PA8J17D1M2
   Coding: 1080003
   VCID: 2649FCB491FC2C9
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Revision: 10011001    Serial number: 256100203
   Coding: 0210044100
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3D7B33D8AC6A8F1
Address 6F: Centr. Conv. II (J773)       Labels: None
   Revision: --------    Serial number: 000000046400
   ROD: EV_Ambie.rod
   VCID: E3CF25A0EA4E191
   Revision: --------    Serial number: 0000120482529
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H07 0082
   Revision: 0L0D5012    Serial number: SN110727  0507
   ASAM Dataset: EV_GSM2x3Mono 001015
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2B5F0D80421E111
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: E5CB3BB8E47A671
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Serial number: 00001638159702
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F67199076066D1
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00001638160002
   Coding: 364FF2
   ROD: EV_IVBPasseSideFrnt_AU64.rod
Address 8A: Multicont. Seat Rear,DS (J875)       Labels: None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Serial number: 00001637035802
   Coding: 200F00
   ROD: EV_IVBDriveSideRear_AU64.rod
   VCID: 2E590494710C649
Address 8B: Adaptive Cruise 2 (J428)       Labels: None
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3601020201
   ROD: EV_AdaptCruisContr2AU64X_AU64.rod
   VCID: 2757F1B05EF6351
Address 8D: Multicont. Seat Rear,PS (J874)       Labels: None
   Serial number: 00001637038001
   Coding: 200F00
   ROD: EV_IVBPasseSideRear_AU64.rod
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 C    HW: 4H0 907 107
   Serial number: 000040220709117
   Coding: 02A19A000111
   ROD: EV_BC7.rod
   VCID: 2649FCB459FC2C9
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066F609031F037E070308014240C2010000
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
Try SpeedTest.net both via you're phone's native connection and via AudiConnect?
04 is a phantom address; it doesn't "talk" directly.
But 09 Should be there. What happens if you try to access 09 directly?
jakematic
NC USA
C?ID=129085
09 is reachable if manually selected:
iPhone hotspot on LTE had excellent performance otherwise, and a browser could get to VCDS-Cloud.com, email, etc.
ASAM codes are giving me fits, just says 'checking with server'
They partially downloaded once after I cancelled an Autoscan, it warned more modules need to be downloaded but couldn't.
Tried clearing cache on HEX-NET and re-scan, wait 4 minutes, no joy.
Self test while attached to iPhone:
Additional data points:
- 2012 A8L
- Autoscan takes ~6 minutes to complete - no recollection of time it used to take on laptop
- took 6 Autoscans
- vehicle was running
Let me know what your thoughts are.
I may have to connect everything to home WiFI to get Cloud access turned on and ASAM downloaded.
jakematic
NC USA
C?ID=129085
Audi Connect with full bars and "Good" signal indication on MMI:
iPhone on LTE with 3 bars:
Advanced test on iPhone hotstpot:
Advanced test on iPhone hotspot - at another cell location:
jakematic
NC USA
C?ID=129085
Traceroute on iPhone hotspot:
The traceroute never finished.
Note that on the second cellular site the signal flipped to "4G"
This wreaked havoc with the ASAM download and HEX-NET lost internet connection.
When it flipped back to LTE, I plugged in the ASAM update URL and it downloaded.
Ran another Autoscan afterward.
Tried to connect to home WiFi but even with the vehicle as close as possible, the DLC on A8 is buried and HEX-NET could not see router.
My conclusion is that 3G Audi Connect is not viable due to network lag.
2 hours later I finally was able to force the ASAM download on the iPhone.
Tests have been performed at at least 4 locations this week, all having different cell towers.
Now for the $64 question - shouldn't I be able to clear DTC's and setup my VCDS-Cloud account now ?
No options present themselves, yet documents are uploading
EDIT: One additional note, once a scan has been uploaded the email option puts only "#hndoc:?docid=00000135" in the body of the email.
Not sure if that is intended functionality.
jakematic
NC USA
C?ID=129085
Additionally I just noticed coding is missing for these modules: 03, 08, 85, 88, 89, 8A, 8D, 8E, 8F, 90
You can see in the scan attached previously it is there using my old cable.
Missing modules and coding can be split into another thread if that makes sense to you guys. Thanks-Jake
Santos
Yes. Have you gone into cloud functions?
Connect to any module. Click functions, then Cloud Functions. It should prompt you with a new user registration page. This video will have the instructions for setting up a cloud account:
http://www.youtube.com/watch?v=bgkm0fZ0cbw
Nah, let's just keep the Jake thread intact, at least for the time being.
The SpeedTest results via AudiConnect are truly pitiful. Also, there's the Port 11011: Failed that's bothersome. The SpeedTest via LTE is much better, but the ping times are still quite bad. Anyway, we're looking at all of this. Thank you for all the feedback so far!
jakematic
NC USA
C?ID=129085
That worked, thanks Santos !
I've been so enormously frustrated trying to get the ASAM data download I forgot how to do that.
And I'm old, and curmudgeonly, and forgetful, and like paper :D
It took over a minute for the Functions button to show up, so I may not have waited long enough earlier today.
Cleared a couple of DTCs and was thinking VCDS classic way of pressing a button to clear everything.
Hopeful Audi Connect works and I can use my iPad [read: see with bifocals] to switch back and forth from logs to Functions.
The port failure comes and goes in my tests.
I get fair or poor ping results even on my home network - cable, 50+ Mbps.
Now that I got past the PEBKAC I'll try Audi Connect again tomorrow.
Glad to assist, and appreciate your teams hard work.
jakematic
NC USA
C?ID=129085
Apologies for the delayed followup - been sick, and busier than a three legged dog burying a bone on a frozen pond.
Attempted to associate HN1-176 with my VCDS-Cloud account and download ASAM data with no joy.
On the home WiFi I was able to 'force' an ASAM download but since the Auto-Scan did not save I'm not sure if it got everything.
Bottom line in the current incarnation, or at least in my area, Audi Connect is not a viable option.
Will tether to the iPhone tomorrow and get this cleaned up.
Doing some traveling this quarter so I'll try it in some different cellular markets as well.
My next A8L should have LTE, so we can revisit it then too.
EDIT: Low power mode worked perfectly for me. Forgot the HEX-NET so had to go back to garage.
Screenshots for your viewing pleasure:
