No crank, no start! Please help...
zacharyprice
Texas
C?ID=267295
Made a stupid mistake because I was in a hurry and when I had a dead battery I used my battery booster to jump my 2012 GTI. Unfortunately for me I didn't pay close enough attention to the polarity and had reversed the leads to the battery which has induced what seems to be multiple abstract failures within my baby.
So far, I have verified that all fuses (in cabin & engine compartment) are good and the battery (which was dead at the time) has been replaced with a brand new one. The relays inside the engine compartment fuse box are also good (check operation and resistance).
Symptoms:
Put key in and turn to ACC, standard operation, lights on dash come on, flash, etc. as usual. When turning to key to crank there is no difference from ACC. In other words the car does not attempt to turn over. It appears to do nothing at all. I have checked the headlights' intensity (as well as the dome lights) when performing this as there is no dimming taking place which leads me to believe that wiring is good.
All that being said, I am a new VCDS user (with a small bit of experience previously) but an avid VW fan. I have chipped my previous VW and am very familiar/comfortable with tweaking engines for performance. I am a web developer so I am also familiar with coding and programming logic and I was an Electronics Technician in the Navy so I have a very good understanding of technical jargon.
Below are my results from my autoscan. I certainly appreciate anyone's time in advance that can point me in the direction that I need to go regarding my next steps as far as deciphering these results and proceeding with the repair. Thank you guys for taking the time to read this.
Saturday,09,January,2016,14:00:09:40722
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(Parallels)
VCDS Version 15.7.3.0 (x64)
Data version: 20151216
Dealer/Shop Name: Price House
VIN: WVWHD7AJ6CW3xxxxx   License Plate: DVW
Mileage: 99320km-61714mi   Repair Order: January-2016
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
VIN: WVWHD7AJ6CW3xxxxx   Mileage: 99320km-61714miles
Address 01: Engine        Labels:
   VCID: 55E24A7CAC9E449672-FFFF
   Part No SW: 02E 300 057 R    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3115
   Revision: 05551213    Serial number: 00001203231314
   VCID: 281C33889B6C097E19-807D
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 00:01:45
   Revision: 00H31001
   Coding: 114B600C49230002880B06E592210041B70800
   VCID: 7BB63CC4FA7A72E624-802F
02214 - Tire Pressure Warning
                    Reset counter: 173
                    Mileage: 93450 km
                    Date: 2015.10.27
                    Time: 12:02:02
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 50176
                    Count: 512
                    Count: 256
                    Reset counter: 61
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 13:16:50
                    Count: 3
                    Count: 15
                    Count: 28672
                    Count: 16390
                    Count: 34048
                    Count: 509
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000001002
   VCID: 004C4B289B9C113E71-8055
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 6F180A1A90272AC4008800C170000D4448052086434D8D20E48420240040
   VCID: 3D32F2DCA4EEBCD65A-8069
   Component: Wischer 30031  26  0512
   Coding: 009795
7 Faults Found:
            000 -  -  - Intermittent
                    Reset counter: 99
                    Mileage: 99229 km
                    Date: 2016.01.03
                    Time: 13:23:21
                        Term 15 Off
                    Voltage: 11.80 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 13:17:59
                        Term 15 Off
                    Voltage: 8.10 V
                        Term 50 Off
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 00:00:14
                        Term 15 Off
                    Voltage: 7.90 V
                        Term 50 Off
01259 - Fuel Pump Relay (J17)
                    Fault Status: 00101001
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 06:09:54
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 01:57:09
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
02391 - Terminal 30 Reference
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 01:58:00
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
01516 - Terminal 30; Left
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 00:01:41
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
   Serial number: 003GVRA1Z789
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 3FCE88D4A6E2AEC648-806B
   Serial number: ---0000R--00002NDA00
   Serial number: 3572MSME7B28746DZZZ8
   Serial number: 3582MSME0222626CZZZQ
   Serial number: 3512QSME74510F40ZZZR
   Serial number: 3522QSME42570F49ZZZ
   Serial number: 35527SME6A4A322CZZZP
   Serial number: 35627SME4C72322CZZZL
13635840 - Supply voltage
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 13:17:50
9483264 - Seat Occupied Recognition
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 13:17:06
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90422LCQ000YQ
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76A02DF0C9582F8E5B-8023
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0007204
   Coding: 830000
   Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
   Coding: 270F01
   VCID: 3620EDF089D86F8E9B-8063
   Revision:   H42       Serial number: 270312F1002413
   Coding: 350002
   VCID: 3A38F9C0B5C08BEE7F-806F
   Component: IMMO          H03 0607
   VCID: 6A9809808DE0FB6ECF-803F
   Revision: A1001003    Serial number: 7662257640
   Coding: 020000
   VCID: 291A368C4066307606-807D
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H35 0265
   Serial number: VWZAZ2M4213046
   Coding: 04000401040005000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 230624A42A4AEA264C-8077
   Component: NAR_V2  0002
1048580 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 101
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 13:17:10
1048584 - Function limitation due to excessive temperature
          B1050 00 [008] -  -
                    Reset counter: 74
                    Mileage: 98131 km
                    Date: 2015.12.21
                    Time: 14:09:59
1048653 - CD ROM Drive
          B1100 07 [008] - Mechanical Failure
                    Reset counter: 18
                    Mileage: 95879 km
                    Date: 2015.11.24
                    Time: 12:07:31
          B11CF 53 [009] - Deactivated
                    Reset counter: 2
                    Mileage: 7898 km
                    Date: 2012.12.22
                    Time: 08:45:26
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0001204
   VCID: 373EE0F446D2968680-8063
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 6.5 V
                        PD
                    Temperature: 29.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Coding: 0001204
   VCID: 3228D1E0ADB073AEB7-8067
   Coding: 1446940
   VCID: 3424D7F857A47D9EA5-8061
   Coding: 00000022
   Coding: 00000022
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 3522EAFC5CDE649692-8061
   Coding: 0001168
   VCID: 3620EDF041D86F8E9B-8063
End-------------------------(Elapsed Time: 01:43)--------------------------
Control Module Part Number: 02E 300 057 R    HW: 02E 927 770 AL
  Component and/or Version: GSG DSG AG6     512 3115
           Software Coding: 0000020
            Work Shop Code: WSC 01357 011 00200
            U0235 - 000 -
                    Reset counter: 40
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 00:01:45
            U0235 - 000 -
                    Reset counter: 40
                    Mileage: 99323 km
                    Date: 2016.01.04
                    Time: 00:01:45
Welder75
Canada
C?ID=261654
is you battery dead from a short draining your battery?
if u have a intelligent charger, it wont do any damage! hopefully you do.
did u clear the faults after you installed new battery? did you do TBA?
if after clearing faults you still have fuel pump relay fault . start there. when u turn on key do u hear a click from fuel pump relay? double check fuse is good?
if nothing else. test your starter.
http://forums.ross-tech.com/showthr...o-do-to-help-yourself-while-waiting-for-help!
zacharyprice
Texas
C?ID=267295
Hey Welder thanks for responding so quickly, I definitely appreciate it.
The battery booster than I used is the Schumacher XP2260 and I haven't checked whether or not it has that capability yet. I do know that these faults did not occur until after I tried to jump the car as it was working flawlessly prior to the battery going bad (which was verified prior to me purchasing the new one). I also own a Schumacher 5212A that I used to quick start the car prior to the booster which led to no better result.
I did not clear any faults after the new battery mainly because I didn't own the VCDS system at that time. Same goes for the TBA. I will clear them, TBA and heck for the FP relay. Thanks for the link on the fuses. I will re-verify them after the faults have cleared and touch base tomorrow after work.
Again I really do thank you for your help and such a speedy reply, it's such a relief.
Zenerdiode
Newcastle, England
C?ID=24330
This rather innocuous part of your Auto-Scan looks worrying. Please try connecting to 01-Engine from the main Select Control Module screen in VCDS. If successful, post the faults you receive. If not - and I'm suspecting - your ECU has been fried...
Welder75
Canada
C?ID=261654
Didnt notice that ... cross your fingers.
Just to clarify...are all idiot lights inside the cabin turning on, radio, heater/fan, wipers, signals? Did you check *all* the fuses, both inside the cabin and the ones near the battery? Even if the Alt. and/or ECU are bad, the car should still crank, so I wouldn't give up yet. Check voltage at the starter (the thick wire) from the battery.
Check terminal 15 relay and ignition switch plausibility for mechanicals since suffering FOD......
zacharyprice
Texas
C?ID=267295
I have tried numerous times to connect to this red line and it will not connect. It is the only fault that will not go to the next screen. ECU being fried sounds terrible...looks like they run almost a grand :(
zacharyprice
Texas
C?ID=267295
Thanks for the input Jack, I will give this a shot when I get home today. I really do appreciate the advice.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Did you check inline fuse strap?
It is located in engine fuse box on side where big red wires connects.Check each one .
I bat it blow few fuses.
Older cars like Mk5 had separate fuses.
Now in New cars is Inline fuse strap,means one piece for all fuses, but it is not to pricey about $30.
I doubt ECU is fried.Anyway you can get Used ECU and I can program it if is that case. But like I said I doubt.
Check what I said above first.
Where are you in TX?
zacharyprice
Texas
C?ID=267295
Thanks for the tip. I am in FW so not too far from you it would appear.
I wasn't aware of any other fuses besides the engine & cabin compartment boxes. I will check those as soon as I get home. God I hope that is all it is. I would think that there would be some kind of protection like that in a car system of today's time.
zacharyprice
Texas
C?ID=267295
All:
I am currently looking into everyone's suggestions. I took a half day off of work in order to get some time to do so. There is a new symptom that I'd like to report.
When I turn on the car (all symptoms normal with the exception of a louder alarm - I assume it is related with the current faulty condition) there is a constant, repetitive and expeditious clicking coming from the device attached to the very front-top of the engine.
zacharyprice
Texas
C?ID=267295
Relays ......Terminals 15 30 and 75..........?
Jack, I checked out Terminal 30 on the fuse box in the engine bay and is was good (physically and resistance wise). There was only one other relay on that fuse box so I checked it as well and it too was good.
According to this diagram I am reading (see image below) it appears that there is a set of relays behind the dash underneath the steering wheel. This is something I just stumbled upon and have not checked yet. Would this be the Terminals 30 & 15 you are referring to?
zacharyprice
Texas
C?ID=267295
I just checked for that set of relays behind the dash and they do not exist :banghead:
zacharyprice
Texas
C?ID=267295
ALL:
Just a status update...
I found the "in-line" fuse which is the plate fuse that Jetta97 was speaking about. I personally have never seen one like this before so I had skipped right over it. I checked it out and it is good. Check images below. I also checked the terminal board and verified the continuity of the fuse from each cable to the other side of the board, across the screw on the smaller plate (again, see image).
I have also attached two images showcasing the object that was expeditiously clicking when I had a full charge. I am guessing it may be a MAF or something as there is a 2.5-3" hose connected to the bottom of it.
Again I thank you all for your advice and look forward to your continued assistance.
Jetta 97
C?ID=81680
You need to put that inline fuse back and You need to check do you get 12V on each cable not continuity.
You need to have 12V on all of them all the time.
I never said to remove it, I said check voltage.
I see you played fuse box but I also see you didn't touch that ground strap on body.........
Check ground points and trace the terminal relays + ignition switch with tone generator to BCM and inspect the inside of the BCM for burn down visually.
NEtech
C?ID=56995
If fuses and relais okay, I would say new Engine Controller, know somebody that just did the same with an VW Scirocco.
LN-TAL
Norway
C?ID=13729
Hmm, I really doubt that the ECU is the problem. How can you then explain a no crank ? Have NOT looked at the wiring diagram for this car, but on most of the cars I have been looking into, the circuit for the starter motor is completely independent of the ECU. I would more closely look at the ignition switch. Get a WD and start measuring. And how do you check the relay's ? Do you put power to them and really check that they do their job (closes the correct terminals) ? Or do you just ohm them ?
Does EVERYTHING else works ? (wipers, seat heating, turn signals, headlights etc). If you send me the VIN and a picture of the service tag (with engine code, gear code etc etc) I can look at the wiring diagram (IF I have it since you are in the US and I am in europe) and give you some hints.
Edit: I now see that this car is 2012. Then you guys are probably correct, the steering coloum electronics controls the starter motor togetheter with the ECU. Somehow I was thinking that this car was made shortly before 2000. I would then check that the ECU have power input on the correct pins.
