Retrofitting multiple parts on Passat B7 EU
RARES
Belgium
C?ID=316732
Hello everyone,
This is my first post here so please bear with me.
I have a 2011 Passat Variant B7 2.0 CR TDI CLBMT 103.
I was recently involved in an accident that damaged both front and back of my car.
I decided to fix it myself and found a donor car from witch I've sourced everything.
Almost everything that I've got is basially a retrofit.
I already have ParkAssist with 12 PDCs from fatory.
So here is the list:
1. Bi-Xenon with static cornering and fog lights + LED tail lights + headlight washing system
2. Automatic open/close hatch
3. Backup camera
4. DCC (I decided not to install the struts since I have Bilstein B16 if I recall)
5. RNS510 with Blaupunkt 8ch digital amplifier
I am almost finished with the installation of everything and I've done a quik test with almost everything connected but I saw a lot of expeted errors.
After I finish with the install I will do another scan and see what is left and post it.
I am asking for support with where to begin, what stepts to follow, quick links to where I can find exatly what to do.
I am asking for this help since this is the car that I work with and not a project car that can wait. I have to do it quick so I can start working again.
Thank you all in advance,
Rares
PetrolDave
Westbury, UK
C?ID=1423
First step here is to post a full unedited VCDS Auto-Scan (using the English version of VCDS) so we have an idea how your Passat is equipped, this will hopefully be a good starting point for us.
RARES
Belgium
C?ID=316732
Here you have the two scans of before and after:
Before
Monday,28,October,2019,22:57:36:48725
VIN: WVWZZZ3CZCE017535   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 4F 52 53 56 61
          62 72 77
VIN: WVWZZZ3CZCE017535   Mileage: 375240km-233163miles
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9978
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 00190032042401080000
   Shop #: WSC 00537 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003008
   ROD: EV_ECM20TDI01103L906018BF.rod
   VCID: 6FB8DB424716E92F20D-803A
4795 - Mass Air Flow Sensor (G70)
          P0101 00 [096] - Implausible Signal
   Part No SW: 3AA 614 109 AC    HW: 3AA 614 109 AC
   Component: J104   C2 450M VDD7 0022
   Revision: --H07---    Serial number: 00000004369150
   Coding: 0003504
   Shop #: WSC 05311 000 00000
   VCID: 6E86C6464C9CE0272BB-803A
   Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
   Component: AC Manuell    H17 0202
   Revision: 00001012
   Coding: 0000000003
   Shop #: WSC 00015 115 00000
   ROD: EV_ClimaBasis_VW46.rod
   VCID: 3D24310A5DFA4BBFE21-8068
   Part No SW: 3AA 937 087 C    HW: 3AA 937 087 C
   Component: BCM PQ47 M    413 0455
   Revision: BA413001
   Coding: 000000000000000000180080540000E407510088426D85606480C7200041
   Shop #: WSC 05311 000 08193
   VCID: 3A2E3A164C547C87C73-806E
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 31051  10  0603
   Coding: 00B795
   Component: RLS 220611 05  54  0403
   Coding: 0A302A
                    Fault Status: 00101010
                    Fault Frequency: 235
                    Reset counter: 0
                    Mileage: 366917 km
                    Date: 2014.01.31
                    Time: 18:08:19
                    Voltage: 11.10 V
                    Fault Frequency: 51
                    Reset counter: 0
                    Mileage: 366917 km
                    Date: 2014.01.31
                    Time: 18:08:19
                    Voltage: 11.10 V
                    Fault Frequency: 34
                    Reset counter: 254
                    Mileage: 366927 km
                    Date: 2014.01.31
                    Time: 20:26:13
                    Voltage: 14.85 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56231115904504
   Coding: 148206
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: 44D244EE3E103A77ADF-8010
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__10H VW10 HI   1918
   Revision: 22014000    Serial number: 003JZPC9JG9I
   Coding: 0012360
   VCID: 4BC06FD21FCEF50F6C5-801E
   Subsystem 1 - Serial number: 6332MTS636381531
   Subsystem 2 - Serial number: 6342MTS604871541
   Subsystem 3 - Serial number: 6351HTS6A44F5AKR
   Subsystem 4 - Serial number: 6361HTS6UP2I5AKR
   Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110616100362
   Coding: 118A250000
   VCID: 76B6EE26384CD8E7E3B-8022
   Coding: E20000
   Part No SW: 3AA 920 870 D    HW: 3AA 920 870 D
   Coding: 161E01
   Shop #: WSC 05314 115 00000
   VCID: 333017326BBE8DCF045-8066
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 070611F2000494
   Coding: 462006
   Shop #: WSC 05314 000 00000
   VCID: 382A201E72586E97317-806C
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   VCID: 76B6EE2634CCD8E7E3B-8022
   Revision: A1001003    Serial number: 7660248983
   VCID: 290CF55AB9F2C71FBE9-807C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003022674
   Coding: 0210B7
   Shop #: WSC 05311 115 00000
   VCID: 3534292A65CA93FF2A1-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000002234674
   Coding: 000090
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.309 0802
   Revision: 1AH03729    Serial number: 00111580309501
   Coding: 0000258
   VCID: 3B203F124F6E458FDC5-806E
   Component:    KSG PQ47 ELV 043 0634
   Coding: 1991020052830E7600029C1CFC084FCE707C01
   Component: EZE_2         H40 1620
   Coding: 00000008
   VCID: 6FB8DB424796E92F20D-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0003037343
   Coding: 0210B6
   VCID: 36362E2678CC98E723B-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002233294
   Coding: 000090
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000055168
   Coding: 0022167
   VCID: 3534292A694A93FF2A1-8060
   Part No SW: 3C8 035 195 F    HW: 3C8 035 195 F
   Component: RCD510        H01 5016
   Revision: -----14S    Serial number: VWZ4Z3L1147906
   Coding: 01000400040011
   VCID: 2B000F52B30ED50F4C5-807E
   Component: Batt.regelung H40 1620
   Coding: 030B185A
   VCID: 71BCDD3A51A2FFDF369-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900735687
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       011 0723
   Revision: --------    Serial number: 35909603179017
   Coding: 020000000000000000000000
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_A02.rod
   VCID: 221EE276C4441447FF3-8076
          U1400 00 [008] - -
                    Reset counter: 254
                    Mileage: 374698 km
                    Date: 2019.10.23
                    Time: 20:07:41
End----------(Elapsed Time: 01:35, VBatt start/end: 14.7V/14.8V)-----------
After:
Thursday,27,February,2020,03:09:18:48725
VIN: WVWZZZ3CZCE017535   License Plate: RARES
Mileage: 381620km-237127mi   Repair Order:
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 47 4C 4F 52
          53 55 56 61 62 6C 6D 72 77 A5
VIN: WVWZZZ3CZCE017535   Mileage: 381620km-237127miles
4C-Tire Pressure II -- Status: Not registered 0001
72-Door, Rear Right -- Status: Sporadic communication error 1000
A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 1100
   VCID: 6FB8DB424716E92F20F-803A
   Component: J104   C2 450M VD18 0022
   Coding: 0003504
   VCID: 6E86C6464C9CE0272B9-803A
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:27:51
                    Speed: 15.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.75 V
                    Bin. Bits: 00011110
                    Count: 247
                    Hex Value: 0x0010
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:28:02
                    Speed: 14.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.75 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
   Revision: 00001012
   Coding: 0000000003
   Shop #: WSC 00015 115 12345
   VCID: 3D24310A5DFA4BBFE23-8068
9475861 - Position Sensor for Temperature Flap Motor
          B1097 15 [009] - Open or Short to Plus
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 00:00:43
9477141 - Position Sensor for Air Distribution Flap Motor
          B109C 15 [009] - Open or Short to Plus
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 00:16:03
13701536 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Türsteuergerät hinten rechts - kein Signal/Kommunikation]
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 01:08:33
9472533 - Temperature Sensor for Evaporator Vent
          B108A 15 [009] - Open or Short to Plus
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 00:00:01
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 000000000000000000180088540029F463D50088626D8D60E480C7240049
   Shop #: WSC 05311 123 08193
   VCID: 392C251A4952779FCEB-806C
   Coding: 00B795
   Coding: 0E302A
8 Faults Found:
                    Fault Status: 00101001
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:00:02
                        Term 15 Off
                    Voltage: 12.75 V
01259 - Fuel Pump Relay (J17)
                    Fault Status: 01101001
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:00:08
                        Term 15 Off
                    Voltage: 12.75 V
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:00:04
                        Term 15 Off
                    Voltage: 12.75 V
                    Fault Status: 01101010
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:02:50
                    Voltage: 12.55 V
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:02:50
                    Voltage: 12.55 V
02092 - Enabling Heated Seat
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:03:34
                    Voltage: 12.60 V
02235 - Stationary Cornering Lamp (Left) (M51)
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:02:50
                    Voltage: 12.55 V
02236 - Stationary Right Cornering Lamp (Right) (M52)
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:02:50
                    Voltage: 12.55 V
   Coding: 148206
   Shop #: WSC 99999 102 209715
   VCID: 44D244EE3E103A77ADD-8010
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [009] - Open Circuit
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 00:16:46
1111316 - Speaker for Front Parking Aid
          B10F5 14 [008] - Open or Short to Ground
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 01:08:33
   Revision: 00000000    Serial number: 01121001530001
   VCID: 2708F362AFE6F16FA8F-8072
8 Faults Found:
00142 - Left Front Dampening Adjustment Valve (N336)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 24
                    Bin. Bits: 00000000 00100000
00143 - Front Right Dampening Adjustment Valve (N337)
                    Reset counter: 24
00144 - Rear Left Dampening Adjustment Valve (N338)
                    Reset counter: 24
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:32
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:11:09
00145 - Rear Right Dampening Adjustment Valve (N339)
                    Reset counter: 24
            000 - - - MIL ON
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:11:09
00149 - End of Line Programming not Completed
            000 - - - MIL ON
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:11:09
   Coding: 0012360
   VCID: 4BC06FD21FCEF50F6C7-801E
8 Faults Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            010 - Open or Short to Plus - Intermittent - MIL ON
                    Fault Status: 10101010
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:34
01220 - Rear Side Airbag Igniter; Passenger Side (N202)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:34
01219 - Rear Side Airbag Igniter; Driver Side (N201)
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:34
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:34
01217 - Side Airbag Igniter; Driver Side (N199)
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:34
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:34
00589 - Airbag Igniter 1; Passenger Side (N131)
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:34
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:33
   Coding: 118A250000
   VCID: 76B6EE26384CD8E7E39-8022
   Coding: E20000
   Coding: 061F01
   Shop #: WSC 05314 115 12345
   VCID: 333017326BBE8DCF047-8066
13648640 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für LaneDepartureWarning: keine Kommunikation]
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 00:20:01
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 241110F2001549
   Coding: 462006
   Shop #: WSC 45403 141 98537
   VCID: 3432142E6E308AF71DD-8060
                    Fault Status: 00110100
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:00:02
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:00:02
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:00:06
                    Fault Frequency: 7
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:00:02
03850 - Front Sensor Electronics for Driver Assistance Systems
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:00:38
   VCID: 76B6EE2634CCD8E7E39-8022
02835 - Communications between Steering Column Lock and Convenience System
                    Reset counter: 64
   VCID: 290CF55AB9F2C71FBEB-807C
03138 - Input AUX IN
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:49:26
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H42 2720
   Revision: AB001001    Serial number: VWZ6Z7K9332195
   Coding: 04070002010000A000
   Shop #: WSC 05314 123 12345
   VCID: 2E060646801CA0276B9-807A
                    Reset counter: 24
                    Mileage: 381624 km
01523 - Microphone for Telephone (R38)
                    Fault Frequency: 12
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:41
00862 - Antenna for GPS Navigation (R50/R52)
                    Fault Status: 00101011
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:41
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:33:35
   Coding: 0210B7
   VCID: 3534292A65CA93FF2A3-8060
   Slave Driver:
   Coding: 000090
   Coding: 0000258
   VCID: 3B203F124F6E458FDC7-806E
00566 - Steering Assistance Operation
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:13:56
                    (no units): 7.0
                    Steering Angle: 182.04°
                        OK
                    Steering Angle: 136.46°
                    (no units): 15
   Coding: 1891020052834E7E00029C1CFC004FCE707C01
   Shop #: WSC 05311 123 12345
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:02:48
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:02:48
Address 47: Sound System
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FB8DB424796E92F20F-803A
   Coding: 0210B6
   VCID: 36362E2678CC98E7239-8062
   Slave Passenger:
   Coding: 000090
   Coding: 0022167
   VCID: 3534292A694A93FF2A3-8060
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0080
   Coding: 02BA00100F000200
   Shop #: WSC 05311 115 08193
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H03 X008
   Coding: 2C0000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H03 X008
   Coding: 2C0000
5275220 - Headlight
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 00:21:52
13705990 - Databus
          U1123 00 [137] - Received Error Message
          [Fehlerwert im Signal NI2_Hoehe_VL_Roh]
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 00:21:51
                    Reset counter: 24
                    Mileage: 381624 km
                    Fault Frequency: 12
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:41
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 01:08:41
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2014.07.20
                    Time: 00:33:35
   Component: Batt.regelung H41 1614
   Coding: 032B1864
   VCID: 71BCDD3A51A2FFDF36B-8024
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H08000    Serial number: 525PA8-J0X2091
   Coding: 0020007
   VCID: 688AB05E6E783E17615-803C
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 J    HW: 3C9 827 383 J
   Component: J605  HECKDECKEL    0804
   Revision: 00H27001
   VCID: 382A201E7E586E97315-806C
   Subsystem 1 - Part No: 3C9 827 384 J
   Component: J756  HECKDECKEL    0804
   Subsystem 2 - Serial number: 1000H27001001A0205ÿ
   VCID: 221EE276C4441447FF1-8076
6 Faults Found:
9457427 - Left audio channel for speech/telephone
          B104F 13 [008] - Short to GND
                    Reset counter: 65
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 01:00:43
9457171 - Right audio channel for speech/telephone
          B104E 13 [008] - Short to GND
                    Reset counter: 65
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 01:00:43
9455635 - Telephone Microphone
          B1048 13 [008] - Open Circuit
                    Reset counter: 65
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 01:00:43
9457939 - Telephone baseplate
          B1051 13 [008] - Open Circuit
          [Halterung für Handyhalter (Baseplate): Unterbrechung]
                    Reset counter: 64
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 01:08:33
9458193 - Control Module for Cellular Telephone
          B1052 14 [009] - Open or Short to Ground
          [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung/ Kurzschluss nach Masse]
                    Reset counter: 24
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 01:08:33
0022 - Radio
          U1066 00 [008] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                    Reset counter: 65
                    Mileage: 381627 km
                    Date: 2020.02.27
                    Time: 01:00:48
Address A5: Frt Sens. Drv. Assist
End----------(Elapsed Time: 02:04, VBatt start/end: 14.8V/13.4V)-----------
RARES
Belgium
C?ID=316732
I have the scan from the donor car as well but some components were already removed from the car before scanning it.
Saturday,01,February,2020,08:46:41:48725
VIN: WVWZZZ3CZBE320764   License Plate: DONOR
Mileage: 108580km-67468mi   Repair Order:
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 47 4F 52 53
VIN: WVWZZZ3CZBE320764   Mileage: 108580km-67468miles
14-Susp. Elect. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 BF    HW: 03C 907 309 E
   Component: 1.4l R4/4V TS H15 9073
   Revision: L5H15---    Serial number: 00000000000000
   Coding: 00190012002401000000
   Shop #: WSC 00017 666 01711
   ASAM Dataset: EV_ECM14TFS01103C906016BF 001006
   ROD: EV_ECM14TFS01103C906016BF.rod
   VCID: 6492A46E9ED05A774DF-8030
8 Faults Found:
8221 - System Voltage
          P0562 00 [032] - Too Low
4635 - Engine Oil Temp. Sensor (G8)
          P0196 00 [032] - Implausible Signal
2813 - Accelerator Position Sensor (G79)
          P2122 00 [032] - Signal too Low
2815 - Accelerator Position Sensor 2 (G185)
          P2127 00 [032] - Signal too Low
4675 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
          [Software Incompatibility with Anti-Lockplease read DTC]
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:16
                    Engine speed: 1119.50 /min
                    Normed load value: 16.5 %
                    Coolant temperature: 21 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 11.803 V
                    Cruise Control System (CCS): status-Bits 0-7: 47
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Acceleration: 0.000 m/s²
4629 - ECM Power Relay Load Circuit
          P068A 00 [039] - Opens Too Early
                    Coolant temperature: 0 °C
                    Intake air temperature: 0 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 13.028 V
                    Mass flow through throttle valve: 0.0 kg/h
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
4043 - Boost Pressure Regulation
          P0234 00 [096] - Limit Exceeded (Overboost Condition)
4044 - Boost Pressure Regulation
          P0299 00 [096] - Control Range Not Reached
   Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
   Component: J104   C2 450M VD18 0005
   Revision: --H07---    Serial number: 00000003463321
   Coding: 0003432
   VCID: 382A201E7E586E97317-806C
                    Fault Frequency: 57
                    Reset counter: 24
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 2
                    Hex Value: 0x0000
                    Fault Frequency: 56
                    Reset counter: 24
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 3
                    Hex Value: 0x0000
                    Fault Frequency: 23
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:01:09
                    Hex Value: 0x0000
                    Voltage: 10.25 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000003
   Shop #: WSC 00015 115 08193
   VCID: 6E86C646401CE0272BB-803A
13701520 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Türsteuergerät hinten links - kein Signal/Kommunikation]
                    Fault Frequency: 10
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:22
          U1111 00 [009] - -
                    Fault Frequency: 10
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:22
   Revision: BC413001
   VCID: 392C251A4952779FCE9-806C
   Component: Wischer 22091  10  0603
   Coding: 00B795
   Component: RLS 241110 05  54  0403
   Coding: 033028
15 Faults Found:
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Fault Status: 00101110
                    Reset counter: 64
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:02:55
                    Voltage: 10.40 V
00317 - Rear Lid Control Module (J605)
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:02:36
                    Voltage: 10.05 V
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Fault Frequency: 40
                    Reset counter: 63
                    Mileage: 102588 km
                    Date: 2020.04.06
                    Time: 10:46:13
                    Voltage: 14.85 V
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:23
                    Voltage: 9.55 V
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:23
                    Voltage: 9.55 V
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:02
                    Voltage: 9.35 V
01503 - Bulb for 3rd Brake Light (M25)
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:03:15
                    Voltage: 14.65 V
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:02:37
                    Voltage: 10.05 V
01505 - Bulb for Blinkers; Rear Right (M8)
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:02
                    Voltage: 9.30 V
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:02
                    Voltage: 9.30 V
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:02
                    Voltage: 9.35 V
02738 - Bulb for Tail/Brake Light; Left
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:03:15
                    Voltage: 14.75 V
02739 - Bulb for Tail/Brake Light; Right
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:03:15
                    Voltage: 14.70 V
02740 - Bulb for Tail Light 2; Left
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:03:15
                    Voltage: 14.70 V
02741 - Bulb for Tail Light 2; Right
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:03:15
                    Voltage: 14.70 V
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20431032416146
   Coding: 308206
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 3C223C0E46E042B7D5F-8068
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:01:29
13637396 - Databus
          [Bremsensteuergerät - mBremse_10.B10_Wegimp_HL - Fehlerspeicher auslesen]
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:21
13637397 - Databus
          [Bremsensteuergerät - mBremse_10.B10_Wegimp_HR - Fehlerspeicher auslesen]
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:21
   Revision: 22014000    Serial number: 003JZPNCR3R2
   Coding: 0012360
   Subsystem 1 - Serial number: 6332MTS678272990
   Subsystem 2 - Serial number: 6342MTS605162990
   Subsystem 3 - Serial number: 00000000000000000
   Subsystem 4 - Serial number: 00000000000000000
9 Faults Found:
01588 - Igniter for Head-Airbag; Drivers Side (N251)
                    Fault Status: 11100001
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:22
01589 - Igniter for Head-Airbag; Passenger Side (N252)
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:22
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:22
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:22
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:22
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:22
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:22
01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
                    Fault Status: 11101010
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:21
01638 - Crash-Sensor for Side Airbag; Rear Drivers Side (G256)
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:21
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101128301046
   Coding: 118A250000
   Coding: E20000
365060 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
                    Reset counter: 64
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:02:06
   Part No SW: 3AA 920 880     HW: 3AA 920 880
   Component: KOMBI         H02 0206
   Coding: 161F01
   VCID: 70BAD83E5A28F6D7397-8024
9453074 - Fuel Level Sensor 1
          B103E 1B [009] - Resistance Too High
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:24
13649664 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Heckdeckelelektronik: keine Kommunikation]
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:04
   Coding: 462006
   VCID: 3432142E6E308AF71DF-8060
7 Faults Found:
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:01
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:01
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:05
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:05
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:15
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:05
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:02
   Component:    IMMO         043 0399
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7668976375
   VCID: 280AF05EA2F8FE17A17-807C
   Coding: 04010002010000A000
   VCID: 2E060646801CA0276BB-807A
10 Faults Found:
00859 - Line-Output; Front Right
                    Reset counter: 64
                    Mileage: 108576 km
00823 - Line-Output; Front Left
                    Reset counter: 64
                    Mileage: 108576 km
00869 - Line Output; Rear Right
                    Reset counter: 64
                    Mileage: 108576 km
00860 - Line-Output; Rear Left
                    Reset counter: 64
                    Mileage: 108576 km
00856 - Radio Antenna
                    Fault Frequency: 10
                    Reset counter: 24
                    Mileage: 108576 km
                    Fault Frequency: 10
                    Reset counter: 24
                    Mileage: 108576 km
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:07
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:52
                    Fault Frequency: 12
                    Reset counter: 24
                    Mileage: 85819 km
                    Date: 2025.02.05
                    Time: 17:33:10
                    Reset counter: 64
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:12
   Revision: 12110009    Serial number: 0001811102
   Coding: 0210B7
65538 - Local Data Bus
          U10BA 00 [009] - No Communication
          [Front Timeout LIN Sub bus]
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:02
   Component: J500__APA-BS KL.315 0802
   Revision: 1AH03729    Serial number: 00103270183601
   Coding: 0000258
01288 - Terminal 30; Steering Assist
                    Fault Priority: 9
                    Reset counter: 24
                    (no units): 2.0
                    Voltage: 12.10 V
                    Fault Status: 11101101
                    Fault Frequency: 18
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:22
                    (no units): 4.0
                    Voltage: 9.70 V
   Component:    KSG PQ47 ELV 043 0631
   Coding: 01900A00D2830E76300494157C084FCE707C01
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
                    Fault Frequency: 11
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:07
                    Reset counter: 64
00625 - Vehicle Speed Signal
                    Reset counter: 64
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:12
   Coding: 050B0508
   Subsystem 3 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Revision: 14110009    Serial number: 0001833642
   Coding: 0210B6
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2020.02.01
                    Time: 00:00:02
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000063483
   Coding: 0022067
   VCID: 33301732673E8DCF045-8066
                    Fault Status: 01101101
                    Fault Frequency: 43
                    Reset counter: 24
                    Voltage: 11.70 V
                    Count: 104
                    Hex Value: 0x1270
                    Hex Value: 0x0082
                    Hex Value: 0x0101
   Coding: 02B200104F000200
   Coding: 2C0000
   Coding: 2C0000
          U1014 00 [009] - -
          [Steuergeraet falsch kodiert]
                    Reset counter: 24
                    Time: 00:00:00
13705985 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HL]
                    Fault Frequency: 21
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:21
13705987 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HR]
                    Fault Frequency: 21
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:21
13705473 - Databus
          U1121 00 [137] - Missing Message
          [Timeout mNiveau_2]
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2026.12.11
                    Time: 00:00:03
10 Faults Found:
                    Reset counter: 64
                    Mileage: 108576 km
                    Reset counter: 64
                    Mileage: 108576 km
                    Reset counter: 64
                    Mileage: 108576 km
                    Reset counter: 64
                    Mileage: 108576 km
                    Fault Frequency: 10
                    Reset counter: 24
                    Mileage: 108576 km
                    Fault Frequency: 10
                    Reset counter: 24
                    Mileage: 108576 km
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:07
                    Reset counter: 24
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:52
                    Fault Frequency: 12
                    Reset counter: 24
                    Mileage: 85819 km
                    Date: 2025.02.05
                    Time: 17:33:10
                    Reset counter: 64
                    Mileage: 108583 km
                    Date: 2021.05.03
                    Time: 00:00:12
   Coding: 032B1864
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370203978
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
   Part No SW: 3AA 980 654     HW: 3AA 980 654
   Component: MFK_Gen1      H08 0102
   Serial number: 0134741949
   Coding: 000002000102020D0200040000000000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 75B4E92A254AD3FFEA1-8020
End----------(Elapsed Time: 01:52, VBatt start/end: 14.9V/14.9V)-----------
RARES
Belgium
C?ID=316732
I have to mention as well a few things that might be important:
1. For the DCC the donor car had also a sensor at each wheel hub + the one on the struts witch I don't use as well.
2. The navigation RNS510 came with the R184 amplifier but I didn't pickup the Dynaudio speakers from the doors so when I've connected the wires to the door connectors I saw that for the front I have only 1 pair but the new cable had 3 pairs (low, miss, highs). For the moment I have no audio and I assume it's because of the speakers that I have. I will try to pick them up next time I go there.
3. The donor car had a front camera witch I took as well but for now I don't have a windscreen that supports it so if possible I want to disable that feature.
4. The J533 that I had didn't allow me to start the car so I've used the one from the donor car and that one is working.
5. I've installed all 3 G-sensors (I don't know if they are needed for AFS or not)
6. The front left angle sensor is not connected yet since I'm fixing one ball joint due to rust.
5. The front fog lights and static cornering lights do not work at all but I've tested the wiring and it's all good.
Thanks.
m87a
Bosnia and Herzegovina
C?ID=156900
You made an unbelievable mess of this, I like it :)
1. For DCC you need all of the sensors connected, from scan there is no communication with dcc module
2. For Navigation recode that there is no amplifier and reset it holding (< > and star or i button) after that you will have sound if you're retrofit amp scratch this
3. Front camera can be later retrofitted and can be coded out from J533
4. J533 needs to be coded to your car / current situation
5. AFS needs all sensors to operate, directly connected or via can shared connected to dcc
6. Get it cleaned, if sensor is moving hard, it's toasted
Best of luck
Also try to connect all of the electronics, clear errors and post fresh scan ;)
RARES
Belgium
C?ID=316732
:) you think?
I will post some pictures later....it was a mess but I said that it can't be that hard to follow Elsa wiring diagrams and cross check each wire where it's going :)
RARES
Belgium
C?ID=316732
I can't do the basic settings on the AFS module. The process starts but it keeps running forever (I didn't wait more then 5min). I see the xenon shape on the wall changes but nothing else.
What else am I missing or how long does it take to do the basic settings?
It takes until you tell it to stop.
See Headlight Adjustment section here.
RARES
Belgium
C?ID=316732
Thanks for that info.
I've cleared that alarm now.
A few more left :)
I still have a J17 pump relay fault that I didn't have before.
I've seen on the petrol harness that I removed from the donor car that there is a relay right outside of the fuel pump under the back seats.
My diesel car does not have that there.
Also the manual AC is not working properly...it is always heating and middle front vents do not open. I've read that there is a way for the climatronic to calibrate it. Is it possible to do it on manual AC as well?
RARES
Belgium
C?ID=316732
I've done a few more investigations and basically I'm left with this for now:
Sunday,08,March,2020,00:13:38:48725
VIN: WVWZZZ3CZCE017535   License Plate: RARES-6
Mileage: 381740km-237202mi   Repair Order:
VIN: WVWZZZ3CZCE017535   Mileage: 381740km-237202miles
14-Susp. Elect. -- Status: Not registered 0011
   Component: J104   C2 450M VD1D 0022
   Coding: 0003504
   Revision: 00001012
   Coding: 0000000003
9473906 - Motor for Temperature Flap
          B108F 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2020.03.06
                    Time: 19:14:38
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2020.03.06
                    Time: 19:14:38
9477490 - Motor for Air Distribution Flap
          B109D 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 11
                    Reset counter: 69
                    Mileage: 381659 km
                    Date: 2020.03.06
                    Time: 19:14:38
                    Reset counter: 29
                    Mileage: 381660 km
                    Date: 2020.03.07
                    Time: 18:37:25
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2020.03.06
                    Time: 19:14:38
   Revision: BC413001
   Coding: 0000000000000000001800885400ADF063D50088626D8560E480C7240049
   Coding: 00B795
   Coding: 0A302A
   Coding: 34C206
   Coding: 000180
8 Faults Found:
            000 - - - MIL ON
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2014.07.28
                    Time: 19:14:37
            000 - - - MIL ON
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2014.07.28
                    Time: 19:14:37
                    Reset counter: 28
                    Reset counter: 28
                    Reset counter: 28
                    Reset counter: 28
03264 - Functionalty Shut Off
            000 - - - MIL ON
                    Fault Frequency: 10
                    Reset counter: 29
                    Mileage: 381659 km
                    Date: 2014.07.29
                    Time: 18:22:22
                    Error Code: 9
                    Bin. Bits: 00000000
                    Fault Status: 00100011
                    Reset counter: 69
                    Mileage: 381660 km
                    Date: 2014.07.29
                    Time: 18:38:12
                    Bin. Bits: 00000010 00000000
   Coding: 0012360
   Coding: 118A250000
   Coding: E20000
   Coding: 061F01
   Coding: 462006
                    Reset counter: 29
                    Mileage: 381659 km
                    Date: 2014.07.28
                    Time: 19:14:38
                    Fault Frequency: 7
                    Mileage: 381659 km
                    Date: 2014.07.28
                    Time: 19:14:38
03927 - Function Restriction due to Driver Fatigue Recognition
                    Fault Status: 01110000
                    Reset counter: 29
                    Mileage: 381734 km
                    Date: 2014.07.29
                    Time: 22:20:23
   Coding: 0210B7
   Slave Driver:
   Coding: 000090
   Coding: 0000258
   Part No SW: 5K0 035 456 A    HW: 5K0 035 456 A
   Component: KonzernAmp 8K H06 0180
   Revision: --------    Serial number: BP218809235351
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst8KanalBNO2.rod
   VCID: 280AF05EA278FE17A15-807C
9462035 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochton Lautsprecher vorne links: Unterbrechung]
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2020.03.07
                    Time: 18:10:01
9462803 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
          [Hochton Lautsprecher vorne rechts: Unterbrechung]
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2020.03.07
                    Time: 18:10:01
9461779 - Front Left Midrange Speaker
          B1060 13 [009] - Open Circuit
          [Mittelton Lautsprecher vorne links: Unterbrechung]
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2020.03.07
                    Time: 18:10:01
9462547 - Front Right Midrange Speaker
          B1063 13 [009] - Open Circuit
          [Mittelton Lautsprecher vorne rechts: Unterbrechung]
                    Reset counter: 28
                    Mileage: 381659 km
                    Date: 2020.03.07
                    Time: 18:10:01
   Coding: 00000008
   Coding: 0210B6
   Slave Passenger:
   Coding: 000090
   Coding: 0022167
   Coding: 2C0000
   Coding: 2C0000
   Coding: 032B1864
   Coding: 0020007
   Revision: 00H27001
   Coding: 000102000102020D0200040000000000
   ROD: EV_47X.rod
   VCID: 75B4E92A254AD3FFEA3-8020
2621440 - Databus
          [ERR_CAN_PSD_01_TIMEOUT]
                    Reset counter: 29
                    Mileage: 381741 km
                    Date: 2020.03.08
                    Time: 00:00:40
2686976 - Databus
          [ERR_CAN_PSD_02_TIMEOUT]
                    Reset counter: 29
                    Mileage: 381741 km
                    Date: 2020.03.08
                    Time: 00:00:40
5570560 - Windscreen Heater for Front Sensors
          B11CE 15 [009] - Open or Short to Plus
                    Reset counter: 29
                    Mileage: 381741 km
                    Date: 2020.03.08
                    Time: 00:00:40
End----------(Elapsed Time: 01:54, VBatt start/end: 14.4V/14.5V)-----------
If anyone has any ideeas on how to fix the HVAC and CAN Gateway alarms would be great.
m87a
C?ID=156900
for HVAC is everything plugged? if so do basic settings from vcds
for gateway
register 14 this will fix Control Module Incorrectly Coded, also Infotainment Databus in Single Wire Operation seems that can wires (twisted pair wires) one of them is not connected correctly?
RARES
Belgium
C?ID=316732
I come back with an update regarding the retrofits and errors that I had.
1. Regarding the HVAC my brother has left a connector unplugged in the front unit, that was an easy fix
2. Regarding the front fog light I had to leave the car at the dealer and they found that there was a missing wire between lights switch and BCM. I guess I've missed installing it.
3. For electronic suspension and AFS error there were 2 issues:
3.1 I have wrongly installed the front left leveling sensor so that the arm was not moving enough. I have reinstalled it properly and most of the problems just vanished. Now the headlights turn with the steering wheel, the Automatic headlights work as well.
3.2 The End of line calibration error was fixed with Adaptation 30 set value from 0 to 1.
3.3 The basic calibration was a bit of a headache. Because I have Bilstein suspesion, when we lifted the car up in the air, the arms with wheels didn't go low enough so both VCDS and ODIS gave errors. We had to disconnect the lower side of the leveling sensors, let them hang, and do the calibration. It worked and the Front Assist errors that I also had are gone as well.
4. Also, since I have installed the automatic trunk opening, I couldn't open it remotely with the key fob or driver's door button. With coding that was fixed as well.
Now I'm left with the infotainment system working in single wire mode but that will be for another time since I have to remove the entire dashboard again and check the junctions for CAN communication.
