AUDI A4 B8 (2009) - J540 - EPB Malfunction
alemos2611
C?ID=271589
I am new to VCDS and I was hoping someone could help me identify the best course of action for the error that I am receiving in the car panel - Ellectronic Break Malfunction when the breaks are activated - as of now, I am only using <P> (park mode) to reduce the risk of the breaks not releasing. The dealership I took the car was claiming it was a EPB failure and needed to be replaced - not sure of this is the proper diagnosis here - Not to mention they are asking for an absurd amount of money hat I simply cannot consider fair - so here I am now learning VCDS and making sure I can understand more and more about Audi systems. I have scanned the car and the info is attached below - It seems that ABS/ESP is somehow having correlated faults (maybe fixing one will clear then all?). I would appreciate if you could give some instructions what seems to be a real issue (which part may be damaged) and what would be your recommendation to service the car - I do have one spare EPB module (not inserted in the car yet). I was wondering if this may be due some stick that may have damaged the wiring near the wheel? If that's the case, any clues to to detect this?
All help appreciated here. Thanks.
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Data version: 20160216
Sunday,21,February,2016,14:05:50:04322
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
          77
VIN: WAUJF68K59A2xxxxx   Mileage: 40010km-24861miles
Address 01: Engine (MA---CDNB)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 Q    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0004
   Revision: E1H14---
   Coding: 0104100C02070160
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM20TFS8K2907115Q A01006
   ROD: EV_ECM20TFS0118K2907115AH.rod
   VCID: 3D71562FAC614CD655-8068
Readiness: 0010 0000
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K0 927 155 AA    HW: 0AW 927 156 H
   Component: 0AW 20TFSIRdW H02 0006
   Revision: --H02---    Serial number: 0000000274
   Coding: 000001
   ASAM Dataset: EV_TCMVL381 A02006
   ROD: EV_TCMVL381_AU48.rod
   VCID: 72EBB513A5BFC3AE78-8026
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
   Component: ESP8 front    H04 0240
   Coding: 260500
   VCID: 7CF79B2BFFFB85DE22-8028
                    Fault Status: 00101101
                    Reset counter: 210
                    Mileage: 39907 km
                    Date: 2016.02.12
                    Time: 11:59:47
                    Hex Value: 0x0000
                    Hex Value: 0x4026
                    Hex Value: 0x122E
                    Hex Value: 0x02AE
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AL    HW: 8K0 907 064 AL
   Component: BCM2 1.1      H80 0145
   Coding: 010100
   VCID: 7AFB9D33F5CFBBEE30-802E
   Subsystem 1 - Part No SW: 8T0 959 754     HW: 8T0 959 754
   Component: J764 ELV MLB  H36 0042
   Part No SW: 8T1 820 043 T    HW: 8T1 820 043 T
   Component: KLIMA 1 ZONE  H06 0150
   Revision: A0000000    Serial number: 01020420090260
   Coding: 64002000
   VCID: 428B25D3DD9F332E28-8016
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H24 0253
   Revision: 04024001    Serial number: 00000000341465
   Coding: 260010804030AF010001000000001D0D0F1C430800010101000000
   VCID: 2F6D7C677E0DAE46D7-807A
   Component: WWS 060409  H06 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 Q    HW: 8K0 941 531 Q
   Component: E1 - LDS  H07 0090
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1F7K99
   Coding: 30343435363030303030554A304C384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 3C775B2BB77B45DE62-8068
   Serial number: 6334MSME4675682BM
   Serial number: 6344MSME4554795FS
   Serial number: 6352QSME1B200F208
   Serial number: 6362QSME6706312CF
   Serial number: 63732SME54213526R
   Serial number: 63832SME4E231622Y
   Revision: --------    Serial number: 90319ID30000I
   Coding: 000036
   VCID: 3D71562FA4614CD655-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 900     HW: 8K0 920 900
   Component: KOMBIINSTR.   H18 0224
   Revision: 00000000    Serial number: 9DL141Z39
   Coding: 0F06080002000008060000
   VCID: 67DDD447967D3606DF-8032
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G0932580B5
   Coding: 000303
   VCID: 4B9508F7EAD5F266DB-801E
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Component: SG ext.Player H08 0210
   Revision: 00000000
   Coding: 020202
   VCID: 78FF873BCBC3A9FE46-802C
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008728153
   Coding: 011C02205000410001
   VCID: 41892ADFD899283631-8014
   Revision: 00002001    Serial number: 0117127321
   Coding: 011A062200390084013001
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 174
                    Mileage: 39862 km
                    Date: 2016.02.05
                    Time: 18:09:32
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 174
                    Mileage: 39862 km
                    Date: 2016.02.06
                    Time: 09:18:16
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: 6ED3A163B987E74E9C-803A
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008735923
   VCID: 408F2FDBD393213E3E-8014
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000342720
   VCID: 3365701792258AA6B3-8066
02432 - Supply Voltage for Left Parking Brake Motor (V282)
                    Fault Status: 00101100
                    Reset counter: 210
                    Mileage: 39907 km
                    Date: 2016.02.12
                    Time: 11:59:47
                    Voltage: 14.20 V
                    Count: 12
                    Hex Value: 0x0261
                    Hex Value: 0x0021
                    Hex Value: 0x0108
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77FD840706DDA6864F-8022
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 AC    HW: 8T1 035 195 AC
   Component: Symphony3 US  H01 0301
   Revision: 00000003    Serial number: AUZ5Z4I1091717
   Coding: 04020082010185000159070800
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
            000 -  -  - Intermittent
                    Reset counter: 210
                    Mileage: 39850 km
                    Date: 2016.02.05
                    Time: 17:22:03
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100938517
   Coding: 010C02204000210001
   VCID: 448723CBC78B3D1E1A-8010
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100938514
   Part No SW: 8T0 862 335 C    HW: 8T0 862 335 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005068147
   Coding: 0010390
   VCID: 3A7B5D33754F7BEE70-806E
End-------------------------(Elapsed Time: 03:07)--------------------------
automech
Poland
C?ID=14925
Check the connector in your left motor if there is any water or rust on pins, which may lead into this kind of problems. If the connector is OK, take a look on cables, maybe isolation on wires got damaged.
Welder75
Canada
C?ID=261654
If a DTC shows as "intermittent "...the condition was temporary and didn't exist at time of scan. Your best bet is to clear all DTC. Scan again to see what returns. If nothing returns ..go for drive down town and back.
So you check DTC Memory and you find
Something interrupted the power supply. but is intermittent. Note existing at the time of scan. but
is maybe the reason its intermittent.
Scan again for any codes. use your brake. If any DTC return post to thread. If they show up as intermittent again you likely have bad/loose connector, wire, ground. Use WD to trace and inspect and test wires and connectors
STEALERSHIP will play the MIL lights as serious...but sometimes it's just a matter of taking 5 mins to clear DTC and scan.
alemos2611
C?ID=271589
Many thanks for the replies !
I did a quick inspection on the cables just to se if there was visible damage such as exposed wires or broken connector - nothing like that - cables are properly fixed and no signs of physical damage. I am going to check the cables again and run a second scan with a mechanic to see if they pick any inconsistencies. About clearing DTC, Should I simply clear ALL (including the ones for the ABS/ESP) that may be related to that? I do not need to have them there if clearing DTC could be the way to try now - just want to make sure I do not erase information that may be worth having still logged.
Regarding the Wiring Diagrams (WD), would you say I should check current and fuses? Fuses are definitely easy to check, but for the wiring itself, I will probably need a mechanic or some "how-to" advice that someone can refer to for such verification ( standard multimeter based testing?).
Thanks.
Welder75
Canada
C?ID=261654
You now have a copy of your autoscan on this thread for reference. You can also copy your scan on VCDS after you scan. Then paste it in your word processor and save a copy on your PC.
You need to clear ALL DTC to see if and what codes return.
I don't think it's a fuse issue due to it just effecting one side.
alemos2611
C?ID=271589
Hello. I have the EPB J540 module replaced and now I am going to test the car. All DTCs cleared so that I can check if anything shows up again. Anyway, the fault was diagnosed by two people as being the module - at least that was related to firmware version that my model could be affected - for the good or bad, the module I have installed is the "H" module ( not the original "G"), which may be already the updated firmware one. Anyway, new module now for testing. Will let you know if I get anything relevant or if you are curious about this case.
BTW: If this fixed the problem, in my case I saved USD 1500.00 on this just not going to the DEALERSHIP. :) :)
diva
IN
C?ID=416029
hi - did you resolve this issue in your car and what was the findings? please post /share it here. thanks and good day
