2006 Audi A6 C6 ABS Fault 01435
davisev5225
C?ID=263265
I've been having an intermittent issue with my ABS controller, and I'm hoping someone here can help me make sense of it.
Most (but not all) of the time that I start my car and begin driving, shortly after I begin my trip, my ABS module will throw out error code 01435 - implausible signal. However, every time I test my brakes, everything works fine. The brake light switch is functioning properly, the brake pressure sensor is reading accurate pressures, etc. I can clear the code, then continue my trip (for as long as I want) with no further issues - cruise control works, I've had the unfortunate pleasure of finding out that the ABS pump still functions, etc. I have also already replaced the brake light switch, just in case, since it was an inexpensive part. "When in doubt, swap it out."
I've attached a full scan of my car, as well as links to screenshots of some of the measuring block values. The only thing I didn't catch, because I only saw it once and couldn't grab a screenshot before it went away, is for a couple seconds I had a NEGATIVE value for my brake pressure reading while holding down the pedal.
Does anyone know what is going on? I'm hoping to avoid changing my ABS pump and control module, as that is a rather expensive repair.
ABS ERROR:
Monday,22,July,2019,06:22:15:10305
VCDS Version: Release 19.6.1 (x64) Running on Windows 10 x64
                Address 03: ABS Brakes       Labels: 4F0-910-517.clb
Control Module Part Number: 4F0 910 517 L    HW: 4F0 614 517 L
  Component and/or Version: ESP 8.0 quattro H04 0090
           Software Coding: 0020895
            Work Shop Code: WSC 02325 785 00200
                      VCID: 2D516BBEB4397F2702-8078
                    Reset counter: 0
                    Mileage: 304009 km
                    Date: 2019.07.22
                    Time: 06:18:34
                    Hex Value: 0x1600
                    Hex Value: 0x4006
                    Hex Value: 0x001C
                    Hex Value: 0xB1AB
                    Hex Value: 0x00FF
SCREENSHOTS:
https://www.dropbox.com/sh/aptace1euzd3uwt/AACkLKU8hfWAjNfcFT9-1xyia?dl=0
FULL SCAN:
Tuesday,23,July,2019,13:09:53:10305
VCDS Version: 19.6.1.0 (x64)
VIN: WAUKH74F86N------   License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 76 77
VIN: WAUKH74F86N------   Mileage: 304290km-189077miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F1 910 559 E    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0060
   Revision: --H15---    Serial number:
   Coding: 010D0109190F0120
   Shop #: WSC 02325 785 00200
005715 - Please check DTC Memory of ABS Controller
               P1653 - 008 -
                    Reset counter: 40
                    Mileage: 304286 km
                    Date: 2019.07.23
                    Time: 12:58:59
                    RPM: 1024 /min
                    Mass Air / Rev.: 87.2 mg/str
                    Temperature: 97.5°C
                        Idle
                    Load: 11.4 %
Readiness: 0000 0100
   Part No SW: 4F2 910 156 D    HW: 09L 927 156 A
   Component: AG6 09L 3,2 FSI USA 0010
   Revision: --H01---    Serial number:        4121901
   VCID: 2643949291CF4C7FC3-8072
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H04 0090
   Coding: 0020895
                    Reset counter: 4
                    Mileage: 304286 km
                    Date: 2019.07.23
                    Time: 12:59:00
                    Hex Value: 0x00C0
                    Hex Value: 0x43A2
                    Hex Value: 0x001C
                    Hex Value: 0xB1A2
                    Hex Value: 0x00FF
   Component: FBSAUDIC6 ELV   H31 0180
   Revision: 30070501    Serial number: 10604000310700
   Coding: 0000143
   Shop #: WSC 22162 444 84622
   VCID: 63C5CD86A27DF957E4-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H45 0070
   Component: FBSAUDIC6 KSG   H27 0080
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 303LU057513496
   Coding: 0001003
   Shop #: WSC 00000 000 08192
   VCID: 316977CEA8011BC726-8064
   Component: Bedienteil MMIC6H09 0060
   Subsystem 2 - Serial number: 00000002106611
   Subsystem 3 - Serial number: 0111.04.130000000100010057ÿ
   Subsystem 4 - Serial number: 010057ÿ
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000030079589
   Coding: 0524582
   VCID: 5BB5F5669A0DC197AC-800E
00739 - Coolant Circulation Pump (V50)
                    Fault Status: 00100001
                    Reset counter: 40
                    Mileage: 303976 km
                    Date: 2019.07.22
                    Time: 05:53:43
                    Temperature: 91.0°C
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0014123
   Shop #: WSC 02335 785 00200
   VCID: 2A5B60A285D7681FE7-807E
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Component: REGENLICHTSENSORH11 0050
   Coding: 00207440
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7263378
   VCID: 1C37B67ADF8386AF65-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
   Component: SDAR XM         H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E0036900
   VCID: 2B5565A68A2D71171C-807E
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 14H29000    Serial number: 00359D0B0SG%
   Coding: 0013878
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0D3D03755
   Subsystem 3 - Serial number: 6342CSME0D3C74089
   Subsystem 4 - Serial number: 6352QSME07174677G
   Subsystem 5 - Serial number: 6362QSME07561A119
   Subsystem 6 - Serial number: 63734SME0527123F-
   Subsystem 7 - Serial number: 63834SME070E29472
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026053240045
   Coding: 0002142
   Shop #: WSC 02323 785 00200
   VCID: 66C3D492514F8C7F03-8032
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H16 0630
   Revision: 00200000    Serial number: 4PY57VXC5
   Coding: 3153203
   Shop #: WSC 22162 067 57207
   VCID: 2149878EF8E1AB47B6-8074
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 1300805C060338
   Coding: ECFE73CD1B7904
   Shop #: WSC 02334 785 00200
   VCID: 275D999696C55577F8-8072
   Coding: 0082954
   VCID: 61C9C78EB861EB47F6-8034
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H45 1100
   Revision: 00000000    Serial number: 355KX057557242
   VCID: 387F4AEA4B7BCA8F61-806C
02261 - Data Medium
                    Fault Status: 00101110
                    Reset counter: 35
                    Mileage: 303792 km
                    Date: 2019.07.18
                    Time: 19:11:26
                    Hex Value: 0x5D30
                    Hex Value: 0xC45E
                    Hex Value: 0x0E00
                    Hex Value: 0x75BC
   Component: TSG FA          H12 0270
   Revision: 00-00000
   Coding: 0052907
   VCID: 2C5766BA8F23762F15-8078
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01009192410000
   Coding: 4618941
   VCID: 2E536CB2B93F043F3B-807A
01134 - Alarm Horn (H12)
                    Reset counter: 4
                    Mileage: 280724 km
                    Date: 2019.01.03
                    Time: 17:52:33
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000702745
   Coding: 0000126
   Shop #: WSC 22162 444 999999
   VCID: 2541939EECC94767CA-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000013563
   Coding: 0002114
   VCID: 5EB3FC72891FD4BFCB-800A
   Component: TSG BF          H12 0270
   Revision: 00-00000
   Coding: 0052907
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   VCID: 5DB1FB7E8419CFA7D2-8008
                    Fault Status: 00101101
                    Reset counter: 44
                    Mileage: 304280 km
                    Date: 2019.07.23
                    Time: 12:59:34
                    Voltage: 12.63 V
                    Count: 236
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Component: AFS 1           H01 0010
   Coding: 0000016
   VCID: 285F9AAA9BDB5A0FF1-807C
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH05 0010
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
   Revision: 00000000    Serial number: 394L+057632927
   Component: ENERGIEMANAGER  H12 0470
   Revision: 00000000    Serial number: 00000000006954
   Shop #: WSC 03830 444 45040
   VCID: 23458D86E2FDB957A4-8076
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  170129T0X7
   Coding: 344630393135313035432056413031373031323954305837
   Shop #: WSC 99999 444 16786
02479 - Partial Consumer Shut-Off Active
                    Fault Frequency: 36
                    Mileage: 303538 km
                    Date: 2019.07.17
                    Time: 17:14:48
02254 - Interface to Generator
                    Fault Frequency: 43
                    Reset counter: 44
                    Mileage: 303538 km
                    Date: 2019.07.17
                    Time: 17:14:55
   Coding: 0052778
   Shop #: WSC 02327 785 00200
   Revision: 00050100    Serial number: 00000900015030
   Coding: 0062221
   VCID: 224B8882FDE7B05FAF-8076
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000511290193
   Shop #: WSC 12336 024 394758
   VCID: 34677EDA57132EEF4D-8060
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Coding: 0052778
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0030
   Revision: 00H09000    Serial number: 11720533417232
   Coding: 0201216
   Component: Handyvorb2      H11 1130
   Revision: 00000000    Serial number: 00000007525555
   Coding: 0010900
End-------------------------(Elapsed Time: 02:56)--------------------------
Nice post.
Obviously, you've been to the Wiki article for this fault.
It sure would be nice if Audi provided more details as to what can cause this "Implausible Signal" code. To me it means the value from the brake pressure sensor isn't reasonable given other values the ABS module is seeing at the same time.
I really wonder about that negative value.. Have you logged Group 9 while driving?
davisev5225
C?ID=263265
My phone ate my first attempted reply...
This is a Bosch controller, so unfortunately, I cannot log anything while driving. Also of interest, now that I've made a post about it, my car has been behaving itself all day today. Go figure.
And yes, I live by your wiki when doing diagnostics work. It's a wonderful resource. I always start there, and only go elsewhere if it doesn't have enough/any information. Unfortunately, even "elsewhere" doesn't have anything terribly helpful for this one.
The sensor is bad, there is a connection issue, ( most likely bad ground since happens cold )contaminated fluid port (doubtful) or faulty ABS module.
The negative value is when sensor reading went or goes offline.
davisev5225
C?ID=263265
Just to clarify and make sure we're on the same page... is that ANY negative value, or just a negative value such as -1? My sensor gave a negative value equivalent to what the actual pressure should be if positive. It was 30-something bar, except negative.
Unplug it and watch values in blocks or additionally hook up a decade box and watch blocks as you tap out reading's to qualify the circuit.
davisev5225
C?ID=263265
I'm afraid you've lost me. There's only a single plug to the ABS controller, so if I unplug it, I can't communicate with it anymore. And what is a decade box?
Variable resister in this case to put between controller and sensor.
JPPSG it's in there & Google it.
Plug to ABS module doesn't mean anything being a single wire, what's the point of your statement?
davisev5225
C?ID=263265
The sensor is built into the controller, so I can't put anything between them.
Single plug means I can't power or communicate with the module if I unplug it, so I also can't try and isolate a single output from it without ruining my wire loom.
It's sounding like I need to replace the module. Didn't want to, but it is what it is. Thank you both for your assistance.
Oh sigh.........
Nope...........
Wire looms can be taken apart without ruining them, time to get proficient?
davisev5225
C?ID=263265
Yeah, no thanks. Already dealing with that headache on my 2001 Allroad. The "eco friendly" biodegradable wiring that Audi used, combined with the 13-year-old heat-damaged plastics, means it is stupidly easy to break a wire or snap a connector. This is my daily driver, I don't want to be replacing sections of the loom because the insulation disintegrated, or the connector broke in half.
That's what the Allroad is for. :D
Indeed.
:D
At what speed does it hang up the connection?
Broadcast shuts down at approx 15 mph usually & some as high as 25 mph depending on where set for COM.
davisev5225
C?ID=263265
I'm pretty sure it's lower than that. I've been coasting in stop-and-go traffic with no connection.
I'll see if I can figure it out sometime in the near future.
I was just going to say additionally some at like 8 mph too.
davisev5225
C?ID=263265
So... this was interesting. I've tried to figure out what speed the ABS controller stops communicating at, but I still cannot say. It will not allow me to open a new diagnostics session, nor will it allow me to send commands to an existing one, but it WILL maintain an existing logging session, so long as it was started while the vehicle was stationary!
Log for a trip to and from the grocery store uploaded to the Dropbox link in my original post. There are quite a few entries with varying negative values for the brake pressure.
I guess the question now is whether that's really the cause of the DTC. Clear the fault code. Try to reproduce a negative value. Is that when the fault code sets?
