A3 8V 2.0 TDI electronic parking brake issues
Ashbash516
Cambridgeshire, UK
C?ID=308959
Hi, has anyone had issues where the EPB stops working on Auto release method. The only way I can release the handbrake is by pressing the button with either the brake or gas pedal pressed. Ran an auto scan on vcds and no errors.
Previously changed the 12v battery (was 12.1v) as my cars 6 years old. Chanting the battery inadvertently resolved the issue and the handbrake started to auto release again. But 2 months on and suddenly the same problem. Battery currently at 12.8v but only 13.2v when the engine is at idle?? This drops to 12.9v under heavy load.... Can this be the cause (i.e alternator).
Any thoughts?
Ashbash516
Cambridgeshire, UK
C?ID=308959
Wednesday,15,May,2019,21:31:35:11164
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUZZZ8V1EA******   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V1EA******   Mileage: 134191km-83382miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7544
   Revision: 83H22---
   Coding: 02190012030501082000
   Shop #: WSC 03080 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79ACE5F1C95BEB0FD93-802C
   Revision: 00000000    Serial number: 63163000001DFC
   Coding: 12F18AA224200A730180060441C9294851245080608294F2004300388608
   Shop #: WSC 06314 790 00021
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 7BA0FFF9C367D91FCBF-802E
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Revision: 20026000    Serial number: 00000000196227
   Coding: 03100104002000011000000000001100
   VCID: 323E12DD54ADD857589-8066
   Serial number: B0480AD6000000000001
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011332400918
   Coding: 07040A42C24120DD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 131111 041 0580
   Serial number:         131112193237
   Coding: 0A47F7
   Light switch:
   Subsystem 2 - Part No SW: 8V0 941 531 J    HW: 8V0 941 531 J
   Component: E1 - LDS MQB H05 0032
   Serial number: 10 07 2013 00000203
   Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA 005 0315
   Serial number: 000000000ZY132802XMB
   Component: Sirene, DWA 004 0311
   Serial number: 00000000000028330265
   Subsystem 5 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS H07 0002
   Serial number: 20565825
   Serial number: 003M2R043PZZ
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4BC06F39D347A99F3BF-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 111 13
   Serial number: 35767000000B182C3E0-
   Subsystem 2 - Part No SW: -----------    HW: 480 002 111 13
   Serial number: 35867000000B172C3E0-
   Subsystem 3 - Part No SW: -----------    HW: 480 401 911 13
   Serial number: 3516502A51230BB280E3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 911 13
   Serial number: 3526502C91118A3202A$
   Subsystem 5 - Part No SW: -----------    HW: 480 400 410 13
   Serial number: 3556502BB1142C8370CC
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 911 13
   Component: PedP_Sensor_D 001 6149
   Serial number: 2286502AF1118A34A259
   Subsystem 7 - Part No SW: -----------    HW: 480 400 911 13
   Component: PedP_Sensor_P 001 6149
   Serial number: 22965029F1118A3283FG
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 911 13
   Component: PedP_Sensor_C 001 6149
   Serial number: 2306502B11118A3162EY
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Component: Lenks. Modul 002 0110
   Revision: --------    Serial number: 19111304401009
   Coding: 8408
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 06569E0D88A594F7A41-8052
   Part No SW: 8V0 920 970 N    HW: 8V0 920 970 N
   Component: KOMBI         H03 2220
   Coding: 278509002B8046000100BA00100000
   VCID: 47C85309CF2F4DFF1F7-8012
   Revision: --------    Serial number: 0001277863
   Coding: 030100040B0876005B000248080B00000001000000000000000000000000
   ROD: EV_GatewLear_010.rod
   VCID: 3FD84BE997FF053FA77-806A
   Component: E221 - MFL H02 0014
   Serial number: 25 10 2013 D0337903
   Component: J367-BDMHella H03 8043
   Serial number: 5066051803
   Serial number: 11111306071280
   Coding: 00108E204001040000001002
   VCID: 40DA4815EA017AC7DED-8014
   Component: EPS_MQB_ZFLS 122 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DC4D11E10B73CFD13-8014
   Serial number: 13111302091525
   Coding: 001086204001040000001002
   Coding: 019C000001000000
   VCID: 75B4E9C1E5438F6FBDB-8020
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    040 0420
   Serial number: A7F02411132757
   Coding: 01730301FF00000021111101000A00002F0001460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3B203FF983E7191F8BF-806E
   Subsystem 1 - Part No SW: 8V0 919 603 B    HW: 8V0 919 603 B
   Component: DU Std H48 0013
   Serial number: AUZ8Z9DM700NFR
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B H33 0037
   Serial number: C1000003101300020047
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 04111303110194
   Coding: 000086204001040000001002
   VCID: 42DE421DE40D68D7C89-8016
   Component: TSG HBFS      020 0025
   Serial number: 04111306070192
End----------(Elapsed Time: 01:16, VBatt start/end: 12.3V/12.3V)-----------
Any thoughts?
ABS module (with integrated parking brake) does not seem to have a new version available.
Is it possible the car things one of the seat belts that should be buckled isn't? I'm pretty sure that will cause the behavior you describe without setting any faults.
Another idea: I wonder if the "cold boot" of all systems when you change the battery is what actually fixed the problem (as opposed to a "new" battery). You might try disconnecting your battery for a bit, then reconnecting it to see if that fixes it again.
Ashbash516
Cambridgeshire, UK
C?ID=308959
Thank you for your help, being a vcds novice how does one apply the new version of the ABS Module? (I only know as much as following YouTube videos to add additional features like needle sweeps and drl brightness chnages).
Yes the car is doing the type of behaviour as if the driver's seatbelt wasn't buckled (but it is in fact bucked in at all times when testing/ driving).
Finally when the battery was changed for me the mechanic did plug in a portable power supply during the battery change to save the cars memory. Should I still try disconnecting the battery?
I did forget to mention that I temporarily over came the problem (on numerous occasions prior to the battery change) by topping up the battery with my ctek 5.0 smart charger. I have since tried this method again but only got an a short lived tempory fix where the auto release started to work for about 50% of the times for 1 short (and now back to not releasing again).
Ashbash516
Cambridgeshire, UK
C?ID=308959
Since there is no newer version available, it doesn't really matter. But if there was a newer version available, the path of least resistance would be to ask a dealer to install it.
Interesting. In that case, a cold boot probably won't help.
You might want to monitor these in the ABS module itself:
IDE03680-IDE04444 -- Supply voltages - Terminal 30 voltage for pump
IDE03680-IDE04445 -- Supply voltages - Terminal 30 voltage for valves
I'm wondering if you have a dodgy connection somewhere that's causing them ABS to see voltages lower than they really are?
