Konstantinas
Norway
C?ID=249262
Hi. I am a freshly VCDs user. I have error code and does not know what it means? Where to look for ills? I can not find any explanation wiki.
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 060807F2002138
Coding: E9801F460008027400
Shop #: WSC 35110 377 00157
VCID: 306F5F8DA33839A1DEF-8065
Reset counter: 149
Mileage: 223519 km
Time: 12:51:47
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
When you have a problem/query you post a full AutoScan of the vehicle, in between
 tags  [CODE] Full AutoScan [/CODE]  as it takes up less room. How to post an Auto-Scan
Konstantinas
Norway
C?ID=249262
Additional information
Thursday,09,July,2015,19:54:10:07018
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WV1ZZZ2KZ8X034098   License Plate:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 69
VIN: WV1ZZZ2KZ8X034098   Mileage: 223650km-138969miles
   Part No SW: 03G 906 016 LF    HW: 03G 906 016 DR
   Component: R4 2,0L EDC 0000SG  0550
   Revision: 12345678    Serial number: VWX7Z0G73N803V
   Coding: 0000071
   VCID: 72EB95856DB44BB168B-8027
18080 - Coolant Fan Control 1
            P1672 - 000 - Open or Short to Ground
                    Torque: 114.7 Nm
                    Voltage: 12.16 V
                    Bin. Bits: 00000100
                    Temperature: 16.2°C
                    Duty Cycle: 9.6 %
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
                    Torque: 114.7 Nm
                    Voltage: 12.16 V
                    Bin. Bits: 00000100
                    Temperature: 16.2°C
                    (no units): 144.0
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 000 -
                    Torque: 114.7 Nm
                    Voltage: 12.16 V
                    Temperature: 18.9°C
                    Temperature: 16.2°C
                    Temperature: 17.1°C
Readiness: 0 0 0 1 1
   Revision: 00H11001
   Coding: 0021205
   VCID: 73E5908112AE42B963D-8026
   Part No SW: 1K0 820 047 HC    HW: 1K0 820 047 HC
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6CD78BFD4F909D41A27-8039
00532 - Supply Voltage B+
            013 - Check DTC Memory
            009 - Open or Short to Ground
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007465075
   Coding: 0888CF030004100047000000000000000009FB075C000100000000000000
   Shop #: WSC 35110 377 08192
   VCID: 6FED9CF17E866659875-803A
   Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 270707 021  0501
   Coding: 00038805
   Shop #: WSC 35110
02071 - Local Databus
                    Reset counter: 138
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 7.15 V
01207 - Control Module for Auxiliary Heater (J364)
                    Reset counter: 149
                    Mileage: 223519 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.60 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 138
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 7.45 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 0A AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD0F6GBE
   Coding: 0012353
   VCID: 7DF1B6B924EA04C9059-8028
   Part No SW: 1K0 953 549 BB    HW: 1K0 953 549 BB
   Component: Lenksäulenmodul 636 0070
   Part No SW: 2K0 920 844 A    HW: 2K0 920 844 A
   Component: KOMBIINSTRUMENT VDD 1212
   Revision: V0002000    Serial number: VWX7Z0G73N803V
   Coding: 0016101
   Shop #: WSC 80093 222 69422
   VCID: 2959B2E980E24869191-807C
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 113
                    Mileage: 222834 km
                    Time: 09:54:10
                    Fault Frequency: 14
                    Reset counter: 153
                    Mileage: 223202 km
                    Time: 09:41:43
                    Reset counter: 153
                    Mileage: 223653 km
                    Time: 12:24:23
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 5K0 963 271 C
   Component: Zuheizer        050 2606
   Revision: 00050000    Serial number: 09021535000000
   Coding: 0000011
   Shop #: WSC 00610 218 104229
   VCID: 2F6D5CF1BE062659C75-807A
01407 - Flame Extinguished
            000 -  -  - Intermittent
                    Reset counter: 8
                    Mileage: 70841 km
                        Start
                    Temperature: 67.0°C
                    Temperature: 66.0°C
                    Voltage: 14.74 V
01406 - No Flame
                    Reset counter: 9
                    Mileage: 71046 km
                        Start
                    Temperature: 87.0°C
                    Temperature: 85.0°C
                    Voltage: 14.53 V
00664 - Fuel gauge
                    Reset counter: 8
                    Mileage: 72323 km
02251 - Heater Unit Locked
                    Reset counter: 224
                    Mileage: 72367 km
                    Reset counter: 149
                    Mileage: 223519 km
                    Time: 12:51:47
   Component: IMMO            VDD 1212
   Shop #: WSC 32367 001 1048576
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 02 0159
   Coding: 0000000
   VCID: 76E3A99501DC5791443-8023
00100 - Drivers Interior Locking Button (E308)
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.140 H08 1901
   Shop #: WSC 35110 666 38454
   VCID: 35616E995C5A1C898D9-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Coding: 80890C087F2D84054848067010C0
   VCID: 000FCF4D531869216EF-8055
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75E1AE991CDA5C894D9-8020
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 D    HW: 1K0 907 383 B
   Component: Anhaenger     H15 0070
   Revision: 3A002001    Serial number: 00000105940680
   Coding: 0100000200000000
   VCID: 2E5341F5790C2F51CC3-807B
            011 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10101011
                    Reset counter: 138
                    Date: 2063.15.31
                    Time: 16:03:63
                    Reset counter: 153
                    Mileage: 223653 km
End-------------------------(Elapsed Time: 01:35)--------------------------
That DTC indicates the Gateway not seeing any traffic on the infotainment CAN bus. If you clear it, how quickly and under what circumstances does it come back?
There are a lot of other faults in your Auto-Scan that I'd be far more concerned with than that one. ;)
martijn v o
C?ID=138199
There are many faults related to undervoltage, so or you have disconnected the battery or the battery (or generator) are causing problems.
