So scanned my car today and found a couple of faults, one of which is more than confusing! My gateway says the 5F module has a fault but when I check for a fault code there is none
Anyone had this before, is it a VCDS bug?
Thursday,20,June,2019,17:54:52:07337
VCDS Version: 19.6.0.6 (x64) HEX-NET CB: 0.4505.4
VIN: WAUZZZ4G2HN000000 License Plate: A6-MMI
Mileage: Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 36 3B 42 44 46 52 53
55 5F 62 6C 6D 72 AC
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 BP HW: 04L 907 309
Component: R4 2,0L EDC H23 1661
Revision: 85H23---
Coding: 12254012242601080000
ASAM Dataset: EV_ECM20TDI01104L906021BP 002006
ROD: EV_ECM20TDI01104L906021BP_002.rod
VCID: 74A407EADFA786EF81-8020
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 N HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H03 0004
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 383CF3DA834F228F6D-806C
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A69E41606579829B00
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 41CA9E3ED0956347DA-8014
Part No SW: 4H0 907 064 HP HW: 4H0 907 064 HP
Component: BCM2 2.0 H61 0825
Coding: 05B96F4E000000000000
VCID: 7EB025C2E9EBDCBFE7-802A
Serial number: 3216000167335007
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 05091600040372
Coding: 34220978290000
VCID: 638674B66A491157E8-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0368
Revision: 14020001 Serial number: 00001457652402
Coding: 0105001440349FE041014083A0001800CF9DC7082F08020100000894E100150200400010010000
VCID: 73A604F6D2A981D798-8026
Component: WWS57X 160622 H38 0080
Serial number: 160701112852
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 62226079
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 31 08 2016 00000886
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 26E8C54800PAG0MUFU03
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4G0 919 475 H HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0080
Revision: -------- Serial number: 56261624900270
Coding: B81318
ASAM Dataset: EV_EPHVA2CAU64X0000 001014
ROD: EV_EPHVA2CAU64X0000.rod
VCID: 3620FDE2895BD4FF7F-8062
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P100B3TC+
Coding: 30333130313630323639554A305234473053
VCID: 3B36ECD6B279099780-806E
Serial number: 3575HRB405F45CG8H11Y
Serial number: 3585HRB405P45HVK68F1
Serial number: 3515JRB401I5752G998Q
Serial number: 3525JRB400U5752ICIAB
Serial number: 3554VRB4002577407P7P
Serial number: 3564VRB400457740B1JK
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560PGR00033
Coding: 000035
VCID: 3B36ECD6BA79099780-806E
Serial number: 26 04 2016 E0084281
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 987 R HW: 4G8 920 987 R
Component: TDieGb H14 0225
Revision: 11001108 Serial number: 658290816596010
Coding: 33A715000B412600010000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 48DC831AF3AF520F1D-801C
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002360987
Coding: C0CD074418
VCID: 3D32E2CEAC6D07A7BE-8068
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 9454011404
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 160622000000000003CE
12290 - Quiescent Current
U1406 00 [009] - Too High
Reset counter: 232
Mileage: 00000 km
Date: 2019.06.13
Time: 00:24:15
Voltage terminal 30: 12.2 V
Voltage terminal 15: 0.0 V
Control Module temperature: 14 °C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 679E60A696717D7734-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 06091600041014
Coding: 22
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000216304628
Coding: 00781B0000006001000001010101102030303232203232
VCID: 77BE30E6C6D1EDF7A4-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720SUMWT
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3326C4F69A29C1D758-8066
Component: TSG FA H03 0511
Coding: 011F16015E01620002080002
VCID: 47DE8026F6B15D7714-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000226657
Coding: 101100010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A38E9D2BD43309F9B-806E
Revision: 00002001 Serial number: 0416506173
Coding: 013B0E22A0B93095C320098400030F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J245 PS20.403 H03 0004
Serial number: 0000FST0015FLKQ00000
Coding: 901E00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Serial number: 0000000AP00024350976
Subsystem 5 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J394 PS20.403 H03 0004
Serial number: 0000FST0015FLMS00000
Coding: 801E00
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93892967
03128 - Switch 1 for Sunroof
Fault Status: 00101100
Reset counter: 8
Mileage: 00000 km
Date: 2019.06.03
Time: 13:30:02
00204 - Sunroof Button (E325)
Reset counter: 8
Mileage: 31706 km
Date: 2019.06.03
Time: 13:30:02
Component: TSG BF H03 0511
VCID: 46C08D22F1BB447FEF-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001954846
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 312ACEFE6035F3C72A-8064
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02102A630200
VCID: 3424C7EA9F27C6EF41-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 F HW: 4G1 035 021 D
Component: MU-H-LND-EU 052 0670
Serial number: A733I0G7510518
Coding: 017502010000000013111102000A00332F0006E7F1700100DF
VCID: 1D72024E0CAD67A79E-8048
Subsystem 1 - Part No SW: V03 959 802 DE HW: -----------
Component: ECE 2019 --- 0175
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY805ZLB
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349PI2000R3
Component: Gracenote2--- --- 1013
Component: TSG HL H03 0511
Coding: 010F14004001620002080002
VCID: 49DA861EE0A5AB0702-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 0275000102002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
VCID: 78BC33DAC3CFE28FAD-802C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 231600041
Coding: 093205C030
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0511
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 162170756
ROD: EV_RDCMA00100_008.rod
VCID: 2F2EC8867601E5373C-807A
End----(Elapsed Time: 02:10, VBatt start/end: 11.7V/11.9V. VIgn 12.0V)-----
