2017 Tiguan MK2 esp light/auto hold, tpms park assist etc function off faults.
Alexcole1991
Portsmouth, UK
C?ID=339078
Hi guys,
Recently purchased a Tiguan mk2, think I’ve been had over. Within 20 miles the above lights appear. Guy before knows nothing about them “obviously”.
When plugged in, 0288 - steering angle sensor B1168 07 - mechanical fault
If I clear it, it will return after a short drive.
I have no history on this car. No service history either as it’s not due it’s first service until soon.
I’ve done a basic settings of the electro steering rack, it completed successfully but light came back on. When steering wheel is straight ahead it reads about 12 degrees off even when calibrated straight. Can anyone confirm if the steering angle sensor is built in the rack?
I’m guessing maybe this car has been involved in some accident and damaged maybe? As it’s only 2 years old and chances of failure isn’t common? I’ve had it up on the ramp and cannot see any signs of damage or repair.
Thursday,14,November,2019,12:07:37:48845
VIN: WVGZZZ5NZHW375725   License Plate:
Mileage: 33110km-20573mi   Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C 42
          44 4B 52 5F 6C 6D A5 BB BC CA CF D6 D7
VIN: WVGZZZ5NZHW375725   Mileage: 33110km-20573miles
29-Left Light -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5N0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 092500322466050B3000
   ASAM Dataset: EV_ECM20TFS0205N0906259 001003
   ROD: EV_ECM20TFS0205N0906259.rod
   VCID: 72A82BBDA511ECDFA1-8026
Readiness: 1110 0001
   Part No SW: 0DL 300 011 P    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2001
   Revision: 00H06V07
   VCID: 3522D0A194FFBBE744-8060
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 63256000000674
   Coding: 0AEE939A54272371477E070262C84950C92AC4E2E046927D384250B8C2AA4200002F641A1B13111435351919323200
   VCID: 79BA1C91F8679F87E0-802C
0288 - Steering angle sensor
          B1168 07 [008] - Mechanical Failure
                    Reset counter: 62
                    Mileage: 33097 km
                    Date: 2019.11.13
                    Time: 19:35:32
16418 - Display for Tire Pressure Monitoring
                    Reset counter: 62
                    Mileage: 33097 km
                    Date: 2019.11.13
                    Time: 19:35:42
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0424121850
   Coding: 032C2C070F
   VCID: 3C34C585B7D56AAFBB-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98100702
   Part No SW: 5NA 907 044 G    HW: 5NA 907 044 G
   Component: AC Automat    H35 4101
   Revision: 20K08000    Serial number: 00000E00312021
   Coding: 0012002420010000110510001210142A
   ASAM Dataset: EV_ACClimaPrehVW37X 002019
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 43C6BE79CA2B1557FA-8016
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 63
                    Mileage: 33088 km
                    Date: 2019.11.13
                    Time: 14:05:30
                    Outside air temperature: 9.5 °C
                    Voltage terminal 30: 14.6 V
                    System run time-Engine running time: 56 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001632000333
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F4EF289E643B1B7DE-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160922  033 0372
   Serial number: 00000001609200303485
   Component: RLHS  042 0105
   Serial number: S7Y16M11D23H16M12S46
   Coding: 00A8DD
204546 - Remote key 2
                    Reset counter: 18
                    Mileage: 33070 km
                    Date: 2019.11.12
                    Time: 18:19:08
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0021
   Serial number: 000111167478010
   Coding: 0331667851
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B36C699B2DB6D97B2-806E
13637426 - Databus
                    Reset counter: 62
                    Mileage: 33097 km
                    Date: 2019.11.13
                    Time: 19:35:33
13679388 - Databus
          [Lenkhilfe - LH_EPS_01.EPS_PLA_Status - Fehlerspeicher auslesen]
                    Reset counter: 63
                    Mileage: 33110 km
                    Date: 2019.11.14
                    Time: 07:45:27
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320047C358FF8428749C8065303085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 62
                    Mileage: 33074 km
                    Date: 2019.11.12
                    Time: 18:35:42
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 36 °C
                    Velocity_vehicle_reference: 13.13 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.28 m/s²
                    Status_ACC_System: ACC_irreversible error
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 62
                    Mileage: 33074 km
                    Date: 2019.11.12
                    Time: 18:35:41
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: 12.90 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.53 m/s²
0928 - Databus
          [FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
                    Fault Frequency: 7
                    Reset counter: 62
                    Mileage: 33075 km
                    Date: 2019.11.12
                    Time: 18:38:06
                    Voltage terminal 15: 12.8 V
                    Longitudinal_acceleration_vehicle_reference: 0.13 m/s²
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 62
                    Mileage: 33074 km
                    Date: 2019.11.12
                    Time: 18:35:41
                    Velocity_vehicle_reference: 12.95 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.50 m/s²
   Serial number: 22101641351086
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383CD99583ED468F5F-806C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2BSVET
   Coding: 98CCC0C00C0000005C540000008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 106C4135CBDDBECF37-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 001 811 16
   Serial number: 357000000005DA650F1R
   Subsystem 2 - Part No SW: -----------    HW: 480 001 811 16
   Serial number: 358000000006DA650F1T
   Subsystem 3 - Part No SW: -----------    HW: 480 402 211 16
   Serial number: 35100019F22EA2A4F6BO
   Subsystem 4 - Part No SW: -----------    HW: 480 402 211 16
   Serial number: 3520001A7231F2C5830-
   Subsystem 5 - Part No SW: -----------    HW: 480 402 111 16
   Serial number: 3550001BF22F9766868N
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 301 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001BF2404066124P
   Subsystem 7 - Part No SW: -----------    HW: 480 401 301 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001C124040621508
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 301 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001BF240406576BY
   Subsystem 9 - Part No SW: -----------    HW: 480 001 010 16
   Serial number: I0M00000000957A84E1C
   Subsystem 10 - Part No SW: -----------    HW: 480 001 310 16
   Serial number: I0N0000000084A30D812
   Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20161124300333
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7EB00F8DE149B8BFD5-802A
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         407 2160
   Coding: 27A510187F88040801886B0B1401000000000000
   Shop #: WSC 38100 381 12345
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 41CAB471D0370747E8-8014
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005618369
   Coding: 030500347F085900FB07225A9E0F00010001050000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F2EE2C976A381370E-807A
   Serial number: 29160002326130086453
   Coding: 2DFFFF
   Serial number: 8134692204
   Serial number: HA1-00028.10.16
   Coding: 0101
   VCID: 4AD8935DED01C41F39-801E
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH07 0014
   VCID: 45C2A061C41F2B67D4-8010
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 61
                    Mileage: 33095 km
                    Date: 2019.11.13
                    Time: 17:40:34
   Serial number: 16000304056008
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA24B1A017D7C758-8024
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PJS15750
   Coding: 0014000000000500018281808181000000008181000000F400
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0310
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
1192062 - Databus
          [databus error value received - PH_Systemzustand]
                    Reset counter: 62
                    Mileage: 33101 km
                    Date: 2019.11.13
                    Time: 19:41:00
                    Control Module temperature: 23 °C
                    Voltage terminal 30: Measured value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measured value not available
                    Voltage terminal 15: 14.30 V
1192264 - Databus
          [databus error value received - PH_Tongeber_H_verfuegbar]
                    Reset counter: 62
                    Mileage: 33101 km
                    Date: 2019.11.13
                    Time: 19:41:00
   Serial number: 130916EIC11334
   Coding: 003F1B20D201040000000000
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 20
                    Mileage: 33088 km
                    Date: 2019.11.13
                    Time: 14:07:02
   Part No SW: 5QF 909 144     HW: 5QF 909 144 _
   Component: EPS_MQB_ZFLS  506 5572
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 075E6A69BE93F977E6-8052
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 09111610520624
   Coding: 000000050100085607000F010A0000000000000000000000000000000000
   Serial number: 251016EJM36679
   Coding: 003F1120DE01040000000000
   VCID: 42C8BB7DD5311C5FF1-8016
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 045 D    HW: 3G0 035 045
   Component: MU-H-N-RW     H51 0814
   Serial number: A688K0G2509834
   Coding: 02730601FF00000051511201C00808001F0106E601200002DF
   VCID: 1F0E1209060311B7BE-804A
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT3646500
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Component: Gracenote2---  --- 4009
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 20
                    Mileage: 33088 km
                    Date: 2019.11.13
                    Time: 14:03:48
                    Voltage terminal 30: 12.3 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
          B201A 00 [009] - -
                    Reset counter: 20
                    Mileage: 33088 km
                    Date: 2019.11.13
                    Time: 14:03:53
                    Status_Software_Version_Management-module_name: MDUV612/Main
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG007196
   Coding: 01230600A20F200000204094
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 30963171000000
   Coding: 0A28
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 24111612P22573
   Coding: 000307060000010100022346C050490084000E200000
   Shop #: WSC 08852 002 1048576
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 62
                    Mileage: 33097 km
                    Date: 2019.11.13
                    Time: 19:35:33
                    Control Module temperature: 17 °C
                    Outside air temperature: 9.0 °C
                    Vehicle speed: 56.18 km/h
                    System run time: 239.9 s
                    Voltage terminal 15: 14.0 V
                    mid: 02 E0
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 151116EKE28138
   Coding: 002A11200100040000000000
   Serial number: 151116EKE16154
   Component: SAD_STG_1     013 0005
   Coding: 108040732602
   VCID: 3D32C881ACCF63A78C-8068
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   VCID: 1660372DE93950FF6D-8042
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:19, VBatt start/end: 12.2V/12.1V)-----------
It would be appropriate to post an Auto-Scan so people can see exactly how this vehicle is equipped.
AIB Wolfgang
Hello
"When steering wheel is straight ahead it reads about 12 degrees off "
Yes, that's the fault.
Wheels in straight position
Steering wheel in straight position
then the displayed angle should be 0 ° +/- 2.5 °.
maybe, a vehicle front axle measure is necessary?
Or assembled incorrectly after a repair?
I think, Steering angle sensor B1168 07 [008] - Mechanical Failure, will be a new sensor:cool:
mrlapou
C?ID=42756
If under 3 years old, VW warranty must still be inplace...
