Audi A6 C5 Tiptronic doesn't work (P0702)
turbokutonen
New Member
Hello!
My Audi A6 C5 Allroad 2.5 TDI AKE 2000 has run to some problems. During the weekend I was in the warm garage doing maintenance (changed CV joint and track rod end). After that I drove my car outside where was -25C, and noticed that my steering wheel wasn't straight. It was little bit to the left while driving straight. Next day after a very cold night, I did an test drive and everyhting was fine except that steering wheel was to the left. Until I noticed that the tiptronic didn't change gears at all.
On the dashboard where is visible current selected gear, there was all lights "on" like I had every gear in. P,R,N,S,D were all "on". Car was powerless, and even that manual gear select +/- didn't work. So i drived back home. After that I checked with VCDS I noticed it had the 4th gear in all the time. I checked the faultcodes and got only one code from transmission:
Sunday,27,January,2019,14:05:08:61411
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ4B42N026830   License Plate: ILT-788
Mileage: 314660km-195520mi   Repair Order: Auto.Vaihteisto vika
          75 76 77
VIN: WAUZZZ4B42N026830   Mileage: 314660km-195520miles
Address 01: Engine        Labels: 059-907-401-AKE.clb
   Part No: 4Z7 907 401 B
   Component:  2.5l/4VTEDC G000AG D06
   Coding: 01016
   Shop #: WSC 02325
   VCID: 3C7CE7332C8444AAC1-4B00
   Subsystem 1 - Part No: 00015059
   Component: 130 106EC150_1.R75438336187
   WAUZZZ4B42N026830     AUZ7Z0A1903996
Readiness: N/A
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4Z7 927 156 H
   Component: AG5 01V 2.5lTDI RdW 2121
   Coding: 00001
   VCID: 4B9EB4EF792AF31278-513C
17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
            P0702 - 35-00 -
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389
   Component: ABS/ESP allrad      D57
   Coding: 06357
   Shop #: WSC 02325
   VCID: 09124EE733D6A1028A-513C
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AD
   Component: A6-Klimavollautomat 0104
   Coding: 00003
   Shop #: WSC 02325
   VCID: 5CBC47B3CCC464AAE1-2578
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 D
   Component: Airbag 8.4E         3000
   Coding: 0000106
   Shop #: WSC 02325 785 00200
   VCID: 50A4A383C00CD0CA0D-5120
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 933 M
   Component: KOMBI+WEGFAHRS. VDO D07
   Coding: 04160
   Shop #: WSC 00001
   VCID: 2D5ADA77E7FEDD2246-5120
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 E
   Component:  - 2C1A1          D040
   Coding: 25500
   Shop #: WSC 09999
   VCID: 479688DF654217725C-5120
01772 - Signal from Level Control Pressure Sensor (G291)
Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
   Part No: 4B0 962 258 K
   Component: Zentralverrieg.,DWA D35
   Coding: 06987
   Shop #: WSC 02325
   VCID: 3162C607FBC6B9C262-4ECA
01560 - Passenger Door
01561 - Rear left door
01562 - Rear right door
            60-00 - Won't Safe
            61-10 - Won't De-Safe - Intermittent
            61-00 - Won't De-Safe
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0101
   Coding: 00001
   VCID: 2C5CD773DCE4D42A51-4B00
Address 37: Navigation        Labels: 4B0-035-192-RNSD-37.lbl
   Part No: 4B0 035 192 M
   Component: RNS 4.1 H06    BNO 0017
   VCID: 2756285FC502F772BC-4ACE
00862 - Antenna for GPS Navigation (R50/R52)
            36-00 - Open Circuit
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00002
   Shop #: WSC 02325
   VCID: 60C47343E0AC404ABD-4B32
   Part No: 4Z7 907 357
   Component: dynamische LWR       D06
   Coding: 00030
   Shop #: WSC 02325
   VCID: 040C5FD314F4FC6AF9-4B7C
Address 56: Radio        Labels: 4B0-035-192-RNSD-56.lbl
   Component: Radio          BNO 0001
   Coding: 00117
   Shop #: WSC 02325
   VCID: 2756285FC502F772BC-4AE6
Address 57: TV Tuner        Labels: 4D0-919-146.clb
   Part No: 4D0 919 146 B
   Component: TV Tuner        H05 0704
   Coding: 0000160
   VCID: 28542B63981CF80AB5-5120
Address 76: Park Assist        Labels: 8E0-919-283-8E2.lbl
   Part No: 8E0 919 283
   Component: Parkingsyst. A6 RDW D09
   Coding: 01186
   Shop #: WSC 02325
   VCID: 6DDA1A77277E1D2206-513C
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
            37-00 - Faulty
End-------------------------(Elapsed Time: 04:44)--------------------------
After that, I took TCU out and got it inside to warm up. I kept it in warm for 2 days, plugged it in again, heated car from inside, and deleted faultcodes. Fault gets back.
I have no idea what should I do next. Do I need to buy new TCU, or is there something else I should check before that?
Thanks for help!
HMC
C?ID=28246
I think the first thing to do is retrace your steps of fitting the CV and track rod end, did you displace/disconnect/damage a TCM connector. Have you checked the fuses that power the TCM. You also need to get the wheel alignment done as the track rod end is not in the same place or has different dimensions from the original.
Regards HMC
turbokutonen
New Member
Thanks for tips!
What should I look for at wheel surrounding? Is there somewhere TCM connector or something? I have checked all the fuses on the drivers side inside car, but I have no idea where the TCM fuse is. Is it where is ECU, under the hood and on the drivers side?
I will get the Wheel alignment done as soon as I get this sorted out, I dont want to drive with that car in case if that would brake the transmission completely… Getting pretty frustrated, should get the car working so I could go to work :banghead:
turbokutonen
New Member
Regards HMC
I checked all fuses, they are okay. Could wheel alignment differense cause this? Or some other minor thing? Is there any way to see/test my TCM condition?
turbokutonen
New Member
