Wednesday,26,June,2019,14:58:27:20561
VCDS Version: 19.6.0.6 (x64) HEX-V2 CB: 0.4505.4
VIN: WUAZZZ8E06N900140 License Plate:
67 69 75 76 77
VIN: WUAZZZ8E06N900140 Mileage: 222020km-137956miles
Address 01: Engine Labels:. 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H03--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 00000 000 02400
VCID: 6393AE3B0750BD0FB77-8036
005241 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure - Intermittent
Mileage: 221821 km
RPM: 964 /min
Load: 52.5 %
Speed: 7.0 km/h
Temperature: 42.0°C
Temperature: 33.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.335 V
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H04 0150
Coding: 0004533
Shop #: WSC 06325 000 00000
VCID: 2B03061B2F00354F4F7-807E
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00001
Shop #: WSC 06325
VCID: 6D87C803D484FB7F113-50D0
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 01041
Shop #: WSC 00012
VCID: 3B23365BDA70A5CFDF7-4AA4
30-00 - Open or Short to Plus
Address 11: Engine II Labels:. 079-910-560-BNS2.lbl
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M007J2L.
Coding: 0430712
VCID: 3B23365BDF60A5CFDF7-806E
Subsystem 1 - Serial number: 6332DRB402004993A
Subsystem 2 - Serial number: 6342DRB4021E0C8DY
Subsystem 3 - Serial number: 6352ARB400984CAC.
Subsystem 4 - Serial number: 6362ARB400984190E
Subsystem 5 - Serial number: 63729RB400B1452DJ
Subsystem 6 - Serial number: 63829RB400B14359H
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 14441
Shop #: WSC 36256
VCID: 44D14DA7A78EDA37AED-4AA4
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H12 0030
Revision: 0030 Serial number: 00000000000000
Coding: 0023101
Shop #: WSC 80093 222 69422
VCID: 2C0105072A1E327746D-50F4
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023101
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760 A
Component: Sitzverstellung H01 0020
Coding: 00001
VCID: 323D1B7F0D0A64870C1-4B1E
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
VCID: 6B83C61BEA90F54F0F7-508A
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CA
Component: Komfortgerát T3B 3332
Coding: 27224
Shop #: WSC 06325
VCID: 72BDDB7FCDBA2487CC1-4AA4
Component: Tõrsteuer.FS BRM 0406
Component: Tõrsteuer.BF BRM 0205
Component: Tõrsteuer.HL BRM 0506
Component: Tõrsteuer.HR BRM 0506
01134 - Alarm Horn (H12)
49-00 - No Communications
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Coding: 0000019
Shop #: WSC 40951 222 94900
VCID: 2615F72F34E20827909-8072
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 193 A HW: 8E0 035 193 A
Component: RNS-E PU EU SP H06 0700
Revision: 0000001S Serial number: AUZBZ7N2900524
Coding: 0301718
VCID: 2313EE3B47F0FD0FF77-50D0
00878 - Connection to Speaker Front Left
Reset counter: 87
Date: 2019.06.13
Time: 23:18:08
00879 - Connection to Speaker Front Right
Reset counter: 87
Date: 2019.06.13
Time: 23:18:08
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 HW: 8E0 907 273
Component: Reifendruck 3 H03 0110
Coding: 0022523
Shop #: WSC 40160 222 89032
VCID: 698FBC13E55CE75F7DB-513C
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
Fault Status: 11100100
Reset counter: 40
(no units): 0.0
Voltage: 12.10 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Resistance: 0.00 ohms
Part No SW: 8P0 862 335 C HW: 8P0 862 335 C
Component: FSE_255x BT H18 0160
Revision: 00000001 Serial number: 00000000300895
Coding: 0010822
Shop #: WSC 67458 141 87521
VCID: 3635276FE45278A7209-50D0
End----(Elapsed Time: 04:40, VBatt start/end: 12.2V/12.2V. VIgn 0.0V)------
