Steering angle, abs, traction fault.
Alexey
C?ID=375089
I have a problem with getting my test drive after wheel bearing and wss replacement. Did 2 at the rear of the car.
I've done a short video and this is what my wheel speed sensors showing at 40kmh. Don't know what exactly the should be like.
Thank you
Actual logged data so people can tell exactly what they're looking at would be preferred to a wobbly video.
Alexey
C?ID=375089
as i said before this is the problem
Wednesday,21,August,2019,20:52:38:12161
Chassis Type: 1K (1K0)
Mileage: 115480km-71755miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 997 056 M    HW: Hardware No
   Component: MED9.5.10       G00 9265
   Revision: 00000000    Serial number: VWZ7Z0C8817741
   Coding: 0000072
   Shop #: WSC 01287 785 00200
   VCID: 372B2B8CD34F7CAF3B3-8062
Readiness: 1110 0001
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0019073
   VCID: 3A2D32B8E05D61C7C4D-806E
   Part No: 1K0 820 047 CC
   Component: Climatic PQ35   080 0201
   VCID: 678BBBCCC36F2C2F6B3-8032
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000493804
   Coding: E58F8F0600041800001400001400000000
   VCID: 382928B0DE5173D7329-806C
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 002  0505
   Coding: 00217125
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0M AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD08EPD8
   Coding: 0012365
   Shop #: WSC 01268 785 00200
   VCID: 2A0D02F810FDD147B4D-807E
   Subsystem 1 - Serial number: 6332MSME69132602
   Subsystem 2 - Serial number: 6342MSME46307001
   Subsystem 3 - Serial number: 6351HSME04106201
   Subsystem 4 - Serial number: 6361HSME60145B01
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   Shop #: WSC 00046 412 688128
   VCID: 76B5E68894C5C5A7E05-8022
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
   Part No: 1K0 920 950 K
   Component: KOMBIINSTRUMENT VDD 3550
   Coding: 0005401
   Shop #: WSC 33120 003 1048576
   VCID: 303910903621AB977A9-8064
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001042020135
   Coding: 3D0F0340070003
   VCID: 270BFBCC03EFEC2FAB3-8072
   Component: IMMO                3550
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0116
   Coding: 0000052
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
   Part No: 1K2 909 144 E
   Component: EPS_ZFLS Kl.1       1302
   VCID: 2E050EE82C15BD67685-807A
02546 - Steering Limit Stop
                    Mileage: 5480 km
                    Temperature: 32.0°C
                    Voltage: 13.50 V
                    Voltage: 13.40 V
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 T
   Component: 0W KSG              0560
   Coding: 99E802087F2D8505485BC61000
   Shop #: WSC 00581 210 06001
   VCID: 41DF45548D8B321F857-8014
   Subsystem 1 - Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 313F15943D2BA29F757-8064
   Part No: 1K0 035 186 J
   Component: Radio BNO           0016
   Coding: 0040400
   VCID: 2D0709E42113C67F51F-8078
End----------(Elapsed Time: 00:57, VBatt start/end: 13.6V/13.6V)-----------
Alexey
C?ID=375089
What test is failing or is a login error because the test is activated?
You need to drive it or maybe lift and set back down to re relax the suspension maybe and drive it?
Alexey
C?ID=375089
It's a possibility, but this is the reason why I posted this here, I've tried to do all the tests in all orders, I can't log in as it's refusing the key, and as far as I tracked down the problem, the test can not be successful due the wheel speed sensor are not reading correctly, as you can see on the graph the speed is actually 20km/h and front right wheel showing around 30km and one at the rear wheels showing around 10km/h.
You would never enter the calibration test mode if that was the case to commence adaption.
Retrace each work step during calibration to complete the adaptation until completed.
Alexey
C?ID=375089
I've done the test drive as it's described, my only problem now is the security access, it wont allow me to accept the 40168. The ecu has been disconnected before and batter has been removed, I've change the all sensors and cleaned all the abs rings on wheel bearings, I don't have a problem with readings anymore, I've solved that problem. My only concern if I need to do some sort of calibration on the abs pump, is there anything you be able to recomend me? Thank you.
