Beetle aftermarket Nav display in MFD with Idatalink Maestro RR
After more searching, I think the main issue I'm dealing with isn't related to the . If I code nav into the installation list, I get the nav display on the MFD, but the instrument cluster is frozen in whatever state it was in when the nav connected to it. The last time I tried it, the instruments were stuck with most of the warning lights on, including the parking brake. The car starts, and runs fine, the tach, speedo, and fuel gauge are working, but the lights stay on. The MFD is also stuck on whatever screen was up when the nav connected, and does not update. The steering wheel controls for the mfd do nothing also. I tested the controls with , and the switches are seen by the controller, but the mfd doesn't respond. Once it's in this state, the only way out of it is to remove nav from the installation list, and disconnect the battery for a few seconds. Turning the car off does nothing. Even after many minutes of power off, and doors closed/locked, the MFD is still lit, and stuck on the last screen. The warning lights also stay on. Once the nav is removed from the installation list, and the battery disconnected for a few minutes then re-connected, everything goes back to normal. It's as if selecting nav freezes the communication to the instrument cluster at least partially with only the tach, speedo, and fuel gauge working. I see nothing in the scan that explains this, but here is the scan anyway. I know the radio, and nav don't show up as connected, but that's how it worked on my Golf with no issues, and idatalink says it should work. I'm going to update the Nav firmware tomorrow, and see if anything changes.
Any ideas are welcome.
Monday,04,May,2015,20:17:30:49008
VCDS Version: 15.3.0.0 (x64)
Data version: 20150314
VIN: 3VWRL7ATXDM656173 License Plate: BEETLE
Mileage: 55200km-34299mi Repair Order:
Chassis Type: AT (6N0)
Scan: 01 03 05 08 09 15 17 19 25 2B 2E 37 44 56 77
VIN: 3VWRL7ATXDM656173 Mileage: 55200km-34299miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 AN HW: 03L 907 309 AA
Component: R4 2,0L EDC G000SG 4815
Revision: 12H15--- Serial number:
Coding: 0050072
VCID: 77FDDB7E06723480F6-8022
000897 - Glow Plug/Heater Indicator Circuit
P0381 - 000 - Implausible Signal
Mileage: 55204 km
Temperature: 25.2°C
Voltage: 12.39 V
Bin. Bits: 01000000
Torque: 219.0 Nm
Temperature: 46.8°C
Readiness: 0 0 0 1 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 5C0 907 379 C HW: 5C0 907 379 C
Component: ESP MK60EC1 H31 0156
Revision: 00H31001
Coding: E14B401649270000870C02EB921C0042A71000
VCID: 2E533E1A79A8354865-807B
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0189241823
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02715
ROD: EV_KESSYPQ35G_AU21.rod
VCID: 34672C729F841F9813-8061
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BC HW: 5C0 820 047 BC
Component: J301 Klimaanlage 0204
Revision: 2001111S Serial number: 00000001328242
VCID: 62CB9A2ABDF0C128B1-8037
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 086 E HW: 5C0 937 086 A
Component: BCM25 JLB M3 H67 0256
Revision: B0067001 Serial number: 04351355120050
Coding: 3BBC29B8080B080000A82800260D84C50082402F60000000B2E004000000
Shop #: WSC 00066 123 12345
Subsystem 1 - Part No SW: 5C5 959 801 M HW: 5C5 959 801 M
Component: J386__TSG_FT 011 1032
Coding: 800000
Subsystem 2 - Part No SW: 5C5 959 802 P HW: 5C5 959 802 P
Component: J387__TSG_BT 011 1032
Coding: 800000
Subsystem 3 - Part No SW: 5C0 959 442 HW: 5C0 959 442
Component: E221__MFL-YVJ H02 0103
Coding: E20000
Part No SW: 5C0 959 655 Q HW: 5C0 959 655 Q
Component: AirbagVW10G 013 0851
Serial number: 003LKM02SBS6
Coding: 00004E45
VCID: 408F70A2DB3CB33887-8015
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y120000MHVX0U
Coding: 30304C
Serial number: 3572MSME2E022273ZZZP
Serial number: 3582MSME59012273ZZZN
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME28180920ZZZO
Subsystem 5 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME7E0F0920ZZZ%
Part No SW: 5C5 920 970 G HW: 5C5 920 970 G
Component: KOMBI H23 0103
Revision: X0023005 Serial number:
Coding: 250E01
Shop #: WSC 00066 123 00125
ASAM Dataset: EV_KombiUDSMM9RM10 A04712
ROD: EV_KombiUDSMM9RM10_VW01.rod
VCID: 2F6D231E76A23C406E-807A
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 086 A
Component: GW-K-CAN TP20 H67 0256
Revision: B0067001
Coding: 402000
VCID: 70EFE062A31C63B837-8025
Reset counter: 196
Mileage: 55204 km
Date: 2015.05.04
Time: 20:10:17
Part No SW: 5K0 953 234 HW: 5C5 920 970 G
Component: IMMO H23 0103
Coding: 000007
Shop #: WSC 00066 000 00125
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_SE25.rod
VCID: 6ADBF20A8DC0996879-803F
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000268220003
Coding: 4100000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7663908493
Coding: 010100
VCID: 2A5B320A45405968B9-807F
00464 - Control Module with Display for Radio and Navigation (J503)
Reset counter: 196
Address 37: Navigation
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
VCID: 377D1B7E46F2F48036-8062
00750 - Warning Lamp
Fault Status: 11101101
Reset counter: 196
Mileage: 55204 km
Date: 2015.05.04
Time: 20:07:57
Voltage: 12.88 V
DD
Temperature: 31.0°C
Address 56: Radio
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663952008
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A7B024ABDE0E9E8C9-806F
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Reset counter: 196
Mileage: 55204 km
Date: 2015.05.04
Time: 20:12:38
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 196
Mileage: 55204 km
Date: 2015.05.04
Time: 20:12:38
End-------------------------(Elapsed Time: 02:37)--------------------------
