- Joined
- Aug 24, 2019
- Messages
- 56
- Reaction score
- 30
- Location
- NW Florida
- VCDS Serial number
- C?ID=369048
Just had my 2019 Atlas serviced at my local VW dealer; they reset the service interval, but now the dash alert says “Inspection in 365 days”. I thought this remainder was only programmed to appear with within 30 days – what happened? I don’t want to reset everything, but how can I get the annoying “365-day” message back to appearing only when within 30 days?
TW
TW
;SW:3CN-920-891-B HW:3CN-920-891-B --- Instruments
;Component:KOMBI 403 4191 Coding:0BA40F1D6F88CF0502886B0B50010000A0000000
;EV_DashBoardVDDMQBAB 9058 EV_DashBoardVDDMQBAB_009_VW37.rod
;Wednesday 15 January 2020 12:07:07:27651
;VCDS Version: Release 19.6.2 (x64) Data version: 20190930 DS308.0
;VCID: 43D34EB83B13182F945-8016
IDE00295-Oil temperature display On 1
IDE00301-Distance 14654 km 3
IDE00342-ESI: Resetting ESI no warning 1
IDE00343-Language version US English 1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK Manual reset: not possible 3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel MFA3-Reset 3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas MFA3-Reset 3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection MFA3-Reset 3
IDE00499-Display correction of consumptions and operating range 100% 1
IDE00500-Hour 12 H 1
IDE00501-Minute 7 min 1
IDE00502-Year 2020 yr 2
IDE00503-Month 1 mon 1
IDE00504-Day 15 d 1
IDE00510-ESI: distance driven from inspection 96 km 3
IDE00511-ESI: time from inspection 1 d 2
IDE00512-ESI: minimum value km-driving distance/inspection 15000 km 2
IDE00513-ESI: maximum value km-driving distance/inspection 30000 km 2
IDE00514-ESI: maximum value of time between inspections 730 d 2
IDE00515-ESI: oil quality poor oil quality 1
IDE00517-ESI: soot entry 0 km 2
IDE00518-ESI: thermal load 100 km 2
IDE00819-Day counter 368 d 2
IDE00820-Activating and deactivating all development messages not active 1
IDE00827-ESI: minimum value of time between inspections 365 d 2
IDE01153-SIA: maximum value of distance to service 16100 km 2
IDE01154-SIA: maximum value of time to service 365 d 2
IDE02489-Display depiction Version 3 1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration -12.8 l 5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1 -12.8 l 5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2 12.7 l 5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3 12.7 l 5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4 12.7 l 5
IDE03329-Driving profiled for range remaining 9.4 l/100km 2
IDE03346-IDE00301-Units adjusted-Distance miles 3
IDE03346-MAS01230-Units adjusted-Date mm_dd_yy 3
IDE03346-MAS01456-Units adjusted-Speed Miles per hour 3
IDE03346-MAS02201-Units adjusted-Temperature Degrees Fahrenheit 3
IDE03346-MAS02957-Units adjusted-Time 12h AM_PM 3
IDE03346-MAS03032-Units adjusted-Volume gallons (US) 3
IDE03346-MAS03034-Units adjusted-Pressure psi 3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas) kg per 100 km 3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas) Miles per gallon (US) 3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive kWh per 100 km 3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground kilogram (kg) 3
IDE03348-MAS01456-Speed warning-Speed 80 2
IDE03348-MAS01561-Speed warning-Unit Miles per hour 2
IDE03348-Speed warning- not active 2
IDE03349-FIX: Max. distance until next mileage-related inspection 30000 km 2
IDE03350-FIX: Maximum time until next time-dependent inspection 1095 d 2
IDE03351-FIX: Distance covered since last mileage-dependent inspection 14600 km 2
IDE03352-FIX: Time since last time-dependent inspection 362 d 2
IDE03372-Source for synchronization of time GPS 1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function On 5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time 10 s 5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic On 5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless On 5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed 20 km/h 5
IDE03568-ENG103545-Service-key settings-p_write_delay_time 40 s 5
IDE03568-ENG104099-Service-key settings-p_write_distance 20 km 5
IDE03867-Deactivate seat belt warning Yes 1
IDE05930-Service notification in days 30 d 1
IDE05931-FIX: Reset value for next mileage-dependent inspection 30000 km 2
IDE05932-FIX: Reset value for next time-dependent inspections 1095 d 2
IDE05971-Vehicle Positioning System Interface Control Module not installed 1
IDE06425-Roller test bench mode: functional not activated 1
IDE06588-Ignition active message: actuator No display 1
IDE06922-No-voltage display Unknown (2) 1
IDE07221-Cylinder shut-off Display 1
IDE11086-Service notification 30 d 1
IDE11932-MAS01877-Display of colour adjustment-Red 0 3
IDE11932-MAS01878-Display of colour adjustment-Green 0 3
IDE11932-MAS01879-Display of colour adjustment-Blue 0 3
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation not active 1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS not active 1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter not active 1
IDE14220-Vehicle speed warning for India- No 1
IDE14220-Vehicle speed warning for India- 0 s 1
ENG117917-BAP_Debug_Mode_Release not_released 1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1 OFF 20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10 OFF 20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11 OFF 20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12 OFF 20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13 OFF 20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14 OFF 20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15 OFF 20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16 OFF 20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17 OFF 20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18 OFF 20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19 OFF 20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2 OFF 20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20 OFF 20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21 OFF 20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22 OFF 20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23 OFF 20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24 OFF 20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25 OFF 20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26 OFF 20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27 OFF 20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28 OFF 20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29 OFF 20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3 OFF 20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30 OFF 20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31 OFF 20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32 OFF 20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33 OFF 20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34 OFF 20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35 OFF 20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36 OFF 20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37 OFF 20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38 OFF 20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39 OFF 20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4 OFF 20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5 OFF 20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6 OFF 20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7 OFF 20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8 OFF 20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9 OFF 20
ENG119875-defuel_threshold 9 l 1
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1 00 00 24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2 00 0A 24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3 00 32 24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4 00 64 24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5 00 96 24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6 00 FD 24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1 00 32 24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2 00 32 24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3 00 78 24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4 00 E6 24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5 01 F4 24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6 03 E8 24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1 00 00 24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2 00 0A 24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3 00 64 24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4 00 96 24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5 00 DC 24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6 00 FD 24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1 00 09 24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2 00 09 24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3 00 50 24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4 01 90 24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5 03 52 24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6 03 E8 24
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1 00 00 20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2 00 01 20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3 00 32 20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4 01 2C 20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5 01 F4 20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1 00 00 20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2 00 0A 20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3 00 32 20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4 00 96 20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5 00 FD 20
ENG119874-Gas_functionality not active 1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim terminal_58xd_log_bus_parkinglight 1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm parking_light 1
ENG119882-init_fuel_algorithm No 1
ENG130585-Leaving_warning_delay 1.6 s 1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0 15 s 16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature 4 °C 16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature 6 °C 16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta 25 °C 16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0 5.0 km 16
ENG102605-ENG103631-outside_temperature-P_speed_threshold 20 km/h 16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off 180 min 16
ENG102605-ENG104179-outside_temperature-p_tendency_damping 15 s 16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold 1.0 °C 16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1 40 s 16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping 2 16
ENG119825-Picture_Upload_Download not active 1
ENG126396-Scale_switching_algorithm lowbeam_foglight 1
ENG153765-Second_digital_speed Display 1
ENG119876-Service_Key_Clear_All_Counter Yes 1
ENG130584-Statistic_phev_mileage 5 km 1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms 2.0 s 18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms 5 s 18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt 35 s 18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF 300 ms 18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms 255 s 18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms 5 s 18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms 6 s 18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms 20 s 18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms 900 s 18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms 10 s 18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms 3 s 18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms 10 s 18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ 0.20 s 18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse 3 18
ENG109442-ENG101663-time_parameter_display-tDD15_off 0.15 18
ENG109442-ENG103975-time_parameter_display-tDD15_on 0 18
ENG109442-ENG100026-time_parameter_display-tDDWUP 0 18
ENG112418-ENG112412-total_range_gas-consumption_factor 0 4
ENG112418-ENG112411-total_range_gas-consumption_profile consumption_profile_calculation 4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor consumption_factor_CAN 4
ENG112418-ENG99298-total_range_gas-State not active 4
ENG153766-Tube_version variant_1 1
Elapsed Time: 00:26
