HELLO to all of you masters of the hexadecimal/binary matrix and you Vag Com wizards!!!!
PLEASE trust that I wouldn't be here asking for help if I didn't, for one second, think that I'd exhausted all possible scenarios my pea-brain could come up with.
I've turned to these forums for help on a similar vehicle.....we were trying to completely delete the DRC system on a 2014 RS7, and with the help of you all, we succeeded AND gained some valuable insight.
Well, here we are again in a similar yet very different situation... .This time we are trying to delete the factory air suspension (34 level control) on another 2014 RS7 (our shop project car). We've made great progress with this conversion using knowledge gained from our last outing.....however, we find ourselves stuck trying to gain security access to the ABS/ESP unit in order to change the coding and adaptations on this car. At this point I believe the fault we are receiving (see auto scan) is telling us why the car is not allowing us to turn off our traction control off(via switch) .. which is a vital step in order to drag-race one of these vehicles and engage the AMAX shifting strategy in the TCU.,
It seems as if the recommended access code "61378" (so nicely provided by Ross-Tech)does not play well with our control unit. We receive "Controller refused the key! Error 35: invalid key" message.
Does anyone have any other suggestions for said security access key so we can implement changes in our code?
PS, please ignore faults in ECM related to mods we've made.... As well as faults in range control and night vision which SHOULD be rectified by some pin changes and jumper wires to satisfy height sensor inputs.
Thank you in advance!!!!!
Saturday,06,July,2019,16:13:25:27499
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: SES
VIN: WUAW2BFC1EN902414 License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 65 6C 6D 72 82 84 85 8B 8E 8F 90 BA
VIN: WUAW2BFC1EN902414 Mileage: 88389km-54922miles
84-Night Vision -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CRDB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 560 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0004
Revision: NCH62---
Coding: 1A2A003265460A0E1000
ASAM Dataset: EV_ECM40TFS0114G0906560B 001008
ROD: EV_ECM40TFS0114G0906560B.rod
VCID: 271E009B5E867F77F8-8072
17875 - Exhaust Pressure Control Valve
P0475 00 [039] - Electrical Malfunction
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:26
Coolant temperature: 87 °C
Intake air temperature: 73 °C
Voltage terminal 30: 13.052 V
Engine status: COENG_READY
17876 - Exhaust Pressure Control Valve 2
P049F 00 [039] - Malfunction
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:26
12352 - Coolant Pump for Intercooler
P023A 00 [039] - Open Circuit
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:26
Readiness: 1110 1100
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 BE HW: 0BK 927 156 AM
Component: 0BK 40TFSIUSA H16 1006
Revision: --H16---
Coding: 000001
VCID: 72A821CFA5C44ADF9F-8026
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 P HW: 4G0 907 379 P
Component: ESP PREMIUM H09 0100
Coding: 61B7530386EDCAC04B00
ASAM Dataset: EV_ESPPremiAU57X 004036
VCID: 3E30C5FFA11CDEBFAB-806A
0055 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Fahrwerk_02_Timeout]
Reset counter: 44
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:24
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: BD
Uz: AA
Part No SW: 4H0 907 064 DR HW: 4H0 907 064 DR
Component: BCM2 2.0 H35 0510
Coding: 0D8A2046000000000000
VCID: 7CB40FF7FF800CAFC5-8028
Serial number: 0213000372472003
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AM HW: 4G0 820 043 AM
Component: KLIMA 4 ZONEN H14 0093
Serial number: 12111300040320
Coding: 680320785D
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: 6A9839AF8D14821F27-803E
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001497574
Coding: 0D073811013E9FE2A10000C7A0003820CF94D208A2090221800308457B00
VCID: 6FAE28BBBEF6673770-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 131030 H36 0080
Serial number: 131101034755
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21948910
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 29 10 2013 00001034
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R8MSB03
Subsystem 5 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0002
Serial number: 00000000001311141262
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0002
Serial number: 00000000001311141293
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA106973000005340362
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 04E889D6000000000001
Subsystem 9 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0002
Serial number: 00000000001311090388
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0002
Serial number: 00000000001311090393
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AC HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0091
Revision: 11001001 Serial number: 61061330403472
Coding: A8E90D
VCID: 73A624CBDADE43D794-8026
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7601010101
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 281C03A75398700FF1-807C
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003PEYE
Coding: 303145313131303030344A55304C34473853
VCID: 3326E4CB9A5E03D754-8066
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y130000YC6Z0F
Serial number: 3575HRB400M50O5UBA0E
Serial number: 3585HRB401250LNGG1MF
Serial number: 3515JRB400250OCCE10G
Serial number: 3525JRB401450OM6A1O1
Serial number: 3554VRB40532FFOAGGBZ
Serial number: 3564VRB40532FFOA6OI+
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372MK8000A9
Coding: 0000FC
VCID: 373ED0DB8626EFF768-8062
Serial number: 21 10 2013 E0270632
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 984 C HW: 4G8 920 984 C
Component: TBenUsaAccNv H58 0621
Revision: 29460235 Serial number: 658071113596001
Coding: 03CF010C8F53D705020500
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3620DDDF892C16FF73-8062
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001182164
Coding: 00E1034800
Serial number: 1566931603
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0200
Serial number: 000311130001928
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 M HW: 4G0 919 158 M
Component: KLIMA FOND H08 0093
Serial number: 13111300042089
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
VCID: 393AD6E3B832F9879E-806C
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000081288874
Coding: 00581B0000002001000001010101102030303232203232
VCID: 77BE10DBC6A62FF7A8-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7E00S2HJ
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 373ED0DB8E26EFF768-8062
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 L HW: 4G0 907 566
Component: J769 SWA MasterH04 0010
Revision: 00H04000 Serial number: 6PZ 010 287-10
Coding: 0000006
VCID: 383CD3E74B38E08F61-806C
Subsystem 1 - Part No: 4G0 907 568 L
Component: J770 SWA Slave H04 0010
Subsystem 2 - Serial number: 6PZ 010 287-30
Subsystem 3 - Serial number: 5F10.10.1300H04000AMS14795ÿ
Subsystem 4 - Serial number: S14795ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F57025E00628002000413
VCID: 45C2AA13CCCA8D67EA-8010
Component: RCEPS H39 0010
Revision: 00001000 Serial number: 0008023935
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 3228E1CF65440ADF5F-8066
Revision: 00002001 Serial number: 0320281437
Coding: 0126063A20FAF08580B00A80020114000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000191218
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO2512280.
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00005169296
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA107207000005343701
Part No SW: 4G0 035 465 C HW: 4G0 035 465 B
Component: BO G3 C7 H09 0160
Revision: 11000000 Serial number: 0018200
VCID: 25020A932C8A6D67CA-8070
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Serial number: 02809130025434
Component: TSG BF H03 0507
Coding: 011F57025E00628002000402
VCID: 46C0AD1FF1CC867FE3-8012
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000887695
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C14FFB747605C2F15-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 131118-0001-016
Coding: 1223A6601002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2D12F2B37C7A552702-8078
126986 - Front Left Ride-Height Sensor
C1034 15 [137] - Open or Short to Plus
Reset counter: 44
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:25
127242 - Rear Left Ride-Height Sensor
C1036 15 [137] - Open or Short to Plus
Reset counter: 44
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:25
393989 - Headlight
Reset counter: 44
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:24
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156K50D7936506
Coding: 020007010000000001
VCID: 2404179727B0946FDD-8070
Part No SW: 4G0 035 746 F HW: 4G0 035 746 E
Component: H-BNT-NA H41 0757
Revision: -------- Serial number: 194KF0D7595594
Coding: 0B0200040303EDEF7D16CB3E00000003100001000000000000
VCID: 2A18F9AF4594421FE7-807E
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD0032FUZ
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349MK800087
Component: CD-Database 5571
Component: TSG HL H03 0507
Coding: 010F17024000628002000002
VCID: 49DAA623E0D269070E-801C
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 HW: 4H0 907 273
Component: RDKBERU25 H09 0700
Serial number: 10000000005070
ROD: EV_RDKBERU25_AU57.rod
VCID: 689C43A79318B00F31-803C
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0118189
Coding: 0206000001010100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_007_AU57.rod
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 R HW: 4G8 959 107 G
Component: HDSG-Modul H13 0043
Revision: 12013001 Serial number: 290300178
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 44C4B717CFF0B46FFD-8010
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 K HW: 4G8 919 604 K
Component: HeadUpDisplay 004 0201
Coding: D60000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
VCID: 3B36CCEBB20ECB978C-806E
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H10 0042
Serial number: 0K84AE40103446
Coding: 1411
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H09 0008
Serial number: 00000000001231200086
9986 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[LWR_AFS: Fehlerspeicher auslesen]
Reset counter: 44
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:24
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 26000D9F598C667FC3-8072
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7601010101
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000121211137
Coding: 03C19A1A0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 312AEEC3604231C726-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H07 0006
Revision: 00001001 Serial number: 97809002752200
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X_AU57.rod
VCID: 66804D9F990CA67F03-8032
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Reset counter: 44
Mileage: 88389 km
Date: 2019.07.06
Time: 16:08:28
End----------(Elapsed Time: 02:56, VBatt start/end: 13.6V/14.0V)-----------
