IMMOBILIZER END OF LINE Error
mirkiaei
IRAN
C?ID=259416
Hi mates,
I'm new to VCDS. We have a VW CADDY 2009 in stock, the engine starts with no problem, but the message: "immobilizer end of line" appears for a few seconds and the yellow Immobilizer alarm blinks permanently on the Dash panel.
Any tip is much appreciated.
The Auto Scan Shows no Fault:
Tuesday,31,May,2016,12:11:35:37122
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WV2ZZZ2KZ9X086586   License Plate: HAYAT
Mileage: 200km-124mi   Repair Order:
Chassis Type: 2K (1K0)
VIN: WV2ZZZ2KZ9X086586   Mileage: 200km-124miles
Address 01: Engine (   )       Labels: Redir Fail!
   Part No SW: 06G 906 022 E    HW: 06G 906 022 A
   Component: 4220 CNG 26A5V0     2809
   Revision: 1RH03---    Serial number: VWX7Z0HN3NL0EL
   Coding: 0030071
   Shop #: WSC 35110 377 00158
   VCID: 2578770EEC7004162D-8070
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0104
   Revision: 00H32001
   Coding: 0020801
   VCID: 76DA604201563F8E54-8022
   Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 6FD455267E0C0E4697-803A
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 01000009164623
   Coding: 018C4F030004100057000000000000000009FF075C000120000000000000
   Shop #: WSC 35110 377 08192
   VCID: 335C995652A46AA6B3-8066
   Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 131108 021  0501
   Coding: 00038805
   Shop #: WSC 35110
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AJ    HW: 6Q0 909 605 AJ
   Component: Z7 AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037UR0155PH
   Coding: 0023095
   VCID: 7F3485662E6C7EC607-802A
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           853 0111
   Coding: 0000004
   VCID: 033C099642841A2663-8056
   Part No: 1T0 920 863 F
   Component: KOMBIINSTRUMENT VDD 0622
   Coding: 0016101
   Shop #: WSC 00099 757 173712
   VCID: 3744AD4646DC86868F-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Revision:   H07 01    Serial number: 281108F1001967
   Coding: E9801F06000202007400
   Component: IMMO            VDD 0622
   Part No SW: 1T0 959 701 M    HW: 1T0 959 701 M
   Component: Tuer-SG         008 2005
   Coding: 0000048
   VCID: 41B0C39E1818C83631-8014
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 140    2301
   Revision: 00H15000
   VCID: 2A628432856E2B6E00-807E
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Coding: 808B0C087F2D8405484A036010C0
   VCID: 0036069A5392013E7E-8054
   Part No SW: 1T0 959 702 M    HW: 1T0 959 702 M
   Coding: 0000048
   VCID: 42B2CC921D1ED32E28-8016
   Part No: 1K0 035 186 AF
   Component: Radio GR0       036 0034
   Revision: 0003606S    Serial number: VWZ2Z2H1236336
   Coding: 0020200
   VCID: 6AE2443245EEEB6EC0-803E
End-------------------------(Elapsed Time: 00:59)--------------------------
Tuesday,31,May,2016,12:35:08:37122
   Coding: 0030071
   Revision: 00H32001
   Coding: 0020801
   Coding: 00038805
   Shop #: WSC 35110
   Coding: 0023095
   Coding: 0000004
   Coding: 0016101
   Coding: 0000048
   Revision: 00H15000
   Coding: 0000048
   Coding: 0020200
HMC
C?ID=28246
Hi Mirkiaei,
A 2009 Caddy with 124 miles suggests to me that someone has been screwing with the instrument cluster.
Regards HMC
Gavra
Melbourne/Belgrade
C?ID=240855
You have immo-off and it's a bad one ........
mirkiaei
IRAN
C?ID=259416
Hi HMC,
I mentioned that the car has been in stock. :)
Regards Mirkiaei
mirkiaei
IRAN
C?ID=259416
Hi Gavra,
Thank u for the reply. How did u figure it out? Any suggestion for fixing?
I don't have SKC or and PIN, but we have a few more cars of the same model.
Regards Mirkiaei
Gavra
Melbourne/Belgrade
C?ID=240855
Well I am not sure is it OK to give you detailed advice as you are not verified yet.......please verify your VCDS and we will continue then ;)
mirkiaei
IRAN
C?ID=259416
Thank you again. I registered yesterday, received Dongle Registration but don't know what else to do? :(
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Registration should happen soon, nevertheless it is rather unlikely that a car build in 12/2008 has only 200 km on the clock. Hence HMCs assessment being fairly realistic. Can you give us some background as to why this car has been sitting this long and supposedly hasn't been driven? As far as the immobilizer question goes - what current value do you have in the ECM, Adaptation Channel 91?
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I know exactly what happen here.
Someone try to add key with low quality tool and mess up immobilizer side in cluster, This can be fixed but need really high quality tool and brain.exe.
VCDS can not help you on this.
I can fix it but need to have cluster.
mirkiaei
IRAN
C?ID=259416
Dear Sebastian,
I work for the official importer. In 2009 we imported 60 units of EcoFuel Caddy, as the sample for an order of thousand units. But due to sanctions against Iran, VW refused further orders and we had to sell the cars to private customers.
This car plus 2 others, are remained from that import. All 3 are faulty, and there is no access to Geko in Iran. So we bought VCDS and I an starting with this car.
I hope this details clarifies the reason why the car has not been sold yet.
Best regards
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Thank you for the clarification, that sure explains some of the weird PR-codes. :) FWIW, it never hurts to tell the full story up-front - usually saves us a lot of questions.
Were the car(s) stored with the battery disconnected and/or did the battery die in the process and/or was completely discharged? Some of the ideas posted above may still apply, due to low voltage conditions it isn't impossible that the immobilizer information in the cluster was corrupted. In order to look at this closer, please provide the following information...
#01 (Engine) > Adaptation - 10 > Channel 91 > What is the current Value?
#17 (Instruments) > Meas. Values - 08 > Block 001, 002 & 003 > What are the current Values?
mirkiaei
IRAN
C?ID=259416
Thank you Sebastian,
I'm back to home, will read the values tomorrow.
Best regards,
Jetta 97
C?ID=81680
On this car Need to go to 25 Immobilizer Meas. Values - 08 > Block 001, 002 & 003
Jetta 97
C?ID=81680
Like I said I know what happened here , had to dig in my old PC :D.
Measuring block 003 files 4 will be 5.0 ( Malfunction in line mode(LED 4Hz)
3O3qUScJ7tCIZoIq4M1-e4VdzgpR_-e3-kgXnJ3YnGgkaWjURo_KeU_FRUclSRBRkv719RixtBhWpeX1vHTAgzL_BF13Jn0EEcx6Q5xtRA6J-8NFnS0b5yGXSh3fGwv2RaF_fHvRGNZPa78WTqaWP_7ReFtMe6sgDr2_En-Au5i-iOwXh__5Gb_fCFpVK_HQnEc7sVQpUUhRWdbmAUdrjpco_bUKbpJp2WTGbEOyKtxGvoLc_0QNtUce9IXNqz8JdSIcbWizcQkTHpnXRyhm6k88lahyBQ9y3EWq1I0EZJJ4_1PYOT1217KwWsFTe9nryzHAXtvblmXrnphUqQbX9KesLgWtkw1bwYcW5Gf6k1uPswADHdYV9vkaysSG85HwBRh6Eoy8VmK6BS7cZCQJ1PJqD9MhMHoqND1-Os0dmN7x6MNTi5PClGjwfCnAMD-Z5mFUbxKRKsowwFSV1jJq113zUBbSw3N0Rh85HKUhcYtYUsR1XMhbjKTO7MTWxWCjd0qo8bvg03LzuDes8v7fFiCDdC3aBE9u1GwpH3FofbbPnuOMPa2SXITlgwYnI_esgXzWfa8orUJ2lRMcADa1a5NPPfHEh4g=w1152-h864-no
mirkiaei
IRAN
C?ID=259416
Measured Data
I read the channels:
Sunday,05,June,2016,14:04:09:37122
VIN: WV2ZZZ2KZ9X086586   License Plate: YARD
Adaptation Channel 091:
Stored value 4
Test value ERROR
Address 25: Immobilizer  (1T0 920 863 F)
14:05:04 Group 001: System Status
  Yes  Engine Start permitted
  Yes  Engine (ECU) responds
  Yes  Key Status OK
  2.0  Number of adapted Keys
14:05:04 Group 002: Key && Adaptation Status
  Yes  Variable Code authorized
  Yes  Key Status (Transponder Lock)
  Yes  Fixed Code authorized
  6.0  Immobilizer Status
14:05:04 Group 003: Lock Times && System Status
  0.0  Lock Time Immobilizer
  0.0  Lock Time Engine
  0.0  Lock Time Transponder
  5.0  Immobilizer (LED) Status
We have Abrites Tool too. I also used it to extract the 5-Digit PIN, then checked it within VCDS Security and it worked.
Since the car is running, I have to work carefully, not harming the IMMO.
Once again I appreciate your help.
With regards.
Gavra
Melbourne/Belgrade
C?ID=240855
Like I said I know what happened here , had to dig in my old PC .
He offered his help first , so I would suggest to install Team Viewer and send PM to Jetta ;)
mirkiaei
IRAN
C?ID=259416
Dear Jetta,
I'm afraid I don't understand. Would you please kindly write a little more clearly. I really appreciate it.
mirkiaei
IRAN
C?ID=259416
Dear Gavra, I don't understand. Jetta's first reply asks for the panel to be sent to him. The second reply gives no clue to me :(
Gavra
Melbourne/Belgrade
C?ID=240855
That's because dealer can not fix this ,only replace cluster :)
Send him PM and maybe he can try to help you with other tool. VCDS can not be used at this stage to help you. And if you have really good tools and can read binary from your cluster no need to send it ;)
mirkiaei
IRAN
C?ID=259416
As I mentioned before, we are importer, so I can replace it a new one, which costs hundred euros. :(
About the tools: I have VCDS, and a Programmer.
Do you guys mean that it's only possible by changing some binary values of the IMMO dump? No suggestion for solving the problem without removing IC from Dash Panel ?
I hope you excuse me for so many question, but I have to convince my employer here ;)
Best regards
