Trucker_v8
- Joined
- Oct 4, 2019
- Messages
- 29
- Reaction score
- 2
- Location
- Sweden
- VCDS Serial number
- C?ID=275515 (NRRT)
Hi. mine passat b5 fitted with an afn-engine with alh pump complications. has erased error codes and checked the fuel quantity several times. has lifted the lid of the pump to watch what happens when you turn the key on and off . what I can see is what it should be. tried with and without the chip. but it still fails. the car black smokes and goes bad for a while at idle before it stops. can not find much info about this error so I turn here i
Saturday,21,March,2020,18:03:23:00080
VCDS Version: 19.6.2.0 (x64)
VIN: License Plate: 7272545742565
Mileage: 243180km-151105mi Repair Order:
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 243180km-151105miles
Part No: 038 906 018 P
Component: 1,9l R4 EDC G10SG 1623
Coding: 00003
Shop #: WSC 05314
VCID: 237DAF2CB1D5A8579A-FFFE
01268 - Quantity Adjuster (N146)
35-00 - -
27-00 - Implausible Signal
00626 - Glow Plug Indicator Light (K29)
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D00
Shop #: BB 24334
VCID: 1C0F94D08CAB97AF5B-FFFE
01203 - Electrical Connection between ABS and Instrument Cluster
31-10 - Open or Short to Ground - Intermittent
35-00 - -
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 A
Component: CLIMATRONIC S 9.0
Coding: 00000
VCID: 1F75A3DC9DBD8CB7BE-FFFE
00787 - Temperature Sensor in Fresh Air intake duct (G89)
35-00 - -
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 607 A
Component: AIRBAG VW3 S V04
Coding: 00065
Shop #: WSC 05311
VCID: 2B6D470CD905601722-FFFE
Address 17: Instruments Labels: 3B0-919-xxx-17.lbl
Part No: 3B0 919 881 N
Component: B5-KOMBIINSTR. VDO V30
Coding: 04140
Shop #: WSC 35161
VCID: 37456B7C154DD4F756-FFFE
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0W0518891
IMMO-IDENTNR: VWZ7Z0W0518891
29-10 - Short to Ground - Intermittent
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 J
Component: 0E Zentral-SG Komf.0002
Coding: 04097
Shop #: WSC 05311
VCID: 45B911B45FA1B667D4-FFFE
Subsystem 1 - Part No: 1J1959801D
Component: 3C Tõrsteuerger. FS0001
Subsystem 2 - Part No: 1J1959802E
Component: 0E Tõrsteuerger. BF0001
Subsystem 3 - Part No: 1J4959811D
Component: 0E Tõrsteuerger. HL0001
Subsystem 4 - Part No: 1J4959812D
Component: 0E Tõrsteuerger. HR0001
End-------------------------(Elapsed Time: 08:21)--------------------------
