Error 31 : Request out of range
Fatbloke
Scotland
Hi All
I am trying to add the oil temp display onto the dash on my 2016 Audi A3 8V S-Line Quattro TDI but it will not take the coding. It just keeps saying Error 31 : Request out of range.
[17] Instruments -> Long Coding -> Byte 10
CHANGE: Tick Bit 1. Display Oil Temperature
The VCDS version is 17.8.0
Can anyone help me fix this?
Regards
Dave
Please post an Auto-Scan so people can see exactly what modules are fitted to this car and how they are configured.
Fatbloke
Scotland
Hi, here is the one I took when I got the vehicle a few weeks ago. The only changes I have made so far is it lowers the passenger mirror when reversing and the needle sweep is enabled.
Wednesday,09,August,2017,17:50:26:62090
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ8V9HA0XXXXX   License Plate:
Mileage: 15265km-9485mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 22 42 44 52 55 5F BB BC
VIN: WAUZZZ8V9HAXXXXX   Mileage: 15265km-9485miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BQ    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H23 1199
   Revision: B5H23---
   Coding: 02190012032701082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TDI01104L906026BQ 002002
   ROD: EV_ECM20TDI01104L906026BN_002.rod
   VCID: 7AFA7044FD2DD396C4-802E
   Part No SW: 5Q0 614 517 AR    HW: 5Q0 614 517 AG
   Component: ESC           H62 0642
   Revision: 00000000    Serial number: 61956000000022
   Coding: 12F18AA224230A6F497D0F0440CA294851245092F0029472026100788008420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
   VCID: 010807A890FB804E85-8054
8400 - Databus
                    Reset counter: 248
                    Mileage: 14938 km
                    Date: 2017.07.30
                    Time: 21:36:06
                    Extended Freeze Frames:
   Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001006464
   Coding: 03100104002000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 3C76B65CB7992DA696-8068
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: A109C04800PAG0MUFU03
   Serial number: 02001621104047
   ROD: EV_BCMBOSCH_017_VW27.rod
   VCID: 7EF27C54E105FFB6F8-802A
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160717  043 0580
   Serial number:         160727095341
   Coding: 0A47F7
   Serial number: 62119713
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Serial number: 12 06 2016  00000467
   Serial number: 000000000ZY161872HP9
   Serial number: 00000000000065865512
15360256 - Component Protection
          U1101 00 [008] - Active
                    Reset counter: 235
                    Mileage: 14771 km
                    Date: 2017.06.22
                    Time: 15:36:03
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR1ZDKY3
   VCID: 102E32ECCB91F9C61A-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 003 007 16
   Serial number: 35700000000CD1596D1W
   Subsystem 2 - Part No SW: -----------    HW: 480 003 007 16
   Serial number: 35800000000AD41D6D1Y
   Subsystem 3 - Part No SW: -----------    HW: 480 400 408 16
   Serial number: 3510001C121DBA14A31-
   Subsystem 4 - Part No SW: -----------    HW: 480 400 408 16
   Serial number: 3520001C121DBA1455A0
   Subsystem 5 - Part No SW: -----------    HW: 480 402 706 16
   Serial number: 3550002AF20FC4C3704D
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 507 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001AD210BB03C23
   Subsystem 7 - Part No SW: -----------    HW: 480 402 507 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001AD210BB0164F2
   Subsystem 8 - Part No SW: -----------    HW: 480 001 607 16
   Serial number: I0M00000000D6C35CC1I
   Subsystem 9 - Part No SW: -----------    HW: 480 001 607 16
   Serial number: I0N00000000F39813D18
   Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 07081604400280
   Coding: A408
   Part No SW: 8V0 920 972 L    HW: 8V0 920 972 L
   Component: KOMBI         H03 8316
   Coding: 27A408002B8026000100E8001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 479CD9B0FE5F7E7E0B-8012
   Revision: --------    Serial number: 0005199594
   Coding: 030100041F0873005B000248080B00000001010000000000000000000000
   VCID: 7CF6765CF719EDA6D6-8028
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0003
   Serial number: 20160722035934 00538
   Serial number: 75410803001608043960
   Serial number: HA1-00029.06.16
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
   VCID: 4A9AE084ED4D831614-801E
   Serial number: 210716EGL11001
   Coding: 001C8A204001040000001002
   VCID: 4384CDA0CA67525ED7-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 4580D3B8C4536C6EF9-8010
   Serial number: 210716EGJ21696
   Coding: 001C82204001040000001002
   VCID: 428AC8A4D57D5B56DC-8016
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0EEE00102B230200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E72BC54A1853FB6B8-806A
   Part No SW: 81A 035 192     HW: 81A 035 192
   Component: MU-HS-LND-EU  045 0148
   Coding: 01730301FF00000011111101000A00102F0032C601F00100CE
   ASAM Dataset: EV_MUHigScl6C3DELP 001011
   ROD: EV_MUHigScl6C3DELP_AU37.rod
   VCID: 5EB21CD441C51FB6D8-800A
   Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
   Component: ECE 2016  --- 0009
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY206VBQ
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL121061600010800
   Serial number: 070716EG611011
   Coding: 000C82204001040000001002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Serial number: 070716EG61057B
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 03:49)--------------------------a
ibis_white
C?ID=236086
Request out of range usually means you need security access to perform an action.
Fatbloke
Scotland
Do you know the security code for that section?
I don't agree that it "usually" means that. While it can mean that, it can also mean that the software in the module simply doesn't support the functionality that would be enabled by that coding change.
DJAlix
London, United Kingdom
C?ID=238277
Reset counter: 235
Mileage: 14771 km
Date: 2017.06.22
Time: 15:36:03
Changed your BCM?
Try 20103 for the 17 - Instruments Security Access Code.
ibis_white
C?ID=236086
I sit corrected. My brain was ready for bed, my hands should have done the same. Apologies.
No worries, I did something similar myself yesterday.
Fatbloke
Scotland
Reset counter: 235
Mileage: 14771 km
Date: 2017.06.22
Time: 15:36:03
Changed your BCM?
I have only had the car a few weeks. What is the BCM and why would it have been changed?
Do I need to worry about this?
I will try that code DJAlix. Cheers.
See how BCM is in dark green, boldface with a dotted double underline? Hover your cursor over it. :)
It's the module at address 09 that has the Component Protection fault in it.
The car has ~9,500 miles on it, but you've only had it a few weeks? Presumably you did not buy it new?
Fatbloke
Scotland
Its just under a year old. I got it with around 9000 miles on it. Will this fault cause any issues? I trust it will be repaired under warranty?
DV52
C?ID=194404
Reset counter: 235
Mileage: 14771 km
Date: 2017.06.22
Time: 15:36:03
Changed your BCM?
DJAlix's: I don't mean to be impertinent, but your magic number might be a tad problematic in OP's hex17 module.
He/she? doesn't say, but the fact that the car has about 15,000 kms on the clock (from the autoscan) strongly suggests that it's a late model vehicle. I'm more than happy for you to tell me otherwise and I'm very nervous suggesting this to someone with your impressive expertise, but I believe that the hex17 module changed in MQB platform vehicles around MY16 so that the venerable 20103 no longer works.
My understanding is that the alternative SA, 25327 is still accepted in late model cars, but that it's application to adaptation changes is still as restrictive as it was in the older modules. I'm not aware that anyone outside the "Geheimpolizei" at VAG HQ has as yet found the new SA!
Again, my apology if my understanding is incorrect.
Have you tried clearing it? With Fault Frequency: 1 and a date stamp of 2017.06.22, I'm thinking you haven't?
Fatbloke
Scotland
I have not cleared it yet. I will try and do it over the next couple of days. Thanks.
Fatbloke
Scotland
I eventually got round to trying VCDS again. The oil temp mod just worked. There were no errors. I have also cleared all error codes and will scan it again in a few weeks to check all is ok.
Thanks for the assistance guys.
Dave
