- Joined
- Apr 17, 2015
- Messages
- 275
- Reaction score
- 86
- Location
- South Africa
- VCDS Serial number
- C?ID=133909
Had the gearbox repaired, new mechatronics fitted & clutch fork repaired. Oil filled correctly. Basic setting runs through 100% (060). Can engage reverse but as soon as ~D~ is selected the fault code appears with no positve torque afterwards. Fault can be cancelled and basic settings runs perfectly.
Any suggestions?
Thursday,31,October,2019,14:07:06:48706
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ16ZDM083969 License Plate: CWJ 485 L
Mileage: 190520km-118383mi Repair Order:
Any suggestions?
Wednesday,16,October,2019,08:30:21:48706
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: WVWZZZ16ZDM083969 Mileage: 190520km-118383miles
02-Auto Trans -- Status: Malfunction 1010
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MP HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9970
Revision: --H43--- Serial number: 00000000000000
Coding: 10254014032500080000
Shop #: WSC 00066 000 00186
ASAM Dataset: EV_ECM16TDI02103L906023MP 003010
ROD: EV_ECM16TDI02103L906023ML_003.rod
VCID: 004C65ED9BBD414FA7-8054
6 Faults Found:
7332 - Mass Air Flow Sensor (G70)
P0103 00 [165] - Signal too High
Time: 00:00:00
Coolant temperature: 54 °C
Intake air temperature: 34 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 12.085 V
Engine speed: 0 /min
Battery voltage: 11.9 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
Air mass: specified value-MAF_SP_MMV: 269.87 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
7366 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 00 [037] - Electrical Fault
Mileage: 190527 km
Date: 2019.10.16
Time: 00:00:20
Coolant temperature: 19 °C
Intake air temperature: 20 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 11.633 V
Glow status-STATE_GLOW: 48
Fuel temperature-TFU: 19 °C
Sensor for engine block temperature: raw value-Coolant temperature: 19 °C
7419 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [037] - Electrical Fault
Mileage: 190527 km
Date: 2019.10.16
Time: 00:00:20
7368 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [037] - Electrical Fault
Mileage: 190527 km
Date: 2019.10.16
Time: 00:00:20
7367 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [037] - Electrical Fault
Mileage: 190527 km
Date: 2019.10.16
Time: 00:00:20
6088 - No Communication with Transmission Control Module
U0101 00 [036] - -
Mileage: 190527 km
Date: 2019.10.16
Time: 00:00:22
Driver request torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 33 °C
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 R HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5270
Revision: 00043014 Serial number: CU501410275184
Shop #: WSC 28747 001 1048576
VCID: 40CCA5ED133D814FE7-8014
006293 - Functional Restriction due to Pressure Drop
P1895 - 000 - - Intermittent
Reset counter: 5
Mileage: 190524 km
Date: 2014.03.08
Time: 12:08:19
001851 - Gear 6
P073B - 008 - Not Selectable - Intermittent - MIL ON
Fault Status: 10101000
Reset counter: 40
Mileage: 190524 km
Date: 2014.03.08
Time: 12:08:20
001850 - Gear 5
P073A - 000 - Not Selectable - Intermittent
Reset counter: 40
Mileage: 190524 km
Date: 2014.03.08
Time: 12:08:23
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: A33B20F8092A00FDC51404EA90220081251000
VCID: 7DB21C19E44F2CA7CC-8028
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
Shop #: WSC 00066 000 00120
VCID: 7BB61201F25B2297F2-802E
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 00000A3A802DE1C040880080140081640170008850A085605C8000000040
VCID: 3E30DB15A9C9F7BF95-806A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 210313 05 54 0403
Coding: 02300A
Subsystem 2 - Part No: 1K8 951 171
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 212
Mileage: 169854 km
Date: 2013.07.15
Time: 12:56:48
Voltage: 13.60 V
Fault Status: 00101010
Fault Frequency: 9
Reset counter: 4
Mileage: 189738 km
Date: 2014.02.26
Time: 12:41:26
Voltage: 12.90 V
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M09BP17
Coding: 00003241
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3228FF25659123DF61-8066
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Serial number: 3572MSME64095177ZZZW
Serial number: 3582MSME65095177ZZZY
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME12450D23ZZZJ
Serial number: 3526KSME682A7023ZZZS
Part No SW: 1K5 953 507 T HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440MCB0019K
Coding: 0892140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 42C8AFE5D531935FF1-8016
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0036
Serial number: 0007866 FLE 20130306
Coding: 830000
Part No SW: 5C6 920 872 A HW: 5C6 920 872 A
Component: KOMBI H07 0705
Coding: 171B01
VCID: 2B16E24142BB721722-807E
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 28041303270720
Coding: 351003
VCID: 74A4393DD7056DEFB3-8020
Reset counter: 3
Mileage: 190527 km
Date: 2014.03.08
Time: 00:00:23
Component: IMMO H07 0705
VCID: 6A9827458DC1AB1F19-803E
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0006621326
Coding: 0002B5
Shop #: WSC 01383 790 50316
VCID: 5BF67281529BC29792-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1508
Serial number: 00000007806972
Coding: 000290
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 219
67074 - Motors for Central Locking
B122B 01 [009] - Electrical Failure
Fault Frequency: 9
Reset counter: 196
Mileage: 180534 km
Date: 2019.06.21
Time: 14:31:07
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 4
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
VCID: 373ECE3146F3C6F756-8062
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.3 V
PD
Temperature: 33.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0006633546
Coding: 0002B4
VCID: 5CF4719D5795C5AF9B-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1508
Serial number: 00000007719042
Coding: 000290
Reset counter: 219
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 219
Mileage: 120668 km
Date: 2017.09.08
Time: 15:47:26
132610 - Motors for Rear Central Locking
B122C 01 [008] - Electrical Failure
Reset counter: 4
Mileage: 165967 km
Date: 2019.01.18
Time: 12:14:28
132866 - Switch for Rear Central Locking
B122E 29 [008] - Signal Implausible
Reset counter: 4
Mileage: 165967 km
Date: 2019.01.18
Time: 12:14:28
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3N1972880
Coding: 05000400040006
VCID: 2404097D2765BD6FE3-8070
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664389147
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 393AC809B8E7D087A0-806C
End----(Elapsed Time: 01:19, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
