Mk7 Golf Airbag Fault
Garydooney
Ireland
C?ID=319270
Hi I have a strange fault with a 2014 Mk7 Golf. Airbag light has illuminated for no apparent reason and the fault will not clear from the vehicle.
The car has not had any airbags deployed and there is no sign of any water ingress at the airbag control module. The fault will not clear from the vehicle.
Any suggestions on where to look next? Thanks
Thursday,17,October,2019,13:09:58:31012
VIN: WVWZZZAUZEP067027   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP067027   Mileage: 121478km-75482miles
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1.6l TDI   H22 9210
   Revision: 84H22---
   Coding: 01110012034505092000
   Shop #: WSC 00856 210 00000
   ASAM Dataset: EV_ECM16TDI01104L906021M 002013
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F3AE38AB79ADE3F633-807A
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 60164000000899
   Coding: 01FA8AA1142609730377060241CA2580512890C06082A4F3F440F074C002
   VCID: 074A6B2A7FAAA67F8B3-8052
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   Shop #: WSC 00028 028 00025
   VCID: 3536D1E255C6E4EF29F-8060
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011401002012
   Coding: 03000842C24102730BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 79AE1DD2395EC08F8D7-802C
   Component: WWS    131215  042 0551
   Serial number:         131220230243
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M01D23H08M24S30S2
   Coding: 00A8DD
   Serial number: 000000000ZY133360MMD
   Serial number: 00000000000058556193
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 16011476510490
   Coding: 00000300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3634D6EE48C0EFF7205-8062
   Component: AirbagVW20    014 0386
   Serial number: 003MLR02XT3B
   Shop #: WSC 00028 028 00058
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5AF3CA277AEEBFB33-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169677B22011470504
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169676B21011450891
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 501 14
   Serial number: 3576700000043C319E0V
   Subsystem 4 - Part No SW: -----------    HW: 480 001 001 14
   Serial number: 35867000000411057E0I
   Subsystem 5 - Part No SW: -----------    HW: 480 400 901 14
   Serial number: 3516502A913013E5429/
   Subsystem 6 - Part No SW: -----------    HW: 480 400 901 14
   Serial number: 3526502A113013E0911O
   Subsystem 7 - Part No SW: -----------    HW: 480 400 401 14
   Serial number: 35565029B13013E1C342
16712469 - Internal Control Module Memory Check Sum Error
          B2000 00 [137] - -
          [Electronic Control Unit Malfunction]
                    Mileage: 121050 km
                    Date: 2019.10.11
                    Time: 16:02:27
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 23011404400644
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7BA207DA3362F29F9FB-802E
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         252 2210
   Coding: 27A41A002780260001882A01040000
   VCID: 2808089692748907A29-807C
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 19011410800909
   Coding: 030100040B087300EF00005C080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3FDAB3CA67FA2EBFF33-806A
   Component: E221__MFL-DC1  H15 0038
   Serial number: 29130000556950073511
   Coding: 2CFFFF
   Serial number: 8281912203
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000088061983
   Coding: 003002208001048000001000
   VCID: 42DCBA3E140843579CD-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003948458
   Coding: 0D0000
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DEB532110E584F857-8014
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000088223825
   Coding: 003000208001048000801000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003798718
   Coding: 050000
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: V5C02101142683
   Coding: 02730000FF00000021111201002800001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F1A134AC73A4EBFD33-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H51 0022
   Serial number: VWZ8Z9NJ703NX7
End----------(Elapsed Time: 01:15, VBatt start/end: 12.1V/12.1V)-----------
Garydooney
Ireland
C?ID=319270
DTCs like that can be caused by wiring faults such as bad grounds, but if that's what caused it, fixing the wiring fault isn't going to to make the DTC go away.
Garydooney
Ireland
C?ID=319270
Thanks for the help Uwe, time to get the test light and multimeter out :thumbs:
