New Member Barbalatte
barbalatte
Sydney, Australia
Hay guys, I just picked up a VCDS. I’m gona download Hex-V2 shortly.
I currently own an Audi RS3, SQ5 and my brother in law has a Q3 and VW Caddy. So plenty to muck around on!
I would like to change some basic stuff 1st. What’s the best way to start fiddling with this thing?
PetrolDave
Westbury, UK
C?ID=1423
ALWAYS take and save an Auto-Scan before you change anything - VCDS automatically saves scans and logs.
If you're not 100% confident what coding(s) and/or adaptation(s) to change then post a full unedited Auto-Scan and ask away :thumbs:
barbalatte
Sydney, Australia
Guys just plugged the VCDS HEX-V2 in for the 1st time.. I’ve run the test and connection seems to be good.
PORT STATUS: OK
INTERFACE: Found
Type Hex-V2
CAN: OK K1: OK K2: OK
After this it jumps to another screen asking for Firmware update.
“Network Error
Unable to contact server. Check your internet access.
Couldn’t connect to server
Outgoing TCP 11000
Test result Fail”
What’s the problem???
Also I have the SQ5 but it’s not listed under the “Auto-Scan” section. If I use Auto detect I get another error
“Failure to communicate (0)
Please use (Options) > (Test) for further details.
barbalatte
Sydney, Australia
Guys i plugged in my RS3 and it worked.
Please see below.
Any help appreciated. I would like to learn how to reprogram a few things like alarm beep. Strobbing(?) lights etc
Saturday,15,June,2019,20:14:44:63594
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WUAZZZ8V8GA901285   License Plate: Nxxxx
Mileage: 31281km-19437mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 52 55 5F
          6C BB BC
VIN: WUAZZZ8V8GA901285   Mileage: 31281km-19437miles
Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404     HW: 07K 907 309 C
   Component: 2.5l R5/4V TF H52 0005
   Revision: NKH52---
   Coding: 12250032252601033620
   Shop #: WSC 29779 002 1048576
   ASAM Dataset: EV_ECM25TFS0118V0907404 001006
   ROD: EV_ECM25TFS0118V0907404.rod
   VCID: 76B51A0DF848BB17E09-8022
   Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5210
   Revision: 00H10V01
   VCID: 290F01717976A4EFBDB-807C
   Part No SW: 8V0 907 379     HW: 8V0 907 379
   Component: ESC           H42 0020
   Revision: 00000000    Serial number: 61345000000176
   Coding: 999CF08DBA9915AA4093086C4396920644990F5DA80210C2496022
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061003
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 015F79D1A1868CAFC5B-8054
   Revision: 00021000    Serial number: 0370138548
   Coding: 030C0C
   VCID: 3A2DCE3D8CD01F77C41-806E
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000674672
   Coding: 03100015110000001000000000001400
   VCID: 3333E319ABBAEE3F077-8066
   Serial number: 276884B7000000000001
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0173
   Serial number: 01061516700117
   Coding: 07151C46C24106FD03844004B31C07A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F61F199B6C4EF9DB-805C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150522  042 0580
   Serial number:         150616233857
   Coding: 0A47F7
   Serial number: 24038408
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 30 03 2015  00000515
   Serial number: 000000000ZY151461H0K
   Serial number: 00000000000032761267
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000D2SKR00000
   Coding: 901E00
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [008] - No Release by Immobilizer
                    Fault Frequency: 45
                    Reset counter: 248
                    Mileage: 29348 km
                    Date: 2019.03.21
                    Time: 15:32:12
   Revision: --------    Serial number: 39391517006018
   Coding: 0030150011
   VCID: 43D3B3D9FB1A5EBF977-8016
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       110615001
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   Component: AirbagVW20    012 0361
   Serial number: 003M2R0VZTS5
   Coding: 98CCC000008000005C54000000C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4BC39BF9D34A96FF6F7-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 306 15
   Serial number: 35767000000B6C21351Q
   Subsystem 2 - Part No SW: -----------    HW: 480 002 306 15
   Serial number: 3586700000077CD0351Y
   Subsystem 3 - Part No SW: -----------    HW: 480 401 606 15
   Serial number: 35165029F1B5A871C13J
   Subsystem 4 - Part No SW: -----------    HW: 480 401 606 15
   Serial number: 3526502C31B5A870B218
   Subsystem 5 - Part No SW: -----------    HW: 480 402 705 15
   Serial number: 3556502C51A14CC3E29P
   Part No SW: 8V0 953 521 FB    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 19061504220345
   Coding: A418
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 7F5BFF29D772FA5FB3F-802A
   Part No SW: 8V0 920 871 L    HW: 8V0 920 871 L
   Component: KOMBI         H02 6420
   Coding: 27AD081A3B8800080104EA001000000000000000
   Shop #: WSC 12345 123 61029
   VCID: 45D7ADC1F52E608FB93-8010
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003635673
   Coding: 030100043F0860005B000268B80B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75B71D01E54EB00FE93-8020
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 04 04 2015  E0012621
   Subsystem 3 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9041
   Serial number: 3513796803
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00026.03.15
   Coding: 0601
   Revision: 00000000    Serial number: 15000164676005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E005AEB4E9071ED-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H05 0080
   Serial number: 0369838358
   Coding: 030312
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3829D435B2DC0D67325-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0080
   Serial number: 0370215124
   Coding: 030312
   Serial number: 090615BF805645
   Coding: 005D1A205C01040000001002
   Coding: 8103
   VCID: 372BD709BFC2021F3BF-8062
   Serial number: 270515BEQ18337
   Coding: 005D12205E01040000001002
   VCID: 42DDB6DDE40057B79C1-8016
   Coding: 01A600002B200200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDBBF2997F23A5FF3F-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
   Part No SW: 8V0 035 022     HW: 8V0 035 022
   Component: MU-H-ND-RW    H45 0398
   Serial number: A628F0F7500714
   Coding: 017303080000000021511102000A00002F000326010001005E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 6A8D3E7DBCF06FF7741-803E
   Subsystem 1 - Part No SW: V03 959 801 PQ    HW: -----------
   Component: ROW 2018  --- 0068
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY203E2Q
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000030041500020193
   Component: Gracenote  --- 4006
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 248
                    Mileage: 27388 km
                    Date: 2018.12.14
                    Time: 10:27:55
                    Voltage terminal 30: 13.0 V
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
   Component: MQB RVC Mid   H07 0140
   Coding: 027300010201000300
   ASAM Dataset: EV_2CamSysRearPASE 006016
   ROD: EV_2CamSysRearPASE.rod
   VCID: 3039EC155AACD5277A5-8064
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 170515BEG18131
   Coding: 004D12204001040000001002
   Serial number: 170515BEG18134
End----------(Elapsed Time: 01:41, VBatt start/end: 12.0V/11.9V)-----------
barbalatte
Sydney, Australia
I can’t see an RS3 but I’m suspecting that the A3/S3/RS3 would be all the same. Correct?
Thanks Uwe
Yes, an except for the engine (and possibly the trans), the A3, S3, and RS3 are all essentially the same. The most important thing is that you find stuff for the correct generation of car; yours is the current 8V chassis. Prior to that, there was the 8P chassis, and before that, the 8L chassis. In some cases, the model year also makes a difference; BCMs tend to change mid-way through the production life of a chassis.
DV52
C?ID=194404
Thanks Uwe
G'day cobber!!! sounds like you are where I was after my first purchase of a VCDS cable -lots of stuff to learn and lots of discoveries. I'm sure that you will have a heap of fun, but try to make a few errors on the way - it's by far the best learning environment!!
Uwe's link is a great reference facility and sites like these (including the brilliant on-line VCDS manual HERE) are real useful. But if you need some specific questions answered - there is an absolutely awesome experience base waiting behind the responses on this forum.
And, my experience has been that even (my) not-so-intelligent questions are answered with due-consideration and sage empathy.
PS: RS3 ? Very nice!! I don't believe that RS3s travel south of Sydney into the bad-lands of Victoria!!;)
barbalatte
Sydney, Australia
I’ve just tested the line and run a scan as you saw above. What would be your next step?
How about I try something like activating the beep on the remote when you turn the alarm on. Hopefully not too difficult.
barbalatte
Sydney, Australia
Thanks for the Help Don.
I understand “Select Control Module” bit but I’m a bit wet behind the ears after that.
After selecting it there is a list of modules.
After selecting one of them like “5F-Info Electric” it scans but after that I don’t know what to do.
After Security access I get stuck. I thing from memory it’s 31347?
Dan
DV52
C?ID=194404
^^^ sure - that's a good tweak for starters. The most important thing when facing difficulties with VCDS is to remember why the book "Hitch Hiker's Guide to the Galaxy" sold so well. As Douglas Adams wrote with such simplistic eloquence - because it had the words "Don't Panic" in big bold letters on the front page. The only time that I do this is when Uwe tells me to panic!!! :cool:
Here's a very, very, very unofficial suggestion as to how to proceed!
After you have fired-up the VCDS software, press select on the "Select Control Module" part of "VCDS:Main screen" -see the top line RHS of the screen for these words. I like to think of this screen as being the front gate to the housing estate that is the CAN network for my car.
After you do this, the RT software loads the control modules in your car that have successfully reported as being installed.
Then select 09-Cent. Elect. module - This is one of the modules and it's sometimes called the BCM (hover your cursor over the word to see what it means) on this forum. The "09" means that the BCM lives @ address hex09 on the CAN bus - which is a geeky way of numbering modules (Mr. Google will tell you more about hexadecimal numbering if you have an interest).
After you do this, you will be presented with the "Open Controller" screen for the BCM. To continue my analogy, I like to think of this screen as being one of the homes in the housing estate - in this case, the particular house has the street address "hex09". Again, in my imagination I liken each of the boxes in the Open Controller screen akin to rooms in my BCM house.
An important room is the one that has the label "Security Access - 16" on the door (I don't know what "16" means, but I suspect that it's part of the standards nomenclature for OBD - in which case it's way too arcane for my feeble brain and I just don't care).
In their infinite wisdom, the sage boffins at the Audi factory have "locked-out" the ability for making some changes to these modules by requiring a security access code (called SA in this forum - hover your cursor over the word). Lots of adaptation channels are locked-out in this fashion
So, to unlock the module for the particular changes that are needed for this tweak, you will need to select "Security Access - 16".
After you do this, you will be presented with a screen that invites you to enter a SA. Now, SA s for new modules are as scarce as rocking-horse shit because they tend to be closely kept secrets by Audi. However, by various means known only to the wizened troglodytes that work tirelessly for us VCDS users in the bowels of RT's HQ, some SA s have been found. I have no idea (and I don't want to know) what nefarious means are employed by RT staff in this endeavor - but SAs are sometimes embedded into the VCDS software and a suggested SA often appears magically in a balloon when you click in the box on this screen.
In any event, the SA for the BCM on your car is now well known - enter the magic number 31347 and then hit the doit!! button. You should be aware that these modules can get very cranky if you enter the wrong SA. You do get a couple of tries, but the module will lock-out for a period of time (measured with the car's ignition turned-on) if you are a recidivist. So, enter the SA carefully!
After you do this, you will return to the Open controller screen, but this time the doors to all of the rooms in the BCM house will be unlocked.
Select "Adaptation - 10" to enter the room that contains the adaptation channels in the BCM house. Now, for your particular BCM, this is a very full room - your BCM contains a large number of adaptation channels (the count can be in excess of 2,000 channels) and the trick to proceeding is to select the correct one. Fortunately those crazy, zany software folk at RT HQ have added a search box on this screen to help us mere mortals navigate the avalanche of adaptation channels that live in this room.
So, your first task is to find the channel called IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln. Note: the name that I'm using here is a little different to the channel name in the instructions that you found from Uwe's reference because the newer RT software now reports adaptation channels with what RT calls "Tags" - which is a string of leading numbers followed by the "old" channel name. Compare my channel name with the name in your instruction to see the newer convention for RT's current naming protocol (this has only happened for adaptation channel names)
Tags are good because all you need do to find the correct channel is to enter the Tag number - just the last part of the Tag number is necessary, so type in "ENG116666" into the search box (hmm.... just ignore the number-of-the-beast in this Tag - I'm sure that it's not a portent for the success of your first tweak)
After you have done this, click on the down-arrow immediately above the search box and you should see the correct adaptation channel displayed - select this channel
You should now be presented with a screen for this particular channel showing the "stored value" and another box called "new value". Click on this second box to see the permissible values for this channel and select the setting in your instructions. Then hit the "doit!! button. The VCDS software then does some secret stuff and eventually the setting that you selected magically appears in the "stored value" box to confirm the change that you made. I normally just stare in sheer wonderment at this part of the process and I contemplate what other secret information of mine is being uploaded onto RT's servers - unbeknown to me (but my therapist keeps cautioning that my conspiracy theories are likely to be unfounded- and I'm sufficiently comforted by this advice to keep using VCDS)
After you do this, you will be returned to the adaptation screen - repeat the process for the second adaptation channel called IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln (remember to search for "ENG116667" - and again, ignore any hidden meaning in the number-of-the-beast!)
That's it - pending the good auspices of the omnipotent deity that oversees ALL VCDS practices and assuming that the force is with you, the tweak will be completed and your Audi should slavishly bleat every time that you turn-ON/OFF the alarm.
barbalatte
Sydney, Australia
Don you are truely a magnificent man! I appreciate very much you going through that step by step.
I wi try this very soon and let you know how I go.
God speed.
You, sir, have the patience of a saint. :)
barbalatte
Sydney, Australia
Hi Don,
I finally got around to doing this and set both to “Active” but still no beep on lock on the key fob.
I have reset the MMI as well but. I go.
UPDATE: It actually worked. The “Chirp” is very faint.
DV52
C?ID=194404
Hi Don,
Congratulations. Your first tweak and successfully completed! You can now be considered to be a blooded VCDS user (an honorarium sought by many, but attained by just a few who have the wisdom to buy a RT cable/dongle) !! ;)
"very faint"? Not sure why this is - on my A3 8V (the R3 is too sporty for my pedestrian personality), the acknowledgement sound frequently wakes-up the dead - according to my neighbors.
I'm not sure and I'm guessing really, but there is another software switch in the Acknowledgement signals suite of adaptation channels that is used to shorten/lengthen the tone. It may just be that this switch is set to "short" on your car - again, I'm guessing?
So- given your recent elevation from newbie status, I won't re-describe all the steps in this tweak, but navigate to the adaptation channel below (remember- search for "ENG122187"):
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn.
This channel can have 2 x settings: kurtz (meaning "short" in English) and normal. If the setting on your car is the former value, back-out of the screen and enter the magic SA - then change setting to normal
barbalatte
Sydney, Australia
Don,
Thanks again. Yes I remember that one. I changed it to Short from Normal. I will change back when I get the laptop back.
On another note, I went through the list of available changes and there are so many! Ones that I can understand I will attempt to change them but how do I find the meaning to the list? Is there a link I can source to read?
One I was particularly interested in was the Ride Height. It was set at 368mm.
I will get a link for a photo up soon.
Am I correct in assuming you can drop the ride height?
After adjusting the "New Value" here:
https://www.dropbox.com/s/jdeiuwwunabuk50/2019-12-02 18.01.16.jpg?dl=0
I got this screen next...
What does this mean?
https://www.dropbox.com/s/kwabwtkydi6bfm7/2019-12-02 18.02.00.jpg?dl=0
SORRY IN ADVANCE, I’m not sure how to make it smaller.
If Moderators could help out.....
Monday,02,December,2019,16:49:52:63594
Mileage: 34249km-21281mi Repair Order:
6C BB BC
VIN: WUAZZZ8V8GA901285 Mileage: 34249km-21281miles
Revision: NKH52---
Revision: 00H10V01
Coding: 030C0C
Coding: 0A47F7
Coding: 00006C
Light switch:
Sun Roof:
Coding: 901E00
Fault Frequency: 64
Reset counter: 254
Mileage: 31418 km
Date: 2019.06.22
Time: 10:50:40
Coding: 0030150011
Coding: A418
Coding: 0601
Coding: 030312
Coding: 030312
Coding: 8103
Coding: E00100
Coding: E00100
Coding: E00100
Coding: E00100
6697 - Databus
Reset counter: 254
Mileage: 27388 km
Date: 2018.12.14
Time: 10:27:55
End----------(Elapsed Time: 01:44, VBatt start/end: 12.0V/12.0V)-----------
barbalatte
Sydney, Australia
Guys I’m not sure if need to start a new thread or stay here but any help would be appreciated.
Thanks Dan
PetrolDave
Westbury, UK
C?ID=1423
If it's about the same problems on the same car, stay with this thread.
