New car with some fault codes, are they important?
BGB
Norway
C?ID=264865 (?) (NRRT)
Friday the 13th gave me some fault codes I can not understand. Please take a look at the full autoscan and tell me what you see.
Friday,13,May,2016,13:42:11:26833
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: TMBLD9NE6G0158055   License Plate: 1305
Mileage: 1171km-727mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 36 42 44 52 55
          5F 69 6D A5
VIN: TMBLD9NE6G0158055   Mileage: 1171km-727miles
Address 01: Engine (J623-CJSB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 349D001A2476010B1000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM18TFS0208V0906264H 001005
   ROD: EV_ECM18TFS0208V0906264H_AU37.rod
   VCID: 4189240BD0E11B3631-8014
   Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4904
   Revision: 06253104    Serial number: TFK01511201275
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1939AC6B18F163F699-804C
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 63365000000381
   Coding: 1C076A913425A9740077070541C82938562C9500E08294FC16415070E009
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 7AFB93E7FDB788EE30-802E
   Revision: 00021000    Serial number: 0387876734
   Coding: 030C0C
   Shop #: WSC 73430 790 00000
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A7B53E7BD3748EE70-806E
   Part No SW: 5E0 907 044 AA    HW: 5E0 907 044 AA
   Component: Climatronic   H04 1002
   Revision: 00001K07
   Coding: 02010004004101011005004100101000
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 64C7CD9F6F336E1EFA-8030
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580812151430
   Coding: 0C031B76C24722FB4FE44004001C17280C00000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 0305EE038A7DC92663-8056
   Slave 1:
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 151115  041 0570
   Serial number:         151124190742
   Coding: 065DDD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y15M12D12H12M20S32
   Coding: 00885D
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391534302056
   Coding: 0071151151
   Shop #: WSC 73430 790 00063
   ROD: EV_EPHVA18AU3700000_SK37.rod
   VCID: 43852E03CAFD092623-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 26111503211971
   Coding: 000C1E00FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   Part No SW: 3Q0 959 655 AQ    HW: 3Q0 959 655 AQ
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SNPNGKT1$
   Coding: 98FCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 0D11C83BDC398F5605-8058
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34169593B11121550576
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34169592B10121590481
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 000 312 15
   Serial number: 3576U00000009B89B71L
   Subsystem 4 - Part No SW: -----------    HW: 454 000 212 15
   Serial number: 3586U0000008199DA71O
   Subsystem 5 - Part No SW: -----------    HW: 454 802 611 15
   Serial number: 3516R4C884A09000000B
   Subsystem 6 - Part No SW: -----------    HW: 454 802 511 15
   Serial number: 3526RBF56F808000000P
   Subsystem 7 - Part No SW: -----------    HW: 454 801 410 15
   Serial number: 3556VD53BD108000000I
   Part No SW: 5Q0 953 507 JB    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 01121504401142
   Coding: 6410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_SK37.rod
   VCID: 7F0D62F3E695ADC607-802A
   Part No SW: 5E0 920 758 B    HW: 5E0 920 758 B
   Component: KOMBI         324 6422
   Coding: 07A50819ED840008018C6A031000000000000000
   Shop #: WSC 73430 031 12345
   VCID: 2B5566A3426DE166FB-807E
Address 18: Aux. Heat (J364)       Labels: 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 F    HW: 5Q0 963 272 F
   Component: STH-MQB       007 0072
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS_AU37.rod
   VCID: 39794CEBB83143F679-806C
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001279532
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004208070
   Coding: 030100347F085900EB00225E1E0F00010001050000000000000000000000
   Shop #: WSC 73430 790 12345
   ROD: EV_GatewLear.rod
   VCID: 79F98CEBF8B183F639-802C
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D2684251115
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001512120263
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00007.11.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4A9B0327EDD7D86EE0-801E
   Revision: 00000000    Serial number: 15000254787001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 34677DDF9F53BE9EAA-8060
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OKA14066
   Coding: 001000000000010001A081808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: 3B7556E3B20D71E66B-806E
   Serial number: 0000178756556
   Coding: 00110920DE00048000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 479D3A13FEC52506FF-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000008291766
   Coding: 010200
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 9103
   ROD: EV_SteerAssisMQB.rod
   VCID: 44872D1FCFF30E1E1A-8010
   Serial number: 0000178905610
   Coding: 00110120DE00048000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 46833717F9CF3C0E04-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000008277538
   Coding: 190200
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [008] - Electrical Failure
                    Reset counter: 172
                    Mileage: 1001 km
                    Date: 2016.04.26
                    Time: 23:07:21
   Coding: 03EA00003F010000
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 408F210FDBEB123E3E-8014
   Coding: 3E0000
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 B    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0318
   Serial number: A676K0FB005175
   Coding: 037342010000000011111202008800002F0002F401208100BE
   VCID: 2541909B2489D7162D-8070
   Media Player Position 1:
   Radio Tuner - Digital:
   Subsystem 2 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H61 0031
   Serial number: SKZ8Z9RW800SU7
   Engine Control Module 2:
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Seat Adjustment Driver Side:
   Subsystem 4 - Part No SW: V03 959 801 JK    HW: -----------
   Component: ECE 2016  --- 0134
   Air Conditioning Compressor:
   Diesel Pump Control Unit:
   Door Electronics Driver Side:
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Brake Assistance:
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Interior Monitoring:
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Sound System:
   Door Electronics Rear Left:
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: -----------    HW: -----------
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1012
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0203
   Revision: 8C001003    Serial number: 0388656291
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_AU37.rod
   VCID: 3E735FF7A11F64CE4C-806A
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 5E0 959 107 A    HW: 5E0 959 107
   Component: HDSG-Modul    H01 0746
   Revision: 42001001    Serial number: 317501780
   Coding: 1233074003
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 2A5B63A74D97F86E00-807E
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000466941
   Coding: 0101010001030308000400000100000101
   ROD: EV_MFKBoschAU370_AU37.rod
   VCID: 3C7755FFB70376DE62-8068
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 194
                    Mileage: 839 km
                    Date: 2016.04.19
                    Time: 18:59:28
1123601 - predictive route data
                    Fault Frequency: 21
                    Reset counter: 191
                    Mileage: 814 km
                    Date: 2016.04.15
                    Time: 16:21:31
End-------------------------(Elapsed Time: 05:57)--------------------------
The only one I find worrisome at all is the one in 02-Auto Trans.
Did you try cranking starter, with the key in anything other than park or neutral....... inducing the code?
Clear the DTC's and see if they come back............
BGB
Norway
I believe I did once when the start/stop function turned the car off in my yard while I took my seatbelt of, the start/stop system said "start the car manually" (since belt was of) and then I tried with gear lever in D. This has happened to me before but never left a fault code.
I googled a bit and and found this thread: http://forums.ross-tech.com/showthread.php?3567-10763-Starter-Enable-from-Selector-Lever-Sensor-System
BGB
Norway
A gentleman at the British Skoda forum Briskoda says this:
Second one is to do with selecting Reverse on a DSG starts the engine again if Start/Stop has kicked in. Just about every DSG O3 (O3= Skoda Octavia 3) I have seen has this logged at some point.
BGB
Norway
So I still get the 1123601 - predictive route data and I now know that it has nothing to do with the visibility of the ACC, also there are now two fault codes where it used to be only one. Would really appreciate if someone could shed some light on this issue.
Could it have something to do with the traffic sign recognition? When I cleared the DTCs a beep and a message saying something about the TSR came up in the display.
Todays auto-scan:
Sunday,29,May,2016,13:55:18:26833
VIN: TMBLD9NE6G0158055   License Plate: IDAG
Mileage: 1436km-892mi   Repair Order:
          5F 69 6D A5
VIN: TMBLD9NE6G0158055   Mileage: 1436km-892miles
   Revision: --H13---
   Coding: 030C0C
   Revision: 00001K07
   Slave 1:
   Coding: 065DDD
   Slave 2:
   Coding: 00885D
   Coding: 0071151151
   Coding: 333135
   Coding: 333135
   Coding: 6410
   Coding: 9309
   Coding: 0001
   Coding: 010200
   Coding: 9103
   Coding: 190200
                    Reset counter: 172
                    Mileage: 1001 km
                    Date: 2016.04.26
                    Time: 23:07:21
   Coding: 3E0000
   Coding: 3E0000
   Brake Assistance:
   Sound System:
   Coding: 1233074003
                    Reset counter: 203
                    Mileage: 1405 km
                    Date: 2016.05.28
                    Time: 12:14:32
                    Reset counter: 203
                    Mileage: 1227 km
                    Date: 2016.05.28
                    Time: 08:47:30
BGB
Norway
So this is where I´m now: I sent the fault code to my Skoda Norway dealership and the head of the service department said after some research that there is some issues with the ACC radar and the factory is working on a solution, exactly what it is they dont know.
I will post more info as soon as I get it.
BGB
Norway
A software update is now ready for this issue. Contact your local dealership if you`re experience this issue.
The reason for this fault is the camera "reading" the speed signs wrong.
BGB
Norway
I have to correct myself as my dealership was kind of vague when explaining this problem.
The problem was never the traffic sign recognizer (camera on top of the front window) but the front assist which uses the same radar as the acc. When the front assist scans the road in front of the car while driving it has trouble when "seeing" things in the roadside such as signs, poles etc. This update fixes this issue. I´m terrible sorry for the first wrong answer.
CZR
Romania
C?ID=243172
Did you do that update ? Did it fix the issue ? A scan would be helpful if yes. This is a pretty common problem.
Thank you.
esteticu
Romania
C?ID=520918
So can we guess what the updated firmware was? Most likely in Address 13: Auto Dist. Reg (J428) / Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F?
I have the same error after MIB2.5 retrofit + A5 camera flash to 5Q0 980 653 G (had 653 F before)
The difference is that my ACC is older:
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 16111403270023 Dataset Number: 5g0114v____ 1020
   Coding: 001C1F00FE0739
   VCID: 382240C2C2DDD38AF7B-806D
I should probably directly upgrade to 3Q0 radar anyway....
