2020 VW Touareg 3.0TDi CR 286PS DENA
maros4341
Slovakia
C?ID=8477
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 29 2B 36 39 42 44 46 52 5F 6D
          74 81 82 84 A5 AC BB BC CA CB D6 D7 DE
VIN: WVGZZZCRZLD004463   Mileage: 8940km-5555miles
84-Night Vision -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: OK 0000
Address 01: Engine (J623-DENA)       Labels: None
   Part No SW: 760 907 401 G    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---
   Coding: 292A4032036E050334080000000400000000000000000000
   Shop #: WSC 31414 037 00001
   ASAM Dataset: EV_ECM30TDI011760907401G 001002
   ROD: N/A
   VCID: 196E3AA919158C4F2E9-804C
No ASAM data for: "EV_ECM30TDI011760907401G" (VW53)
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 760 927 158 B    HW: 0D5 927 156 N
   Component: 0D5  30TDIRdW H05 1003
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011.rod
   VCID: 1F1A14B10731E27FD0D-804A
   Part No SW: 4M6 907 379 AC    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0856
   Coding: 1DA732B730A20B9A96A24897188056E6E93AE1B84C0CD06912186A67975C87
   ASAM Dataset: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_VW53.rod
   VCID: 7EA40935E07B4B77BBB-802A
468224 - Airbag Control Module
          U1243 00 [040] - Implausible Message
          [Signal_AB_Gurtschloss_FA_invalid_(0_or_1)_or_PDU_Airbag_02_not_received_correctly_(combination_of_Timeout:_CS:_AC)]
                    Mileage: 8859 km
                    Date: 2019.12.03
                    Time: 10:08:27
467968 - Databus
          U1122 00 [040] - Implausible Message
          [Signal_AB_Gurtschloss_FA_invalid_(0_or_1)]
                    Mileage: 8832 km
                    Date: 2019.12.03
                    Time: 07:47:33
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000382317095
   Coding: 0118B8000000A88188000101210100008900000707008F8F00000000015000
   Shop #: WSC 31414 050 00001
   ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
   VCID: 3D26CE39ADFD906FE21-8068
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ800122071940258343
   Coding: BF2F00
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Coding: 07501140E13B0000074D170858AF8040800B30100000009301100A003B24F6019BC5013B0256C1170000010000D1281B1C02040144010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016_VW53.rod
   VCID: 7DA60E39ED7D506FA21-8028
   Subsystem 1 - Part No SW: 761 955 113     HW: 761 955 113
   Component: WIPER 170719  011 0420
   Serial number: VZ1SKA 1001103170719
   Serial number: 23373975X81A955555A0
   Coding: 0200FE
   Light switch:
   Subsystem 3 - Part No SW: 761 941 633     HW: 761 941 633
   Component: E1 - LTM  H06 0054
   Serial number: 14S02.08.1900140247
   Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
   Serial number: GX1CE109051920810455
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 760 947 105 S    HW: 760 947 105 S
   Component: Dachelektroni  H32 0057
   Serial number: 00000784840000000000
   Part No SW: 760 907 561 C    HW: 760 907 561
   Component: LRR4R         H04 0333
   Coding: 32657FC278000400000020A000000010051246484401009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 1C6023BD1627F96735F-8048
2095 - Databus
          [FAULT_SEATBELT_FAIL]
                    Reset counter: 194
                    Mileage: 8832 km
                    Date: 2019.12.03
                    Time: 07:47:32
                    Control Module temperature: 3 °C
                    Voltage terminal 15: 11.2 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
                    Steering_angle-Data: 52.300 °
                    Yaw_rate-Data: -0.001 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.234 °
                    Misalignment angle: horiz: fast algorithm: 0.260 °
                    Congestion pilot: status: OFF
                    Outside air temperature: -0.50 °C
                    Sensor blindness: radar: no blindness detected
   Part No SW: 4M0 959 655 J    HW: 4M0 959 655 J
   Component: AirbagVW31    H07 2720
   Serial number: 003YQM0212W-
   Coding: 88CCC0C00C800000585400EF301D41A80065
   Shop #: WSC 31414 031 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 42DCBDC5D403EF979F3-8016
   Subsystem 1 - Part No SW: -----------    HW: 480 002 307 19
   Serial number: 35700000000C40719E3M
   Subsystem 2 - Part No SW: -----------    HW: 480 002 907 19
   Serial number: 35800000000E99597E30
   Subsystem 3 - Part No SW: -----------    HW: 480 032 607 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351001C24B988AB09CFZ
   Subsystem 4 - Part No SW: -----------    HW: 480 032 607 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352001C244ECC4B10C6J
   Subsystem 5 - Part No SW: -----------    HW: 480 030 606 19
   Component: FrontSensor_D  002 0189
   Serial number: 355001C20C14E6211A81
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 030 606 19
   Component: FrontSensor_P  002 0189
   Serial number: 356001C20C1CEA20B97L
   Pedestrian Protection Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 031 807 19
   Component: PedP_Sensor_D  002 014A
   Serial number: 228001C2462845E04952
   Subsystem 8 - Part No SW: -----------    HW: 480 031 807 19
   Component: PedP_Sensor_P  002 014A
   Serial number: 229001C2462888B14F4D
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 033 107 19
   Component: PedP_Sensor_C  002 014A
   Serial number: 230001C1C321C1E128A%
   Subsystem 10 - Part No SW: -----------    HW: 480 001 806 19
   Serial number: I0M00000000F2DA8CCB.
   Subsystem 11 - Part No SW: -----------    HW: 480 001 806 19
   Serial number: I0N0000000017DA8CCBT
9444359 - Safety belt switch - driver side
          B101C 07 [008] - Mechanical Failure
                    Reset counter: 194
                    Mileage: 8832 km
                    Date: 2019.12.02
                    Time: 20:36:23
   Part No SW: 760 953 507 B    HW: 760 953 507 B
   Component: Lenks.Modul   H03 0006
   ROD: EV_SMLSKLOAU736_VW53.rod
   Part No SW: 761 920 790 A    HW: 761 920 790 A
   Component: FBenRDW       H12 0208
   Coding: 85A431E27F84000800A86B22B0F04808F40000A0
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 1A6C25A51C138757273-804E
   Operating Unit Drive Mode Selection:
   Subsystem 1 - Part No SW: 760 927 531 G    HW: 760 927 531 G
   Component: E881 BedieFPA  001 0460
   Serial number: 000000091171SGG000ET
   Level control system control head:
   Subsystem 2 - Part No SW: 760 927 135 B    HW: 760 927 135 B
   Component: E281 BedieNiv  001 0110
   Serial number: 000000091171SG40015H
   Part No SW: 4N2 907 468 BB    HW: 4N2 907 468 AB
   Component: Gateway       H16 0052
   Revision: BD000001    Serial number: 018BD768619726
   Coding: 0701000300800E407F07000000DB05325A9E00071C000000037D078E10000100
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   VCID: 7AAC0525FC536757873-802E
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190001557290089273
   Coding: 2FFFFF
   Serial number: 1365241905
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 3F0 907 155     HW: 3F0 907 155
   Component: U13  DCAC  H14 0017
   Serial number: 00000000000003009784
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H07 0022
   ASAM Dataset: EV_LCMLeftCONTIAU426 001009
   ROD: EV_LCMLeftCONTIAU426_VW53.rod
   VCID: 3038E70D6AAF6D07797-8064
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000210219002
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3430EB1D9EB751271DF-8060
   Component: MEM-FS        009 0044
   Serial number: 00000382302874
   Coding: 011898000000A08188000101210100008900000707008F8F00000000015000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ800123071940258192
   Coding: BF2F00
Address 39: Right Light (J1023)       Labels: None
   ASAM Dataset: EV_LCMRightCONTIAU426 001009
   Part No SW: 4M1 959 593 J    HW: 4M1 959 593 D
   Component: TSG FS002 0421
   Serial number: YE007SFJ16404
   Coding: 003E9A00D000040000003082
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO_VW53.rod
   VCID: 44D0BBDDCE17E1A7ADF-8010
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Coding: B2000101000100
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323CED0564A35F170F3-8066
   Part No SW: 4N0 907 064 DP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H15 0202
   Coding: 01342C002FB000487309A0047C00080203004004044706502F0400000508803F001F31D4010001
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_VW53.rod
   VCID: 005877CD9A8F3D87C97-8054
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY191800HJH
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000495317
   Heated Windshield Control Module:
   Subsystem 4 - Part No SW: 4N0 907 133 A    HW: 4N0 907 133 A
   Component: J505-FSH  H20 0600
   Serial number: 19207002514011120081
   Subsystem 5 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11849531
   Rear Spoiler Adjustment:
65760 - Databus
          [Airbag control module: error value in signal AB_Gurtschloss_FA]
                    Reset counter: 194
                    Mileage: 8832 km
                    Date: 2019.12.03
                    Time: 07:47:38
                    Supply voltages-Supply voltage: Terminal 30: 15.227 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 15.123 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 15.074 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                    general_additional_freeze_frame-coprocessor_spi_status: 00000000
                    general_additional_freeze_frame-dataflash_status: 00000000
                    general_additional_freeze_frame-interior_temperature: -50.0 °C
                    general_additional_freeze_frame-Operating_Status: 00000000 00000000
                    general_additional_freeze_frame-production_mode: not active
                    general_additional_freeze_frame-reset_cause: 00000000
                    general_additional_freeze_frame-Reset_counter: 0
                    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 94 02 78
                    general_additional_freeze_frame-Transport_Mode: not active
                    general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
   Part No SW: 4M1 959 592 J    HW: 4M1 959 592 D
   Component: TSG BFS002 0421
   Serial number: YE007SFO01837
   Coding: 003E9A00D000040000003080
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 43D2B8C1CB19E69F945-8016
   Part No SW: 760 035 064 A    HW: 760 035 064 A
   Component: MU-H-LN-EU    049 2648
   Coding: 02350601FF00000043110001000808301F0100E401A004009F
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_VW53.rod
   VCID: 1078478DCAEF4D07597-8044
   Subsystem 1 - Part No SW: 761 919 618     HW: 761 919 618
   Component: ABT_Prem_L  H40 5211
   Serial number: VWZ6ZGW2190177
   Subsystem 2 - Part No: V03 959 805 HD
   Component: MIB2P_EU_Q218  0294
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 761 927 341     HW: 761 927 341
   Component: VW536LLB  H06 0109
   Serial number: 2019061300000128
   Media socket:
   Subsystem 5 - Part No SW: 5G0 035 953 D    HW: 0
H08 0014
   Part No SW: 4M0 959 107 E    HW: 4M0 959 107 C
   Component: HDSG-Modul    H14 0171
   Revision: --------    Serial number: A2-C756-6240-7
   Coding: 1778
   ROD: EV_DeckLidCONTIAU736_VW53.rod
   VCID: 3536D61995CD482F2A1-8060
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 S    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H37 1253
   Serial number: 2407190273
   Coding: 30505138F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 49CEAAE9E9353CCF5E9-801C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130670313
   Coding: 303030
   Part No SW: 761 713 041 B    HW: 4M1 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19071253792172
   ROD: EV_GSMWaehlZFAU736.rod
   Part No SW: 761 919 608 A    HW: 761 919 608 A
   Component: HeadupDisplay H13 0197
   Coding: DF40C0
   ASAM Dataset: EV_HeadUpDisplAU65X 001010
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 2018174D3A4FDD87E97-8074
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 760 907 547 A    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H13 0084
   Serial number: 645976300201931
   Coding: 200111
   ASAM Dataset: EV_NightVisioG3AUTOLVW536 001003
   ROD: EV_NightVisioG3AUTOLVW536.rod
   VCID: 1E6429B5003BEB77DBB-804A
   Camera For Night Vision System:
   Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H06 0007
   Serial number: 639589400B1917100374
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AL    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0293
   Coding: 04028400000000000008060000D0C42C589F5200000000000000000000000000000000000000000000000000000000000000000000000000000040000000000000001C90000000700000004000000000008040000020
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_VW53.rod
   VCID: 094E6AE9A9B57CCF9E9-805C
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 7
                    Reset counter: 194
                    Mileage: 8832 km
                    Date: 2019.12.03
                    Time: 07:47:33
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_VW53.rod
   Part No SW: 4M1 959 595 J    HW: 4M1 959 595 D
   Component: TSG HFS004 0421
   Serial number: YE007SFL00144
   Coding: 003E92000000040000013080
   Shop #: WSC 31414 045 00001
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   VCID: 46D4A1D5F82BD3B7B3B-8012
   Component: TSG HBFS004 0421
   Serial number: YE007SFL00913
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
   Part No SW: 4K0 907 594 AA    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 488040753602
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
   VCID: 73B22801DB39161FC45-8026
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_
   Coding: 42240A00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 6FBA2471B71132FF20D-803A
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 AA    HW: 7PP 941 592 A
   Component: LED1L         H09 4002
   ROD: EV_LEDModLeftMELCOAU736_VW41.rod
   VCID: 176A3C91EF019A3F18D-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H09 4002
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   ASAM Dataset: EV_Charg1MobilDevicAU651 004001
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 231218412B59C69FF45-8076
Momen Al-Himony
Palestine
C?ID=334956
Hello sir,
Do you find the problem??
I have almost like this problem, what is the problem with your vw?.
regards
