2005 Audi A8L Rear Pad Warning
Jack88
California, USA
C?ID=242298
Hello! I've tried the procedure a couple ways, followed the video exactly, and so on, but I cannot get the rear pad thickness warning to go away. I've probably tried it a couple dozen times and that damn chime and little light still haunts me. Someone try to help me figure this out before I go to the only solution I know to shut off this damn light and set the car on fire. :banghead:
Did you measure the thickness of the new pads? What was the measurement? What number did you put in the Adaptation channel?
Jack88
California, USA
C?ID=242298
I don't know, the brake job was done about 9 months ago by my brother when he owned the car, so I've been putting in 10 for the measurement, figuring there is probably at least that much left. The car will need rotors next time, so I'm not to worried about guessing wrong. He could never figure out the reset, and I recently got the car from him.
mattylondon
United Kingdom
C?ID=219022
Can you also post a channel map for measuring and adaptations please. Also, let the car calibrate by parking in P, leave EPB off and shut the car down. The caliper motors should wind in and out a few times.... and they're noisy on the D3 A8.
OK, so you're guessing. ;)
Jack88
California, USA
C?ID=242298
Okay, I've let the car do it's parking brake adaption on its own and forcing it, and in either case, it makes no difference. Oddly, I can clear the codes and none are reported, at least at first, even if the pad warning light is on. I have a scan from a few months ago, when I had to swap out a strut and some fog lights and some other nonsense, it's a different story as to what's with the time gap. At the time of the scan, the brake issue was present and I killed the battery a couple times due to a pair of inadequate chargers.
Wednesday,20,December,2017,07:11:33:10235
VCDS Version: 17.8.1.0 (x64)
VIN: WAUML44E35N008073   License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 34 36 37 38 42 46 47
          4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUML44E35N008073   Mileage: 239750km-148973miles
0E-Media Player 1 -- Status: Malfunction 0010
Address 01: Engine        Labels: 077-910-560-BFM.clb
   Part No SW: 4E0 910 560 J    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: --------    Serial number: AUX3Z0D8749686
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 285FC4079BD4E006F9-807C
29698 - Please Check Fault Codes in Comfort System Control Module (J393)
            U1002 - 008 -  - Intermittent
   Part No SW: 4E0 910 156 S    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0020
   Revision: --H01---    Serial number:        0044151
   VCID: 326B266FAD089AD657-8066
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H50 0510
   Coding: 0007597
   Shop #: WSC 12345 000 00000
   VCID: 224BD62FFDE80A56A7-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 D
   Component:     FBS AUDID3  H04 0140
   Revision: 01404004    Serial number: AUX3Z0D8749686
   Coding: 0410624
   Shop #: WSC 02311 785 00200
   VCID: 58BFB4C7EB34908689-800C
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940448
   Shop #: WSC 19224 444 83967
   VCID: 2447D037E7FC0466D5-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 732 T    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 300E9087601052
   Coding: 0000003
   VCID: 3365236B521293DE5C-8066
   Subsystem 1 - Part No: 4E0 910 609 A
   Component: Bedienteil MMI  H42 0020
   Subsystem 2 - Serial number: 317IZ047537458
   Subsystem 3 - Serial number: 7414.09.0400000000217B0134ÿ
   Subsystem 4 - Serial number: 7B0134ÿ
   Part No SW: 4E0 910 043 A    HW: 4E0 820 043 A
   Component: KLIMAAUTOMAT    016 0340
   Revision: 00000027    Serial number: 00000000052893
   Coding: 1085761
   VCID: 1B35EBCBDA823B9E64-804E
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 J    HW: 4E0 907 279 J
   Component: ILM Fahrer      H12 0190
   Coding: 0123124
   VCID: 2F6D2F1BBE3AB73E38-807A
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H50 0400
   Coding: 00000035
   Shop #: WSC 02313
   Coding: 00152621
   Shop #: WSC 02313
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 212
                    Mileage: 239754 km
                    Date: 2017.12.20
                    Time: 09:58:13
01024 - Rain Sensor (G213)
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 46
                    Reset counter: 210
                    Mileage: 237287 km
                    Date: 2004.03.25
                    Time: 10:15:57
                    Reset counter: 212
                    Mileage: 239754 km
                    Date: 2017.12.20
                    Time: 09:58:14
Address 0E: Media Player 1        Labels: None
   VCID: 55A1BDF3BC26ADEE92-FFFE
No Faults Found
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Coding: 0012141
   VCID: 65C18D33AC463D6E02-8030
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 950 G    HW: 4E0 920 950 G
   Component: KOMBIINSTR. VDO H49 0210
   Revision: D04         Serial number: AUDID3D8001914
   Coding: 0016104
   Shop #: WSC 12345 123 45725
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B074258003
   Coding: F5D5DF7F30720E00
   VCID: 2D513513B436C52E0A-8078
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 H    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 4480
   Coding: 0010010
01772 - Signal from Level Control Pressure Sensor (G291)
                    Fault Frequency: 7
                    Reset counter: 252
                    Mileage: 239677 km
                    Date: 2017.12.19
                    Time: 11:33:39
01583 - Leak in System Detected
            000 -  -  - Intermittent
                    Reset counter: 252
                    Mileage: 239690 km
                    Date: 2017.12.19
                    Time: 14:19:14
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory FS  H08  0060
   Coding: 4071530
   Shop #: WSC 26110 444 84265
   VCID: 2345D32BE2F2035EAC-8076
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H43 1100
   Revision: 00000000    Serial number: 355HQ047545107
   VCID: 387F14474B74708669-806C
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H02 0090
   Serial number: 00000424400019
   Coding: 0003477
   VCID: 1D31E5D3C49635AE9A-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 B
   Component: Türsteuer.FS BRM002 0060
   Coding: 0028204
   VCID: 204FDC27F3E41846B1-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H04 0040
   Revision: 00400004    Serial number:  W040409070294
   Coding: 0065150
   VCID: 275DC73B96CAEF7EF0-8072
   Component: Heckdeckel   P27H08 0090
   Component: Neigungssensor  H03 0020
02231 - Brake Light Request from ABS Control Module
                    Reset counter: 250
                    Mileage: 239676 km
                    Date: 2017.12.19
                    Time: 10:45:43
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 224 C    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0470
   Revision: Dev_D01     Serial number: 00000000002890
   Coding: 0000016
   VCID: 1E33E2DFC9902EB683-804A
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H09 0040
   Revision:             Serial number: 00000000047730
   Coding: 0010111
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T0EW7E
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
   Component: Türsteuer.BF BRM002 0060
   Coding: 0028204
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000531
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   VCID: 62CB962FBD684A56E7-8036
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 E
   Revision: 00000000    Serial number: 396KR047501135
   VCID: 31692963A80EA1CE2E-8064
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H11 0510
   Revision: 00000000    Serial number: 00000000008176
   Shop #: WSC 26118 444 57572
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  1409140034
   Coding: 344530393135313035412056413031343039313430303334
   Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM002 0060
   Coding: 0028204
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01
   Revision: 00010027    Serial number: 00000700026351
   Coding: 0202230
   VCID: 5FCD9FDB8E1A67BEC8-800A
01477 - System Switched Off
                    Fault Frequency: 27
                    Reset counter: 212
                    Mileage: 239676 km
                    Date: 2017.12.19
                    Time: 10:43:19
                    Temperature: 5.0°C
                    Error Code: 128
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000411050240
   Shop #: WSC 12336 024 394758
   VCID: 34672077571C94E645-8060
   Revision: --H05---    Serial number: 525PA8-J1845BZ
   Coding: 1100601
   Shop #: WSC 98765 666 38384
   VCID: 2541CD33ECC6FD6EC2-8070
03006 - Back-up Camera System not calibrated
                    Reset counter: 207
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: Türsteuer.HR BRM002 0060
   Coding: 0028204
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H12 0020
   Revision: --.--.--    Serial number: 08730425103209
   Coding: 0001208
   VCID: 2149D923F8EE114EBE-8074
   Component: Handyvorb2      H18 1130
   Revision: 00000000    Serial number: 00000005029612
   Coding: 0010900
End-------------------------(Elapsed Time: 03:23)--------------------------
2005
Pad shims to give the spec you want to offset rotor wear?
Advance the stepper motor to where you want the count manually & by removing & compensating for the offset by reset then reinstalling stepper to do the ADP?
Install new rotors and pads and do a total reset?
Calculate the actual value and input in VCDS then do the ADP?
Get a viable battery charger?
Jack88
California, USA
C?ID=242298
My answers in red! I should note that a few times during the procedure, after closing the parking brake for the end of the job, the parking brake was set, so I was unable to follow the procedure since it already was set.
I did aim low when guessing the pad thickness, figuring putting in a falsely low number would trick the computer into thinking there was more to the rotor, which are due to be changed but not urgently
No idea what a stepper motor is!
That really is my last resort, but I'm afraid that even if I did, it will still have the code. Maybe just the rotors?
Could try that, disassemble, measure, and reinput data. I did think that the procedure tricked the car into believing you had done the repair, though.
I've got one now!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Light on, but no relevant codes... this may not be an EPB thing at all. That's what you'd get from a traditional brake pad wear sensor setup going open-circuit, as it would if the brake pads were worn down enough to cut the sensor wire, or if your new brake pad sensor connectors were not plugged in, or your new brake pads didn't have sensors at all. That last one is a pretty easy situation to get into.
I looked at your instrument cluster (address 17) label file, and I see a reference to traditional pad wear monitoring in MVB 121. However, I don't see a way to disable brake pad monitoring via coding in 17, which is usually possible. That's unfortunate. Anyway, I'd have a look under the car to see if there is a mysterious disconnected wire hanging from the car next to both of your rear wheels.
I don't think the rears use pad wear sensors; I believe the EPB module can figure out when the rears are too thin.
However, if the OP is indeed mistaking the pad wear light for the EBP light on the dash, then he needs to have a look at the wiring/circuit to the front pads.
Maybe he could post a picture of the warning light in question?
Jack88
California, USA
C?ID=242298
It looks like below, and it says "Service!" on start up with a single long chime.
Jack88
California, USA
C?ID=242298
Is it? What does the one for rears look like? I was going off of the fact my brother told me it was the rears that had needed doing.
I believe rear pads don't have sensors............didn't Uwe already say that too?
What about fluid level......?
Jack88
California, USA
C?ID=242298
All right, here's the video! Better than a picture. Ignore the dying key battery, that's new and I know I just need to get a new battery for it.
Jack88
California, USA
C?ID=242298
The rears have no sensors as far as I have found, the EPB can tell how much pad there is by how much it has to travel to set. Telling the computer the pad thickness is to give it a setpoint so it can account for rotor thickness. Also, I checked the owner's manual and found no differentiation between needing fronts and rears, it indicates that a shop needs to figure out which it is for.
Or you could go inspect the front pads for being run down and wiring or fluid level.......... :rolleyes:
I agree. I think this is either the front pads and their circuit, or the fluid level and that circuit. Both are simple "got continuity?" checks done directly by the cluster.
Circle with half moons
Yellow usually means pads and red brake fluid, switches.
Jack88
California, USA
C?ID=242298
Okay, I'll look into it in a bit and see what I can find. First, I need to do another scan, if I recall, it does keep coming up with the rear brake code after driving a bit.
