Retrofitted Direct TPMS to a NA Passat TDI 2016, but no car image icon on the cluster
NothernSky
New Member
Mexico
HC402084 (2nd hand?)
So I retrofitted Direct TPMS to VW NAR Passat TDI 2016.
All is working fine, but somehow in the cluster the car icon is not showing up.
Parts:
3AA 907 275 F. Wheel Sensors: Quantity 4 (Should use 3AA 907 275 B but revision F worked for me)
3AA 907 273 D. Antenna: (Also 3AA 907 273 F works but has different tire parametrization not for NA Passat)
8E0 971 934 A. Antenna connector.
3AA 907 538. Antenna support.
000 979 009 E. Cables. Qty 2
3C0 972 741. Grommets.Qty 4
Antenna Connector------------> Gateway (with Extended Can Bus feature)
Pin 1 ---------------------------> Pin 7 Gateway CAN Extended +
Antenna Connector------------> Fuse Panel +
Pin 2 ---------------------------> 10A + Switched Power (I connected to FUSE# 10)
Pin 3 ---------------------------> Pin 17 Gateway CAN Extended -
Antenna Connector------------> Any good ground connection.
Pin 4 ---------------------------> Ground -
VCDS:
19 Address: Gateway add address on the installation list, tick 65.
17 Address: Instruments and tick TPMS Byte 2.
Monday,09,September,2019,21:04:38:32969
VCDS Version: 19.6.1.0 (x64)
VIN: 1VWCV7A3XGC005566   License Plate:
Mileage: 36560km-22717mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 36 3C 42 44 46 47
          4F 52 5F 62 65 72 75 A5
VIN: 1VWCV7A3XGC005566   Mileage: 36560km-22717miles
Address 01: Engine (J623-DEKA)       Labels: None
   Part No SW: 04L 906 016 NP    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 4790
   Revision: 8AH20---
   Coding: 011D0012034410089000
   Shop #: WSC 20200 993 00000
   ASAM Dataset: EV_ECM20TDI01104L906016NP 004003
   ROD: EV_ECM20TDI01104L906016NP.rod
   VCID: 840DADB70F9B566F3D-80D0
   Part No SW: 02E 300 063 J    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4915
   Revision: 06253104    Serial number: 00001507050398
   Shop #: WSC 09003 957 00200
   VCID: 9D3BF8D3443187A712-80C8
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5492200FFA31003EA921F004201F1F01A
   VCID: F5EBC0735C417FE73A-80A0
   Part No SW: 5K0 959 434 F    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1202
   Revision: 00093000    Serial number: 0376496207
   Coding: 130C0C
   VCID: B875094703D3C28FE1-80EC
   Part No SW: 561 907 044 AM    HW: 561 907 044 AM
   Component: Climatronic   H07 0910
   Revision: 00001K04
   Coding: 0050019012
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: E2C18B2FF5CFF85F6F-80B6
   Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
   Component: BCM PQ35 H++  122 0183
   Revision: BN122001
   Coding: EF200E3BD82B08D4098806093400854806F1000645B005B0E4806000BC70
   Shop #: WSC 13385 003 104857
   VCID: FF07225B6E7D35B760-80AA
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 150915 03  37  0059
   Coding: 0038DD
   Part No SW: 1K8 919 475 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0479
   Revision: --------    Serial number: 39411433601309
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00_VW36.rod
   VCID: B9730C4338D9DB871E-80EC
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 13081577031458
   Coding: 01001002FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: B56B007314C13FE7FA-80E0
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM00ZVBX
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW41.rod
   VCID: E3CF8E2BEAD5F15764-80B6
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003GT6O
   Coding: 30324A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 708 15
   Serial number: 35700000000EC109E51S
   Subsystem 3 - Part No SW: -----------    HW: 480 000 708 15
   Serial number: 3580000000075664F51M
   Subsystem 4 - Part No SW: -----------    HW: 480 022 108 15
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B91BE60638665
   Subsystem 5 - Part No SW: -----------    HW: 480 022 408 15
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001C31BE606337A1
   Subsystem 6 - Part No SW: -----------    HW: 480 022 807 15
   Component: FrontSensor_D  000 0189
   Serial number: 3550001B11B2C525773
   Subsystem 7 - Part No SW: -----------    HW: 480 020 508 15
   Component: FrontSensor_P  000 0189
   Serial number: 3560001B719BDF23375G
   Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20150727300040
   Coding: 2012C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 8005A1A71B834A4F19-80D4
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 3461501192300065AE2B
   Coding: 2D0000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 981 A    HW: 561 920 981 A
   Component: KOMBI         H04 1008
   Coding: 231E090000
   VCID: 9A31F3CF9D1FF09FF7-80CE
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 09091503000428
   Coding: 461010
   VCID: F2E1FB6F2D2F68DF1F-80A6
   Component: IMMO          H04 1008
   Coding: 000007
   VCID: EAD1E30F0DFFA01FA7-80BE
   Revision: 00000000    Serial number: 15000178363007
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: B0653167EBA31ACFA9-80E4
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0183
   Revision: AA000000    Serial number: 00000159150901
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: A241CB2FBD4FB85F2F-80F6
Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
   Component: HRE_Master    H11 0071
   Serial number: 0377246863
   Coding: 02011102
   ROD: EV_HREntryHella_VW27.rod
   VCID: BC7D155737EBEEAF05-80E8
No ASAM data for: "EV_HREntryHella" (VW41)
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0009951391
   Coding: 3415FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 9E39FFDF81379CBF0B-80CA
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630150928214210
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 313    3501
   Revision: 00H22000
   VCID: B9730C43F0D9DB871E-80EC
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0069297
   VCID: A855D907D373520F71-80FC
   Component: EZE_2         H56 1663
   Coding: 01030108
   VCID: EFE7F21B3E1D4537F0-80BA
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011501401389
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  001 0002
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0009956559
   Coding: 3415FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 9F47C2DB863D95B700-80CA
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631150928144824
   Coding: 800000
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H21 0245
   Serial number: VWZAZ2R0379323
   Coding: 02140102AA00000051220003001808001F0100D400200105C6
   Shop #: WSC 13385 003 1048576
   ROD: EV_MUStd4CTSAT_VW41.rod
   Subsystem 1 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 30000000014146
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140542
   Coding: 02140102C24232007F1606000000
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 942D9DF77FFBC6EFAD-80C0
Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0023
   Serial number: 070715null0565
   Coding: 000401010001020100201346C0804000D0000E230020
   ROD: EV_MFKBoschMQBB_001_VW27.rod
   VCID: B7770A7B0ECDCDF7E8-80E2
No ASAM data for: "EV_MFKBoschMQBB" (VW41)
End-------------------------(Elapsed Time: 04:03)--------------------------
Not showing the car icon :cry:
NothernSky
New Member
Mexico
It should look like something like this: (Courtesy of Kufatec)
grant@gendan
The clusters look different. Does your cluster support this graphic? Sometimes only the higher spec clusters show all the graphics and others have a more basic screen.
NothernSky
New Member
Mexico
The color cluster is from a North American Passat TDI Highline (SEL) 2016.
I wonder same as you, but even the black/white Jetta/Polo cluster has them when they retrofit :banghead: Maybe a tweak on the instrument cluster recode to a Passat CC/Tiguan maybe :confused:
Polo
Tiguan
Spacewalker
Poland
C?ID=159607
not all cluster SW support that unfortunatelly
you can try edit eeprom to change logo , and then maybe you will have logo on that screen
