DISABLE DAY LIGHT VW TRANPORTER T6.1 MY2020
ARSHAD
Réunion
C?ID=291393
Hello
This is my new van and the central electric module is not yet supported for coding.
I would like to disable Daylight .
Many thanks
Sunday,07,June,2020,09:06:49:29185
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WV1ZZZ7HZLH001432 License Plate:
Address 09: Cent. Elect.
Control Module Part Number: 2Q5 937 090
Component and/or Version: BCM T6PA Std+ H10 0935
Software Coding:
Work Shop Code: WSC 00000
VCID: 74A41148DFC92E261F-8020
Advanced Identification/FAZIT
Serial number: 01101923100662
Identification: SME-RBG
Date: 19.08.19
Manufacturer number: 0026
Test stand number: 1384
Flash Status
Programming Attempts(application): 1/0/0
Programming Attempts(data): 1
Successful Attempts(data): 1
Flash Date: 00.00.00
Flash Tool Code(data): 00073 790 00012
Misc.
Hardware number: 2Q5 937 090
Workshop System Name: J519
Equipment/PR Code: 000001DDA9B4370D507F93C7
Dataset Number: V03935310QQ
Dataset Version: 0001
ASAM Dataset: EV_BCMA0
ASAM Dataset Revision: 205001
VCDS Info:
Labels:
ROD: EV_BCMA0_205.rod
PetrolDave
Westbury, UK
C?ID=1423
It would be really helpful if you post a complete Auto-Scan - 2020 models probably look a lot different!
Also, please post an Adaptation Channel Map. Based on what I see in the data for this module, it has a metric ship-ton of the and uses Leuchte channels in a manner somewhat similar to the MQB cars.
ARSHAD
Réunion
C?ID=291393
Hi
I have an autoscan but i used my french version of VCDS
I will post english version and also adaptation channel map later
Dimanche,07,Juin,2020,06:14:58:29185
VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 7 x64
Version VCDS: FRM 19.6.2.1  HEX-NET CB: 0.4508.4
Version données: 20190930 DS308.0
www.rosstech.fr
VIN: WV1ZZZ7HZLH001432   Plaque d'immat.:
Type chassis: 7H-VN75 (3Q0)
Scanner: 01 03 08 09 10 15 17 19 44 5F 65
01-Moteur -- Etat: Défaut 0010
03-Freins ABS -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: Défaut 0010
10-Assistance stationnt -- Etat: Défaut 0010
15-Airbags -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
5F-Electr. d'informat. -- Etat: OK 0000
65-Pression pneus -- Etat: OK 0000
Adresse 01: Moteur (J623-CXHC)       Labels: Aucun
   No. pièce Log: 04L 906 056 SC    Mat: 04L 907 445 M
   Pièce: R4 2.0l TDI   H01 9707
   Révision: 23301001
   Codage: 001140144324050900000000000000000000000000000000
   No. Atelier: WSC 00012 790 00073
   Jeu de données ASAM: EV_ECM20TDI03004L906056SC 004007
   ROD: EV_ECM20TDI03004L906056LE.rod
   VCID: 004C4D989B71024FA6-8054
2 Codes défaut trouvés:
27277 - Alimentation en tension Tension trop faible
          P0562 00 [032] - -
          Intermittent - Non Confirmé - Testé depuis RàZ mémoire
             Capture:
                    Etat du défaut: 00000001
                    Priorité du défaut: 2
                    Fréquence du défaut: 1
                    Kilométrage: 21 km
                    Régime moteur: 0.00 /min
                    Valeur de charge normée: 0.0 %
                    Vitesse du véhicule: 0 km/h
                    Température du liquide de refroidissem.: 43 °C
                    Température air d'admission: 0 °C
                    Pression de l'air ambiant: 1010 mbar
                    Tension borne 30: 12.289 V
                    Compteur de désapprentissage selon OBD: 36
                    Masse d'air sur le débitmètre d'air massique 1: 0.0 kg/h
                    Rapport de flux d'air normé: 1.000 compte
                    Vanne recycl. gaz1: banc1: rétromessage pos. - Val. effec.: 0.48 %
                    Actionneur papillon1: banc1: rétromess. pos. - Val. effec.: 0.00 %
                    Pression de suralimentation de consigne: 0.003 bar
                    Entrée refr.air suralim. transm.press.1 banc1 val.brute: 1019 mbar
                    Débit d'injection moyen: 0 mg/course
                    Index du mode de fonctionnement moteur actuel: 4
                    Index du prochain mode de fonctionnement moteur demandé: 7
                    Index du mode de fonctionnement moteur objectif: 7
25126 - ESP
          U0416 00 [032] - Signal non plausible
             Capture:
                    Priorité du défaut: 6
                    Kilométrage: 21 km
                    Date: 2020.06.04
                    Temps: 00:02:39
                    Température du liquide de refroidissem.: 44 °C
                    Tension borne 30: 12.312 V
                    Accélération: 0.000 m/s²
                    Vitesse moyenne du véhicule: 0.00 km/h
                    Régulateur de vitesse: état: Commande principale OFF
                    Coordinateur chaîne cinématique: statuts de défaut ACC-ACC activé malgré décélération EPB: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-ACC activé bien que TSK passif: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-Souhait de démarrage ou d'arrêt à vitesse d'arrêt non défini: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-Souhaits de démarrage et d'arrêt envoyés simultanément: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-ACC activé bien que limiteur activé: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-ACC se réactive après blocage: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-ACC envoie des signaux non définis: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-ACC activé bien que commande principale off: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-ACC activé malgré freinage du conducteur: non
                    Coordinateur chaîne cinématique: statuts de défaut ACC-ACC activé malgré désactivation ESP/ASR: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Intervention ABS: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Intervention ESP: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Intervention EDS: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Intervention ASR: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Intervention MSR: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Conducteur freine: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-HDC activé: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-ESP exécute freinage TSK: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-EPB actif: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Intervention ASP: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Intervention ADS: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-À-coup d'avertissement AWV2: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-ESP passif coupé (ESP désactivé): non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-ASR passif coupé (ASR désactivé): non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-ESP détecte arrêt du véhicule: non
                    Coordinateur chaîne cinématique: état fonctionnem. freins-Régulateur de distance d'arrêt ACC actif: non
                    Coordinateur chaîne cinématique: statuts de défaut freins-Régulateur de décélération indisponible: non
                    Coordinateur chaîne cinématique: statuts de défaut freins-Défaut régulateur de décélération: non
                    Coordinateur chaîne cinématique: statuts de défaut freins-Défaut système ESP: non
                    Coordinateur chaîne cinématique: statuts de défaut freins-Défaut système ESP dû à inexactitude des couples moteur: non
                    Coordinateur chaîne cinématique: statuts de défaut freins-ESP signale défaut de cohérence du message TSK: non
                    Coordinateur chaîne cinématique: statuts de défaut freins-TSK/ESP défaut Handshake: non
                    Coordinateur chaîne cinématique: statuts de défaut freins-Activation forcée ESP défectueuse: non
                    Coordinateur chaîne cinématique: statuts de défaut freins-Feu stop non plausible: non
Tests passés: N/D
Adresse 03: Freins ABS (J104)       Labels: Aucun
   No. pièce Log: 7LB 614 517     Mat: 7LB 614 517
   Pièce: ESC_base      H01 0650
   No. de série: 08504647190701
   Codage: 305524524847EE860C5824A71268770638202078
   Jeu de données ASAM: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X.rod
   VCID: 7DB2346CEC836FA7CD-8028
Aucun code défaut trouvé.
Adresse 08: Climatronic (J301)       Labels: Aucun
   No. pièce Log: 7LA 907 426 B    Mat: 7LA 907 426 B
   Pièce: AC Manuell    H01 0502
   Codage: A03010000810000001000800504001050000000000000000800000000000
   No. Atelier: WSC 00012 790 00067
   Jeu de données ASAM: EV_AirCondiBHTCT6PA 001004
   ROD: N/D
   VCID: 42C88790D5FDD05FF0-8016
Aucune donnée ASAM n'est disponible pour ce calculateur: "EV_AirCondiBHTCT6PA" (VN75)
Adresse 09: Centrale Elec. (J519)       Labels: Aucun
   No. pièce Log: 2Q5 937 090     Mat: 2Q5 937 090
   Pièce: BCM T6PA Std+ H10 0935
   No. de série: 01101923100662
   No. Atelier: WSC 00000 000 00000
   Jeu de données ASAM: EV_BCMA0 205001
   ROD: EV_BCMA0_204.rod
   VCID: 74A41148DFC92EEFB2-8020
   Appareil de commande de porte: côté conducteur:
   Sous-système 1 - No. pièce Log: 7L2 959 405     Mat: 7L2 959 163
   Pièce: FHSG_DRV  001 0002
   No. de série: 00000000000026716920
   Codage: 130008
   Appareil de commande de porte: côté passager AV:
   Sous-système 2 - No. pièce Log: 7L2 959 406     Mat: 7L2 959 164
   Pièce: FHSG_PSG  001 0002
   No. de série: 00000000000032251781
   Codage: 090000
590853 - Lève-glace AV côté conducteur
          B14D1 54 [008] - Calibration manquante
          Intermittent - Confirmé - Testé depuis RàZ mémoire
             Capture:
                    Compteur de RAZ: 42
                    Kilométrage: 20 km
                    Date: 2020.06.04
                    Temps: 10:48:03
                    Zusaetzliche Umgebungsdaten-Etat borne*15: On
                    Zusaetzliche Umgebungsdaten-Etat borne*50: OFF
                    Zusaetzliche Umgebungsdaten-Feux de croisement: Non actionné(e)
                    Zusaetzliche Umgebungsdaten-OFF: Non actionné(e)
                    Zusaetzliche Umgebungsdaten-Température extérieure: 0
                    Zusaetzliche Umgebungsdaten-Commande automatique des feux: Non actionné(e)
                    Zusaetzliche Umgebungsdaten-Feu de position: Non actionné(e)
                    Zusaetzliche Umgebungsdaten-Feu de stationnement G: Non actionné(e)
                    Zusaetzliche Umgebungsdaten-Feu de stationnement D: Non actionné(e)
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: 0
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.2 V
592133 - Lève-glace AV côté passager AV
          B14D2 54 [008] - Calibration manquante
             Capture:
                    Compteur de RAZ: 42
                    Kilométrage: 20 km
                    Date: 2020.06.04
                    Temps: 10:48:03
Adresse 10: Assistance stationnt (J446)       Labels:| 5Q0-919-283.clb
   No. pièce Log: 5QA 919 283 E    Mat: 5QA 919 283
   Pièce: PDC 4 Kanal   H08 0061
   No. de série: 000150059619158
   Codage: 0601150001
   Jeu de données ASAM: EV_EPHVA14AU3700000 009044
   ROD: EV_EPHVA14AU3700000_009.rod
   VCID: 4CD4A9A8E7B9162F0A-8018
1 Code défaut trouvé:
13637426 - Bus de données
          U1123 00 [008] - valeur de défaut reçue
             Capture:
                    Compteur de RAZ: 42
                    Kilométrage: 20 km
                    Date: 2020.06.04
                    Temps: 10:48:03
Adresse 15: Airbags (J234)       Labels:* Aucun
   No. pièce Log: 2Q0 959 655 AD    Mat: 2Q0 959 655 AD
   Pièce: VW22Airbag    013 0506
   Révision: --------
   Codage: 8800C00000000000400000CF000C00000065
   Jeu de données ASAM: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 7F4ECE64E68F7DB7DF-802A
Adresse 17: Instruments (J285)       Labels: Aucun
   No. pièce Log: 7LA 920 741     Mat: 7LA 920 741
   Pièce: KOMBI         204 6750
   Codage: 07A412802080000801082A040401000000000000
   No. Atelier: WSC 00012 790 00163
   Jeu de données ASAM: EV_DashBoardVDDMQBAB 009069
   ROD: N/D
   VCID: 7BB63A74F2976197F3-802E
Aucune donnée ASAM n'est disponible pour ce calculateur: "EV_DashBoardVDDMQBAB" (VN75)
Adresse 19: Gateway CAN (J533)       Labels:| 3Q0-907-530-V1.clb
   No. pièce Log: 3Q0 907 530 AC    Mat: 3Q0 907 530 C
   Pièce: GW MQB High   521 5388
   No. de série: 05071910522587
   Codage: 030000044F05730000000008000F00010001070000000000000000000000
   Jeu de données ASAM: EV_GatewNF 013026
   ROD: EV_GatewNF.rod
   VCID: 70AC1D58ABD112CF56-8024
   Alternateur:
   Pièce: 4-01-09-01-04
   Calculateur de surveillance de la batterie:
   Sous-système 2 - No. pièce Log: 7E0 915 181 N    Mat: 7E0 915 181 N
   Pièce: J367-BDMConti  H03 1052
   No. de série: 77343301001908170538
Adresse 44: Direction assistée (J500)       Labels: Aucun
   No. pièce Log: 7LA 909 144 F    Mat: 7LA 909 144 D
   Pièce: EPS_MQB_ZFLS  751 7150
   Codage: 0106
   Jeu de données ASAM: EV_SteerAssisMNB 002012
   ROD: N/D
   VCID: 45C29C8CC4D3E767D5-8010
Aucune donnée ASAM n'est disponible pour ce calculateur: "EV_SteerAssisMNB" (VN75)
Adresse 5F: Electr. d'informat. (J794)       Labels:* Aucun
   No. pièce Log: 3G0 035 869 A    Mat: 3G0 035 869 A
   Pièce: MU-E--ER      715 0740
   No. de série: 19071900011014
   Codage: 066401003C00000041110001000110001F0000D40000010001
   Jeu de données ASAM: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 2A18CF304D8D281FD8-807E
Adresse 65: Pression pneus (J502)       Labels: 3AA-907-273.clb
   No. pièce Log: 5Q0 907 273 D    Mat: 5Q0 907 273
   Pièce: RDKBERU30     H05 0010
   No. de série: 30000000306582
   Jeu de données ASAM: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_005.rod
   VCID: 3620EB4089357CFF4C-8062
Fin----------(Temps écoulé: 00:57, VBatt début/fin: 12.3V/12.4V)-----------
