Hi All, I have an official USB-HEX cable back in 2014 i fiddled with my Audi A5 to retrofit the 3g high MMi system
I dont know what i did but i programmed the volume control button on my steering wheel incorrectly and cannot for the life of me find out how to correct it
volume up and down works o.k - but when you press it in to mute you get "navigation is not active"
here is my self diagnosis
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 17.8.1(x64) Data version: 20171130 DS276.6
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,19,December,2017,13:17:13:28488
VIN: WAUZZZ8T9******** License Plate: <HIDDEN>
Mileage: 65670km-40805mi Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 72
VIN: WAUZZZ8T9******** Mileage: 65670km-40805miles
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JH HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2903
Revision: 45H25---
Coding: 0A194012232601080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JH 003003
ROD: EV_ECM20TDI01103L906018JH.rod
VCID: 79FC6A6CF8B61A8ED6-802C
U1113 00 [032] - -
U1113 00 [032] - -
Part No SW: 8K0 907 379 CJ HW: 8K0 907 379 CJ
Component: ESP8 quattro H09 0100
Coding: 181544
Shop #: WSC 06324 000 00000
VCID: 03000884827A505E8C-8056
Fault Frequency: 7
Reset counter: 30
Mileage: 64185 km
Date: 2017.10.31
Time: 12:28:24
Hex Value: 0x00C0
Hex Value: 0x0006
Hex Value: 0x1227
Hex Value: 0x1677
Hex Value: 0x0000
Self-Diagnosis Log
Page 3
Part No SW: 8K0 907 064 FE HW: 8K0 907 064 FE
Component: BCM2 2.0 H10 0602
Coding: 03B40000000000000000
Shop #: WSC 06325 000 00000
VCID: 78FA6F68CBBC0386A9-802C
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0812000029348021
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000027307004
Part No SW: 8K2 820 043 AD HW: 8K2 820 043 AD
Component: KLIMA 3 ZONEN H04 0036
Revision: D1000000 Serial number: 01270220120176
Coding: 342402E000
VCID: 6BD040248AEAB81E54-803E
Self-Diagnosis Log
Page 4
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 AH
Component: BCM1 1.0 H14 0103
Revision: 08014001 Serial number: 00000382645301
Coding: 26000091C034AFC00081400300001D0D001D030827090301000008000400030100000020000000
Shop #: WSC 00048 210 91068
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 240212 H13 0070
Serial number: SWF12020240098
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20176781
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001702120937
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 5D68C516000000000001
01771 - Control Module for Headlight Range (J431)
Reset counter: 139
Mileage: 45335 km
Date: 2016.05.15
Time: 14:06:20
Self-Diagnosis Log
Page 5
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD91CH37
Coding: 30533938363030303030554A305238543053
VCID: 489ADFA8F3DCB30619-801C
Serial number: 6334MSME6B342B6AQ
Serial number: 6344MSME6B216379J
Serial number: 6352QSME7B0B2C72T
Serial number: 6362QSME400D027EI
Serial number: 63732SME430D1446Y
Serial number: 63832SME460D3C78A
Self-Diagnosis Log
Page 6
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H03 0004
Revision: -------- Serial number: 90372KAE0017Q
Coding: 0000D6
Shop #: WSC 02391 823 56573
VCID: 4482CB98C7F49766F5-8010
Component: E221 - MFL H03 0003
Reset counter: 30
Self-Diagnosis Log
Page 7
Part No SW: 8T0 920 982 F HW: 8T0 920 982 F
Component: KOMBIINSTR. H35 0540
Revision: 00000000 Serial number: NSV468E2D
Coding: 23FF31000200B700010401
VCID: 408AC788D3EC8B46D1-8014
Reset counter: 250
Mileage: 65671 km
Date: 2017.12.19
Time: 14:07:57
00003 - Control Module
Fault Status: 01100101
Reset counter: 250
Mileage: 65671 km
Date: 2017.12.19
Time: 14:07:58
Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H10 0025
Revision: 1Y030014 Serial number: 1441Y11A040220
Coding: 00CF03FF00
VCID: 3F88C474AE12F4BEA8-806A
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790969646
Self-Diagnosis Log
Page 8
Part No SW: 8T0 959 793 F HW: 8T0 959 793 H
Component: TSG FA H09 0302
Coding: 011002624C01450005
VCID: 4C92E3B8EFA45F263D-8018
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0013374757
Coding: 100000000001
Shop #: WSC 00720 210 91851
ROD: EV_RCEPSAU48X_008.rod
VCID: 34629B589F5427E645-8060
18689 - Terminal 30
U140A 00 [008] - Open Circuit
Reset counter: 14
Mileage: 64722 km
Date: 2017.11.16
Time: 15:42:42
valid
2305 - Function Restriction due to Start Voltage Interruption
U1410 00 [008] - -
Reset counter: 30
Mileage: 65390 km
Date: 2017.12.10
Time: 12:23:45
valid
Self-Diagnosis Log
Page 9
Revision: 00002001 Serial number: 0171687611
Coding: 013B062220B900408120043680000000
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H08 0190
Revision: 00008001 Serial number: 34881005235003
VCID: 7AFE7560F5B01196DF-802E
Part No SW: 8T0 959 792 H HW: 8T0 959 792 H
Component: TSG BF H08 0302
Coding: 011002220C01450005
VCID: 4D94EEBC14BE562E2A-8018
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 10000000021342
ROD: EV_ParkiBrake_VW51.rod
VCID: 3666A150892835F67B-8062
Self-Diagnosis Log
Page 10
Part No SW: 4G0 035 061 M HW: 4G0 035 061
Component: Radio U DAB H60 0140
Revision: AB001007 Serial number: 109A20C7544899
Coding: 010103010000000001
VCID: 27587C1456825C7EF0-8072
02877 - Digital Radio Antenna (R183)
Reset counter: 139
Mileage: 45335 km
Date: 2016.05.15
Time: 14:06:30
Voltage: 11.30 V
01043 - Control Module; Incorrect Software Version
Reset counter: 139
Mileage: 45335 km
Date: 2016.05.16
Time: 07:09:46
Bin. Bits: 00000000 00000010
Self-Diagnosis Log
Page 11
Part No SW: 8T2 035 666 M HW: 8T2 035 666 E
Component: H-BN-EU H52 0187
Revision: -------- Serial number: 475G 0B7570172
Coding: 010101040106C1FD01000F1E000000030000
Shop #: WSC 06335 000 00000
VCID: 4584D69CCCCEAE6EE2-8010
Subsystem 1 - Part No: 8R0 060 884 BK
Component: EUR 2014 1703
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0098
Serial number: 9466GR0B0623250
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000869502
Component: CD-Database 2712
6 Faults Found:
Reset counter: 139
Mileage: 45335 km
Date: 2016.05.15
Time: 15:07:47
Voltage: 11.00 V
03175 - Invalid Data Set
Reset counter: 139
Mileage: 45335 km
Date: 2016.05.15
Time: 15:07:42
Voltage: 11.00 V
Self-Diagnosis Log
Page 12
Reset counter: 139
Mileage: 45335 km
Date: 2016.05.15
Time: 15:07:50
Bin. Bits: 00000001 00000000
Bin. Bits: 00000000 10000000
Bin. Bits: 00000000 00000000
02168 - Left Front Microphone (R140)
Reset counter: 250
Mileage: 61277 km
Date: 2017.08.08
Time: 15:39:31
Voltage: 12.60 V
02169 - Front Right Microphone (R141)
Reset counter: 139
Mileage: 45335 km
Date: 2016.05.15
Time: 15:07:47
Voltage: 11.00 V
02612 - Audio Wire Adapter Set
Self-Diagnosis Log
Page 13
Reset counter: 139
Mileage: 45335 km
Date: 2016.05.15
Time: 15:07:55
Voltage: 11.00 V
Part No SW: 8T0 959 795 H HW: 8T0 959 795 H
Component: TSG HL H07 0302
Coding: 010002224001450005
VCID: 50AAF7C8038C7BC641-8004
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0302
End-------------------------(Elapsed Time: 03:04)--------------------------
